  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 466.6k Views 30 Watching
  • M meddie
    @Anticimex
    the interesting thing is when i upload the same sketch to the sensebender micro it works the AES Key will be stored correctly.
    But on the Sensebender Gateway only the first two digits
    AnticimexA
    AnticimexA
    Anticimex
    @meddie ok, so samd hardware. @tbowmo is eeprom handling on samd fully compatible with avr? It would appear something is not quite right with eeprom writes (or reads) on samd.
    • tbowmoT
      tbowmoT
      tbowmo
      @Anticimex
      eeprom on samd is handled differently, than avr, since it's an external I2C eeprom. So the normal avr commands for read/write to the eeprom doesn't work.
      the pieces that handle eeprom is located in MyHwSAMD.cpp between line 45 and 100
      https://github.com/mysensors/MySensors/blob/development/core/MyHwSAMD.cpp#L45
      AnticimexA 1 Reply Last reply
      • tbowmoT tbowmo
        @Anticimex
        AnticimexA
        AnticimexA
        Anticimex
        @tbowmo
        That may be, but I would still expect hwReadConfigBlock and hwWriteConfigBlock to be chip agnostic.
          meddie
          @tbowmo
          sorry can you say me please what i have to add to the sketch that will store my aes key on the sensebender gateway?
          I am a very very noob
          thanks
          • M meddie
            @tbowmo
            thanks
            AnticimexA
            AnticimexA
            Anticimex
            @meddie could you please try an experiment?
            Configure the personalizer to use soft signing and store a soft hmac key and serial to eeprom? Just make up some numbers as keys and see if the same problem happen with those or if it is just the AES key that fail.
            M 2 Replies Last reply
            • AnticimexA Anticimex
              meddie
              @Anticimex
              yes of course!!!
              here is the sketch:
              #include "sha204_library.h"
              #define MY_CORE_ONLY
              #if DOXYGEN
              #define LOCK_CONFIGURATION
              #define LOCK_DATA
              #define SKIP_KEY_STORAGE
              #define USER_KEY
              #define SKIP_UART_CONFIRMATION
              #define USE_SOFT_SIGNING
              #define STORE_SOFT_KEY
              #define USER_SOFT_KEY
              #define STORE_SOFT_SERIAL
              #define USER_SOFT_SERIAL
              #define STORE_AES_KEY
              #define USER_AES_KEY
              //#define LOCK_DATA
              //#define SKIP_KEY_STORAGE
              //#define USER_KEY
              //#define USER_AES_KEY
              #ifdef USER_KEY
              #ifdef USER_SOFT_KEY
              #define MY_SOFT_HMAC_KEY 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x010,0x11,0x12,0x13,0x14,0x15,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F,0xAA,0xAB,0xBA,0xBB,0xAC,0xAD,0xAE,0xEB,0xEC,0xED,0xDD
              #ifdef USER_SOFT_SERIAL
              #define MY_SOFT_SERIAL 0x10,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02
              #ifdef USER_AES_KEY
              #define MY_AES_KEY 0x15,0x14,0x13,0x12,0x11,0x10,0x09,0x08,0x07,0x06,0x05,0x05,0x04,0x03,0x14,0x15
              #ifndef USE_SOFT_SIGNING
              void halt()
              	while(1);
              	uint16_t crc = 0;
              	uint8_t config_word[4];
              	uint8_t ret_code;
              	bool do_write;
              		do_write = true;
              		if (i == 20) {
              			config_word[0] = 0x8F;
              			config_word[1] = 0x80;
              			config_word[2] = 0x80;
              			config_word[3] = 0xA1;
              		} else if (i == 24) {
              			config_word[0] = 0x82;
              			config_word[1] = 0xE0;
              			config_word[2] = 0xA3;
              			config_word[3] = 0x60;
              		} else if (i == 28) {
              			config_word[0] = 0x94;
              			config_word[1] = 0x40;
              			config_word[2] = 0xA0;
              			config_word[3] = 0x85;
              		} else if (i == 32) {
              			config_word[0] = 0x86;
              			config_word[2] = 0x87;
              			config_word[3] = 0x07;
              		} else if (i == 36) {
              			config_word[0] = 0x0F;
              			config_word[1] = 0x00;
              			config_word[2] = 0x89;
              			config_word[3] = 0xF2;
              		} else if (i == 40) {
              			config_word[0] = 0x8A;
              			config_word[1] = 0x7A;
              			config_word[2] = 0x0B;
              			config_word[3] = 0x8B;
              		} else if (i == 44) {
              			config_word[0] = 0x0C;
              			config_word[1] = 0x4C;
              			config_word[2] = 0xDD;
              			config_word[3] = 0x4D;
              		} else if (i == 48) {
