  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 466.6k Views 30 Watching
  • AnticimexA Anticimex
    @meddie Well, you have to make the patch to the baud rate and the changes we discussed earlier. I presume you did something necessary since you got output previously.
    meddie
    @Anticimex
    when i run the personalizer sketch i see in all keys FFFFFF....... What does it mean that no keys are stored?
    AnticimexA 1 Reply Last reply
    • M meddie
      @Anticimex
      AnticimexA
      AnticimexA
      Anticimex
      @meddie yes, that mean eeprom is in default state. The node has not been properly personalized.
        meddie
        @Anticimex
        ok, i think i know what went wrong! But i dont know how to fix it. On the first run when i tried came the prompt to sens space to lock configuration i did it.
        Now when i upload the modified personalization sketch with my keys i get this output on serial monitor:
        of course i removed my keys with xx!
        Device serial:   {0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX}
        xxxxxxxxxxxxxxxxxxxxx
        Skipping configuration write and lock (configuration already locked).
        Chip configuration:
        EEPROM DATA:
        AES_KEY       | XXFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        ATSHA204A DATA:
                   SN[0:1]           |         SN[2:3]           | XX   XX | XX   XX
                                  Revnum                         | 00   09   04   00
                                  SN[4:7]                        | XX   XX   XX   XX
            SN[8]    |  Reserved13   | I2CEnable | Reserved15    | EE | 10 | 00 | 00
          I2CAddress |  TempOffset   |  OTPmode  | SelectorMode  | C8 | 00 | 55 | 00
                 SlotConfig00        |       SlotConfig01        | 8F   80 | 80   A1
                 SlotConfig02        |       SlotConfig03        | 82   E0 | A3   60
                 SlotConfig04        |       SlotConfig05        | 94   40 | A0   85
                 SlotConfig06        |       SlotConfig07        | 86   40 | 87   07
                 SlotConfig08        |       SlotConfig09        | 0F   00 | 89   F2
                 SlotConfig0A        |       SlotConfig0B        | 8A   7A | 0B   8B
                 SlotConfig0C        |       SlotConfig0D        | 0C   4C | DD   4D
                 SlotConfig0E        |       SlotConfig0F        | C2   42 | AF   8F
          UseFlag00  | UpdateCount00 | UseFlag01 | UpdateCount01 | FF | 00 | FF | 00
          UseFlag02  | UpdateCount02 | UseFlag03 | UpdateCount03 | FF | 00 | FF | 00
          UseFlag04  | UpdateCount04 | UseFlag05 | UpdateCount05 | FF | 00 | FF | 00
          UseFlag06  | UpdateCount06 | UseFlag07 | UpdateCount07 | FF | 00 | FF | 00
                              LastKeyUse[0:3]                    | FF   FF   FF   FF
                              LastKeyUse[4:7]                    | FF   FF   FF   FF
                              LastKeyUse[8:B]                    | FF   FF   FF   FF
                              LastKeyUse[C:F]                    | FF   FF   FF   FF
          UserExtra  |    Selector   | LockValue |  LockConfig   | 00 | 00 | 55 | 00
        Using this user supplied HMAC key:
        #define MY_HMAC_KEY 0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,0xxx,\
        Writing key to slot 0...
        Data not locked. Define LOCK_DATA to lock for real.
        Configuration is LOCKED
        Data is UNLOCKED
        i thin this is the reason:
        and what i find very interestin that the first two signs of AES Key are correct the rest of them are FFFFF
        is it possible to unlock the configuration or did i kill the chip?
        Thank you
        Greets Eddie
        • M meddie
          @Anticimex
          Chip configuration:
          EEPROM DATA:
          ATSHA204A DATA:
          Data is UNLOCKED
          Thank you
          Greets Eddie
          AnticimexA
          AnticimexA
          Anticimex
          @meddie you cannot undo a lock, and you have to lock the chip in order to use it. And it is not an error that it reports chip is already locked since you have locked it already.
          Furthermore, AES key and eeprom has nothing to do with the atsha204a chip so the lock state of the chip is irrelevant.
