  3. RFID and NRF24L01 Wireless Network Coding Issues
23 Posts 8 Posters 12.4k Views 8 Watching
  • martinsM
    martinsM
    martins
    Found the solution in this thread:
    https://forum.mysensors.org/topic/2439/rfid-garage-door-opener/35
    void before() {
    // Make sure MFRC is disabled from the SPI bus
    pinMode(RST_PIN, OUTPUT);
    digitalWrite(RST_PIN, LOW);
    pinMode(SS_PIN, OUTPUT);
    digitalWrite(SS_PIN, LOW);
    gohanG 1 Reply Last reply
    • rejoe2R
      rejoe2R
      rejoe2
      At least in some first test I got a second SPI device (MCP4131) on the same wires working using the before() instruction.
      int CS1 = 10; //MCP4131
      void before() {
        pinMode (CS1, OUTPUT);
      digitalWrite(CS1, HIGH);
      Another option may be to use SoftSPI for thenRF (see Network-Gateway-sketch).
      • martinsM martins
        void before() {
        @martins
        Is it working for you?
        martinsM 1 Reply Last reply
          @martins
          martinsM
          martinsM
          martins
          @gohan Yes
            I can't figure out what is wrong with mine
              martinsM
              martinsM
              martins
              @gohan What is the serial output or error that you get ?
                just look at the garage door opener link you posted, there is log and code. If I unplug the radio and use some demo code to read the rfid tag I can read it, but I can't find where it conflicts with the radio
                  martinsM
                  martinsM
                  martins
                  wrote on last edited by gohan
                  @gohan This is the code that works for me on my pro mini. Try it out.
                  Here is my pins used:
                  MOSI: Pin 11
                  MISO: Pin 12
                  SCK : Pin 13
                  SS : Pin 8 (Configurable)
                  RST : Pin 6 (Configurable)
                    Arduino RFID Access Control
                    Security !
                    To keep it simple we are going to use Tag's Unique IDs
                    as only method of Authenticity. It's simple and not hacker proof.
                    If you need security, don't use it unless you modify the code
                    Copyright (C) 2015 Omer Siar Baysal
                    This program is free software; you can redistribute it and/or modify
                    it under the terms of the GNU General Public License as published by
                    the Free Software Foundation; either version 2 of the License, or
                    (at your option) any later version.
                    This program is distributed in the hope that it will be useful,
                    but WITHOUT ANY WARRANTY; without even the implied warranty of
                    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
                    GNU General Public License for more details.
                    You should have received a copy of the GNU General Public License along
                    with this program; if not, write to the Free Software Foundation, Inc.,
                    51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
                  //#define MY_RFM69_FREQUENCY RF69_433MHZ
                  //#define MY_IS_RFM69HW
                  #if F_CPU == 8000000L
                  #define MY_BAUD_RATE 38400
                  #define CHILD_ID 8
                  #define MAX_CARDS       18
                  #include <EEPROM.h>     // We are going to read and write PICC's UIDs from/to EEPROM
                  #include <SPI.h>        // RC522 Module uses SPI protocol
                  #include <MFRC522.h>	// Library for Mifare RC522 Devices
                  	For visualizing whats going on hardware
                  	we need some leds and
                  	to control door lock a relay and a wipe button
                  	(or some other hardware)
                  	Used common anode led,digitalWriting HIGH turns OFF led
                  	Mind that if you are going to use common cathode led or
                  	just seperate leds, simply comment out #define COMMON_ANODE,
                  int value=0;
                  boolean match = false;          // initialize card match to false
                  boolean programMode = false;	// initialize programming mode to false
                  boolean replaceMaster = false;
                  int successRead;		// Variable integer to keep if we have Successful Read from Reader
                  byte storedCard[4];		// Stores an ID read from EEPROM
                  byte readCard[4];		// Stores scanned ID read from RFID Module
                  byte masterCard[4];		// Stores master card's ID read from EEPROM
                  byte countValidCards = 0;
                  	We need to define MFRC522's pins and create instance
                  	Pin layout should be as follows (on Arduino Uno):
                  	MOSI: Pin 11 / ICSP-4
                  	MISO: Pin 12 / ICSP-1
                  	SCK : Pin 13 / ICSP-3
                  	SS : Pin 10 (8)(Configurable)
                  	RST : Pin 9 (6)(Configurable)
                  	look MFRC522 Library for
                  	other Arduinos' pin configuration
                  // bool lockStatus;
                  #define SS_PIN 8
                  #define RST_PIN 6
                  MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance.
                  // MFRC522::Uid validCards[MAX_CARDS];
                  //MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
                  // MFRC522 mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance.
                  ///////////////////////////////////////// Setup ///////////////////////////////////
                    //Protocol Configuration
                    //Serial.begin(9600);	 // Initialize serial communications with PC
                    SPI.begin();           // MFRC522 Hardware uses SPI protocol
                    mfrc522.PCD_Init();    // Initialize MFRC522 Hardware
                    //If you set Antenna Gain to Max it will increase reading distance
                    //mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max);
                    Serial.println(F("Access Control v3.4"));   // For debugging purposes
                    ShowReaderDetails();	// Show details of PCD - MFRC522 Card Reader details
                    if (EEPROM.read(500) != 143) {
                      Serial.println(F("No Master Card Defined"));
                      Serial.println(F("Scan A PICC to Define as Master Card"));
                      do {
                        successRead = getID();            // sets successRead to 1 when we get read from reader otherwise 0
                      while (!successRead);                  // Program will not go further while you not get a successful read
                  //    printHex(mfrc522.uid.uidByte, mfrc522.uid.size);
                      for ( int j = 0; j < 4; j++ ) {        // Loop 4 times
                        EEPROM.write( 2 + j, readCard[j] );  // Write scanned PICC's UID to EEPROM, start from address 3
                      EEPROM.write(500, 143);                  // Write to EEPROM we defined Master Card.
