  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 466.6k Views 30 Watching
  • M meddie
    and on the node this sketch:
    #include <stdint.h>
    #include <pins_arduino.h>
    //#define MY_SIGNING_SOFT
    #define MY_SIGNING_ATSHA204
    But the node does not connect and i get this on the serial monitor:
    0 MCO:BGN:INIT NODE,CP=RNNNAA-,VER=2.1.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSF:SID:OK,ID=100
    16 TSM:FPAR
    18 Will not sign message for destination 255 as it does not require it
    67 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2076 !TSM:FPAR:NO REPLY
    2078 TSM:FPAR
    2080 Will not sign message for destination 255 as it does not require it
    2127 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4139 !TSM:FPAR:NO REPLY
    4141 TSM:FPAR
    4143 Will not sign message for destination 255 as it does not require it
    4190 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6199 !TSM:FPAR:NO REPLY
    6201 TSM:FPAR
    6203 Will not sign message for destination 255 as it does not require it
    6250 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8259 !TSM:FPAR:FAIL
    8261 TSM:FAIL:CNT=1
    8263 TSM:FAIL:PDT
    18266 TSM:FAIL:RE-INIT
    18268 TSM:INIT
    18276 TSM:INIT:TSP OK
    18278 TSF:SID:OK,ID=100
    18280 TSM:FPAR
    18282 Will not sign message for destination 255 as it does not require it
    18331 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20340 !TSM:FPAR:NO REPLY
    20342 TSM:FPAR
    20344 Will not sign message for destination 255 as it does not require it
    20393 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22403 !TSM:FPAR:NO REPLY
    22405 TSM:FPAR
    22407 Will not sign message for destination 255 as it does not require it
    22456 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24465 !TSM:FPAR:NO REPLY
    24467 TSM:FPAR
    24469 Will not sign message for destination 255 as it does not require it
    24518 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26527 !TSM:FPAR:FAIL
    26529 TSM:FAIL:CNT=2
    26531 TSM:FAIL:PDT
    36534 TSM:FAIL:RE-INIT
    36536 TSM:INIT
    36544 TSM:INIT:TSP OK
    36546 TSF:SID:OK,ID=100
    36548 TSM:FPAR
    36550 Will not sign message for destination 255 as it does not require it
    36599 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    38610 !TSM:FPAR:NO REPLY
    38612 TSM:FPAR
    38615 Will not sign message for destination 255 as it does not require it
    38664 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    40673 !TSM:FPAR:NO REPLY
    40675 TSM:FPAR
    40677 Will not sign message for destination 255 as it does not require it
    40726 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    42735 !TSM:FPAR:NO REPLY
    42737 TSM:FPAR
    42739 Will not sign message for destination 255 as it does not require it
    42788 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    44800 !TSM:FPAR:FAIL
    44802 TSM:FAIL:CNT=3
    44804 TSM:FAIL:PDT
    54808 TSM:FAIL:RE-INIT
    54810 TSM:INIT
    54818 TSM:INIT:TSP OK
    54820 TSF:SID:OK,ID=100
    54822 TSM:FPAR
    54824 Will not sign message for destination 255 as it does not require it
    54874 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    56883 !TSM:FPAR:NO REPLY
    56885 TSM:FPAR
    56887 Will not sign message for destination 255 as it does not require it
    56936 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    please help me once again
    Thank you
    AnticimexA
    AnticimexA
    Anticimex
    #298
    @meddie if you want your node to sign messages to the gateway you have to tell the gateway to require it. The log says that it does not require it and it is clear from your gateway sketch that you have disabled the requirement.
    Is that your problem?
    EDIT: I see that the messages are broadcasts, those will never be signed. So the "will not sign messages" are perfectly normal no matter how you configure your gateway in this case.
    The problem, at least based on the node log is that your node cannot find a parent to communicate with for some reason.