          Now, why your AES key is only partially stored, I am not sure. But my bet would be that you have an error in the line where you define it in the sketch. A space or something like that.
          Finally, as long as you don't lock the data zone, and you don't tamper with the configuration bits for the atsha204a device, you cannot destroy the chip. You can always replace the hmac key, which is the only thing you program to the atsha using the personalizer. Except for the chip configuration bits, and those the sketch handles for you and once config is locked they are fixed in place.
          M 2 Replies Last reply
            meddie
            @Anticimex
            i checked the sketch already few times but i dont see an error.
            here is the code i have only change my key with XX
            #include "sha204_library.h"
            #define MY_CORE_ONLY
            #if DOXYGEN
            #define LOCK_CONFIGURATION
            #define LOCK_DATA
            #define SKIP_KEY_STORAGE
            #define USER_KEY
            #define SKIP_UART_CONFIRMATION
            #define USE_SOFT_SIGNING
            #define STORE_SOFT_KEY
            #define USER_SOFT_KEY
            #define STORE_SOFT_SERIAL
            #define USER_SOFT_SERIAL
            #define STORE_AES_KEY
            #define USER_AES_KEY
            //#define LOCK_DATA
            //#define SKIP_KEY_STORAGE
            #define USER_KEY
            //#define USE_SOFT_SIGNING
            //#define STORE_SOFT_KEY
            //#define USER_SOFT_KEY
            //#define STORE_SOFT_SERIAL
            //#define USER_SOFT_SERIAL
            #ifdef USER_KEY
            #define MY_HMAC_KEY 0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX
            #ifdef USER_SOFT_KEY
            #ifdef USER_SOFT_SERIAL
            #ifdef USER_AES_KEY
            #define MY_AES_KEY 0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX,0xXX
            #ifndef USE_SOFT_SIGNING
            void halt()
            	while(1);
            	uint16_t crc = 0;
            	uint8_t config_word[4];
            	uint8_t ret_code;
            	bool do_write;
            		do_write = true;
            		if (i == 20) {
            			config_word[0] = 0x8F;
            			config_word[1] = 0x80;
            			config_word[2] = 0x80;
            			config_word[3] = 0xA1;
            		} else if (i == 24) {
            			config_word[0] = 0x82;
            			config_word[1] = 0xE0;
            			config_word[2] = 0xA3;
            			config_word[3] = 0x60;
            		} else if (i == 28) {
            			config_word[0] = 0x94;
            			config_word[1] = 0x40;
            			config_word[2] = 0xA0;
            			config_word[3] = 0x85;
            		} else if (i == 32) {
            			config_word[0] = 0x86;
            			config_word[2] = 0x87;
            			config_word[3] = 0x07;
            		} else if (i == 36) {
            			config_word[0] = 0x0F;
            			config_word[1] = 0x00;
            			config_word[2] = 0x89;
            			config_word[3] = 0xF2;
            		} else if (i == 40) {
            			config_word[0] = 0x8A;
            			config_word[1] = 0x7A;
            			config_word[2] = 0x0B;
            			config_word[3] = 0x8B;
            		} else if (i == 44) {
            			config_word[0] = 0x0C;
            			config_word[1] = 0x4C;
            			config_word[2] = 0xDD;
            			config_word[3] = 0x4D;
            		} else if (i == 48) {
            			config_word[0] = 0xC2;
            			config_word[1] = 0x42;
            			config_word[2] = 0xAF;
            			config_word[3] = 0x8F;
            			config_word[0] = 0xFF;
            			config_word[2] = 0xFF;
            			config_word[3] = 0x00;
            			config_word[1] = 0xFF;
            			config_word[3] = 0xFF;
            				halt();
            			do_write = false;
            		// Write config word
            		if (do_write) {
            				Serial.print(i);
            				halt();
            	return crc;
            void write_key(uint8_t* key)
            	uint8_t ret_code;
            	// Write key to slot 0
            		halt();
            void dump_configuration()
            	uint8_t buffer[32];
            	for (int j=0; j<32; j++) {
            		if (buffer[j] < 0x10) {