              			config_word[0] = 0xC2;
              			config_word[1] = 0x42;
              			config_word[2] = 0xAF;
              			config_word[3] = 0x8F;
              			config_word[0] = 0xFF;
              			config_word[2] = 0xFF;
              			config_word[3] = 0x00;
              			config_word[1] = 0xFF;
              			config_word[3] = 0xFF;
              				halt();
              			do_write = false;
              		// Write config word
              		if (do_write) {
              				Serial.print(i);
              				halt();
              	return crc;
              void write_key(uint8_t* key)
              	uint8_t ret_code;
              	// Write key to slot 0
              		halt();
              void dump_configuration()
              	uint8_t buffer[32];
              	for (int j=0; j<32; j++) {
              		if (buffer[j] < 0x10) {
              		Serial.print(buffer[j], HEX);
              	Serial.println();
              	for (int j=0; j<9; j++) {
              	Serial.println();
              	for (int j=0; j<16; j++) {
              	Serial.println();
              	uint8_t ret_code;
              			halt();
              		if (i == 0x00) {
              			for (int j=0; j<4; j++) {
              				if (j == 1) {
              					Serial.print(F(" | "));
              					Serial.print(F("   "));
              			Serial.println();
              		} else if (i == 0x04) {
              			Serial.println();
              		} else if (i == 0x08) {
              			Serial.println();
              		} else if (i == 0x0C) {
              				if (j < 3) {
              			Serial.println();
              		} else if (i == 0x10) {
              				if (j < 3) {
              			Serial.println();
              		} else if (i == 0x14) {
              				if (j == 1) {
              			Serial.println();
              		} else if (i == 0x18) {
              				if (j == 1) {
              			Serial.println();
              		} else if (i == 0x1C) {
              				if (j == 1) {
              			Serial.println();
              		} else if (i == 0x20) {
              				if (j == 1) {
              			Serial.println();
              		} else if (i == 0x24) {
              				if (j == 1) {
              			Serial.println();
              		} else if (i == 0x28) {
              				if (j == 1) {
              			Serial.println();
              		} else if (i == 0x2C) {
              				if (j == 1) {
              			Serial.println();
              		} else if (i == 0x30) {
              				if (j == 1) {
              			Serial.println();
              		} else if (i == 0x34) {
              				if (j < 3) {
              			Serial.println();
              		} else if (i == 0x38) {
              				if (j < 3) {
              			Serial.println();
              		} else if (i == 0x3C) {
              				if (j < 3) {
              			Serial.println();
              		} else if (i == 0x40) {
              				if (j < 3) {
              			Serial.println();
              		} else if (i == 0x44) {
              			Serial.println();
              		} else if (i == 0x48) {
              			Serial.println();
              		} else if (i == 0x4C) {
              			Serial.println();
              		} else if (i == 0x50) {
              			Serial.println();
              		} else if (i == 0x54) {
              				if (j < 3) {
              			Serial.println();
              	uint8_t ret_code;
              	uint8_t lockConfig = 0;
              	uint8_t lockValue = 0;
              	uint16_t crc;
              	(void)crc;
              	// initialize pseudo-RNG
              	uint8_t key[32];
              	(void)key;
              	Serial.begin(9600);
              	hwInit();
              		halt();
              		halt();
              #ifdef STORE_SOFT_KEY
              #ifdef USE_SOFT_SIGNING
              		halt();
              	if (lockConfig == 0x00) {
              #endif // not USER_SOFT_KEY
              	for (int i=0; i<32; i++) {
              		Serial.print("0x");
              		if (key[i] < 0x10) {
              		Serial.print(key[i], HEX);
              		if (i < 31) {
              			Serial.print(',');
              	Serial.println();
              #endif // STORE_SOFT_KEY
              #ifdef STORE_SOFT_SERIAL
              	for (int i = 0; i < 9; i++) {
              		halt();
              	for (int i=0; i<9; i++) {
              		Serial.print("0x");
              		if (i < 8) {
              			Serial.print(',');
              	Serial.println();
              #endif // STORE_SOFT_SERIAL
              #ifdef STORE_AES_KEY
              #ifdef USER_AES_KEY
              		halt();
              #endif // not USER_AES_KEY
              	Serial.print("#define MY_AES_KEY ");
              	for (int i=0; i<16; i++) {
              		Serial.print("0x");
              		if (i < 15) {
              			Serial.print(',');
