  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.0k Views 21 Watching
  • pansenP pansen
    @marceloaqno: I'm in the process of enabling SPI1 (and nrf24 subsequently) on the OPI Plus2e and it seems there are some hardware modifications necessary...I'd like to document on the way and when I am finished submit it somehow so it can be included here. Any suggestions for that?
    marceloaqno
    Code Contributor
    @pansen You could document your steps here and I'll update the building guide. If changes to the code are required, please send a PR to the development branch.
    • pansenP
      pansenP
      pansen
      wrote on last edited by pansen
      @marceloaqno: ok so here are my conclusions:
      After going through the schematics of the OPi Plus2e I realized that the H3 has dedicated pins for NAND/eMMC, which is probably not the case for the H2+ in the OPi zero. They used the pins of SPI1 for a status LED and a "MUTE" net, which is not connected anywhere so at first I was like "wtf?"...
      So, the SPI0 is free for usage out of the box and the .fex does not need to be modified. Summed up:
      If the OPi to be used has "SPI0" in the GPIO header, no .fex modifications are necessary. CE and CN/CS/CSN pin can be chosen freely (?), I picked it like this:
      ce - gray - pa13 - PHYSICAL pin8 - LOGICAL pin13 (1-1)*32 + 13
      cn - blue - pa14 - PHYSICAL pin10 - LOGICAL pin14 (1-1)*32 + 14
      If another pin is chosen, the pin number can be calculated with that formula: (position of letter in alphabet - 1) * 32 + pin number (from: https://linux-sunxi.org/GPIO)
      The pinout of the connector can be found here: https://linux-sunxi.org/Xunlong_Orange_Pi_Plus_2E#Expansion_Port (SPI0 pins are PC0-PC2 or 19,21,23)
      After connecting the physical pins 8,10,19,21 and 23 to the nrf24 (and pin 1 for 3.3v), following command was sufficient to set up mysgw and get the nrf24 to respond:
      ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=13 --my-rf24-cs-pin=14
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
      S 1 Reply Last reply
      • L
        L
        lecintre
        hello
        I build this and work great for my OrangePI PC+ but I do not know how to integrate it in domoticz???
        Can you help me please
        thank's for you good work
        • pansenP
          pansenP
          pansen
          @lecintre: I just installed domoticz and I could enable my gateway by clicking on "please setup your Hardware" in the start screen, then selecting "mysensors gateway with lan interface" with the lan ip of my orange pi (but i guess 127.0.0.1 would also work) and port 5003.
          this should appear then:
          mysensors_lan_gw Yes MySensors Gateway with LAN interface
          Version: 2.2.0-beta Setup 0.0.0.0 5003 Disabled
          clicking on "Setup" then leads to a menu where i see my first test node:
          NodeID
          Name
          Sketch Name
          Version
          Children
          Last Seen
          0 Unknown Unknown 1.0 1 2017-01-29 20:27:28
          1 Unknown nrf24LEDtest 1.0 2 2017-01-29 20:28:27
          let me know if that works out for you
          • L
            L
            lecintre
            @pansen: Thank you very much it works very well.
            Cool for your help
            thank you so much
            For you which is the best domoticz or jeedom ?? With mysensors protocol
            • pansenP
              pansenP
              pansen
              @lecintre: avec plaisir :) I only compared OpenHAB and domoticz so far. Domoticz worked out of the box with the nrf24 but does not have support for my 5.1 receiver (which OpenHAB does). Jeedom looks to commercial (for example no free app+controller) for my taste and there seems to be no community. A good starting point for me was the popularity of each controller in this forum: https://forum.mysensors.org/category/3/controllers
              I guess it really depends on your application, if you only have DYI sensors and actuators, domoticz is probably enough.
              • YveauxY
                @marceloaqno Great job man!
                Looking at the radio connection, there is a 5V -> 3V3 conversion layed out.
                The Pi Zero Schematics sheet 7-D1, 7-B5 and 11-D4 indicate VCC3V3-EXT is present on pin 1 of the IO connector and internally connected to VCC-IO, which can supply 1A @ 3V3.
                Don't you think there is enough margin to supply the nRF24 directly from VCC3V3-EXT?
                • YveauxY Yveaux
                  marceloaqno
                  Code Contributor
                  @Yveaux Yes, more than enough :smile: . Thanks and thanks for pointing that out.
                    i've not checked yet, i miss time for trying the linux port :blush: but i'm curious to know if this power supply would be noisy..which may need a ferrite and capas, else radio could have a bad snr and less range/sensitiviy. Maybe i'm wrong.. i'll try to scope when i'll have some time, or if i remember about it lol!
