  3. RFID and NRF24L01 Wireless Network Coding Issues
23 Posts 8 Posters 12.4k Views 8 Watching
    did you figure out how to make it work?
    • martinsM
      martinsM
      martins
      Sit with the same scenario. Separately both function. As soon as you share miso, mosi and sck it fails to initialize the radio. Anybody knows whether you can share this ?
      • martinsM
        martinsM
        martins
        Found the solution in this thread:
        https://forum.mysensors.org/topic/2439/rfid-garage-door-opener/35
        void before() {
        // Make sure MFRC is disabled from the SPI bus
        pinMode(RST_PIN, OUTPUT);
        digitalWrite(RST_PIN, LOW);
        pinMode(SS_PIN, OUTPUT);
        digitalWrite(SS_PIN, LOW);
        gohanG 1 Reply Last reply
        • rejoe2R
          rejoe2R
          rejoe2
          At least in some first test I got a second SPI device (MCP4131) on the same wires working using the before() instruction.
          int CS1 = 10; //MCP4131
          void before() {
            pinMode (CS1, OUTPUT);
          digitalWrite(CS1, HIGH);
          Another option may be to use SoftSPI for thenRF (see Network-Gateway-sketch).
          • martinsM martins
            void before() {
            @martins
            Is it working for you?
            martinsM 1 Reply Last reply
              @martins
              martinsM
              martinsM
              martins
              @gohan Yes
                I can't figure out what is wrong with mine
                  martinsM
                  martinsM
                  martins
                  @gohan What is the serial output or error that you get ?
                    just look at the garage door opener link you posted, there is log and code. If I unplug the radio and use some demo code to read the rfid tag I can read it, but I can't find where it conflicts with the radio
                      martinsM
                      martinsM
                      martins
                      wrote on last edited by gohan
                      @gohan This is the code that works for me on my pro mini. Try it out.
                      Here is my pins used:
                      MOSI: Pin 11
                      MISO: Pin 12
                      SCK : Pin 13
                      SS : Pin 8 (Configurable)
                      RST : Pin 6 (Configurable)
                        Arduino RFID Access Control
                        Security !
                        To keep it simple we are going to use Tag's Unique IDs
                        as only method of Authenticity. It's simple and not hacker proof.
                        If you need security, don't use it unless you modify the code
                        Copyright (C) 2015 Omer Siar Baysal
                        This program is free software; you can redistribute it and/or modify
                        it under the terms of the GNU General Public License as published by
                        the Free Software Foundation; either version 2 of the License, or
                        (at your option) any later version.
                        This program is distributed in the hope that it will be useful,
                        but WITHOUT ANY WARRANTY; without even the implied warranty of
                        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
                        GNU General Public License for more details.
                        You should have received a copy of the GNU General Public License along
                        with this program; if not, write to the Free Software Foundation, Inc.,
                        51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
                      //#define MY_RFM69_FREQUENCY RF69_433MHZ
                      //#define MY_IS_RFM69HW
                      #if F_CPU == 8000000L
                      #define MY_BAUD_RATE 38400
                      #define CHILD_ID 8
                      #define MAX_CARDS       18
                      #include <EEPROM.h>     // We are going to read and write PICC's UIDs from/to EEPROM
                      #include <SPI.h>        // RC522 Module uses SPI protocol
                      #include <MFRC522.h>	// Library for Mifare RC522 Devices
                      	For visualizing whats going on hardware
                      	we need some leds and
                      	to control door lock a relay and a wipe button
                      	(or some other hardware)
                      	Used common anode led,digitalWriting HIGH turns OFF led
                      	Mind that if you are going to use common cathode led or
                      	just seperate leds, simply comment out #define COMMON_ANODE,
                      int value=0;
                      boolean match = false;          // initialize card match to false
                      boolean programMode = false;	// initialize programming mode to false
                      boolean replaceMaster = false;
                      int successRead;		// Variable integer to keep if we have Successful Read from Reader
                      byte storedCard[4];		// Stores an ID read from EEPROM
                      byte readCard[4];		// Stores scanned ID read from RFID Module
                      byte masterCard[4];		// Stores master card's ID read from EEPROM
                      byte countValidCards = 0;
                      	We need to define MFRC522's pins and create instance
                      	Pin layout should be as follows (on Arduino Uno):
                      	MOSI: Pin 11 / ICSP-4
                      	MISO: Pin 12 / ICSP-1
                      	SCK : Pin 13 / ICSP-3
                      	SS : Pin 10 (8)(Configurable)
                      	RST : Pin 9 (6)(Configurable)
                      	look MFRC522 Library for
                      	other Arduinos' pin configuration
                      // bool lockStatus;
                      #define SS_PIN 8
                      #define RST_PIN 6
                      MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance.
                      // MFRC522::Uid validCards[MAX_CARDS];
                      //MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
                      // MFRC522 mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance.
                      ///////////////////////////////////////// Setup ///////////////////////////////////
                        //Protocol Configuration
                        //Serial.begin(9600);	 // Initialize serial communications with PC
                        SPI.begin();           // MFRC522 Hardware uses SPI protocol
                        mfrc522.PCD_Init();    // Initialize MFRC522 Hardware
                        //If you set Antenna Gain to Max it will increase reading distance
                        //mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max);
                        Serial.println(F("Access Control v3.4"));   // For debugging purposes
                        ShowReaderDetails();	// Show details of PCD - MFRC522 Card Reader details
                        if (EEPROM.read(500) != 143) {
                          Serial.println(F("No Master Card Defined"));
                          Serial.println(F("Scan A PICC to Define as Master Card"));
                          do {
                            successRead = getID();            // sets successRead to 1 when we get read from reader otherwise 0
                          while (!successRead);                  // Program will not go further while you not get a successful read
                      //    printHex(mfrc522.uid.uidByte, mfrc522.uid.size);
                          for ( int j = 0; j < 4; j++ ) {        // Loop 4 times
                            EEPROM.write( 2 + j, readCard[j] );  // Write scanned PICC's UID to EEPROM, start from address 3
                          EEPROM.write(500, 143);                  // Write to EEPROM we defined Master Card.