    • M meddie
      #include <stdint.h>
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      16 TSM:FPAR
      2078 TSM:FPAR
      4141 TSM:FPAR
      6201 TSM:FPAR
      8259 !TSM:FPAR:FAIL
      8261 TSM:FAIL:CNT=1
      8263 TSM:FAIL:PDT
      18268 TSM:INIT
      18280 TSM:FPAR
      20342 TSM:FPAR
      22405 TSM:FPAR
      24467 TSM:FPAR
      26531 TSM:FAIL:PDT
      36536 TSM:INIT
      36548 TSM:FPAR
      38612 TSM:FPAR
      40675 TSM:FPAR
      42737 TSM:FPAR
      44804 TSM:FAIL:PDT
      54810 TSM:INIT
      54822 TSM:FPAR
      56885 TSM:FPAR
      Thank you
      AnticimexA
      AnticimexA
      Anticimex
      @meddie for parsing the log file you can use this tool
      • M meddie
        #include <stdint.h>
        4 TSM:INIT
        4 TSF:WUR:MS=0
        12 TSM:INIT:TSP OK
        16 TSM:FPAR
        2078 TSM:FPAR
        4141 TSM:FPAR
        6201 TSM:FPAR
        8259 !TSM:FPAR:FAIL
        8261 TSM:FAIL:CNT=1
        8263 TSM:FAIL:PDT
        18268 TSM:INIT
        18280 TSM:FPAR
        20342 TSM:FPAR
        22405 TSM:FPAR
        24467 TSM:FPAR
        26531 TSM:FAIL:PDT
        36536 TSM:INIT
        36548 TSM:FPAR
        38612 TSM:FPAR
        40675 TSM:FPAR
        42737 TSM:FPAR
        44804 TSM:FAIL:PDT
        54810 TSM:INIT
        54822 TSM:FPAR
        56885 TSM:FPAR
        Thank you
        AnticimexA
        AnticimexA
        Anticimex
        @meddie I also see that you fail to find parent. Have you verified that you had working node-gateway communication before you enabled signing?
          meddie
          @Anticimex
          Hi, i have just uploaded the GatewayW5100 Sketch to the Gateway and the HumidtyTemp Sketch to the Node and it works fine, but without signing and encryption.
          AnticimexA 1 Reply Last reply
          • M meddie
            @Anticimex
            AnticimexA
            AnticimexA
            Anticimex
            @meddie You had encryption enabled when it failed? That could explain the failure of the broadcast if you did not have a matching setting between the nodes/gateway.
            • AnticimexA Anticimex
              meddie
              @Anticimex
              yes the encryption was enabled. Should i upload the personalized sketch again with my keys?
              • M meddie
                @Anticimex
                AnticimexA
                AnticimexA
                Anticimex
                @meddie You can just run an unmodified personalizer to have it read the EEPROM contents. That way you can verify that all devices share the exact same AES key. Assuming a mismatch in the AES key was the reason for the problem.
                But I strongly encourage you to just enable one security feature at a time if you are not sure what you are doing or it will be hard to debug what is going wrong.
                  meddie
                  @Anticimex
                  yes, i try to activate one feature and when it works the next. So i decided to activate the encryption and then when it works then i try to activate the signing. But first i would to check the keys like you said and when i now upload the securitypersonalization sketch unmodified i dont get any output on the serial monitor.
                  :disappointed:
                  • M meddie
                    @Anticimex
                    :disappointed:
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @meddie Well, you have to make the patch to the baud rate and the changes we discussed earlier. I presume you did something necessary since you got output previously.
                      meddie
                      @Anticimex
                      when i run the personalizer sketch i see in all keys FFFFFF....... What does it mean that no keys are stored?
                      • M meddie
                        @Anticimex
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @meddie yes, that mean eeprom is in default state. The node has not been properly personalized.
                          meddie
                          @Anticimex
                          ok, i think i know what went wrong! But i dont know how to fix it. On the first run when i tried came the prompt to sens space to lock configuration i did it.
                          Now when i upload the modified personalization sketch with my keys i get this output on serial monitor:
                          of course i removed my keys with xx!
                          Device serial:   {0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX}
                          xxxxxxxxxxxxxxxxxxxxx
                          Skipping configuration write and lock (configuration already locked).
