  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • sundberg84S sundberg84
    @fhenryco said in reporting battery to domoticZ:
    where can i read the actual void sendBatteryLevel() to understand what it is doing exactly ?
    Domoticz: https://github.com/domoticz/domoticz/blob/3741a530c2260cea2f337a095aa9477847fc00cb/hardware/MySensorsBase.cpp#L444
    MySensors: https://github.com/mysensors/MySensors/blob/9041c8ba3d896484b6d9dca6e8ff5e81a828ffa3/core/MySensorsCore.cpp#L308
    Maybe you can show us your sketch code? I have this working with Domoticz just fine.
    fhenrycoF
    fhenrycoF
    fhenryco
    @sundberg84 thank you but as i said i did no modification to the sketch in https://www.mysensors.org/build/battery appart merging it with a DHT11 sketch. However i did notice something strange: when i switch on the arduino (sensor side) the first percentage i get in DomoticZ was 102%, then at the next update it fell to 60% and has not changed since then. I'm suspecting there is something wrong measuring the battery level from A0 pin just after sending a temperature value ??
    Insert Code Here/**
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    //#define MY_RS485
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 600000;
    int oldBatteryPcnt = 0;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      sendSketchInfo("Battery Meter", "1.0");
      present(CHILD_ID_HUM, S_HUM);
        analogReference(INTERNAL1V1);
        analogReference(INTERNAL);
      // get the battery Voltage
    #ifdef MY_DEBUG
        Serial.println(sensorValue);
    #ifdef MY_DEBUG
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
            // Power up radio after sleep
            oldBatteryPcnt = batteryPcnt;
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    • fhenrycoF fhenryco
      Insert Code Here/**
      //#define MY_RS485
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      sundberg84S
      sundberg84S
      @fhenryco - if you are experience changes it might help adding a wait(); or delay(); to get a more stable reading. If something is using power just as you read it might be strange values.
      This is one of my sketches (DHT + Bat): https://github.com/sundberg84/MySensors2.0.0/blob/master/NorrHumAs/NorrHumAs.ino and im using the voltage divider to A0 to measure the battery.
      fhenrycoF 1 Reply Last reply
        fhenrycoF
        fhenrycoF
        fhenryco
        @sundberg84 thanks,
        the delay 500 has a big effect , now i get 116% hence a battery voltage=3.5V, while the multimeter gives it 3V ! may be the internal reference is not 1.1V in my low cost chinese pro mini 3.3v .
        BTW i did not understand why you have also a delay 500 after reading the analog pin, i would have thought that a delay before reading the analog pin is sufficient ... (?)
          @sundberg84 thanks,
          sundberg84S
          sundberg84S
          @fhenryco - could be the delay before is sufficient.
          • fhenrycoF
            fhenrycoF
            fhenryco
            wrote on last edited by fhenryco
            this morning , i get 102% , much closer to the actual value ... assuming that the ADC activity did not discharge my battery at an unprecedented level (i had this sketch working for two monthes with very little discharge of the battery before adding this battery monitoring functionality). I will know for sure if the battery level does not drop further in the coming days...i'm concerned that the delay 500 might produce non negligible battery consumption
              sundberg84S
              sundberg84S
              @fhenryco Its hard to reach a 100% correct value on the chinese clones. I get a 5% off probably all the time. Because of that I have added an average so I collect three values every 20min into an array and send the average every hour.
              • fhenrycoF
                fhenrycoF
                fhenryco
                ok, thanks again, something else i v been wondering about is why domoticz will show the temp + humidity sensor as a single sensor even though there are separate instructions
                for the presentation :
                and for the messages themselves
                what should be modified if i want domoticZ to treat the two sensors separately ? (this is for Yana, a speech recognition software that has a plugin for domoticZ, but apparantly is not able to handle several values for a given sensor).
                is it the sendSketchInfo("TemperatureAndHumidity", "1.1"); that needs to be replaced by two sendSketchInfo, one for temp and one for humidity ?
                  fhenrycoF
                  fhenrycoF
                  fhenryco
                  @fhenryco apparantly something like send(msgTemp.setSensor(CHILD_ID_TEMP).set(temperature,1));
                  send(msgHum.setSensor(CHILD_ID_HUM).set(humidity,1));
                  should do the job ! going to try that
                  but i'm surprised this is not done by default since msgHum and msgTemp are defined separately for each sensor Id
                    fhenrycoF
                    fhenrycoF
                    fhenryco
                    @fhenryco it did nothing different ... still have a single sensor temp+hum don't understand why ...
                      sundberg84S
                      sundberg84S
                      @fhenryco - Yes, and there is a trick to seperate them... and i if I remembe right @AWI is the one to ask.
                      Edit, found his post here: https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz/13
                      • fhenrycoF
                        fhenrycoF
                        fhenryco
                        using V_text and S_info is a workaround to avoid grouping
                        • R
                          R
                          Rene046
                          i would like to ask something to ,
                          Now i have the battery level showing up in Domoticz what can i do to log the voltage in volts, should i add something inside the sketch or something in domoticz..
                          fhenrycoF AWIA 2 Replies Last reply
                          • R Rene046
                            fhenrycoF
                            fhenrycoF
                            fhenryco
                            @Rene046
                            This is the instruction in your sketch which allows to see the battery level of devices in domoticZ
                            But as you noticed , this is not reported in the logs. One possibility to see it in the Log is to as well send this batteryPcnt information with a send(msgbatt.set(batteryPcnt ,1);
                            provided you have defined
                            MyMessage msgbatt(CHILD_ID_BATT, V_TEXT);
                            In other words you send the battery info as if it was the info of an additional sensor sending text type info
                            which you also need to present in the presentation void with
                            present(CHILD_ID_BATT, S_INFO);
                            For instance if you already have two sensors in you sketch let's say temp and hum with ID =0 and 1 respectively you would give the battery level the next unused ID
                            CHILD_ID_BATT=2
                            There might be a simpler and more natural way but i don't know it .