                          delay(500);
                          Serial.println(F("Master Card Defined"));
                      //    storeEeprom();
                        Serial.println(F("-------------------"));
                        Serial.println(F("Master Card's UID"));
                        for ( int i = 0; i < 4; i++ ) {          // Read Master Card's UID from EEPROM
                          masterCard[i] = EEPROM.read(2 + i);    // Write it to masterCard
                          Serial.print(masterCard[i], HEX);
                        Serial.println("");
                        Serial.println(F("Everything Ready"));
                        Serial.println(F("Waiting PICCs to be scanned"));
                        Serial.println(EEPROM.read(500));
                        sendSketchInfo("RFID Gate", "1.0");
                        present(CHILD_ID, S_DOOR);
                      ///////////////////////////////////////// Main Loop ///////////////////////////////////
                      void loop () {
                        send(msg.set(value==HIGH ? 1 : 0));
                        do {
                        while (!successRead); 	//the program will not go further while you not get a successful read
                        if (programMode) {
                          if ( isMaster(readCard) ) { //If master card scanned again exit program mode
                            Serial.println(F("Master Card Scanned"));
                            Serial.println(F("Exiting Program Mode"));
                            Serial.println(F("-----------------------------"));
                            return;
                          else {
                            if ( findID(readCard) ) { // If scanned card is known delete it
                              Serial.println(F("I know this PICC, removing..."));
                              deleteID(readCard);
                              Serial.println("-----------------------------");
                              Serial.println(F("Scan a PICC to ADD or REMOVE to EEPROM"));
                            else {                    // If scanned card is not known add it
                              Serial.println(F("I do not know this PICC, adding..."));
                              writeID(readCard);
                        else {
                          if ( isMaster(readCard)) {  	// If scanned card's ID matches Master Card's ID enter program mode
                            programMode = true;
                            Serial.println(F("Hello Master - Entered Program Mode"));
                            int count = EEPROM.read(0); 	// Read the first Byte of EEPROM that
                            Serial.print(F("I have "));    	// stores the number of ID's in EEPROM
                            Serial.print(count);
                            Serial.print(F(" record(s) on EEPROM"));
                            Serial.println("");
                            Serial.println(F("Scan Master Card again to Exit Program Mode"));
                          else {
                            if ( findID(readCard) ) {	// If not, see if the card is in the EEPROM
                              Serial.println(F("Welcome, You shall pass"));
                              granted(300);        	// Open the door lock for 300 ms
                            else {			// If not, show that the ID was not valid
                              Serial.println(F("You shall not pass"));
                              denied();
                      /////////////////////////////////////////  Access Granted    ///////////////////////////////////
                      void granted (int setDelay) {
                        // setLockState(!lockStatus, true);
                        value = 1;
                        smartSleep(5000);
                        value = 0;
                      ///////////////////////////////////////// Access Denied  ///////////////////////////////////
                      void denied() {
                      ///////////////////////////////////////// Get PICC's UID ///////////////////////////////////
                      int getID() {
                        // Getting ready for Reading PICCs
                          if ( ! mfrc522.PICC_IsNewCardPresent())
                          return 0;
                        // Verify if the NUID has been readed
                        if ( ! mfrc522.PICC_ReadCardSerial())
                          return 0;
                        Serial.print(F("PICC type: "));
                        MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
                        Serial.println(mfrc522.PICC_GetTypeName(piccType));
                        // Check is the PICC of Classic MIFARE type
                        if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&  piccType != MFRC522::PICC_TYPE_MIFARE_1K && piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
                          Serial.println(F("Your tag is not of type MIFARE Classic."));
                          return;
                        Serial.println(F("Scanned PICC's UID:"));
                        for (int i = 0; i < 4; i++) {  //
                          readCard[i] = mfrc522.uid.uidByte[i];
                          Serial.print(readCard[i], HEX);
                        Serial.println("");
                        mfrc522.PICC_HaltA();
                        return 1;
                      /*  while (! mfrc522.PICC_IsNewCardPresent())
                        { //If a new PICC placed to RFID reader continue
                          Serial.println("No NCP");
                          return 0;
                        {   //Since a PICC placed get Serial and continue
                          Serial.println("RCS");
                          return 0;
                        // There are Mifare PICCs which have 4 byte or 7 byte UID care if you use 7 byte PICC
                        // I think we should assume every PICC as they have 4 byte UID
                        // Until we support 7 byte PICCs
                        Serial.println("");
                        mfrc522.PICC_HaltA(); // Stop reading
                        return 1;
                      void ShowReaderDetails() {
                        // Get the MFRC522 software version
                        byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
                        Serial.print(F("MFRC522 Software Version: 0x"));
                        Serial.print(v, HEX);
                        if (v == 0x91)
                          Serial.print(F(" = v1.0"));
                        else if (v == 0x92)
                          Serial.print(F(" = v2.0"));
                          Serial.print(F(" (unknown),probably a chinese clone?"));
                        Serial.println("");
                        // When 0x00 or 0xFF is returned, communication probably failed
                        if ((v == 0x00) || (v == 0xFF)) {
                          Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
                          Serial.println(F("SYSTEM HALTED: Check connections."));
                          while (true); // do not go further
                      ///////////////////////////////////////// Cycle Leds (Program Mode) ///////////////////////////////////
                      void cycleLeds() {
                      //////////////////////////////////////// Normal Mode Led  ///////////////////////////////////
                      void normalModeOn () {
                      //////////////////////////////////////// Read an ID from EEPROM //////////////////////////////
                      void readID( int number ) {
                        int start = (number * 4 ) + 2; 		// Figure out starting position
                        for ( int i = 0; i < 4; i++ ) { 		// Loop 4 times to get the 4 Bytes
                          storedCard[i] = EEPROM.read(start + i); 	// Assign values read from EEPROM to array
                      ///////////////////////////////////////// Add ID to EEPROM   ///////////////////////////////////
                      void writeID( byte a[] ) {
                        if ( !findID( a ) ) { 		// Before we write to the EEPROM, check to see if we have seen this card before!