            		Serial.print(buffer[j], HEX);
            	Serial.println();
            	for (int j=0; j<9; j++) {
            	Serial.println();
            	for (int j=0; j<16; j++) {
            	Serial.println();
            	uint8_t ret_code;
            			halt();
            		if (i == 0x00) {
            			for (int j=0; j<4; j++) {
            				if (j == 1) {
            					Serial.print(F(" | "));
            					Serial.print(F("   "));
            			Serial.println();
            		} else if (i == 0x04) {
            			Serial.println();
            		} else if (i == 0x08) {
            			Serial.println();
            		} else if (i == 0x0C) {
            				if (j < 3) {
            			Serial.println();
            		} else if (i == 0x10) {
            				if (j < 3) {
            			Serial.println();
            		} else if (i == 0x14) {
            				if (j == 1) {
            			Serial.println();
            		} else if (i == 0x18) {
            				if (j == 1) {
            			Serial.println();
            		} else if (i == 0x1C) {
            				if (j == 1) {
            			Serial.println();
            		} else if (i == 0x20) {
            				if (j == 1) {
            			Serial.println();
            		} else if (i == 0x24) {
            				if (j == 1) {
            			Serial.println();
            		} else if (i == 0x28) {
            				if (j == 1) {
            			Serial.println();
            		} else if (i == 0x2C) {
            				if (j == 1) {
            			Serial.println();
            		} else if (i == 0x30) {
            				if (j == 1) {
            			Serial.println();
            		} else if (i == 0x34) {
            				if (j < 3) {
            			Serial.println();
            		} else if (i == 0x38) {
            				if (j < 3) {
            			Serial.println();
            		} else if (i == 0x3C) {
            				if (j < 3) {
            			Serial.println();
            		} else if (i == 0x40) {
            				if (j < 3) {
            			Serial.println();
            		} else if (i == 0x44) {
            			Serial.println();
            		} else if (i == 0x48) {
            			Serial.println();
            		} else if (i == 0x4C) {
            			Serial.println();
            		} else if (i == 0x50) {
            			Serial.println();
            		} else if (i == 0x54) {
            				if (j < 3) {
            			Serial.println();
            	uint8_t ret_code;
            	uint8_t lockConfig = 0;
            	uint8_t lockValue = 0;
            	uint16_t crc;
            	(void)crc;
            	// initialize pseudo-RNG
            	uint8_t key[32];
            	(void)key;
              Serial.begin(9600);
            	hwInit();
            		halt();
            		halt();
            #ifdef STORE_SOFT_KEY
            #ifdef USE_SOFT_SIGNING
            		halt();
            	if (lockConfig == 0x00) {
            #endif // not USER_SOFT_KEY
            	for (int i=0; i<32; i++) {
            		Serial.print("0x");
            		if (key[i] < 0x10) {
            		Serial.print(key[i], HEX);
            		if (i < 31) {
            			Serial.print(',');
            	Serial.println();
            #endif // STORE_SOFT_KEY
            #ifdef STORE_SOFT_SERIAL
            	for (int i = 0; i < 9; i++) {
            		halt();
            	for (int i=0; i<9; i++) {
            		Serial.print("0x");
            		if (i < 8) {
            			Serial.print(',');
            	Serial.println();
            #endif // STORE_SOFT_SERIAL
            #ifdef STORE_AES_KEY
            #ifdef USER_AES_KEY
            		halt();
            #endif // not USER_AES_KEY
            	Serial.print("#define MY_AES_KEY ");
            	for (int i=0; i<16; i++) {
            		Serial.print("0x");
            		if (i < 15) {
            			Serial.print(',');
            	Serial.println();
            #endif // STORE_AES_KEY
            	Serial.println(F("EEPROM configuration:"));
            	dump_configuration();
            	// Output device revision on console
            	ret_code = sha204.sha204m_dev_rev(tx_buffer, rx_buffer);
            		Serial.print(F("Failed to determine device revision. Response: "));
            		halt();
            		Serial.print(F("Device revision: "));