              	Serial.println();
              #endif // STORE_AES_KEY
              	Serial.println(F("EEPROM configuration:"));
              	dump_configuration();
              	// Output device revision on console
              	ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
              		Serial.print(F("Failed to determine device revision. Response: "));
              		halt();
              		Serial.print(F("Device revision: "));
              		for (int i=0; i<4; i++) {
              			if (rx_buffer[SHA204_BUFFER_POS_DATA+i] < 0x10) {
              			Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+i], HEX);
              		Serial.println();
              	// Output serial number on console
              	ret_code = sha204.getSerialNumber(rx_buffer);
              		Serial.print(F("Failed to obtain device serial number. Response: "));
              		halt();
              		Serial.print(F("Device serial:   "));
              		Serial.print('{');
              			Serial.print(F("0x"));
              			if (rx_buffer[i] < 0x10) {
              			Serial.print(rx_buffer[i], HEX);
              			if (i < 8) {
              				Serial.print(',');
              		Serial.print('}');
              		Serial.println();
              		Serial.println();
              	if (lockConfig != 0x00) {
              		// Write config and get CRC for the updated config
              		crc = write_config_and_get_crc();
              		// List current configuration before attempting to lock
              		Serial.println(F("Chip configuration:"));
              #ifdef LOCK_CONFIGURATION
              		// Purge serial input buffer
              #ifndef SKIP_UART_CONFIRMATION
              		while (Serial.available()) {
              			Serial.read();
              		Serial.println(F("Send SPACE character now to lock the configuration..."));
              		while (Serial.available() == 0);
              		if (Serial.read() == ' ')
              #endif //not SKIP_UART_CONFIRMATION
              			Serial.println(F("Locking configuration..."));
              			// Correct sequence, resync chip
              			ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
              			if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
              				Serial.print(F("Resync failed. Response: "));
              				halt();
              			// Lock configuration zone
              			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
              			                                  crc, 0, NULL, 0, NULL, 0, NULL,
              			                                  LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
              				Serial.print(F("Configuration lock failed. Response: "));
              				halt();
              				Serial.println(F("Configuration locked."));
              				// Update lock flags after locking
              					halt();
              		else {
              			Serial.println(F("Unexpected answer. Skipping lock."));
              #else //LOCK_CONFIGURATION
              		Serial.println(F("Configuration not locked. Define LOCK_CONFIGURATION to lock for real."));
              		Serial.println(F("Skipping configuration write and lock (configuration already locked)."));
              #ifdef SKIP_KEY_STORAGE
              	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
              #ifdef USER_KEY
              	memcpy(key, user_key_data, 32);
              	Serial.println(F("Using this user supplied HMAC key:"));
              		halt();
              		Serial.println(F("Take note of this key, it will never be the shown again:"));
              	Serial.print("#define MY_HMAC_KEY ");
              		Serial.print("0x");
              		if (i < 31) {
              			Serial.print(',');
              		if (i+1 == 16) {
              			Serial.print("\\\n                    ");
              	Serial.println();
              	// It will not be possible to write the key if the configuration zone is unlocked
              		// Write the key to the appropriate slot in the data zone
              		Serial.println(F("Writing key to slot 0..."));
              		write_key(key);
              		Serial.println(F("Skipping key storage (configuration not locked)."));
              		Serial.println(F("The configuration must be locked to be able to write a key."));
              	if (lockValue != 0x00) {
              #ifdef LOCK_DATA
              			Serial.read();
              		Serial.println(F("Send SPACE character to lock data..."));
              				halt();
              			// If configuration is unlocked, key is not updated. Locking data in this case will cause
              			// slot 0 to contain an unknown (or factory default) key, and this is in practically any
              			// usecase not the desired behaviour, so ask for additional confirmation in this case.