                          int num = EEPROM.read(0); 		// Get the numer of used spaces, position 0 stores the number of ID cards
                          int start = ( num * 4 ) + 6; 	// Figure out where the next slot starts
                          num++; 								// Increment the counter by one
                          EEPROM.write( 0, num ); 		// Write the new count to the counter
                            EEPROM.write( start + j, a[j] ); 	// Write the array values to EEPROM in the right position
                          successWrite();
                          Serial.println(F("Succesfully added ID record to EEPROM"));
                        else {
                          failedWrite();
                          Serial.println(F("Failed! There is something wrong with ID or bad EEPROM"));
                      ///////////////////////////////////////// Remove ID from EEPROM   ///////////////////////////////////
                      void deleteID( byte a[] ) {
                        if ( !findID( a ) ) { 		// Before we delete from the EEPROM, check to see if we have this card!
                          failedWrite(); 			// If not
                        else {
                          int slot; 			// Figure out the slot number of the card
                          int start;			// = ( num * 4 ) + 6; // Figure out where the next slot starts
                          int looping; 		// The number of times the loop repeats
                          int j;
                          int count = EEPROM.read(0); // Read the first Byte of EEPROM that stores number of cards
                          slot = findIDSLOT( a ); 	// Figure out the slot number of the card to delete
                          start = (slot * 4) + 2;
                          looping = ((num - slot) * 4);
                          num--; 			// Decrement the counter by one
                          for ( j = 0; j < looping; j++ ) { 				// Loop the card shift times
                            EEPROM.write( start + j, EEPROM.read(start + 4 + j)); 	// Shift the array values to 4 places earlier in the EEPROM
                          for ( int k = 0; k < 4; k++ ) { 				// Shifting loop
                            EEPROM.write( start + j + k, 0);
                          successDelete();
                          Serial.println(F("Succesfully removed ID record from EEPROM"));
                      ///////////////////////////////////////// Check Bytes   ///////////////////////////////////
                      boolean checkTwo ( byte a[], byte b[] ) {
                        if ( a[0] != NULL ) 			// Make sure there is something in the array first
                          match = true; 			// Assume they match at first
                        for ( int k = 0; k < 4; k++ ) { 	// Loop 4 times
                          if ( a[k] != b[k] ) 		// IF a != b then set match = false, one fails, all fail
                            match = false;
                        if ( match ) { 			// Check to see if if match is still true
                          return true; 			// Return true
                        else  {
                          return false; 			// Return false
                      ///////////////////////////////////////// Find Slot   ///////////////////////////////////
                      int findIDSLOT( byte find[] ) {
                        for ( int i = 1; i <= count; i++ ) { 		// Loop once for each EEPROM entry
                          readID(i); 								// Read an ID from EEPROM, it is stored in storedCard[4]
                          if ( checkTwo( find, storedCard ) ) { 	// Check to see if the storedCard read from EEPROM
                            // is the same as the find[] ID card passed
                            return i; 				// The slot number of the card
                            break; 					// Stop looking we found it
                      ///////////////////////////////////////// Find ID From EEPROM   ///////////////////////////////////
                      boolean findID( byte find[] ) {
                            return true;
                          else {  	// If not, return false
                        return false;
                      ///////////////////////////////////////// Write Success to EEPROM   ///////////////////////////////////
                      // Flashes the green LED 3 times to indicate a successful write to EEPROM
                      void successWrite() {
                      ///////////////////////////////////////// Write Failed to EEPROM   ///////////////////////////////////
                      // Flashes the red LED 3 times to indicate a failed write to EEPROM
                      void failedWrite() {
                      ///////////////////////////////////////// Success Remove UID From EEPROM  ///////////////////////////////////
                      // Flashes the blue LED 3 times to indicate a success delete to EEPROM
                      void successDelete() {
                      ////////////////////// Check readCard IF is masterCard   ///////////////////////////////////
                      // Check to see if the ID passed is the master programing card
                      boolean isMaster( byte test[] ) {
                        if ( checkTwo( test, masterCard ) )
                          return true;
                          return false;
                       * Helper routine to dump a byte array as hex values to Serial.
                      void printHex(byte *buffer, byte bufferSize) {
                        for (byte i = 0; i < bufferSize; i++) {
                          Serial.print(buffer[i] < 0x10 ? " 0" : " ");
                          Serial.print(buffer[i], HEX);
                      //void presentation()  {
                      //  sendSketchInfo("RFID Lock", "1.0");
                      //  present(CHILD_ID, S_LOCK);
                      void before() {
                        Tnx, I'll try in the next days.