                          Chip configuration:
                          EEPROM DATA:
                          AES_KEY       | XXFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                          ATSHA204A DATA:
                                     SN[0:1]           |         SN[2:3]           | XX   XX | XX   XX
                                                    Revnum                         | 00   09   04   00
                                                    SN[4:7]                        | XX   XX   XX   XX
                              SN[8]    |  Reserved13   | I2CEnable | Reserved15    | EE | 10 | 00 | 00
                            I2CAddress |  TempOffset   |  OTPmode  | SelectorMode  | C8 | 00 | 55 | 00
                                   SlotConfig00        |       SlotConfig01        | 8F   80 | 80   A1
                                   SlotConfig02        |       SlotConfig03        | 82   E0 | A3   60
                                   SlotConfig04        |       SlotConfig05        | 94   40 | A0   85
                                   SlotConfig06        |       SlotConfig07        | 86   40 | 87   07
                                   SlotConfig08        |       SlotConfig09        | 0F   00 | 89   F2
                                   SlotConfig0A        |       SlotConfig0B        | 8A   7A | 0B   8B
                                   SlotConfig0C        |       SlotConfig0D        | 0C   4C | DD   4D
                                   SlotConfig0E        |       SlotConfig0F        | C2   42 | AF   8F
                            UseFlag00  | UpdateCount00 | UseFlag01 | UpdateCount01 | FF | 00 | FF | 00
                            UseFlag02  | UpdateCount02 | UseFlag03 | UpdateCount03 | FF | 00 | FF | 00
                            UseFlag04  | UpdateCount04 | UseFlag05 | UpdateCount05 | FF | 00 | FF | 00
                            UseFlag06  | UpdateCount06 | UseFlag07 | UpdateCount07 | FF | 00 | FF | 00
                                                LastKeyUse[0:3]                    | FF   FF   FF   FF
                                                LastKeyUse[4:7]                    | FF   FF   FF   FF
                                                LastKeyUse[8:B]                    | FF   FF   FF   FF
                                                LastKeyUse[C:F]                    | FF   FF   FF   FF
                            UserExtra  |    Selector   | LockValue |  LockConfig   | 00 | 00 | 55 | 00
                          Using this user supplied HMAC key:
                          #define MY_HMAC_KEY 0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,\
                          Writing key to slot 0...
                          Data not locked. Define LOCK_DATA to lock for real.
                          Configuration is LOCKED
                          Data is UNLOCKED
                          i thin this is the reason:
                          and what i find very interestin that the first two signs of AES Key are correct the rest of them are FFFFF
                          is it possible to unlock the configuration or did i kill the chip?
                          Thank you
                          Greets Eddie
                          • M meddie
                            @Anticimex
                            Chip configuration:
                            EEPROM DATA:
                            ATSHA204A DATA:
                            Data is UNLOCKED
                            Thank you
                            Greets Eddie
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @meddie you cannot undo a lock, and you have to lock the chip in order to use it. And it is not an error that it reports chip is already locked since you have locked it already.
                            Furthermore, AES key and eeprom has nothing to do with the atsha204a chip so the lock state of the chip is irrelevant.
                            Now, why your AES key is only partially stored, I am not sure. But my bet would be that you have an error in the line where you define it in the sketch. A space or something like that.
                            Finally, as long as you don't lock the data zone, and you don't tamper with the configuration bits for the atsha204a device, you cannot destroy the chip. You can always replace the hmac key, which is the only thing you program to the atsha using the personalizer. Except for the chip configuration bits, and those the sketch handles for you and once config is locked they are fixed in place.
                            M 2 Replies Last reply
                              meddie
                              @Anticimex
                              i checked the sketch already few times but i dont see an error.