              					Serial.read();
              				Serial.println(F("*** ATTENTION ***"));
              				Serial.println(F("Configuration is not locked. Are you ABSULOUTELY SURE you want to lock data?"));
              				Serial.println(F("Locking data at this stage will cause slot 0 to contain a factory default key"));
              				Serial.println(
              				    F("which cannot be change after locking is done. This is in practically any usecase"));
              				Serial.println(F("NOT the desired behavour. Send SPACE character now to lock data anyway..."));
              				if (Serial.read() != ' ') {
              					halt();
              			// Lock data zone
              			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_DATA | LOCK_ZONE_NO_CRC,
              			                                  0x0000, 0, NULL, 0, NULL, 0, NULL,
              				Serial.print(F("Data lock failed. Response: "));
              				halt();
              				Serial.println(F("Data locked."));
              					halt();
              		else {
              #else //LOCK_DATA
              		Serial.println(F("Data not locked. Define LOCK_DATA to lock for real."));
              		Serial.println(F("Skipping OTP/data zone lock (zone already locked)."));
              	Serial.println(F("--------------------------------"));
              	Serial.println(F("Personalization is now complete."));
              	Serial.print(F("Configuration is "));
              		Serial.println("LOCKED");
              		Serial.println("UNLOCKED");
              	Serial.print(F("Data is "));
              	if (lockValue == 0x00) {
              /** @brief Sketch execution code */
                meddie
                @Anticimex
                and this is the serial output:
                #define MY_AES_KEY 0x6A,0x2B,0xF7,0xFB,0x03,0x8D,0x03,0x85,0x4D,0xDA,0x2D,0x89,0x9F,0xAD,0x8B,0x4F
                SOFT_HMAC_KEY | 01FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                SOFT_SERIAL   | 10FFFFFFFFFFFFFFFF
                AES_KEY       | 6AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                • M meddie
                  @Anticimex
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @meddie ok, clearly there is some issue with eeprom storage on samd then.
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    We will investigate this further. Thanks for identifying the issue. Perhaps you could test signing with atsha on the gateway. That should work since it does not depend on eeprom.
                      meddie
                      @Anticimex
                      thank you very much for your support and for your patience with me!!!!
                      i just tried and the signing is working fine!!!!
                      i look forward to try the encryption! i
                      • M meddie
                        @Anticimex
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @meddie you are so welcome! Glad that signing works for you. That is actually more complicated than encryption. We (the core team) have confirmed a problem with the write routine to the I2C eeprom on the SenseBender gateway. So people are investigating.
                        • M meddie
                          @Anticimex
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @meddie the development branch has been updated with a bug fix for the eeprom problem on samd based boards. If you pull the latest changes you should be able to properly personalize the AES key so that encryption will work.
                            meddie
                            @Anticimex
                            Hi, i just tried it out and now it and it has worked! The Aes key is stored correctly! BUT i get now an error on compile the gateway sketch
                            C:\Users\meddie\Documents\Arduino\SenseebnderGW_LAN_NRF24\SenseebnderGW_LAN_NRF24.ino\SenseebnderGW_LAN_NRF24.ino.ino: In function 'bool testEEProm()':
                            SenseebnderGW_LAN_NRF24.ino:315: error: 'i2c_eeprom_read_byte' was not declared in this scope
                               eeprom_d1 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
                            SenseebnderGW_LAN_NRF24.ino:318: error: 'i2c_eeprom_write_byte' was not declared in this scope
                               i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
                            i could use the stable lib again then it should compile, but i think you would like to know that an error occours.