            		for (int i=0; i<4; i++) {
            			if (rx_buffer[SHA204_BUFFER_POS_DATA+i] < 0x10) {
            			Serial.print(rx_buffer[SHA204_BUFFER_POS_DATA+i], HEX);
            		Serial.println();
            	// Output serial number on console
            	ret_code = sha204.getSerialNumber(rx_buffer);
            		Serial.print(F("Failed to obtain device serial number. Response: "));
            		halt();
            		Serial.print(F("Device serial:   "));
            		Serial.print('{');
            			Serial.print(F("0x"));
            			if (rx_buffer[i] < 0x10) {
            			Serial.print(rx_buffer[i], HEX);
            			if (i < 8) {
            				Serial.print(',');
            		Serial.print('}');
            		Serial.println();
            		Serial.println();
            	if (lockConfig != 0x00) {
            		// Write config and get CRC for the updated config
            		crc = write_config_and_get_crc();
            		// List current configuration before attempting to lock
            		Serial.println(F("Chip configuration:"));
            #ifdef LOCK_CONFIGURATION
            		// Purge serial input buffer
            #ifndef SKIP_UART_CONFIRMATION
            		while (Serial.available()) {
            			Serial.read();
            		Serial.println(F("Send SPACE character now to lock the configuration..."));
            		while (Serial.available() == 0);
            		if (Serial.read() == ' ')
            #endif //not SKIP_UART_CONFIRMATION
            			Serial.println(F("Locking configuration..."));
            			// Correct sequence, resync chip
            			ret_code = sha204.sha204c_resync(SHA204_RSP_SIZE_MAX, rx_buffer);
            			if (ret_code != SHA204_SUCCESS && ret_code != SHA204_RESYNC_WITH_WAKEUP) {
            				Serial.print(F("Resync failed. Response: "));
            				halt();
            			// Lock configuration zone
            			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_CONFIG,
            			                                  crc, 0, NULL, 0, NULL, 0, NULL,
            			                                  LOCK_COUNT, tx_buffer, LOCK_RSP_SIZE, rx_buffer);
            				Serial.print(F("Configuration lock failed. Response: "));
            				halt();
            				Serial.println(F("Configuration locked."));
            				// Update lock flags after locking
            					halt();
            		else {
            			Serial.println(F("Unexpected answer. Skipping lock."));
            #else //LOCK_CONFIGURATION
            		Serial.println(F("Configuration not locked. Define LOCK_CONFIGURATION to lock for real."));
            		Serial.println(F("Skipping configuration write and lock (configuration already locked)."));
            #ifdef SKIP_KEY_STORAGE
            	Serial.println(F("Disable SKIP_KEY_STORAGE to store key."));
            #ifdef USER_KEY
            	memcpy(key, user_key_data, 32);
            	Serial.println(F("Using this user supplied HMAC key:"));
            		halt();
            		Serial.println(F("Take note of this key, it will never be the shown again:"));
            	Serial.print("#define MY_HMAC_KEY ");
            		Serial.print("0x");
            		if (i < 31) {
            			Serial.print(',');
            		if (i+1 == 16) {
            			Serial.print("\\\n                    ");
            	Serial.println();
            	// It will not be possible to write the key if the configuration zone is unlocked
            		// Write the key to the appropriate slot in the data zone
            		Serial.println(F("Writing key to slot 0..."));
            		write_key(key);
            		Serial.println(F("Skipping key storage (configuration not locked)."));
            		Serial.println(F("The configuration must be locked to be able to write a key."));
            	if (lockValue != 0x00) {
            #ifdef LOCK_DATA
            			Serial.read();
            		Serial.println(F("Send SPACE character to lock data..."));
            				halt();
            			// If configuration is unlocked, key is not updated. Locking data in this case will cause
            			// slot 0 to contain an unknown (or factory default) key, and this is in practically any
            			// usecase not the desired behaviour, so ask for additional confirmation in this case.
