  3. Vera
  4. "Choose the Serial Port" error with MySensors and RFXtrx433?
29 Posts 6 Posters 12.9k Views 6 Watching
    The next logical step would probably be to ssh into the Vera box to see which devices hat pops up using lsusb when you plug in/out devices.
    But as the vera Luup engine is closed source we don't really know what it does.
    Do you have another usb hub laying around to test with?
    • Aron SjöbergA
      Aron SjöbergA
      Aron Sjöberg
      I think I have another powered hub laying around! Will try when I get home from work. I can check the 1usb-folder as well.
      • Aron SjöbergA Aron Sjöberg
        Hmm... I'm using the vanilla version av the gateway. Measured the power consumption and the powered USB hub should be able to provide enough power for both devices. There must be some configuration error, but I can't figure out what. The Vera can use both the RFXtrx and a USB drive (for logs) at the same time, also using the single USB port with a powered hub.
        I don't have the technological skill to troubleshoot this, but until you can confirm there is another user that have gotten Vera to work with both a connected RFXtrx AND MySensors gateway this seems to be an issue.
        MagnusM
        MagnusM
        Magnus
        @Aron-Sjöberg Did you solve your problem? I have a mysensors serial gateway, a rfxtrx433e and a USB stick connected to my Vera (Edge) through an externally powered USB hub (plexgear). They all work just fine.
        • miroM
          miroM
          miro
          @Magnus
          Do you have this one?
          https://www.kjell.com/se/sortiment/dator-natverk/datortillbehor/usb-tillbehor/usb-hubbar/plexgear-usb-hubb-4-vags-med-stromforsorjning-p68296
          I don`t have a second hub to try with so I need to buy a new one...
          MagnusM 1 Reply Last reply
          • miroM miro
            @Magnus
            MagnusM
            MagnusM
            Magnus
            @miro
            I've got this one
            https://www.kjell.com/se/sortiment/dator-natverk/datortillbehor/usb-tillbehor/usb-hubbar/plexgear-usb-3-0-hubb-4-vags-p61062
            It's been up running for a year now.
            • Aron SjöbergA
              Aron SjöbergA
              Aron Sjöberg
              No, still have the same issue with port conflict with the RFXtrx... :(
              I'm going to try another hub and build the serial gateway again.
              • Aron SjöbergA
                Aron SjöbergA
                Aron Sjöberg
                Argh!
                I finally received my new USB-hub and tried a new serial gateway I built.
                I STILL get the same error. I can't seem to have both my RFXtrx433E and the MySensor gateway connected (and working) at the same time.
                @Magnus, could you post a screenshot of your settings in Vera Edge?
                • miroM
                  miroM
                  miro
                  I bought this one: https://www.kjell.com/se/sortiment/dator-natverk/datortillbehor/usb-tillbehor/usb-hubbar/plexgear-usb-hubb-7-vags-med-stromforsorjning-p68616
                  Now all is working fine for me.
                    Argh!
                    MagnusM
                    MagnusM
                    Magnus
                    wrote on last edited by Magnus
                    @Aron-Sjöberg
                    My config below:
                    0_1487014260023_upload-8c1c7a47-553e-4710-bd9d-6492dcabd120
                    BartEB Aron SjöbergA 2 Replies Last reply
                    • MagnusM Magnus
                      @Aron-Sjöberg
                      My config below:
                      BartEB
                      BartEB
                      BartE
                      @Magnus just a wild guess.
                      Did you try to compile the MySensors GW with baudrate set to 38400 so they both use the same baudrate?
                      Aron SjöbergA 1 Reply Last reply
                      • BartEB BartE
                        Aron SjöbergA
                        Aron SjöbergA
                        Aron Sjöberg
                        @BartE Hmm... I didn't know you could choose the baudrate? I just followed the instructions on the website (https://www.mysensors.org/build/serial_gateway) but when I check the code I can clearly read that there is something in the sketch about the baud rate:
                        #if F_CPU == 8000000L
                        #define MY_BAUD_RATE 38400
                        However, I use the recommended Arduino Nano for my Vera Serial Gateway, not Arduino Pro Mini 3.3V or SenseBender.