                            Greets Eddie
                            • M meddie
                              @Anticimex
                              Greets Eddie
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @meddie thanks for reporting! @tbowmo something that slipped through the Jenkins filter?
                              • M meddie
                                @Anticimex
                                Greets Eddie
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @meddie the sketch you compile, is it from the MySensors library examples tree, the external examples repository, or a local sketch?
                                  meddie
                                  wrote on last edited by meddie
                                  #330
                                  @Anticimex
                                  its combined from two example sketches sensebendergateway and gatewayw5100 example sketch
                                  • M meddie
                                    @Anticimex
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @meddie ok, if it is a local construction, it might be an expected error due to api changes in the library, in which case you need to update locally. The examples from the repository should compile ok.
                                      meddie
                                      i used the stable lib and comiled the sketch both features are now working encryption and signing! Thank you very much!!!!! I will try to update the example lib and try again.
                                      I got just the next problem the space from sensebender micro is not enought to use all three features signing, encryption and ota. When i use AES and Signing i get over 109%, when i use the example sketch temp and humidty meassure.
                                      Greets Eddie
                                      • M meddie
                                        Greets Eddie
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @meddie you could consider using a conversion board (@tbowmo has published one at openhardware.io) and use rfm69 radios which do AES encryption in hw. It should put less strain on memory resources.
                                        alexsh1A 1 Reply Last reply
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Anticimex I am using a default SensebenderGatewaySerial sketch and get the following error when compiling:
                                          In file included from C:\Users\Alex\Documents\Arduino\SensebenderGatewaySerial-2.1.1\SensebenderGatewaySerial-2.1.1.ino:98:0:
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: redefinition of 'uint8_t device_pin'
                                           static uint8_t device_pin;
                                          In file included from C:\Users\Alex\Documents\Arduino\libraries\MySensors/MySensors.h:131:0,
                                                           from C:\Users\Alex\Documents\Arduino\SensebenderGatewaySerial-2.1.1\SensebenderGatewaySerial-2.1.1.ino:96:
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: 'uint8_t device_pin' previously declared here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void swi_set_signal_pin(uint8_t)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: redefinition of 'void swi_set_signal_pin(uint8_t)'
                                           static void swi_set_signal_pin(uint8_t is_high)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: 'void swi_set_signal_pin(uint8_t)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t swi_send_bytes(uint8_t, uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:35:16: error: redefinition of 'uint8_t swi_send_bytes(uint8_t, uint8_t*)'
                                           static uint8_t swi_send_bytes(uint8_t count, uint8_t *buffer)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:35:16: error: 'uint8_t swi_send_bytes(uint8_t, uint8_t*)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t swi_send_byte(uint8_t)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:74:16: error: redefinition of 'uint8_t swi_send_byte(uint8_t)'
                                           static uint8_t swi_send_byte(uint8_t value)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:74:16: error: 'uint8_t swi_send_byte(uint8_t)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t swi_receive_bytes(uint8_t, uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:79:16: error: redefinition of 'uint8_t swi_receive_bytes(uint8_t, uint8_t*)'
                                           static uint8_t swi_receive_bytes(uint8_t count, uint8_t *buffer)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:79:16: error: 'uint8_t swi_receive_bytes(uint8_t, uint8_t*)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204p_receive_response(uint8_t, uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:178:16: error: redefinition of 'uint8_t sha204p_receive_response(uint8_t, uint8_t*)'
                                           static uint8_t sha204p_receive_response(uint8_t size, uint8_t *response)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:178:16: error: 'uint8_t sha204p_receive_response(uint8_t, uint8_t*)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204c_resync(uint8_t, uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:212:16: error: redefinition of 'uint8_t sha204c_resync(uint8_t, uint8_t*)'
                                           static uint8_t sha204c_resync(uint8_t size, uint8_t *response)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:212:16: error: 'uint8_t sha204c_resync(uint8_t, uint8_t*)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204c_send_and_receive(uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:234:16: error: redefinition of 'uint8_t sha204c_send_and_receive(uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t)'