                    • pansenP pansen
                      SdeWeb
                      wrote on last edited by SdeWeb
                      @pansen Hi, Please could you confirm your pin connection beetween NRF24L01 and the Opi Plus2E, il followed your setup inctruction (no .fex modification and your specific ./configure), but mine don't work, i got this error "mysgw: Could not open /sys/class/gpio/gpio13/direction".
                      I connected my NRF24L01 on OPI P2E like this :
                      • NRF Port Name / (N°) ------- OPI Port (N°) / Name
                        • GND (1) <------------> (6) GND
                        • VCC (2) <------------> (17) 3.3V PWR
                        • CE (3) <---------------> (8)
                        • CSN (4) <------------> (10)
                        • SCK (5) <-------------> (23)
                        • MOSI (6) <-----------> (19) MOSI
                        • MISO (7) <-----------> (21) MISO
                        • IRQ (8) <---------------> NC
                      Seb.
                      • pansenP
                        pansenP
                        pansen
                        Hi @SdeWeb header pins 8 and 10 are used by some other hardware (SPI1, UART3) which might need to be deactivated in the .fex in your system, for me it worked straight away so that would be weird..just check the .fex if SPI1 and UART3 are indeed disabled.
                        It looks like the definitions for the GPIO are faulty, you could try a LED test to see if they work at all. If the problem persists rather open a topic in the Development sub forum 8) Or, pick another GPIO, for example header pins 14 and 16.
                        • W
                          W
                          Wascht'l
                          would it be possible to add the wiring for the RS485-Modules, please?
                          will it be similar to the Raspberry Pi?
                          Thank you. Waschtl.
                            SdeWeb
                            Well done finally i used the dedicated .fex file for Orange Pi Plus 2E here :
                            at this point :
                            https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepiplus2e.fex
                            Read the .fex file in a text editor, u'll see important things about "gpio_config" for H3 cpu :
                            ; NOTE: This section is necessary only for "gpio_sunxi" driver
                            ; which is obsolete for H3 boards
                            [gpio_para]
                            gpio_used = 0
                            gpio_num = 0
                            NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                                                  GND (1)  <-----------> (20) / GND
                                                  VCC (2)  <-----------> (17) / 3.3V PWR
                                                  CE (3)   <-----------> (22) / (PA2 / GPIO2)
                                                  CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                                                  SCK (5)  <-----------> (23)
                                                  IRQ (8)  <-----------> NC
                            So "MySensors" setup is :
                            ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                            Then
                            ./bin/mysgw -d
                            Return :
                            root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
                            mysgw: Starting gateway...
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: TSM:INIT:TSP OK
                            mysgw: TSM:INIT:GW MODE
                            mysgw: MCO:REG:NOT NEEDED
                            mysgw: MCO:BGN:STP
                            mysgw: MCO:BGN:INIT OK,TSP=1
                            Best.
                            Seb.
                            E 1 Reply Last reply
                            • W Wascht'l
                              Thank you. Waschtl.
                              SdeWeb
                              @Wascht'l Hi,
                              Take a look here, to get some idea :
                              https://fr.pinout.xyz/pinout/rs485_pi#
                              Regards.
                              • R
                                R
                                Reza
                                wrote on last edited by Reza
                                i have problem :/
                                what about this :
                                root@orangepione:~/MySensors# ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                                 -bash: ./configure: Permission denied
                                • R Reza
                                  i have problem :/
                                  what about this :
                                  Tag
                                  wrote on last edited by Tag
                                  @Reza
                                  Seems your ./configure script is not executable... try:
                                  chmod 755 ./configure
                                  R 1 Reply Last reply
                                  • T Tag
                                    @Reza
                                    R
                                    R
                                    Reza
                                    @Tag
                                    root@orangepione:~/MySensors# chmod 755 ./configure
                                    root@orangepione:~/MySensors# chmod 755 ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13
                                    chmod: unrecognized option '--spi-spidev-device=/dev/spidev1.0'
                                    Try 'chmod --help' for more information.
                                    • R Reza
                                      @Tag
                                      SdeWeb
                                      @Reza
                                      after "chmoded" the file you don't need anymore chmod command, run directly ./configure .
                                      Regards
                                      • S SdeWeb
                                        @Reza
                                        Regards
                                        R
                                        R
                                        Reza
                                        @SdeWeb thank you . this is ok
                                        • R
                                          R
                                          Reza
                                          can i add this lines ? for orangepi ?
                                          #define MY_RF24_CHANNEL 0
                                          but after add i have problem :
                                          root@orangepione:~/MySensors# make
                                          gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                          g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                          g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                          g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                          g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                          g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                          g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                          g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                          g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                          g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                          g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                          In file included from examples_linux/mysgw.cpp:73:0:
                                          ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                                                           from ./MySensors.h:294,
                                          compilation terminated.
                                          T S 2 Replies Last reply