                        Ps I edited your post with the correct tag for the code
                        • Aron SjöbergA
                          Aron SjöbergA
                          Aron Sjöberg
                          Help!
                          I have a RFID RC522 module I'm trying to use instead of the PN532 NFC RFID Reader/Writer Module used in the RFID Lock Sensor example (https://www.mysensors.org/build/rfid).
                          I thought I could use the sketch above posted by @martins but I get the following error message. I'm a newbie so I don't really know what I'm doing wrong?
                          Arduino: 1.8.1 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
                          C:\Users\arons\Documents\Arduino\Vera_RFID-RC522\Vera_RFID-RC522.ino: In function 'int getID()':
                          Vera_RFID-RC522:259: error: return-statement with no value, in function returning 'int' [-fpermissive]
                               return;
                          exit status 1
                          • Aron SjöbergA Aron Sjöberg
                            Help!
                                 return;
                            exit status 1
                            martinsM
                            martinsM
                            martins
                            @Aron-Sjöberg said in RFID and NRF24L01 Wireless Network Coding Issues:
                            int getID()
                            Change that line in the getID() function to return 0;
                            PlantexP 1 Reply Last reply
                            • martinsM martins
                              int getID()
                              PlantexP
                              PlantexP
                              Plantex
                              @martins
                              Could You please explain what do You mean by "Change that line in the getID() function to return 0;"
                              I am trying to run the sketch but I have the same problem as @Aron-Sjöberg.
                              Could You let me know which MFC library version I should use ?
                              • IspandyI
                                IspandyI
                                Ispandy
                                Hi everyone,
                                I have problem on RFID sketch, when i scan the card its unlock the door but when i switch from openhab its not unlock.
                                the sketch is
                                   Example sketch/program showing An Arduino Door Access Control featuring RFID, EEPROM, Relay
                                   This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
                                   This example showing a complete Door Access Control System
                                  Simple Work Flow (not limited to) :
                                  +----------------------------------->READ TAGS+^------------------------------------------+
                                  |                         +----v-----+        +-----v----+                                |
                                  |                         |MASTER TAG|        |OTHER TAGS|                                |
                                  |                      +-----v---+        +----v----+   +----v------+                     |
                                  |         +------------+READ TAGS+---+    |KNOWN TAG|   |UNKNOWN TAG|                     |
                                  |    +----v-----+   +----v----+   +--v--------+     +-v----------+  +------v----+         |
                                  |    |MASTER TAG|   |KNOWN TAG|   |UNKNOWN TAG|     |GRANT ACCESS|  |DENY ACCESS|         |
                                  |       +----+     +----v------+     +--v---+             |               +--------------->
                                  +-------+EXIT|     |DELETE FROM|     |ADD TO|             |                               |
                                          +----+     |  EEPROM   |     |EEPROM|             |                               |
                                   Use a Master Card which is act as Programmer then you can able to choose card holders who will granted access or not
                                 * **Easy User Interface**
                                   Just one RFID tag needed whether Delete or Add Tags. You can choose to use Leds for output or Serial LCD module to inform users.
                                 * **Stores Information on EEPROM**
                                   Information stored on non volatile Arduino's EEPROM memory to preserve Users' tag and Master Card. No Information lost
                                   if power lost. EEPROM has unlimited Read cycle but roughly 100,000 limited Write cycle.
                                 * **Security**
                                   To keep it simple we are going to use Tag's Unique IDs. It's simple and not hacker proof.
                                   @license Released into the public domain.
                                   Typical pin layout used:
                                               MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
                                               Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
                                   Signal      Pin          Pin           Pin       Pin        Pin              Pin
                                   RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
                                   SPI SS      SDA(SS)      10            53        D10        10               10
                                   SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
                                   SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
                                   SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
                                #define MY_RADIO_RF24
                                #define MY_NODE_ID 50
                                  Instead of a Relay you may want to use a servo. Servos can lock and unlock door locks too
                                  Relay will be used by default
                                #define RFID 1
                                // #include <Servo.h>
                                  For visualizing whats going on hardware we need some leds and to control door lock a relay and a wipe button
                                  (or some other hardware) Used common anode led,digitalWriting HIGH turns OFF led Mind that if you are going
                                  to use common cathode led or just seperate leds, simply comment out #define COMMON_ANODE,
                                //#define COMMON_ANODE
                                #ifdef COMMON_ANODE
                                #define LED_ON LOW
                                #define LED_OFF HIGH
                                #define LED_ON HIGH
                                #define LED_OFF LOW
                                #define redLed 4    // Set Led Pins
                                #define greenLed 5
                                #define blueLed 6
                                #define relay 2       // Set Relay Pin
                                #define wipeB 3     // Button pin for WipeMode
                                bool programMode = false;  // initialize programming mode to false
                                uint8_t successRead;    // Variable integer to keep if we have Successful Read from Reader
                                byte dumpedCard[4];
                                static const uint8_t MAGIC = 168;
                                #define SS_PIN 8
                                #define RST_PIN 7
                                void before() {
                                   //Arduino Pin Configuration
                                  pinMode(redLed, OUTPUT);
                                  pinMode(greenLed, OUTPUT);
                                  pinMode(blueLed, OUTPUT);
                                  pinMode(wipeB, INPUT_PULLUP);   // Enable pin's pull up resistor
                                  pinMode(relay, OUTPUT);
                                  //Be careful how relay circuit behave on while resetting or power-cycling your Arduino
                                  digitalWrite(relay, HIGH);    // Make sure door is locked
                                  digitalWrite(redLed, LED_OFF);  // Make sure led is off
                                  digitalWrite(greenLed, LED_OFF);  // Make sure led is off
                                  digitalWrite(blueLed, LED_OFF); // Make sure led is off
                                  Serial.begin(115200);  // Initialize serial communications with PC
                                   Serial.println(F("Access Control v2.0"));   // For debugging purposes
                                  checkWipe();
                                  // Check if master card defined, if not let user choose a master card
                                  // This also useful to just redefine the Master Card
                                  // You can keep other EEPROM records just write other than MAGIC to EEPROM address 1
                                  // EEPROM address 1 should hold magical number which is 'MAGIC'
                                  if (loadState(1) != MAGIC) {
                                    do {
                                      digitalWrite(blueLed, LED_ON);    // Visualize Master Card need to be defined
                                      delay(200);
                                      delay(200);
                                    for ( uint8_t j = 0; j < 4; j++ ) {        // Loop 4 times
                                      saveState( 2 + j, readCard[j] );  // Write scanned PICC's UID to EEPROM, start from address 3
                                    saveState(1, MAGIC);                  // Write to EEPROM we defined Master Card.
