  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • F
    F
    Fabien
    Just try standard GatewayW5100MQTTClient sketch. It works fine with RFM69HW
    On your log you seems to have issue with your IP. Just my log :
    0;255;3;0;9;MCO:BGN:STP
    IP: 192.168.1.47
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=15
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,15-15-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=15,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;Sending message on topic: mygateway1-out/15/3/1/0/16
    • tmn103T tmn103
      Just tried the MQTT gateway sketch and got some strange behaviour.
      Seems to pick up one of the nodes, but can't get an ip address or mqtt connection.
      Any ideas on what to try?
      IP: 0.0.0.0
      0;255;3;0;9;TSF:MSG:READ,113-113-0,s=0,c=1,t=0,pt=7,l=5,sg=0:20.8
      IP: 255.255.255.255
      IP: 0.0.0.0
      IP: 255.255.255.255
      IP: 0.0.0.0
      IP: 255.255.255.255
      IP: 0.0.0.0
      blaceyB
      blaceyB
      blacey
      @tmn103 said in 💬 Sensebender Gateway:
      IP: 255.255.255.255
      IP: 0.0.0.0
      I would triple-check the IP addresses that you are using...
        meddie
        i have uploaded this securitypersonalizer.ino sketch:
         * @ingroup MySigninggrp
         * @file SecurityPersonalizer.ino
         * @brief Security personalization sketch
         *  - See git log (git log libraries/MySensors/examples/SecurityPersonalizer/SecurityPersonalizer.ino)
         * @example SecurityPersonalizer.ino
         * This sketch will personalize either none-volatile memory or ATSHA204A for security functions
         * available in the MySensors library.
         * For ATSHA204A:
         * It will write factory default settings to the configuration zone
         * and then lock it.<br>
         * It will then either<br>
         * -# Generate a random value to use as a key which will be stored in
         * slot 0. The key is printed on UART (115200) in clear text for the user to be
         * able to use it as a user-supplied key in other personalization executions
         * where the same key is needed.
         * -# Use a user-supplied value to use as a key which will be stored in
         * slot 0.
         * Finally it will lock the data zone.
         * By default, no locking is performed. User have to manually enable the flags that
         * turn on the locking. Furthermore, user have to send a SPACE character on serial
         * console when prompted to do any locking. On boards that does not provide UART
         * input it is possible to configure the sketch to skip this confirmation.
         * Default settings use ATSHA204A on @ref MY_SIGNING_ATSHA204_PIN.
         * For Soft signing:
         * It will<br>
         * -# Generate a random value to use as a key which will be stored in EEPROM.
         * The key is printed on UART (115200) in clear text for the user to be ablle to
         * use it as a user-supplied key in other personalization executions where the same
         * key is needed.
         * -# Use a user-supplied value to use as a key which will be stored in EEPROM.
         * -# Generate a random value to use as a serial number which will be stored in EEPROM.
         * The serial number is printed on UART (115200) in clear text for the user to be ablle to
         * use it as a user-supplied serial number in other personalization executions where the
         * serial is needed (typically for a whitelist).
         * -# Use a user-supplied value to use as a serial which will be stored in EEPROM.
         * For Encryption support:
         * -# Generate a random value to use as a AES key which will be stored in EEPROM.
         * The AES key is printed on UART (115200) in clear text for the user to be ablle to
         * use it as a user-supplied AES key in other personalization executions where the
         * AES key is needed (typically for RF encryption).
         * -# Use a user-supplied value to use as a AES key which will be stored in EEPROM.
         * Personalizing EEPROM or ATSHA204A still require the appropriate configuration of the
         * library to actually have an effect. There is no problem personalizing EEPROM and
         * ATSHA204A at the same time. There is however a security risk with using the same
         * data for EEPROM and ATSHA204A so it is recommended to use different serial and HMAC
         * keys on the same device for ATSHA204A vs soft signing settings.
         * Details on personalization procedure is given in @ref personalization.
        #include "sha204_library.h"
        #define MY_CORE_ONLY
        #if DOXYGEN
        #define LOCK_CONFIGURATION
        #define LOCK_DATA
        #define SKIP_KEY_STORAGE
        #define USER_KEY
        #define SKIP_UART_CONFIRMATION
        #define USE_SOFT_SIGNING
        #define STORE_SOFT_KEY
        #define USER_SOFT_KEY
        #define STORE_SOFT_SERIAL
        #define USER_SOFT_SERIAL
        #define STORE_AES_KEY
        #define USER_AES_KEY
         * @def LOCK_CONFIGURATION
         * @brief Uncomment this to enable locking the configuration zone.