                              here is the code i have only change my key with XX
                              #include "sha204_library.h"
                              #define MY_CORE_ONLY
                              #if DOXYGEN
                              #define LOCK_CONFIGURATION
                              #define LOCK_DATA
                              #define SKIP_KEY_STORAGE
                              #define USER_KEY
                              #define SKIP_UART_CONFIRMATION
                              #define USE_SOFT_SIGNING
                              #define STORE_SOFT_KEY
                              #define USER_SOFT_KEY
                              #define STORE_SOFT_SERIAL
                              #define USER_SOFT_SERIAL
                              #define STORE_AES_KEY
                              #define USER_AES_KEY
                              //#define LOCK_DATA
                              //#define SKIP_KEY_STORAGE
                              #define USER_KEY
                              //#define USE_SOFT_SIGNING
                              //#define STORE_SOFT_KEY
                              //#define USER_SOFT_KEY
                              //#define STORE_SOFT_SERIAL
                              //#define USER_SOFT_SERIAL
                              #ifdef USER_KEY
                              #define MY_HMAC_KEY 0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX
                              #ifdef USER_SOFT_KEY
                              #ifdef USER_SOFT_SERIAL
                              #ifdef USER_AES_KEY
                              #define MY_AES_KEY 0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX
                              #ifndef USE_SOFT_SIGNING
                              void halt()
                              	while(1);
                              	uint16_t crc = 0;
                              	uint8_t config_word[4];
                              	uint8_t ret_code;
                              	bool do_write;
                              		do_write = true;
                              		if (i == 20) {
                              			config_word[0] = 0x8F;
                              			config_word[1] = 0x80;
                              			config_word[2] = 0x80;
                              			config_word[3] = 0xA1;
                              		} else if (i == 24) {
                              			config_word[0] = 0x82;
                              			config_word[1] = 0xE0;
                              			config_word[2] = 0xA3;
                              			config_word[3] = 0x60;
                              		} else if (i == 28) {
                              			config_word[0] = 0x94;
                              			config_word[1] = 0x40;
                              			config_word[2] = 0xA0;
                              			config_word[3] = 0x85;
                              		} else if (i == 32) {
                              			config_word[0] = 0x86;
                              			config_word[2] = 0x87;
                              			config_word[3] = 0x07;
                              		} else if (i == 36) {
                              			config_word[0] = 0x0F;
                              			config_word[1] = 0x00;
                              			config_word[2] = 0x89;
                              			config_word[3] = 0xF2;
                              		} else if (i == 40) {
                              			config_word[0] = 0x8A;
                              			config_word[1] = 0x7A;
                              			config_word[2] = 0x0B;
                              			config_word[3] = 0x8B;
                              		} else if (i == 44) {
                              			config_word[0] = 0x0C;
                              			config_word[1] = 0x4C;
                              			config_word[2] = 0xDD;
                              			config_word[3] = 0x4D;
                              		} else if (i == 48) {
                              			config_word[0] = 0xC2;
                              			config_word[1] = 0x42;
                              			config_word[2] = 0xAF;
                              			config_word[3] = 0x8F;
                              			config_word[0] = 0xFF;
                              			config_word[2] = 0xFF;
                              			config_word[3] = 0x00;
                              			config_word[1] = 0xFF;
                              			config_word[3] = 0xFF;
                              				halt();
                              			do_write = false;
                              		// Write config word
                              		if (do_write) {
                              				Serial.print(i);
                              				halt();
                              	return crc;
                              void write_key(uint8_t* key)
                              	uint8_t ret_code;
                              	// Write key to slot 0
                              		halt();
                              void dump_configuration()
                              	uint8_t buffer[32];
                              	for (int j=0; j<32; j++) {
                              		if (buffer[j] < 0x10) {
                              		Serial.print(buffer[j], HEX);
                              	Serial.println();
                              	for (int j=0; j<9; j++) {
                              	Serial.println();
                              	for (int j=0; j<16; j++) {
                              	Serial.println();
                              	uint8_t ret_code;
                              			halt();
                              		if (i == 0x00) {
                              			for (int j=0; j<4; j++) {
                              				if (j == 1) {
                              					Serial.print(F(" | "));
                              					Serial.print(F("   "));
                              			Serial.println();
                              		} else if (i == 0x04) {
                              			Serial.println();
                              		} else if (i == 0x08) {