                                           static uint8_t sha204c_send_and_receive(uint8_t *tx_buffer, uint8_t rx_size, uint8_t *rx_buffer,
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:234:16: error: 'uint8_t sha204c_send_and_receive(uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204m_read(uint8_t*, uint8_t*, uint8_t, uint16_t)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:379:16: error: redefinition of 'uint8_t sha204m_read(uint8_t*, uint8_t*, uint8_t, uint16_t)'
                                           static uint8_t sha204m_read(uint8_t *tx_buffer, uint8_t *rx_buffer, uint8_t zone, uint16_t address)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:379:16: error: 'uint8_t sha204m_read(uint8_t*, uint8_t*, uint8_t, uint16_t)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void sha204c_calculate_crc(uint8_t, uint8_t*, uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:399:13: error: redefinition of 'void sha204c_calculate_crc(uint8_t, uint8_t*, uint8_t*)'
                                           static void sha204c_calculate_crc(uint8_t length, uint8_t *data, uint8_t *crc)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:399:13: error: 'void sha204c_calculate_crc(uint8_t, uint8_t*, uint8_t*)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t sha204c_check_crc(uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:424:16: error: redefinition of 'uint8_t sha204c_check_crc(uint8_t*)'
                                           static uint8_t sha204c_check_crc(uint8_t *response)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:424:16: error: 'uint8_t sha204c_check_crc(uint8_t*)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void atsha204_init(uint8_t)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:438:6: error: redefinition of 'void atsha204_init(uint8_t)'
                                           void atsha204_init(uint8_t pin)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:438:6: error: 'void atsha204_init(uint8_t)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void atsha204_idle()':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:455:6: error: redefinition of 'void atsha204_idle()'
                                           void atsha204_idle(void)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:455:6: error: 'void atsha204_idle()' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void atsha204_sleep()':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:460:6: error: redefinition of 'void atsha204_sleep()'
                                           void atsha204_sleep(void)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:460:6: error: 'void atsha204_sleep()' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t atsha204_wakeup(uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:465:9: error: redefinition of 'uint8_t atsha204_wakeup(uint8_t*)'
                                           uint8_t atsha204_wakeup(uint8_t *response)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:465:9: error: 'uint8_t atsha204_wakeup(uint8_t*)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t atsha204_execute(uint8_t, uint8_t, uint16_t, uint8_t, uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:495:9: error: redefinition of 'uint8_t atsha204_execute(uint8_t, uint8_t, uint16_t, uint8_t, uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t*)'
                                           uint8_t atsha204_execute(uint8_t op_code, uint8_t param1, uint16_t param2,
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:495:9: error: 'uint8_t atsha204_execute(uint8_t, uint8_t, uint16_t, uint8_t, uint8_t*, uint8_t, uint8_t*, uint8_t, uint8_t*)' previously defined here
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'uint8_t atsha204_getSerialNumber(uint8_t*)':
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:571:9: error: redefinition of 'uint8_t atsha204_getSerialNumber(uint8_t*)'
                                           uint8_t atsha204_getSerialNumber(uint8_t * response)
                                          C:\Users\Alex\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:571:9: error: 'uint8_t atsha204_getSerialNumber(uint8_t*)' previously defined here
                                          Multiple libraries were found for "SD.h"
                                           Used: C:\Users\Alex\Documents\Arduino\libraries\SD
                                           Not used: C:\Program Files (x86)\Arduino\libraries\SD
                                          Using library MySensors at version 2.1.1 in folder: C:\Users\Alex\Documents\Arduino\libraries\MySensors
                                          Using library Wire at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire
                                          Using library SPI at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI
                                          Using library SD at version 1.1.1 in folder: C:\Users\Alex\Documents\Arduino\libraries\SD
                                          exit status 1
                                          Error compiling for board Sensebender Gateway.
                                          If I delete "#include <drivers/ATSHA204/ATSHA204.cpp>", it compiles just fine.
                                          Any ideas please?
                                          I am using Mysensors 2.1.1, Arduino IDE 1.8.1 and latest SAMD board def.