         * It is still possible to change the key, and this also enable random key generation.
         * @warning BE AWARE THAT THIS PREVENTS ANY FUTURE CONFIGURATION CHANGE TO THE CHIP
         * @def LOCK_DATA
         * @brief Uncomment this to enable locking the data zone.
         * It is not required to lock data, key cannot be retrieved anyway, but by locking
         * data, it can be guaranteed that nobody even with physical access to the chip,
         * will be able to change the key.
         * @warning BE AWARE THAT THIS PREVENTS THE KEY TO BE CHANGED
        //#define LOCK_DATA
         * @def SKIP_KEY_STORAGE
         * @brief Uncomment this to skip key storage (typically once key has been written once)
         * @def USER_KEY
         * @brief Uncomment this to skip key generation and use @ref user_key_data as key instead.
        //#define USER_KEY
         * @def SKIP_UART_CONFIRMATION
         * @brief Uncomment this for boards that lack UART
         * @b Important<br> No confirmation will be required for locking any zones with this configuration!
         * Also, key generation is not permitted in this mode as there is no way of presenting the generated key.
         * @def USE_SOFT_SIGNING
         * @brief Uncomment this to store data to EEPROM instead of ATSHA204A
        //#define USE_SOFT_SIGNING
         * @def STORE_SOFT_KEY
         * @brief Uncomment this to store soft HMAC key to EEPROM
        //#define STORE_SOFT_KEY
         * @def USER_SOFT_KEY
         * @brief Uncomment this to skip soft HMAC key generation and use @ref user_soft_key_data as HMAC key instead.
        //#define USER_SOFT_KEY
         * @def STORE_SOFT_SERIAL
         * @brief Uncomment this to store soft serial to EEPROM
        //#define STORE_SOFT_SERIAL
         * @def USER_SOFT_SERIAL
         * @brief Uncomment this to skip soft serial generation and use @ref user_soft_serial as serial instead.
        //#define USER_SOFT_SERIAL
         * @def STORE_AES_KEY
         * @brief Uncomment this to store AES key to EEPROM
        //#define STORE_AES_KEY
         * @def USER_AES_KEY
         * @brief Uncomment this to skip AES key generation and use @ref user_aes_key as key instead.
        //#define USER_AES_KEY
        #ifdef USER_KEY
        #ifdef USER_SOFT_KEY
        #ifdef USER_SOFT_SERIAL
        #ifdef USER_AES_KEY
        #ifndef USE_SOFT_SIGNING
        void halt()
        	while(1);
         * @brief Write default configuration and return CRC of the configuration bits
         * @returns CRC over the configuration bits
        	uint16_t crc = 0;
        	uint8_t config_word[4];
        	uint8_t ret_code;
        	bool do_write;
        	// We will set default settings from datasheet on all slots. This means that we can use slot 0 for the key
        	// as that slot will not be readable (key will therefore be secure) and slot 8 for the payload digest
        	// calculationon as that slot can be written in clear text even when the datazone is locked.
        	// Other settings which are not relevant are kept as is.
        		do_write = true;
        		if (i == 20) {
        			config_word[0] = 0x8F;
        			config_word[1] = 0x80;
        			config_word[2] = 0x80;
        			config_word[3] = 0xA1;
        		} else if (i == 24) {
        			config_word[0] = 0x82;
        			config_word[1] = 0xE0;
        			config_word[2] = 0xA3;
        			config_word[3] = 0x60;
        		} else if (i == 28) {
        			config_word[0] = 0x94;
        			config_word[1] = 0x40;
        			config_word[2] = 0xA0;
        			config_word[3] = 0x85;
        		} else if (i == 32) {
        			config_word[0] = 0x86;
        			config_word[2] = 0x87;
        			config_word[3] = 0x07;
        		} else if (i == 36) {
        			config_word[0] = 0x0F;
        			config_word[1] = 0x00;
        			config_word[2] = 0x89;
        			config_word[3] = 0xF2;
        		} else if (i == 40) {
        			config_word[0] = 0x8A;
        			config_word[1] = 0x7A;
        			config_word[2] = 0x0B;
        			config_word[3] = 0x8B;
        		} else if (i == 44) {
        			config_word[0] = 0x0C;
        			config_word[1] = 0x4C;
        			config_word[2] = 0xDD;
        			config_word[3] = 0x4D;
        		} else if (i == 48) {