                              			Serial.println();
                              		} else if (i == 0x0C) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x10) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x14) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x18) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x1C) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x20) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x24) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x28) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x2C) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x30) {
                              				if (j == 1) {
                              			Serial.println();
                              		} else if (i == 0x34) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x38) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x3C) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x40) {
                              				if (j < 3) {
                              			Serial.println();
                              		} else if (i == 0x44) {
                              			Serial.println();
                              		} else if (i == 0x48) {
                              			Serial.println();
                              		} else if (i == 0x4C) {
                              			Serial.println();
                              		} else if (i == 0x50) {
                              			Serial.println();
                              		} else if (i == 0x54) {
                              				if (j < 3) {
                              			Serial.println();
                              	uint8_t ret_code;
                              	uint8_t lockConfig = 0;
                              	uint8_t lockValue = 0;
                              	uint16_t crc;
                              	(void)crc;
                              	// initialize pseudo-RNG
                              	uint8_t key[32];
                              	(void)key;
                                Serial.begin(9600);
                              	hwInit();
                              		halt();
                              		halt();
                              #ifdef STORE_SOFT_KEY
                              #ifdef USE_SOFT_SIGNING
                              		halt();
                              	if (lockConfig == 0x00) {
                              #endif // not USER_SOFT_KEY
                              	for (int i=0; i<32; i++) {
                              		Serial.print("0x");
                              		if (key[i] < 0x10) {
                              		Serial.print(key[i], HEX);
                              		if (i < 31) {
                              			Serial.print(',');
                              	Serial.println();
                              #endif // STORE_SOFT_KEY
                              #ifdef STORE_SOFT_SERIAL
                              	for (int i = 0; i < 9; i++) {
                              		halt();
                              	for (int i=0; i<9; i++) {
                              		Serial.print("0x");
                              		if (i < 8) {
                              			Serial.print(',');
                              	Serial.println();
                              #endif // STORE_SOFT_SERIAL
                              #ifdef STORE_AES_KEY
                              #ifdef USER_AES_KEY
                              		halt();
                              #endif // not USER_AES_KEY
                              	Serial.print("#define MY_AES_KEY ");
                              	for (int i=0; i<16; i++) {
                              		Serial.print("0x");
                              		if (i < 15) {
                              			Serial.print(',');
                              	Serial.println();
                              #endif // STORE_AES_KEY
                              	Serial.println(F("EEPROM configuration:"));
                              	dump_configuration();
                              	// Output device revision on console
                              	ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
                              		Serial.print(F("Failed to determine device revision. Response: "));
                              		halt();
                              		Serial.print(F("Device revision: "));
                              		for (int i=0; i<4; i++) {
                              			if (rx_buffer[SHA204_BUFFER_POS_DATA+i] < 0x10) {
                              			Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+i], HEX);
                              		Serial.println();
                              	// Output serial number on console
                              	ret_code = sha204.getSerialNumber(rx_buffer);
                              		Serial.print(F("Failed to obtain device serial number. Response: "));
                              		halt();
                              		Serial.print(F("Device serial:   "));
                              		Serial.print('{');
                              			Serial.print(F("0x"));
                              			if (rx_buffer[i] < 0x10) {
                              			Serial.print(rx_buffer[i], HEX);
                              			if (i < 8) {
                              				Serial.print(',');
                              		Serial.print('}');
                              		Serial.println();
                              		Serial.println();
                              	if (lockConfig != 0x00) {
                              		// Write config and get CRC for the updated config
                              		crc = write_config_and_get_crc();
                              		// List current configuration before attempting to lock
                              		Serial.println(F("Chip configuration:"));
                              #ifdef LOCK_CONFIGURATION
                              		// Purge serial input buffer
                              #ifndef SKIP_UART_CONFIRMATION
                              		while (Serial.available()) {
