  3. Can't ping Ethernet Gateway ENC28J60 + Arduino Nano Clone
pingethernet gatewayenc28j60arduino nano
16 Posts 4 Posters 9.3k Views 4 Watching
  • cadetC
    cadetC
    cadet
    wrote on last edited by cadet
    I was try with nano and shield and nrf24
    Also i was try uno
    I was comment all! Led, debug and no result
    Only comment nrf24 will help and ethernet will ping.
    Waiting for ftdi and w5100 (
    • M MLs
      Hello I upload ENC28J60 Ethernet sample file from MySensors and it worked with MySensors Lib 2.1.1. And I used the Arduino Pro Mini, nRF24L01 Radio and ENC28J60 Ethernet. Do you use Arduino Pro Mini, you must disable debugging.
      //Mattias
      cadetC
      cadetC
      cadet
      @MLs
      Please post the code
      • cadetC cadet
        @MLs
        MLs
        wrote on last edited by MLs
        @cadet
        You need to 'change the IP addresses
         * Version 1.0 - Henrik EKblad
         * LED purposes:
        // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
        #define MY_RF24_CE_PIN 5
        #define MY_RF24_CS_PIN 6
        #define MY_GATEWAY_ENC28J60
        // Gateway IP address
        #define MY_IP_ADDRESS 192,168,0,178
        #define MY_PORT 5003
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 201
        #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xFE
        // Flash leds on rx/tx/err
        //#define MY_LEDS_BLINKING_FEATURE
        // Set blinking period
        // Enable inclusion mode
        #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
        #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
        #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
        #include <UIPEthernet.h>
        //Mattias
        cadetC 1 Reply Last reply
        • M MLs
          @cadet
           * LED purposes:
          //Mattias
          cadetC
          cadetC
          cadet
          @MLs
          I think you use enc28 ethernet module not shield
          I have same code but no ping if nrf not commented
          • cadetC cadet
            @MLs
            MLs
            @cadet
            Yes, I put together this some years ago. But now i uses W5100 instead.
            //Mattias
            • M MLs
              @cadet
              //Mattias
              cadetC
              cadetC
              cadet
              @MLs
              I'm also use W5100 now, but have two enc28 shield )
              • cadetC cadet
                @MLs
                MLs
                @cadet
                Ok, you have linked NRF24 radio right?
                https://www.mysensors.org/build/ethernet_gateway#enc28j60-ethernet-module
                Also verified that the shield is properly attached?
                //Mattias
                • M MLs
                  @cadet
                  //Mattias
                  cadetC
                  cadetC
                  cadet
                  @MLs
                  Nano with shield and no nrf24 ping only with commented nrf24
                  Then uncomment nrf24 GW has no connection over ethernet
                  No ping no telnet
                  • cadetC cadet
                    @MLs
                    No ping no telnet
                    MLs
                    @cadet
                    There I can say is that the circuit ENC28J60 works with MySensors lib 2.1.1
                    Try to connect your components to breadboard.
                    • M MLs
                      @cadet
                      cadetC
                      cadetC
                      cadet
                      @MLs
                      And that way I was tested
                      Connect via breadboard to nano and uno
                      With same results
                      • cadetC cadet
                        @MLs
                        With same results
                        MLs
                        @cadet
                        I'm no expert but I would have looked at the data sheet and measured up to make sure that the hardware are not defective in any way.
                        http://ww1.microchip.com/downloads/en/DeviceDoc/39662c.pdf
                        Or the radio.
                        //Mattias