            					Serial.read();
            				Serial.println(F("*** ATTENTION ***"));
            				Serial.println(F("Configuration is not locked. Are you ABSULOUTELY SURE you want to lock data?"));
            				Serial.println(F("Locking data at this stage will cause slot 0 to contain a factory default key"));
            				Serial.println(
            				    F("which cannot be change after locking is done. This is in practically any usecase"));
            				Serial.println(F("NOT the desired behavour. Send SPACE character now to lock data anyway..."));
            				if (Serial.read() != ' ') {
            					halt();
            			// Lock data zone
            			ret_code = sha204.sha204m_execute(SHA204_LOCK, SHA204_ZONE_DATA | LOCK_ZONE_NO_CRC,
            			                                  0x0000, 0, NULL, 0, NULL, 0, NULL,
            				Serial.print(F("Data lock failed. Response: "));
            				halt();
            				Serial.println(F("Data locked."));
            					halt();
            		else {
            #else //LOCK_DATA
            		Serial.println(F("Data not locked. Define LOCK_DATA to lock for real."));
            		Serial.println(F("Skipping OTP/data zone lock (zone already locked)."));
            	Serial.println(F("--------------------------------"));
            	Serial.println(F("Personalization is now complete."));
            	Serial.print(F("Configuration is "));
            		Serial.println("LOCKED");
            		Serial.println("UNLOCKED");
            	Serial.print(F("Data is "));
            	if (lockValue == 0x00) {
            /** @brief Sketch execution code */
              meddie
              @Anticimex
              the interesting thing is when i upload the same sketch to the sensebender micro it works the AES Key will be stored correctly.
              But on the Sensebender Gateway only the first two digits
              • M meddie
                @Anticimex
                #if DOXYGEN
                #define LOCK_DATA
                #define USER_KEY
                //#define LOCK_DATA
                #define USER_KEY
                #ifdef USER_KEY
                #ifdef USER_AES_KEY
                void halt()
                	while(1);
                	uint16_t crc = 0;
                	uint8_t ret_code;
                	bool do_write;
                		do_write = true;
                		if (i == 20) {
                				halt();
                			do_write = false;
                		if (do_write) {
                				Serial.print(i);
                				halt();
                	return crc;
                	uint8_t ret_code;
                		halt();
                	uint8_t buffer[32];
                	Serial.println();
                	Serial.println();
                	Serial.println();
                	uint8_t ret_code;
                			halt();
                		if (i == 0x00) {
                				if (j == 1) {
                			Serial.println();
                			Serial.println();
                			Serial.println();
                				if (j < 3) {
                			Serial.println();
                				if (j < 3) {
                			Serial.println();
                				if (j == 1) {
                			Serial.println();
                				if (j == 1) {
                			Serial.println();
                				if (j == 1) {
                			Serial.println();
                				if (j == 1) {
                			Serial.println();
                				if (j == 1) {
                			Serial.println();
                				if (j == 1) {
                			Serial.println();
                				if (j == 1) {
                			Serial.println();
                				if (j == 1) {
                			Serial.println();
                				if (j < 3) {
                			Serial.println();
                				if (j < 3) {
                			Serial.println();
                				if (j < 3) {
                			Serial.println();
                				if (j < 3) {
                			Serial.println();
                			Serial.println();
                			Serial.println();
                			Serial.println();
                			Serial.println();
                				if (j < 3) {
                			Serial.println();
                	uint8_t ret_code;
                	uint16_t crc;
                	(void)crc;
                	uint8_t key[32];
                	(void)key;
                  Serial.begin(9600);
                	hwInit();
                		halt();
                		halt();
                		halt();
                		Serial.print("0x");
                		if (i < 31) {
                			Serial.print(',');
                	Serial.println();
                		halt();
                		Serial.print("0x");
                		if (i < 8) {
                			Serial.print(',');
                	Serial.println();
                #ifdef USER_AES_KEY
                		halt();
                		Serial.print("0x");
                		if (i < 15) {
                			Serial.print(',');
                	Serial.println();
                		halt();
                		Serial.println();
                		halt();
                		Serial.print('{');
                			if (i < 8) {
                				Serial.print(',');
                		Serial.print('}');
                		Serial.println();
                		Serial.println();
                			Serial.read();
                				halt();
                				halt();
                					halt();
                		else {
                #ifdef USER_KEY
                		halt();
                		Serial.print("0x");
                		if (i < 31) {
                			Serial.print(',');
                		if (i+1 == 16) {
                	Serial.println();
                		write_key(key);
                #ifdef LOCK_DATA
                			Serial.read();
                				halt();
                					Serial.read();
                				Serial.println(
                					halt();
                			// Lock data zone
                				halt();
                					halt();
                		else {
                #else //LOCK_DATA
                AnticimexA
                AnticimexA
                Anticimex
                @meddie sorry, I cannot see anything out of the ordinary. What hardware do you run on? SAMD? I know the personalizer to work on AVR.