                                  for ( uint8_t i = 0; i < 4; i++ ) {          // Read Master Card's UID from EEPROM
                                    masterCard[i] = loadState(2 + i);    // Write it to masterCard
                                  Serial.println("");
                                  Serial.println(F("Everything is ready"));
                                  cycleLeds();    // Everything ready lets give user some feedback by cycling leds
                                //////////////////////////////////////// MySensors Presentation ///////////////////////////////
                                MyMessage lockMsg(RFID, V_LOCK_STATUS);
                                  sendSketchInfo("RFID PintuBesi", "1.0");
                                  present(RFID, S_LOCK);
                                void loop () {
                                  do {
                                    checkWipe();
                                    if (programMode) {
                                      cycleLeds();              // Program Mode cycles through Red Green Blue waiting to read a new card
                                    else {
                                      normalModeOn();     // Normal mode, blue Power LED is on, all others are off
                                  while (!successRead);   //the program will not go further while you are not getting a successful read
                                  if (programMode) {
                                    if ( isMaster(readCard) ) { //When in program mode check First If master card scanned again to exit program mode
                                      return;
                                    else {
                                        deleteID(readCard);
                                        writeID(readCard);
                                  else {
                                    if ( isMaster(readCard)) {    // If scanned card's ID matches Master Card's ID - enter program mode
                                      programMode = true;
                                      uint8_t count = loadState(0);   // Read the first Byte of EEPROM that
                                      Serial.println("");
                                    else {
                                        denied();
                                void granted ( uint16_t setDelay) {
                                  digitalWrite(blueLed, LED_OFF);   // Turn off blue LED
                                  digitalWrite(redLed, LED_OFF);  // Turn off red LED
                                  digitalWrite(greenLed, LED_ON);   // Turn on green LED
                                  digitalWrite(relay, LOW);     // Unlock door!
                                  send(lockMsg.set(false));
                                  delay(setDelay);          // Hold door lock open for given seconds
                                  digitalWrite(relay, HIGH);    // Relock door
                                  send(lockMsg.set(true));
                                  delay(1000);            // Hold green LED on for a second
                                void denied() {
                                  digitalWrite(greenLed, LED_OFF);  // Make sure green LED is off
                                  digitalWrite(blueLed, LED_OFF);   // Make sure blue LED is off
                                  digitalWrite(redLed, LED_ON);   // Turn on red LED
                                  delay(1000);
                                uint8_t getID() {
                                  if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
                                    return 0;
                                  if ( ! mfrc522.PICC_ReadCardSerial()) {   //Since a PICC placed get Serial and continue
                                    return 0;
                                  for ( uint8_t i = 0; i < 4; i++) {  //
                                  Serial.println("");
                                  return 1;
                                  if (v == 0x91)
                                  else if (v == 0x92)
                                  Serial.println("");
                                    // Visualize system is halted
                                void cycleLeds() {
                                  digitalWrite(redLed, LED_OFF);  // Make sure red LED is off
                                  digitalWrite(greenLed, LED_ON);   // Make sure green LED is on
                                  delay(200);
                                  digitalWrite(blueLed, LED_ON);  // Make sure blue LED is on
                                  delay(200);
                                  digitalWrite(redLed, LED_ON);   // Make sure red LED is on
                                  delay(200);
                                  digitalWrite(blueLed, LED_ON);  // Blue LED ON and ready to read card
                                  digitalWrite(redLed, LED_OFF);  // Make sure Red LED is off
                                  digitalWrite(greenLed, LED_OFF);  // Make sure Green LED is off
                                  digitalWrite(relay, HIGH);    // Make sure Door is Locked
                                void readID( uint8_t number ) {
                                  uint8_t start = (number * 4 ) + 2;    // Figure out starting position
                                  loadCard(start, storedCard);
                                    uint8_t num = loadState(0);     // Get the numer of used spaces, position 0 stores the number of ID cards
                                    uint8_t start = ( num * 4 ) + 6;  // Figure out where the next slot starts
                                    saveState( 0, num );     // Write the new count to the counter
                                    //for ( uint8_t j = 0; j < 4; j++ ) {   // Loop 4 times
                                    //  saveState( start + j, a[j] );  // Write the array values to EEPROM in the right position
                                    saveCard(start, a);
                                    successWrite();
                                  else {
                                    failedWrite();
                                  else {
                                    uint8_t slot;       // Figure out the slot number of the card
                                    uint8_t start;      // = ( num * 4 ) + 6; // Figure out where the next slot starts
                                    uint8_t looping;    // The number of times the loop repeats
                                    uint8_t j;
                                    uint8_t count = loadState(0); // Read the first Byte of EEPROM that stores number of cards
                                      saveState( start + j, loadState(start + 4 + j));   // Shift the array values to 4 places earlier in the EEPROM
                                    for ( uint8_t k = 0; k < 4; k++ ) {         // Shifting loop
                                      saveState( start + j + k, 0);
                                    successDelete();
