  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
    meddie
    yes i have seen this an my console is set to 115200 bauds, but no output
    AnticimexA 1 Reply Last reply
    • M meddie
      AnticimexA
      AnticimexA
      Anticimex
      Hm. Then I don't know what's wrong. I have not yet used that hardware.
        meddie
        i just get the output, the serial console must be open while uploading the sketch, immedialty after the upload i see the output.
        But all Keys are FFFFFFF
        ATSHA204A DATA:
        Why this?
        • tbowmoT
          tbowmoT
          tbowmo
          While(! Serial()) {}
          • tbowmoT tbowmo
            AnticimexA
            AnticimexA
            Anticimex
            • tbowmoT
              tbowmoT
              tbowmo
              @Anticimex
              • tbowmoT tbowmo
                @Anticimex
                AnticimexA
                AnticimexA
                Anticimex
                	Serial.begin(MY_BAUD_RATE);
                • AnticimexA
                  AnticimexA
                  Anticimex
                  • FleischtorteF
                    FleischtorteF
                    Fleischtorte
                    hi all,
                    ClearEEPROM:
                    		hwWriteConfig(i,0xFF);
                    Set ENC-Key:
                        uint8_t key[32];
                    • FleischtorteF Fleischtorte
                      hi all,
                      ClearEEPROM:
                      Set ENC-Key:
                          uint8_t key[32];
                      AnticimexA
                      AnticimexA
                      Anticimex
                      • FleischtorteF
                        FleischtorteF
                        Fleischtorte
                        @Anticimex okay, thanks for the fast response :+1:
                        • scalzS scalz
                          @alexsh1 why, i don't understand :stuck_out_tongue_winking_eye:
                          Here it is : http://www.thingiverse.com/thing:2084269
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @scalz Did you manage to do the 3D case for the PA LNA transceiver for the sensebender gateway please?
                          • AnticimexA Anticimex
                            ted
                            @Anticimex said in 💬 Sensebender Gateway:
                            MY_CORE_ONLY
                            • T ted
                              MY_CORE_ONLY
                              AnticimexA
                              AnticimexA
                              Anticimex
                                #209
                                @alexsh1
                                woops, yes i made it but forgot the upload. it's now uploaded here https://www.mysensors.org/hardware/sensebender-gateway#design-files
                                Enjoy :)
                                alexsh1A zboblamontZ 2 Replies Last reply
                                • scalzS scalz
                                  @alexsh1
                                  Enjoy :)
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #210
                                  @scalz Thank you.
                                  Does anyone have the PA transceiver version with Sensebender Gateway?
                                  Any feedback please?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @alexsh1
                                    If you mean using a nrf24 with lna/pa, with the gateway. Then yes.. I have had it running for some months now.
                                    Anything in particular that you want to know?
                                    alexsh1A 1 Reply Last reply
                                    • tbowmoT tbowmo
                                      @alexsh1
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #212
                                      @tbowmo yes, that's what I meant
                                      I am thinking about installing either a normal nrf24l01+ or lna/pa version. I have had some issues with power in the past with the lna/pa transceiver.
                                      What's your experience? What kind of power supply do you use? How better is the coverage?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        I haven't checked if the coverage is any better with the lna/pa version, compared to standard modules.
                                        Currently the gateway is connected to a RPI2, which in turn is powered by a 2A powersupply from RS Components
                                        I haven't had any issues with it yet, but then again.. I mainly receive data from sensor nodes, and not that much sending data to distant nodes from the gateway
                                        • tbowmoT tbowmo
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @tbowmo It is probably not Sensebender topic, but more lna+pa range one.
                                          I am not sure about my RPi3 as though it is powered by the 3A PSU, I have a USB z-wave stick, three transceivers, one UPS Plco (as HAT) and a 20x4 screen. I lot of power is consumed so not sure adding yet another one. (lna+pa is power hungry during peaks).
                                          I'll get the nrf24l01+ lna+pa ordered and test the range. In my view rfm69 range is probably better, but I have the rfm69 gateway on moteino with a trace antenna (very small footprint and it is based on ATMega1284P so 128KB sketch flash memory - more than I need).
                                          @hek - is it the intention to combine rfm69 and nrf24l01+ gateways in one in the future?
                                          I understand Sensebender GW is ready for it, but it is more a software limitation???
                                          I am really looking forward to combined GW.
                                          I also have a separate one for rfm95 so that I can use some remote sensors.