                Have you executed a sketch between personalizer rounds? Perhaps it overwrite parts of the eeprom.
                  meddie
                  @Anticimex
                  the troubles i have on sensebender gateway its a samd. On the micro (avr based) works fine.
                  On the gateway i didnt upload a sketch between. I have uploaded the personalizer sketch and after them i tried the unmoded personalizer.
                  • M meddie
                    @Anticimex
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @meddie ok, so samd hardware. @tbowmo is eeprom handling on samd fully compatible with avr? It would appear something is not quite right with eeprom writes (or reads) on samd.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Anticimex
                      eeprom on samd is handled differently, than avr, since it's an external I2C eeprom. So the normal avr commands for read/write to the eeprom doesn't work.
                      the pieces that handle eeprom is located in MyHwSAMD.cpp between line 45 and 100
                      https://github.com/mysensors/MySensors/blob/development/core/MyHwSAMD.cpp#L45
                      • tbowmoT tbowmo
                        @Anticimex
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @tbowmo
                        That may be, but I would still expect hwReadConfigBlock and hwWriteConfigBlock to be chip agnostic.
                          meddie
                          @tbowmo
                          sorry can you say me please what i have to add to the sketch that will store my aes key on the sensebender gateway?
                          I am a very very noob
                          thanks
                          • M meddie
                            @tbowmo
                            thanks
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @meddie could you please try an experiment?
                            Configure the personalizer to use soft signing and store a soft hmac key and serial to eeprom? Just make up some numbers as keys and see if the same problem happen with those or if it is just the AES key that fail.
                              meddie
                              @Anticimex
                              yes of course!!!
                              here is the sketch:
                              #if DOXYGEN
                              #define LOCK_DATA
                              #define USER_KEY
                              //#define LOCK_DATA
                              //#define USER_KEY
                              //#define USER_AES_KEY
                              #ifdef USER_KEY
                              #define MY_SOFT_HMAC_KEY 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x010,0x11,0x12,0x13,0x14,0x15,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F,0xAA,0xAB,0xBA,0xBB,0xAC,0xAD,0xAE,0xEB,0xEC,0xED,0xDD
                              #define MY_SOFT_SERIAL 0x10,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02
                              #ifdef USER_AES_KEY
                              #define MY_AES_KEY 0x15,0x14,0x13,0x12,0x11,0x10,0x09,0x08,0x07,0x06,0x05,0x05,0x04,0x03,0x14,0x15
                              void halt()
                              	while(1);
                              	uint16_t crc = 0;
                              	uint8_t ret_code;
                              	bool do_write;
                              		do_write = true;
                              		if (i == 20) {
                              				halt();
                              			do_write = false;
                              		if (do_write) {
                              				Serial.print(i);
                              				halt();
                              	return crc;
                              	uint8_t ret_code;
                              		halt();
                              	uint8_t buffer[32];
                              	Serial.println();
                              	Serial.println();
                              	Serial.println();
                              	uint8_t ret_code;
                              			halt();
                              		if (i == 0x00) {
                              				if (j == 1) {
                              			Serial.println();
                              			Serial.println();
                              			Serial.println();
                              				if (j < 3) {
                              			Serial.println();
                              				if (j < 3) {
                              			Serial.println();
                              				if (j == 1) {
                              			Serial.println();
                              				if (j == 1) {
                              			Serial.println();
                              				if (j == 1) {
                              			Serial.println();
                              				if (j == 1) {
                              			Serial.println();
                              				if (j == 1) {
                              			Serial.println();
                              				if (j == 1) {
                              			Serial.println();
                              				if (j == 1) {
                              			Serial.println();
                              				if (j == 1) {
                              			Serial.println();
                              				if (j < 3) {
                              			Serial.println();
