  3. SOLVED: MySController 1.0.0beta and ESP8266 MQTT Gateway
3 Posts 2 Posters 1.8k Views 1 Watching
  • D
    dirtbikr
    wrote on last edited by dirtbikr
    Hello :). Back in November I built a Vera compatible gateway out of a NodeMCU v1.0 board and an NRF board. This worked fine (and I could connect/manage with the MySController application) but I have started transitioning everything to MQTT to reduce my dependence on the (sometimes flaky) Vera.
    I reflashed my Vera gateway with the ESP8266 MQTT gateway code and everything works fine except for communication with the MySController application. My gateway's IP is 192.168.1.24 and I assume the port is still the same (5003)? I even attempted to define MY_PORT as 5003 that did not work. The log in MySController says "INFO Connected to 192.168.24:5003" then immediately after "ERROR Error on connect: connection refused"
    Thank you in advance!
    tekkaT 1 Reply Last reply
    • D dirtbikr
      tekkaT
      tekkaT
      tekka
      @dirtbikr MYSController does not suppory MQTT (yet).
      • D
        dirtbikr
        Thank you for the information tekka, I appreciate it. That is what I gathered from the thread about MYSController but I wasn't totally sure.