                            • R Rene046
                              AWIA
                              AWIA
                              AWI
                              @Rene046 The "royal" way to report battery level is to define it as S_MULTIMETER and use it to report voltage. Domoticz will take the voltage and can graph it. i.e.
                              definitions: MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
                              in presentation: present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery level" );
                              sending: send(voltageMsg.set(lastVoltage,2)); //send battery in Volt 2 decimal places
                              • R
                                R
                                Rene046
                                @ fhenryco
                                Cant get it to work, if you have time could help with my sketch.
                                #define CHILD_ID_BATTERY 4
                                unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                                #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
                                #define SKETCH_VERSION "2.1"                    // Your version
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                boolean metric = true;
                                MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
                                //MyMessage msgbatt(CHILD_ID_BATTERY, V_TEXT);
                                #define VBAT_PER_BITS 0.0041055718475073313782991202346
                                #define VMIN 3.6                                  //  Vmin (radio Min Volt)=1.9V (564v)
                                #define VMAX 4.2                                  //  Vmax = (2xAA bat)=3.0V (892v)
                                  present(CHILD_ID_BATTERY, S_INFO);
                                  //present(CHILD_ID_BATTERY, S_CUSTOM);
                                    if (!metric) {
                                      lastHum = humidity;
                                  batM();
                                   delay(500);
                                   // Battery monitoring reading
                                   delay(500);
                                   // Calculate the battery in %
                                   if (batLoop > 2) {
                                   if (batteryPcnt > 100) {
                                     batteryPcnt=100;
                                       batLoop = 0;
                                     batLoop++;
                                My sketch is not working 100% my voltage is not precise, giving me even 221 in percentage while  lipo is at this moment 3.7 volt (simulated with a variable power supply)
                                im running it on a nano on 1 lipo cell and a dc dc powerup to 5 volt measuring the lipo voltage with a  divider 1M/470K
                                Hope to add a soil moisture sensor and baro sensor in future.
                                p.s. any one with some better idea sketch its ver welcome. im just started to experiment with Mysensor
                                R fhenrycoF 2 Replies Last reply
                                • R Rene046
                                  @ fhenryco
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                      if (!metric) {
                                        lastHum = humidity;
                                    batM();
                                     delay(500);
                                     delay(500);
                                     if (batLoop > 2) {
                                       batteryPcnt=100;
                                         batLoop = 0;
                                       batLoop++;
                                  R
                                  R
                                  Rene046
                                  O i forget to tell im running the latest gateway from Mysensor.
                                  • R Rene046
                                    @ fhenryco
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                        if (!metric) {
                                          lastHum = humidity;
                                      batM();
                                       delay(500);
                                       delay(500);
                                       if (batLoop > 2) {
                                         batteryPcnt=100;
                                           batLoop = 0;
                                         batLoop++;
                                    fhenrycoF
                                    fhenrycoF
                                    fhenryco
                                    @Rene046
                                    not
                                    but
                                    send(msgbatt.set(batteryPcnt ,1));
                                    also may be better to use S_MULTIMETER and V_VOLTAGE (rather than S_INFO and V_TEXT) as adviced by AWI and also 2 decimals hence
                                    send(msgbatt.set(batteryPcnt ,2));
                                    • R
                                      R
                                      Rene046
                                      thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
                                      DHT dht;
                                      float lastTemp;
                                      float lastHum;
                                      #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
                                      #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
                                      #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
                                          if (!metric) {
                                            lastHum = humidity;
                                        batM();
                                         delay(500);
                                         delay(500);
                                         if (batLoop > 2) {
                                           batteryPcnt=100;
                                             batLoop = 0;
                                           batLoop++;
                                      R AWIA Arnold ŠlepetisA 3 Replies Last reply
                                      • R Rene046
                                        DHT dht;
                                        float lastTemp;
                                        float lastHum;
                                            if (!metric) {
                                              lastHum = humidity;
                                          batM();
                                           delay(500);
                                           delay(500);
                                           if (batLoop > 2) {
                                             batteryPcnt=100;
                                               batLoop = 0;
                                             batLoop++;
                                        R
                                        R
                                        Rene046
                                        And my serial monitor is going wild .lol
                                        41815 MCO:SLP:WUP=-1
                                        Battery percent: 95 %
                                        Battery Average (Send): -12 %
                                        45359 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:244
                                        45403 !TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=1,st=NACK:-12.00
                                        45410 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                        45415 MCO:SLP:TPD
                                        45417 MCO:SLP:WUP=-1
                                        47962 !TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=NACK:20.0
                                        T: 20.00
                                        48007 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=NACK:49.6
                                        H: 49.60
                                        Battery percent: -49 %
                                        49014 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                        49020 MCO:SLP:TPD
                                        49022 MCO:SLP:WUP=-1
                                        51567 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=4,st=NACK:49.2
                                        H: 49.20
                                        Battery percent: -26 %
                                        52575 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                        52582 MCO:SLP:TPD
                                        • R
                                          R
                                          Rene046
                                          And it seems like instead of real voltage i seen percentage in the log
                                          12.5k