                              				if (j < 3) {
                              			Serial.println();
                              				if (j < 3) {
                              			Serial.println();
                              				if (j < 3) {
                              			Serial.println();
                              			Serial.println();
                              			Serial.println();
                              			Serial.println();
                              			Serial.println();
                              				if (j < 3) {
                              			Serial.println();
                              	uint8_t ret_code;
                              	uint16_t crc;
                              	(void)crc;
                              	uint8_t key[32];
                              	(void)key;
                              	Serial.begin(9600);
                              	hwInit();
                              		halt();
                              		halt();
                              		halt();
                              		Serial.print("0x");
                              		if (i < 31) {
                              			Serial.print(',');
                              	Serial.println();
                              		halt();
                              		Serial.print("0x");
                              		if (i < 8) {
                              			Serial.print(',');
                              	Serial.println();
                              #ifdef USER_AES_KEY
                              		halt();
                              		Serial.print("0x");
                              		if (i < 15) {
                              			Serial.print(',');
                              	Serial.println();
                              		halt();
                              		Serial.println();
                              		halt();
                              		Serial.print('{');
                              			if (i < 8) {
                              				Serial.print(',');
                              		Serial.print('}');
                              		Serial.println();
                              		Serial.println();
                              			Serial.read();
                              				halt();
                              				halt();
                              					halt();
                              		else {
                              #ifdef USER_KEY
                              		halt();
                              		Serial.print("0x");
                              		if (i < 31) {
                              			Serial.print(',');
                              		if (i+1 == 16) {
                              	Serial.println();
                              		write_key(key);
                              #ifdef LOCK_DATA
                              			Serial.read();
                              				halt();
                              					Serial.read();
                              				Serial.println(
                              					halt();
                              			// Lock data zone
                              				halt();
                              					halt();
                              		else {
                              #else //LOCK_DATA
                                meddie
                                @Anticimex
                                and this is the serial output:
                                #define MY_AES_KEY 0x6A,0x2B,0xF7,0xFB,0x03,0x8D,0x03,0x85,0x4D,0xDA,0x2D,0x89,0x9F,0xAD,0x8B,0x4F
                                SOFT_HMAC_KEY | 01FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                SOFT_SERIAL   | 10FFFFFFFFFFFFFFFF
                                AES_KEY       | 6AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                • M meddie
                                  @Anticimex
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @meddie ok, clearly there is some issue with eeprom storage on samd then.
                                  • AnticimexA
                                    AnticimexA
                                    Anticimex
                                    We will investigate this further. Thanks for identifying the issue. Perhaps you could test signing with atsha on the gateway. That should work since it does not depend on eeprom.
                                      meddie
                                      @Anticimex
                                      thank you very much for your support and for your patience with me!!!!
                                      i just tried and the signing is working fine!!!!
                                      i look forward to try the encryption! i
                                      • M meddie
                                        @Anticimex
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @meddie you are so welcome! Glad that signing works for you. That is actually more complicated than encryption. We (the core team) have confirmed a problem with the write routine to the I2C eeprom on the SenseBender gateway. So people are investigating.
                                        • M meddie
                                          @Anticimex
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @meddie the development branch has been updated with a bug fix for the eeprom problem on samd based boards. If you pull the latest changes you should be able to properly personalize the AES key so that encryption will work.