                              			Serial.read();
                              		Serial.println(F("Send SPACE character now to lock the configuration..."));
                              		while (Serial.available() == 0);
                              		if (Serial.read() == ' ')
                              #endif //not SKIP_UART_CONFIRMATION
                              			Serial.println(F("Locking configuration..."));
                              			// Correct sequence, resync chip
                              			ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
                              			if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
                              				Serial.print(F("Resync failed. Response: "));
                              				halt();
                              			// Lock configuration zone
                              			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
        crc, 0, NULL, 0, NULL, 0, NULL,
        LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
                              				Serial.print(F("Configuration lock failed. Response: "));
                              				halt();
                              				Serial.println(F("Configuration locked."));
                              				// Update lock flags after locking
                              					halt();
                              		else {
                              			Serial.println(F("Unexpected answer. Skipping lock."));
                              #else //LOCK_CONFIGURATION
                              		Serial.println(F("Configuration not locked. Define LOCK_CONFIGURATION to lock for real."));
                              		Serial.println(F("Skipping configuration write and lock (configuration already locked)."));
                              #ifdef SKIP_KEY_STORAGE
                              	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
                              #ifdef USER_KEY
                              	memcpy(key, user_key_data, 32);
                              	Serial.println(F("Using this user supplied HMAC key:"));
                              		halt();
                              		Serial.println(F("Take note of this key, it will never be the shown again:"));
                              	Serial.print("#define MY_HMAC_KEY ");
                              		Serial.print("0x");
                              		if (i < 31) {
                              			Serial.print(',');
                              		if (i+1 == 16) {
                              			Serial.print("\\\n                    ");
                              	Serial.println();
                              	// It will not be possible to write the key if the configuration zone is unlocked
                              		// Write the key to the appropriate slot in the data zone
                              		Serial.println(F("Writing key to slot 0..."));
                              		write_key(key);
                              		Serial.println(F("Skipping key storage (configuration not locked)."));
                              		Serial.println(F("The configuration must be locked to be able to write a key."));
                              	if (lockValue != 0x00) {
                              #ifdef LOCK_DATA
                              			Serial.read();
                              		Serial.println(F("Send SPACE character to lock data..."));
                              				halt();
                              			// If configuration is unlocked, key is not updated. Locking data in this case will cause
                              			// slot 0 to contain an unknown (or factory default) key, and this is in practically any
                              			// usecase not the desired behaviour, so ask for additional confirmation in this case.
                              					Serial.read();
                              				Serial.println(F("*** ATTENTION ***"));
                              				Serial.println(F("Configuration is not locked. Are you ABSULOUTELY SURE you want to lock data?"));
                              				Serial.println(F("Locking data at this stage will cause slot 0 to contain a factory default key"));
                              				Serial.println(
                              				    F("which cannot be change after locking is done. This is in practically any usecase"));
                              				Serial.println(F("NOT the desired behavour. Send SPACE character now to lock data anyway..."));
                              				if (Serial.read() != ' ') {
                              					halt();
                              			// Lock data zone
                              			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_DATA | LOCK_ZONE_NO_CRC,
        0x0000, 0, NULL, 0, NULL, 0, NULL,
                              				Serial.print(F("Data lock failed. Response: "));
                              				halt();
                              				Serial.println(F("Data locked."));
                              					halt();
                              		else {
                              #else //LOCK_DATA
                              		Serial.println(F("Data not locked. Define LOCK_DATA to lock for real."));
                              		Serial.println(F("Skipping OTP/data zone lock (zone already locked)."));
                              	Serial.println(F("--------------------------------"));
                              	Serial.println(F("Personalization is now complete."));
                              	Serial.print(F("Configuration is "));
                              		Serial.println("LOCKED");
                              		Serial.println("UNLOCKED");
                              	Serial.print(F("Data is "));
                              	if (lockValue == 0x00) {
                              /** @brief Sketch execution code */
                                meddie
                                @Anticimex
                                the interesting thing is when i upload the same sketch to the sensebender micro it works the AES Key will be stored correctly.
