  3. Custom sensors
Custom sensors
20 Posts 4 Posters 9.3k Views 1 Watching
    Creating a new device type on Vera is not that hard, just a few config files.
    But finding a standard set of speeds for a fan is harder. There might be all kinds of configurations here. Maybe a dimmer-slider is the best way to handle this and the sketch has to translate it into the local-attached fans step-levels. So in your example setting fan-slider to just above 50% represents MED-speed on fan.
    Then we're back to the Dimmer device with a custom icon :smile:
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    Right then, that works for me.
    anything that works, works! I have a few fans I want to Arduino-ize. :wink:
      @hek
      I like the fan idea. an everyday item that is in a lot of homes.
      Here in the US we see mainly 3 speed fans. It would be great to see a four button interface, OFF, LOW, MED, HI
      I have never even looked into developing a 'device' on vera; would that be too hard?
      We could develop a capacitor speed control board, like what you all did for the RGBW lights, no?
      axillentA
      axillentA
      axillent
      @BulldogLowell you can use regular dim controll to control fans with just a few speeds
      I use so with my kitchen fan which is drived automatically depending on the oven power consumption
      my fan has 3 speeds (and off position), so I use 3 SSR to manage one of the 3 speeds and I'm using dim on vera side
      whatever value i will select on dim my device will approximate it into one of 4 positions and will return a new value back to vera
      this behaves very well
      sense and drive
      • axillentA axillent
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @axillent
        hmmm... you are controlling with arduino?
        axillentA 1 Reply Last reply
          @axillent
          axillentA
          axillentA
          axillent
          @BulldogLowell i have build a few devices based on MySensors project and they are doing their job for a few months already
          sense and drive
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @axillent
            great, did you post them already?
            I'd like to start a fan project.
            • marceltrapmanM
              marceltrapmanM
              marceltrapman
              While thinking about this. There are these 5 generic variables. But are there any generic sensors?
              Imho the 'ARDUINO_NODE' and 'ARDUINO_RELAY' are boards and not sensors so they can't be used for that.
              Shouldn't we have something like 'BINARY' and maybe 'VARIABLE'.
              I know that Indigo uses generic naming for z-wave devices that they do not recognise but here we are in a different play field, creating our own sensors.
              Or am I missing something here?
              Fulltime Servoy Developer
              hekH 1 Reply Last reply
                @marceltrapman
                Vera also got some generic device it shows for unrecognized or missing device files. Let me think about it... GENERIC might be good to add to the device list to match the VAR1-5.
                • marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  'GENERIC' would do too I guess because the var1-5 values can be used for binary as well as any other value obviously.
                  hekH axillentA 2 Replies Last reply
                    wrote on last edited by hek
                    @marceltrapman
                    Ahh.. ok, now I understand what you mean.. You need to transfer binary data to the controller? I have added a flag in the message-structure for this... but it has not been implemented fully (the serial protocol should produce base64 encoded output for payload or similar when this flag is set).
                    And Vera controller does not consider this flag.
                      axillentA
                      axillentA
                      axillent
                      @marceltrapman are you looking for binary transfer between node and vera or between two nodes?
                      i would like to see an application which requires binary transfer with vera. Currently do not see it
                      for node to node it is good to have an ability to transfer any kind of custom data including binary.
                      in my view it can be very useful to define own custom struct and transfer it between nodes
                      sense and drive
                        @axillent
                        Marcel is developing a MySensor plugin for the indigo controller .
                        http://forum.mysensors.org/topic/62/plugin-for-indigo-for-mac