                                bool checkTwo ( byte a[], byte b[] ) {
                                  for ( uint8_t k = 0; k < 4; k++ ) {   // Loop 4 times
                                    if ( a[k] != b[k] ) {     // IF a != b then false, because: one fails, all fail
                                       return false;
                                  return true;
                                uint8_t findIDSLOT( byte find[] ) {
                                  for ( uint8_t i = 1; i <= count; i++ ) {    // Loop once for each EEPROM entry
                                bool findID( byte find[] ) {
                                    if ( checkTwo( find, storedCard ) )    // Check to see if the storedCard read from EEPROM
                                      return true;
                                  return false;
                                  digitalWrite(greenLed, LED_OFF);  // Make sure green LED is on
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                bool isMaster( byte test[] ) {
                                  return checkTwo(test, masterCard);
                                bool monitorWipeButton(uint32_t interval) {
                                  uint32_t now = (uint32_t)millis();
                                  while ((uint32_t)millis() - now < interval)  {
                                    // check on every half a second
                                    if (((uint32_t)millis() % 500) == 0) {
                                      if (digitalRead(wipeB) != LOW)
                                        return false;
                                  return true;
                                void saveCard(uint8_t startPos, byte *card) {
                                    saveState( startPos + j, card[j] );  // Write scanned PICC's UID to EEPROM, start from address 3
                                void loadCard(uint8_t startPos, byte *card) {
                                  for ( uint8_t i = 0; i < 4; i++ )    // Read Card's UID from EEPROM
                                    card[i] = loadState(startPos + i);    // Write it to the card
                                void checkWipe() {
                                  //Wipe Code - If the Button (wipeB) Pressed while setup run (powered on) it wipes EEPROM
                                  if (digitalRead(wipeB) == LOW) {  // when button pressed pin should get low, button connected to ground
                                    digitalWrite(redLed, LED_ON); // Red Led stays on to inform user we are going to wipe
                                    Serial.println(F("Wipe Button Pressed"));
                                    Serial.println(F("You have 10 seconds to Cancel"));
                                    Serial.println(F("This will be remove all records and cannot be undone"));
                                    bool buttonState = monitorWipeButton(10000); // Give user enough time to cancel operation
                                    if (buttonState == true && digitalRead(wipeB) == LOW) {    // If button still be pressed, wipe EEPROM
                                      Serial.println(F("Starting Wiping EEPROM"));
                                       Serial.println(F("Starting Wiping"));
                                      saveState(0, 0 );     // light wipe. only erase number
                                      saveState(1, 0);      // light wipe. only erase magic number
                                      Serial.println(F("EEPROM Successfully Wiped"));
                                      digitalWrite(redLed, LED_OFF);  // visualize a successful wipe
                                      delay(200);
                                      delay(200);
                                      delay(200);
                                      delay(200);
                                    else {
                                      Serial.println(F("Wiping Cancelled")); // Show some feedback that the wipe button did not pressed for 15 seconds
                                  if (message.type == V_LOCK_STATUS) {
                                    // Change relay state
                                      if (!message.getBool()) {
                                      granted(300);
                                need advise, thanks
                                regards
                                • E
                                  E
                                  evb
                                  @mfalkvidd, should this not be better receive it's own topic?
                                  @Ispandy, does your node receives the message from openhab?
                                  Change the code in the receive method to be able to serial print debug messages. Maybe openhab is not using the correction message type...
                                  IspandyI 1 Reply Last reply
                                  • E evb
                                    IspandyI
                                    IspandyI
                                    Ispandy
                                    @evb, thank you for the reply
                                    In that sketch above the node doesn't receive message from openhab, but the other node using same message type "message.type == V_LOCK_STATUS" it does receive message from openhab.
                                    E 1 Reply Last reply
                                    • IspandyI Ispandy
                                      E
                                      E
                                      evb
                                      @Ispandy are you now speaking about 2 nodes?
                                      Did you add serial prints to be sure you don't receive anything. May you receive messages but not of the type V_LOCK_STATUS.
                                      You should explain more in detail how your setup is done, because for me it isn't clear
                                      • E evb
                                        IspandyI
                                        IspandyI
                                        Ispandy
                                        @evb yes i have 2 nodes (node 3 and node 50) all with MRFC522 right now, the node 3 is working perfectly but i dont like add and remove card system, I just want to change the part of the RFID sketch on node 3 using the sketch above, so i make one node for test (node 50) and put the code
                                        and
                                        to this
                                        and i add this to node 50
                                              granted(300);
                                            Serial.print(F("Lock status: "));
                                              Serial.print(F("Incoming msg type: "));
                                              Serial.print(message.type);
                                              Serial.print(F(" id: "));
                                              Serial.print(F(" content: "));
                                        nothing happen...
