  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    While(! Serial()) {}
    AnticimexA 1 Reply Last reply
    • tbowmoT tbowmo
      AnticimexA
      AnticimexA
      Anticimex
      • tbowmoT
        tbowmoT
        tbowmo
        @Anticimex
        • tbowmoT tbowmo
          @Anticimex
          AnticimexA
          AnticimexA
          Anticimex
          	Serial.begin(MY_BAUD_RATE);
          • AnticimexA
            AnticimexA
            Anticimex
            • FleischtorteF
              FleischtorteF
              Fleischtorte
              hi all,
              ClearEEPROM:
              		hwWriteConfig(i,0xFF);
              Set ENC-Key:
                  uint8_t key[32];
              • FleischtorteF Fleischtorte
                hi all,
                ClearEEPROM:
                Set ENC-Key:
                    uint8_t key[32];
                AnticimexA
                AnticimexA
                Anticimex
                • FleischtorteF
                  FleischtorteF
                  Fleischtorte
                  @Anticimex okay, thanks for the fast response :+1:
                  • scalzS scalz
                    @alexsh1 why, i don't understand :stuck_out_tongue_winking_eye:
                    Here it is : http://www.thingiverse.com/thing:2084269
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @scalz Did you manage to do the 3D case for the PA LNA transceiver for the sensebender gateway please?
                    • AnticimexA Anticimex
                      ted
                      @Anticimex said in 💬 Sensebender Gateway:
                      MY_CORE_ONLY
                      • T ted
                        MY_CORE_ONLY
                        AnticimexA
                        AnticimexA
                        Anticimex
                          #209
                          @alexsh1
                          woops, yes i made it but forgot the upload. it's now uploaded here https://www.mysensors.org/hardware/sensebender-gateway#design-files
                          Enjoy :)
                          alexsh1A zboblamontZ 2 Replies Last reply
                          • scalzS scalz
                            @alexsh1
                            Enjoy :)
                            alexsh1A
                            alexsh1A
                            alexsh1
                            #210
                            @scalz Thank you.
                            Does anyone have the PA transceiver version with Sensebender Gateway?
                            Any feedback please?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @alexsh1
                              If you mean using a nrf24 with lna/pa, with the gateway. Then yes.. I have had it running for some months now.
                              Anything in particular that you want to know?
                              alexsh1A 1 Reply Last reply
                              • tbowmoT tbowmo
                                @alexsh1
                                alexsh1A
                                alexsh1A
                                alexsh1
                                #212
                                @tbowmo yes, that's what I meant
                                I am thinking about installing either a normal nrf24l01+ or lna/pa version. I have had some issues with power in the past with the lna/pa transceiver.
                                What's your experience? What kind of power supply do you use? How better is the coverage?
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  I haven't checked if the coverage is any better with the lna/pa version, compared to standard modules.
                                  Currently the gateway is connected to a RPI2, which in turn is powered by a 2A powersupply from RS Components
                                  I haven't had any issues with it yet, but then again.. I mainly receive data from sensor nodes, and not that much sending data to distant nodes from the gateway
                                  • tbowmoT tbowmo
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tbowmo It is probably not Sensebender topic, but more lna+pa range one.
                                    I am not sure about my RPi3 as though it is powered by the 3A PSU, I have a USB z-wave stick, three transceivers, one UPS Plco (as HAT) and a 20x4 screen. I lot of power is consumed so not sure adding yet another one. (lna+pa is power hungry during peaks).
                                    I'll get the nrf24l01+ lna+pa ordered and test the range. In my view rfm69 range is probably better, but I have the rfm69 gateway on moteino with a trace antenna (very small footprint and it is based on ATMega1284P so 128KB sketch flash memory - more than I need).
                                    @hek - is it the intention to combine rfm69 and nrf24l01+ gateways in one in the future?
                                    I understand Sensebender GW is ready for it, but it is more a software limitation???
                                    I am really looking forward to combined GW.
                                    I also have a separate one for rfm95 so that I can use some remote sensors.
                                      wrote on last edited by hek
                                      #215
                                      No, I haven't heard of any near plans in the core team about doing multi radio/sub-network support in 2.0.
                                      This requires some extra thoughts and would probably only fit on SAMD/ESP nodes.
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @hek Which is good as the Sensebender GW is based on SAMD! So it is ready to be the first 2-in-1 GW.
                                        Anyway, keep on doing a great work! I'll patiently wait until the combined GW is there.
                                        • NiklasON
                                          NiklasON
                                          NiklasO
                                          wrote on last edited by NiklasO
                                          #217
                                          Ordered from ITEAD. Nice to get rid of this stuff:
                                          Just nudging anything result in problems. ;-)
                                          Time to fire up the 3D-printer.