        			config_word[0] = 0xC2;
        			config_word[1] = 0x42;
        			config_word[2] = 0xAF;
        			config_word[3] = 0x8F;
        			config_word[0] = 0xFF;
        			config_word[2] = 0xFF;
        			config_word[3] = 0x00;
        			config_word[1] = 0xFF;
        			config_word[3] = 0xFF;
        				halt();
        			do_write = false;
        		// Write config word
        		if (do_write) {
        				Serial.print(i);
        				halt();
        	return crc;
        void write_key(uint8_t* key)
        	uint8_t ret_code;
        	// Write key to slot 0
        		halt();
        void dump_configuration()
        	uint8_t buffer[32];
        	for (int j=0; j<32; j++) {
        		if (buffer[j] < 0x10) {
        		Serial.print(buffer[j], HEX);
        	Serial.println();
        	for (int j=0; j<9; j++) {
        	Serial.println();
        	for (int j=0; j<16; j++) {
        	Serial.println();
        	uint8_t ret_code;
        			halt();
        		if (i == 0x00) {
        			for (int j=0; j<4; j++) {
        				if (j == 1) {
        					Serial.print(F(" | "));
        					Serial.print(F("   "));
        			Serial.println();
        		} else if (i == 0x04) {
        			Serial.println();
        		} else if (i == 0x08) {
        			Serial.println();
        		} else if (i == 0x0C) {
        				if (j < 3) {
        			Serial.println();
        		} else if (i == 0x10) {
        				if (j < 3) {
        			Serial.println();
        		} else if (i == 0x14) {
        				if (j == 1) {
        			Serial.println();
        		} else if (i == 0x18) {
        				if (j == 1) {
        			Serial.println();
        		} else if (i == 0x1C) {
        				if (j == 1) {
        			Serial.println();
        		} else if (i == 0x20) {
        				if (j == 1) {
        			Serial.println();
        		} else if (i == 0x24) {
        				if (j == 1) {
        			Serial.println();
        		} else if (i == 0x28) {
        				if (j == 1) {
        			Serial.println();
        		} else if (i == 0x2C) {
        				if (j == 1) {
        			Serial.println();
        		} else if (i == 0x30) {
        				if (j == 1) {
        			Serial.println();
        		} else if (i == 0x34) {
        				if (j < 3) {
        			Serial.println();
        		} else if (i == 0x38) {
        				if (j < 3) {
        			Serial.println();
        		} else if (i == 0x3C) {
        				if (j < 3) {
        			Serial.println();
        		} else if (i == 0x40) {
        				if (j < 3) {
        			Serial.println();
        		} else if (i == 0x44) {
        			Serial.println();
        		} else if (i == 0x48) {
        			Serial.println();
        		} else if (i == 0x4C) {
        			Serial.println();
        		} else if (i == 0x50) {
        			Serial.println();
        		} else if (i == 0x54) {
        				if (j < 3) {
        			Serial.println();
        	uint8_t ret_code;
        	uint8_t lockConfig = 0;
        	uint8_t lockValue = 0;
        	uint16_t crc;
        	(void)crc;
        	// initialize pseudo-RNG
        	uint8_t key[32];
        	(void)key;
        	hwInit();
        		halt();
        		halt();
        #ifdef STORE_SOFT_KEY
        #ifdef USE_SOFT_SIGNING
        		halt();
        	if (lockConfig == 0x00) {
        #endif // not USER_SOFT_KEY
        	for (int i=0; i<32; i++) {
        		Serial.print("0x");
        		if (key[i] < 0x10) {
        		Serial.print(key[i], HEX);
        		if (i < 31) {
        			Serial.print(',');
        	Serial.println();
        #endif // STORE_SOFT_KEY
        #ifdef STORE_SOFT_SERIAL
        	for (int i = 0; i < 9; i++) {
        		halt();
        	for (int i=0; i<9; i++) {
        		Serial.print("0x");
        		if (i < 8) {
        			Serial.print(',');
        	Serial.println();
        #endif // STORE_SOFT_SERIAL
        #ifdef STORE_AES_KEY
        #ifdef USER_AES_KEY
        		halt();
        .... i have cut the rest of code because its to long to post here complete ...
        but i dont get any output on serial monitor. Do you know whaat is went wrong?
        thanks
        AnticimexA 1 Reply Last reply
        • M meddie
           * For ATSHA204A:
           * slot 0.
           * For Soft signing:
           * It will<br>
           * key is needed.