                                        sketch Node 3
                                        // Enable debug prints
                                        #define MY_NODE_ID 3
                                        //#define MY_RF24_CHANNEL  10
                                        #define RF_INIT_DELAY   125
                                        #define ONE_SEC         1000
                                        #define PROG_WAIT       10
                                        #define HEARTBEAT       10
                                        #define BAUD            115200
                                        /*Pin definitions*/
                                        #define LED_PIN         4
                                        #define GARAGEPIN       2
                                        #define SWITCH_PIN      3
                                        #define RST_PIN   7   //  MFRC
                                        #define SS_PIN    8   //  MFRC
                                        MFRC522::Uid olduid;
                                        MFRC522::Uid masterkey = { 4,{ 0xEF,0xDB,0x8E,0x79 },0 };
                                        void       ShowCardData(MFRC522::Uid* uid);
                                        bool       sameUid(MFRC522::Uid* old, MFRC522::Uid* check);
                                        void       copyUid(MFRC522::Uid* src, MFRC522::Uid* dest);
                                        bool       isValidCard(MFRC522::Uid* uid);
                                        int        releasecnt = 0;
                                        //#define    CHILD_ID_ALARM    2
                                        #define    CHILD_ID_LOCK     1
                                        Bounce     debouncer = Bounce();
                                        int        oldSwitchValue = -1;
                                        int        switchValue = 0;
                                        long       timer = -1;
                                        bool       programmode = false;
                                        bool       ledon;
                                        int        programTimer = 0;
                                        bool       armed = true;
                                        unsigned long lastTime = 0;
                                        MyMessage  lockMsg(CHILD_ID_LOCK, V_LOCK_STATUS);
                                        //MyMessage  lockArmMsg(CHILD_ID_ALARM, V_ARMED);
                                        //MyMessage  wrongMsg(CHILD_ID_ALARM, V_TRIPPED);
                                        void before() {
                                          sendSketchInfo("RFID Garage", "1.1"); delay(RF_INIT_DELAY);
                                          present(CHILD_ID_LOCK, S_LOCK);      delay(RF_INIT_DELAY);
                                          //present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);
                                          Serial.begin(BAUD);   // Initialize serial communications with the PC
                                          pinMode(GARAGEPIN, OUTPUT);     // Initialise in/output ports
                                                          // Make sure MFRC will be disabled on the SPI bus
                                          /*pinMode(RST_PIN, OUTPUT);
                                          digitalWrite(SS_PIN, LOW);*/
                                          pinMode(LED_PIN, OUTPUT);
                                          digitalWrite(LED_PIN, LOW);
                                          // Setup the button
                                          pinMode(SWITCH_PIN, INPUT);
                                          // Activate internal pull-up
                                          digitalWrite(SWITCH_PIN, HIGH);
                                          debouncer.attach(SWITCH_PIN);
                                          debouncer.interval(5);
                                          // Init mysensors library
                                          /*sendSketchInfo("RFID Garage", "1.1"); delay(RF_INIT_DELAY);
                                          present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);*/
                                          recallEeprom();
                                          // Init MFRC RFID sensor
                                          SPI.begin();      // Init SPI bus
                                          mfrc522.PCD_Init();   // Init MFRC522
                                          //send(lockArmMsg.set(armed));
                                          Serial.println(F("Init done..."));
                                          timer++;
                                          delay(HEARTBEAT);
                                          debouncer.update();
                                          // Get the update value
                                          int switchValue = debouncer.read();
                                          if (switchValue != oldSwitchValue) {
                                            // Send in the new value
                                            Serial.print(F("Switch "));
                                            Serial.println(switchValue);
                                            if (switchValue && programmode) {
                                              lastTime = millis() / 1000;
                                            if (!switchValue && programmode && lastTime > 0) {
                                              if ((millis() / 1000) - lastTime > 3) {
                                                Serial.println(F("Reset all cards"));
                                                blinkFast(50);
                                              else {
                                                Serial.println(F("Program off"));
                                                storeEeprom();
                                            if (!switchValue) {
                                              programTimer = 0;
                                            oldSwitchValue = switchValue;
                                          if (programmode && ((timer % (ONE_SEC / HEARTBEAT)) == 0)) {
                                            ledon = !ledon;
                                            digitalWrite(LED_PIN, ledon);
                                            programTimer++;
                                            // Stop program mode after 20 sec inactivity
                                            if (programTimer > PROG_WAIT) {
                                              digitalWrite(LED_PIN, false);
                                              Serial.println(F("Program expired"));
                                          if ((timer % (200 / HEARTBEAT)) == 0) {
                                            // Look for new cards
                                            if (!mfrc522.PICC_IsNewCardPresent()) {
                                              if (releasecnt > 0) {
                                                releasecnt--;
                                                if (!releasecnt) {
                                                  olduid.size = 0;
                                                  Serial.println(F("release"));
                                              return;
                                            releasecnt = 5;
                                            // Select one of the cards
                                            if (!mfrc522.PICC_ReadCardSerial()) {
                                              return;
                                            // Dump debug info about the card; PICC_HaltA() is automatically called
                                            //mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
                                            if (!olduid.size || !sameUid(&(mfrc522.uid), &olduid)) {
                                              ShowCardData(&(mfrc522.uid));
                                              copyUid(&(mfrc522.uid), &olduid);
                                              if (isValidCard(&olduid)) {
                                                OpenDoor(false);
                                              else {
                                                if (sameUid(&(mfrc522.uid), &masterkey)) {
                                                  // Only switch in program mode when mastercard is found AND the program button is pressed
                                                  if (switchValue) {
                                                    Serial.println(F("Program mode"));
                                                    programmode = true;
                                                    programTimer = 0;
                                                    lastTime = 0;
                                                else {
                                                  if (programmode) {
                                                    Serial.println(F("new card"));
                                                    programTimer = 0;
                                                    if (countValidCards < MAX_CARDS)
                                                      // Add card to list...