                        How would I change the baud rate for the MySensor gateway if I can't use 38400 because it is used by my RFXtrx433E?
                        BartEB 1 Reply Last reply
                        • MagnusM Magnus
                          @Aron-Sjöberg
                          My config below:
                          Aron SjöbergA
                          Aron SjöbergA
                          Aron Sjöberg
                          @Magnus Thank you for your trouble! Did you photoshop your screenshot or can you configure two different serial port devices at the same time? I only have one instance I can change settings for?
                          Otherwise my settings seems to be the same as yours.
                            BartEB
                            BartEB
                            BartE
                            @Aron-Sjöberg said in "Choose the Serial Port" error with MySensors and RFXtrx433?:
                            Add this line
                            above the #include <SPI.h>
                            • miroM
                              miroM
                              miro
                              @Aron-Sjöberg
                              Have you restart luup after you connected both usb-ports?
                                MagnusM
                                MagnusM
                                Magnus
                                @Aron-Sjöberg I can configure both ports at the same time. It looks exactly as in the posted picture.
                                @BartE I justfollowed the instructions on the website. This was probably a year ago and the code used for the serial GW was designed only for Arduino Nano 328p / 16MHz.
                                • Aron SjöbergA
                                  Aron SjöbergA
                                  Aron Sjöberg
                                  Thank you for your help!
                                  Unfortunately nothing works. I have even tried to change the radio module from RFM69 to NRF24L01 to make sure it wasn't the connections that was badly soldered.
                                  @Magnus Could you please post the sketch you use for your gateway? I tried to add #define MY_BAUD_RATE 38400 as @BartE suggested but this doesn't seem to make a difference.
                                  I'm starting to think there is something wrong on Veras end. I don't get two different devices under the Serial Port configuration like @Magnus. You also have different ports (3482 for the serial gateway and 3481 for the RFXtrx).
                                  As a last resort I guess I could install Domoticz on a RPi and import the devices to the Vera as virtual devices, but this seems like a hassle if it is possible for the gateway to work directly.
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    Have you ever confirmed that the MySensors USB gateway works without the RFXtrx attached? Or checked that you really have an FTDI chip on the MySensors USB gateway? This is the only chip that the Vera can detect out of the box. A complete reboot of your Vera might also help.
                                    • Tomas
                                    • Aron SjöbergA
                                      Aron SjöbergA
                                      Aron Sjöberg
                                      I'm using a Arduino Nano. How do I check if it is a genuine FTDI chip?
                                      korttomaK 1 Reply Last reply
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @Aron-Sjöberg the FTDI chip is on the under side of Arduino nanos and clearly sais FTDI. Please post pictures of your devise if your uncertain. I don't know if fake or real maters when used on Vera.
                                        • Tomas
                                        • Aron SjöbergA
                                          Aron SjöbergA
                                          Aron Sjöberg
                                          @korttoma said in "Choose the Serial Port" error with MySensors and RFXtrx433?:
                                          Arduino nanos
                                          It's a bit hard to read but the black chips on the back says:
                                          A106
                                          and
                                          WCH
                                          CH340G
                                          202686635
                                          and
                                          AMS1117
                                          5.0 DN628
                                          on the front (where the button is)
                                          ALMEL
                                          MEGA328P
                                          AU 1639
                                          I can't find any mention of "FTDI". Should I assume it is not a genuine Arduino nano?
                                          I DO have an unused Arduino Uno laying around. Maybe it would be easier to buy a ethernet shield and use a ethernet gateway instead of the serial gateway? Is it a W5100 ethernet shield I would need for the Uno?
                                          MagnusM 2 Replies Last reply