                                But on the Sensebender Gateway only the first two digits
                                • M meddie
                                  @Anticimex
                                  #if DOXYGEN
                                  #define LOCK_DATA
                                  #define USER_KEY
                                  //#define LOCK_DATA
                                  #define USER_KEY
                                  #ifdef USER_KEY
                                  #ifdef USER_AES_KEY
                                  void halt()
                                  	while(1);
                                  	uint16_t crc = 0;
                                  	uint8_t ret_code;
                                  	bool do_write;
                                  		do_write = true;
                                  		if (i == 20) {
                                  				halt();
                                  			do_write = false;
                                  		if (do_write) {
                                  				Serial.print(i);
                                  				halt();
                                  	return crc;
                                  	uint8_t ret_code;
                                  		halt();
                                  	uint8_t buffer[32];
                                  	Serial.println();
                                  	Serial.println();
                                  	Serial.println();
                                  	uint8_t ret_code;
                                  			halt();
                                  		if (i == 0x00) {
                                  				if (j == 1) {
                                  			Serial.println();
                                  			Serial.println();
                                  			Serial.println();
                                  				if (j < 3) {
                                  			Serial.println();
                                  				if (j < 3) {
                                  			Serial.println();
                                  				if (j == 1) {
                                  			Serial.println();
                                  				if (j == 1) {
                                  			Serial.println();
                                  				if (j == 1) {
                                  			Serial.println();
                                  				if (j == 1) {
                                  			Serial.println();
                                  				if (j == 1) {
                                  			Serial.println();
                                  				if (j == 1) {
                                  			Serial.println();
                                  				if (j == 1) {
                                  			Serial.println();
                                  				if (j == 1) {
                                  			Serial.println();
                                  				if (j < 3) {
                                  			Serial.println();
                                  				if (j < 3) {
                                  			Serial.println();
                                  				if (j < 3) {
                                  			Serial.println();
                                  				if (j < 3) {
                                  			Serial.println();
                                  			Serial.println();
                                  			Serial.println();
                                  			Serial.println();
                                  			Serial.println();
                                  				if (j < 3) {
                                  			Serial.println();
                                  	uint8_t ret_code;
                                  	uint16_t crc;
                                  	(void)crc;
                                  	uint8_t key[32];
                                  	(void)key;
                                    Serial.begin(9600);
                                  	hwInit();
                                  		halt();
                                  		halt();
                                  		halt();
                                  		Serial.print("0x");
                                  		if (i < 31) {
                                  			Serial.print(',');
                                  	Serial.println();
                                  		halt();
                                  		Serial.print("0x");
                                  		if (i < 8) {
                                  			Serial.print(',');
                                  	Serial.println();
                                  #ifdef USER_AES_KEY
                                  		halt();
                                  		Serial.print("0x");
                                  		if (i < 15) {
                                  			Serial.print(',');
                                  	Serial.println();
                                  		halt();
                                  		Serial.println();
                                  		halt();
                                  		Serial.print('{');
                                  			if (i < 8) {
                                  				Serial.print(',');
                                  		Serial.print('}');
                                  		Serial.println();
                                  		Serial.println();
                                  			Serial.read();
                                  				halt();
                                  				halt();
                                  					halt();
                                  		else {
                                  #ifdef USER_KEY
                                  		halt();
                                  		Serial.print("0x");
                                  		if (i < 31) {
                                  			Serial.print(',');
                                  		if (i+1 == 16) {
                                  	Serial.println();
                                  		write_key(key);
                                  #ifdef LOCK_DATA
                                  			Serial.read();
                                  				halt();
                                  					Serial.read();
                                  				Serial.println(
                                  					halt();
                                  			// Lock data zone
                                  				halt();
                                  					halt();
                                  		else {
                                  #else //LOCK_DATA
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @meddie sorry, I cannot see anything out of the ordinary. What hardware do you run on? SAMD? I know the personalizer to work on AVR.
                                  Have you executed a sketch between personalizer rounds? Perhaps it overwrite parts of the eeprom.
                                    meddie
                                    @Anticimex
                                    the troubles i have on sensebender gateway its a samd. On the micro (avr based) works fine.
                                    On the gateway i didnt upload a sketch between. I have uploaded the personalizer sketch and after them i tried the unmoded personalizer.
                                    • M meddie
                                      @Anticimex
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @meddie ok, so samd hardware. @tbowmo is eeprom handling on samd fully compatible with avr? It would appear something is not quite right with eeprom writes (or reads) on samd.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @Anticimex
                                        eeprom on samd is handled differently, than avr, since it's an external I2C eeprom. So the normal avr commands for read/write to the eeprom doesn't work.
                                        the pieces that handle eeprom is located in MyHwSAMD.cpp between line 45 and 100
                                        https://github.com/mysensors/MySensors/blob/development/core/MyHwSAMD.cpp#L45
                                        • tbowmoT tbowmo
                                          @Anticimex
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @tbowmo
                                          That may be, but I would still expect hwReadConfigBlock and hwWriteConfigBlock to be chip agnostic.