                                                      copyUid(&(mfrc522.uid), &validCards[countValidCards]);
                                                      countValidCards++;
                                                      blinkFast(15);
                                                  else {
                                                    Serial.println(F("Invalid card"));
                                                    //if (armed) {
                                                     // send(wrongMsg.set(1));
                                                     // delay(2000);
                                                      //send(wrongMsg.set(0));
                                        void ShowCardData(MFRC522::Uid* uid) {
                                          Serial.print(F("Card UID:"));
                                          for (byte i = 0; i < uid->size; i++) {
                                            if (uid->uidByte[i] < 0x10) {
                                              Serial.print(F(" 0"));
                                            else {
                                              Serial.print(F(" "));
                                            Serial.print(uid->uidByte[i], HEX);
                                          Serial.println();
                                          dest->size = src->size;
                                          dest->sak = src->sak;
                                          for (byte i = 0; i < src->size; i++) {
                                            dest->uidByte[i] = src->uidByte[i];
                                          if (old->size != check->size) {
                                            return false;
                                          for (byte i = 0; i < old->size; i++) {
                                            if (old->uidByte[i] != check->uidByte[i]) {
                                              return false;
                                          return true;
                                          for (byte i = 0; i < countValidCards; i++) {
                                            if (validCards[i].size != uid->size) {
                                            for (int j = 0; j < uid->size; j++) {
                                              if (validCards[i].uidByte[j] != uid->uidByte[j]) {
                                              if (j == (uid->size - 1)) {
                                                return true;
                                          return false;
                                        void storeEeprom()
                                          byte address = 0;
                                          saveState(address++, countValidCards);
                                            saveState(address++, validCards[i].size);
                                            for (byte j = 0; j < 10; j++) {
                                              saveState(address++, validCards[i].uidByte[j]);
                                        void recallEeprom()
                                          byte address = 0;
                                          countValidCards = loadState(address++);
                                          if (countValidCards > MAX_CARDS) {
                                            Serial.println(F("Not a valid EEPROM reading set to default"));
                                            storeEeprom();
                                            return;
                                            validCards[i].size = loadState(address++);
                                              validCards[i].uidByte[j] = loadState(address++);
                                        void blinkFast(int times)
                                          for (int i = 0; i < times; i++) {
                                            ledon = !ledon;
                                            delay(100);
                                        void OpenDoor(bool fakeOpen)
                                          Serial.println(F("Open door!"));
                                          if (!fakeOpen) {
                                            digitalWrite(LED_PIN, HIGH);
                                            digitalWrite(GARAGEPIN, HIGH);
                                          delay(1000);
                                          if (!fakeOpen) {
                                            digitalWrite(GARAGEPIN, LOW);
                                          if (v == 0x91) {
                                          else if (v == 0x92) {
                                          else {
                                            Serial.print(F(" (unknown)"));
                                          Serial.println("");
                                              OpenDoor(false);
                                          /*else
                                            if (message.type == V_ARMED) {
                                              armed = message.getBool();
                                              Serial.print(F("Arm status: "));
                                        I'm not good at programming that's why I'm asking for help:expressionless: :expressionless:
                                        • IspandyI Ispandy
                                          and
                                          to this
                                                granted(300);
                                          nothing happen...
                                          sketch Node 3
                                          #define BAUD            115200
                                          /*Pin definitions*/
                                          #define LED_PIN         4
                                          #define GARAGEPIN       2
                                          int        releasecnt = 0;
                                          long       timer = -1;
                                          bool       ledon;
                                          bool       armed = true;
                                          void before() {
                                            // Setup the button
                                            recallEeprom();
                                            timer++;
                                            delay(HEARTBEAT);
                                            debouncer.update();
                                                  blinkFast(50);
                                                else {
                                                  storeEeprom();
                                              if (!switchValue) {
                                                programTimer = 0;
                                              ledon = !ledon;
                                              programTimer++;
                                                  releasecnt--;
                                                  if (!releasecnt) {
                                                    olduid.size = 0;
                                                return;
                                              releasecnt = 5;
                                                return;
                                                  OpenDoor(false);
                                                else {
                                                    if (switchValue) {
                                                      programmode = true;
                                                      programTimer = 0;
                                                      lastTime = 0;
                                                  else {
                                                    if (programmode) {
                                                      programTimer = 0;
                                                        countValidCards++;
                                                        blinkFast(15);
                                                    else {
                                                      //if (armed) {
                                                       // delay(2000);
                                              else {
                                            Serial.println();
                                              return false;
                                                return false;
                                            return true;
                                                  return true;
                                            return false;
                                          void storeEeprom()
                                            byte address = 0;
                                          void recallEeprom()
                                            byte address = 0;
                                              storeEeprom();
                                              return;
                                              ledon = !ledon;
                                              delay(100);
                                            if (!fakeOpen) {
                                            delay(1000);
                                            if (!fakeOpen) {
                                            if (v == 0x91) {
                                            else {
                                            Serial.println("");
                                                OpenDoor(false);
                                            /*else
                                          E
                                          E
                                          evb
                                          @Ispandy what happens if you download the same sketch from the working node 3 tot your new node 50?
                                          Adapt of course the node-id!
                                          If it works we can exclude a hardware problem, then it must be a software problem.
                                          In that last case, we can check your sketch more deeply.
                                          12.5k