          #if DOXYGEN
          #define LOCK_DATA
          #define USER_KEY
           * @def LOCK_DATA
          //#define LOCK_DATA
           * @def USER_KEY
          //#define USER_KEY
           * @def USER_AES_KEY
          #ifdef USER_KEY
          #ifdef USER_AES_KEY
          void halt()
          	while(1);
          	uint16_t crc = 0;
          	uint8_t ret_code;
          	bool do_write;
          		do_write = true;
          		if (i == 20) {
          				halt();
          			do_write = false;
          		if (do_write) {
          				Serial.print(i);
          				halt();
          	return crc;
          	uint8_t ret_code;
          		halt();
          	uint8_t buffer[32];
          	Serial.println();
          	Serial.println();
          	Serial.println();
          	uint8_t ret_code;
          			halt();
          		if (i == 0x00) {
          				if (j == 1) {
          			Serial.println();
          			Serial.println();
          			Serial.println();
          				if (j < 3) {
          			Serial.println();
          				if (j < 3) {
          			Serial.println();
          				if (j == 1) {
          			Serial.println();
          				if (j == 1) {
          			Serial.println();
          				if (j == 1) {
          			Serial.println();
          				if (j == 1) {
          			Serial.println();
          				if (j == 1) {
          			Serial.println();
          				if (j == 1) {
          			Serial.println();
          				if (j == 1) {
          			Serial.println();
          				if (j == 1) {
          			Serial.println();
          				if (j < 3) {
          			Serial.println();
          				if (j < 3) {
          			Serial.println();
          				if (j < 3) {
          			Serial.println();
          				if (j < 3) {
          			Serial.println();
          			Serial.println();
          			Serial.println();
          			Serial.println();
          			Serial.println();
          				if (j < 3) {
          			Serial.println();
          	uint8_t ret_code;
          	uint16_t crc;
          	(void)crc;
          	uint8_t key[32];
          	(void)key;
          	hwInit();
          		halt();
          		halt();
          		halt();
          		Serial.print("0x");
          		if (i < 31) {
          			Serial.print(',');
          	Serial.println();
          		halt();
          		Serial.print("0x");
          		if (i < 8) {
          			Serial.print(',');
          	Serial.println();
          #ifdef USER_AES_KEY
          		halt();
          thanks
          AnticimexA
          AnticimexA
          Anticimex
          #194
          @meddie it is a limitation of the current personalizer that it does not inherit the baud rate from the library settings. It is stuck to 115200. (can be changed of course). It will be fixed in the next personalizer update. Perhaps you expect a different baud rate?
          See
            meddie
            yes i have seen this an my console is set to 115200 bauds, but no output
            • M meddie
              AnticimexA
              AnticimexA
              Anticimex
              Hm. Then I don't know what's wrong. I have not yet used that hardware.
                meddie
                i just get the output, the serial console must be open while uploading the sketch, immedialty after the upload i see the output.
                But all Keys are FFFFFFF
                ATSHA204A DATA:
                Why this?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  While(! Serial()) {}
                  • tbowmoT tbowmo
                    AnticimexA
                    AnticimexA
                    Anticimex
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Anticimex
                      • tbowmoT tbowmo
                        @Anticimex
                        AnticimexA
                        AnticimexA
                        Anticimex
                        	Serial.begin(MY_BAUD_RATE);
                        • AnticimexA
                          AnticimexA
                          Anticimex
                          • FleischtorteF
                            FleischtorteF
                            Fleischtorte
                            hi all,
                            ClearEEPROM:
                            		hwWriteConfig(i,0xFF);
                            Set ENC-Key:
                                uint8_t key[32];
                            • FleischtorteF Fleischtorte
                              hi all,
                              ClearEEPROM:
                              Set ENC-Key:
                                  uint8_t key[32];
                              AnticimexA
                              AnticimexA
                              Anticimex
                              • FleischtorteF
                                FleischtorteF
                                Fleischtorte
                                @Anticimex okay, thanks for the fast response :+1:
                                • scalzS scalz
                                  @alexsh1 why, i don't understand :stuck_out_tongue_winking_eye:
                                  Here it is : http://www.thingiverse.com/thing:2084269
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @scalz Did you manage to do the 3D case for the PA LNA transceiver for the sensebender gateway please?
                                  • AnticimexA Anticimex
                                    ted
                                    @Anticimex said in 💬 Sensebender Gateway:
                                    MY_CORE_ONLY
                                    • T ted
                                      MY_CORE_ONLY
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                        #209
                                        @alexsh1
                                        woops, yes i made it but forgot the upload. it's now uploaded here https://www.mysensors.org/hardware/sensebender-gateway#design-files
                                        Enjoy :)
                                        alexsh1A zboblamontZ 2 Replies Last reply
                                        • scalzS scalz
                                          @alexsh1
                                          Enjoy :)
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #210
                                          @scalz Thank you.
                                          Does anyone have the PA transceiver version with Sensebender Gateway?
                                          Any feedback please?
