  3. Can't ping Ethernet Gateway ENC28J60 + Arduino Nano Clone
pingethernet gatewayenc28j60arduino nano
16 Posts 4 Posters 9.1k Views 4 Watching
  • G Offline
    G Offline
    gammlerstyle
    Hi everyone,
    At first I have to say that I am new to the world of MySensors. I learned programming with c and c++, so I thought that this shouldn't be a big thing. But it is...
    The circumstances:
    Arduino IDE : 1.8.1
    MySensors Library: 2.1.1
    UIPEthernet Library: 2.0.1
    Arduino AVR Borads: 1.6.17
    1.6.11
    1.6.09
    Controller: Domoticz on Raspberry Pi 3
    Hardware:
    Arduino Board: Nano Clone
    Ethernet-Board: ENC28J60
    Radio: NRF24L01+
    So, I tried to build my first Ethernet Gateway by following the steps in the Build section on MySensors. But I had a few errors concerning the library versions, so I read a lot in the forum to get it done. I double checkt wireing for about 20 times, tried to fix my problems by using different Board Versions and changed the Ethernet Board (thought maybe it is defect), but no success.
    I found out, that I am not able to ping the gateway, even when it says that it is running.
    As I thougt the mistake was in the Configuration I decided to use an example sketch of the UIPEthernet library to check if this works (Used sketch: Echo Server). But again the same error. When I am trying to ping the Arduino, it says "target host not reachable".
    I think it has to to with the combination of the Arduino IDE and the version of the library.
    Is here someone, who has the same combination of hardware and could tell me what combination of Arduino IDE and librarys work?
    Any help would be great, I am pretty dejected because nothing works.
    Edit: I want to use Signing and Encryption later on the Ethernet gateway, herefor I already bought an Arduino mega an read the step by step guide. I also want to stay at the MySensors library Version 2.1.1.
    But at first I need to get the "normal" gateway to work.
    Thank You in advance!
    • cadetC Offline
      cadetC Offline
      cadet
      This configuration is dead.
      try to comment NRF - and will ping.
      Use WI-Fi
      G 1 Reply Last reply
      • cadetC cadet
        Use WI-Fi
        G Offline
        G Offline
        gammlerstyle
        @cadet Sorry, but I don't get it.
        Why is the configuration dead?
        Or rather : what do you exactly mean? (Is the enc28j60 no longer supported by MySensors?)
        NRF wasn't activated while testing the enc28j60 with the Echo Server Sketch.
        I don't want to use Wi-Fi.
        • hekH Offline
          hekH Offline
          Not sure anyone has bothered checking with the latest version of the library....
          My experience is that the enc-module is really unreliable (and CPU intensive). Save yourself a lot of problems and get the W5100 module which offloads much of the work.
          • M Offline
            M Offline
            MLs
            Hello I upload ENC28J60 Ethernet sample file from MySensors and it worked with MySensors Lib 2.1.1. And I used the Arduino Pro Mini, nRF24L01 Radio and ENC28J60 Ethernet. Do you use Arduino Pro Mini, you must disable debugging.
            //Mattias
            cadetC 1 Reply Last reply
            • cadetC Offline
              cadetC Offline
              cadet
              wrote on last edited by cadet
              I was try with nano and shield and nrf24
              Also i was try uno
              I was comment all! Led, debug and no result
              Only comment nrf24 will help and ethernet will ping.
              Waiting for ftdi and w5100 (
              • M MLs
                //Mattias
                cadetC Offline
                cadetC Offline
                cadet
                @MLs
                Please post the code
                • cadetC cadet
                  @MLs
                  M Offline
                  M Offline
                  MLs
                  wrote on last edited by MLs
                  @cadet
                  You need to 'change the IP addresses
                   * Version 1.0 - Henrik EKblad
                   * LED purposes:
                  // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
                  #define MY_RF24_CE_PIN 5
                  #define MY_RF24_CS_PIN 6
                  #define MY_GATEWAY_ENC28J60
                  // Gateway IP address
                  #define MY_IP_ADDRESS 192,168,0,178
                  #define MY_PORT 5003
                  #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 201
                  #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xFE
                  // Flash leds on rx/tx/err
                  //#define MY_LEDS_BLINKING_FEATURE
                  // Set blinking period
                  // Enable inclusion mode
                  #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                  #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                  #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                  #include <UIPEthernet.h>
                  //Mattias
                  • M MLs
                    @cadet
                     * LED purposes:
                    //Mattias
                    cadetC Offline
                    cadetC Offline
                    cadet
                    @MLs
                    I think you use enc28 ethernet module not shield
                    I have same code but no ping if nrf not commented
                    • cadetC cadet
                      @MLs
                      M Offline
                      M Offline
                      MLs
                      @cadet
                      Yes, I put together this some years ago. But now i uses W5100 instead.
                      //Mattias
                      • M MLs
                        @cadet
                        //Mattias
                        cadetC Offline
                        cadetC Offline
                        cadet
                        @MLs
                        I'm also use W5100 now, but have two enc28 shield )
                        • cadetC cadet
                          @MLs
                          M Offline
                          M Offline
                          MLs
                          @cadet
                          Ok, you have linked NRF24 radio right?
                          https://www.mysensors.org/build/ethernet_gateway#enc28j60-ethernet-module
                          Also verified that the shield is properly attached?
                          //Mattias
                          • M MLs
                            @cadet
                            //Mattias
                            cadetC Offline
                            cadetC Offline
                            cadet
                            @MLs
                            Nano with shield and no nrf24 ping only with commented nrf24
                            Then uncomment nrf24 GW has no connection over ethernet
                            No ping no telnet
                            • cadetC cadet
                              @MLs
                              No ping no telnet
                              M Offline
                              M Offline
                              MLs
                              @cadet
                              There I can say is that the circuit ENC28J60 works with MySensors lib 2.1.1
                              Try to connect your components to breadboard.
                              • M MLs
                                @cadet
                                cadetC Offline
                                cadetC Offline
                                cadet
                                @MLs
                                And that way I was tested
                                Connect via breadboard to nano and uno
                                With same results
                                • cadetC cadet
                                  @MLs
                                  With same results
                                  M Offline
                                  M Offline
                                  MLs
                                  @cadet
                                  I'm no expert but I would have looked at the data sheet and measured up to make sure that the hardware are not defective in any way.
                                  http://ww1.microchip.com/downloads/en/DeviceDoc/39662c.pdf
                                  Or the radio.
                                  //Mattias