                      delay(500);
                      Serial.println(F("Master Card Defined"));
                  //    storeEeprom();
                    Serial.println(F("-------------------"));
                    Serial.println(F("Master Card's UID"));
                    for ( int i = 0; i < 4; i++ ) {          // Read Master Card's UID from EEPROM
                      masterCard[i] = EEPROM.read(2 + i);    // Write it to masterCard
                      Serial.print(masterCard[i], HEX);
                    Serial.println("");
                    Serial.println(F("Everything Ready"));
                    Serial.println(F("Waiting PICCs to be scanned"));
                    Serial.println(EEPROM.read(500));
                    sendSketchInfo("RFID Gate", "1.0");
                    present(CHILD_ID, S_DOOR);
                  ///////////////////////////////////////// Main Loop ///////////////////////////////////
                  void loop () {
                    send(msg.set(value==HIGH ? 1 : 0));
                    do {
                    while (!successRead); 	//the program will not go further while you not get a successful read
                    if (programMode) {
                      if ( isMaster(readCard) ) { //If master card scanned again exit program mode
                        Serial.println(F("Master Card Scanned"));
                        Serial.println(F("Exiting Program Mode"));
                        Serial.println(F("-----------------------------"));
                        return;
                      else {
                        if ( findID(readCard) ) { // If scanned card is known delete it
                          Serial.println(F("I know this PICC, removing..."));
                          deleteID(readCard);
                          Serial.println("-----------------------------");
                          Serial.println(F("Scan a PICC to ADD or REMOVE to EEPROM"));
                        else {                    // If scanned card is not known add it
                          Serial.println(F("I do not know this PICC, adding..."));
                          writeID(readCard);
                    else {
                      if ( isMaster(readCard)) {  	// If scanned card's ID matches Master Card's ID enter program mode
                        programMode = true;
                        Serial.println(F("Hello Master - Entered Program Mode"));
                        int count = EEPROM.read(0); 	// Read the first Byte of EEPROM that
                        Serial.print(F("I have "));    	// stores the number of ID's in EEPROM
                        Serial.print(count);
                        Serial.print(F(" record(s) on EEPROM"));
                        Serial.println("");
                        Serial.println(F("Scan Master Card again to Exit Program Mode"));
                      else {
                        if ( findID(readCard) ) {	// If not, see if the card is in the EEPROM
                          Serial.println(F("Welcome, You shall pass"));
                          granted(300);        	// Open the door lock for 300 ms
                        else {			// If not, show that the ID was not valid
                          Serial.println(F("You shall not pass"));
                          denied();
                  /////////////////////////////////////////  Access Granted    ///////////////////////////////////
                  void granted (int setDelay) {
                    // setLockState(!lockStatus, true);
                    value = 1;
                    smartSleep(5000);
                    value = 0;
                  ///////////////////////////////////////// Access Denied  ///////////////////////////////////
                  void denied() {
                  ///////////////////////////////////////// Get PICC's UID ///////////////////////////////////
                  int getID() {
                    // Getting ready for Reading PICCs
                      if ( ! mfrc522.PICC_IsNewCardPresent())
                      return 0;
                    // Verify if the NUID has been readed
                    if ( ! mfrc522.PICC_ReadCardSerial())
                      return 0;
                    Serial.print(F("PICC type: "));
                    MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
                    Serial.println(mfrc522.PICC_GetTypeName(piccType));
                    // Check is the PICC of Classic MIFARE type
                    if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&  piccType != MFRC522::PICC_TYPE_MIFARE_1K && piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
                      Serial.println(F("Your tag is not of type MIFARE Classic."));
                      return;
                    Serial.println(F("Scanned PICC's UID:"));
                    for (int i = 0; i < 4; i++) {  //
                      readCard[i] = mfrc522.uid.uidByte[i];
                      Serial.print(readCard[i], HEX);
                    Serial.println("");
                    mfrc522.PICC_HaltA();
                    return 1;
                  /*  while (! mfrc522.PICC_IsNewCardPresent())
                    { //If a new PICC placed to RFID reader continue
                      Serial.println("No NCP");
                      return 0;
                    {   //Since a PICC placed get Serial and continue
                      Serial.println("RCS");
                      return 0;
                    // There are Mifare PICCs which have 4 byte or 7 byte UID care if you use 7 byte PICC
                    // I think we should assume every PICC as they have 4 byte UID
                    // Until we support 7 byte PICCs
                    Serial.println("");
                    mfrc522.PICC_HaltA(); // Stop reading
                    return 1;
                  void ShowReaderDetails() {
                    // Get the MFRC522 software version
                    byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
                    Serial.print(F("MFRC522 Software Version: 0x"));
                    Serial.print(v, HEX);
                    if (v == 0x91)
                      Serial.print(F(" = v1.0"));
                    else if (v == 0x92)
                      Serial.print(F(" = v2.0"));
                      Serial.print(F(" (unknown),probably a chinese clone?"));
                    Serial.println("");
                    // When 0x00 or 0xFF is returned, communication probably failed
                    if ((v == 0x00) || (v == 0xFF)) {
                      Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
                      Serial.println(F("SYSTEM HALTED: Check connections."));
                      while (true); // do not go further
                  ///////////////////////////////////////// Cycle Leds (Program Mode) ///////////////////////////////////
                  void cycleLeds() {
                  //////////////////////////////////////// Normal Mode Led  ///////////////////////////////////
                  void normalModeOn () {
                  //////////////////////////////////////// Read an ID from EEPROM //////////////////////////////
                  void readID( int number ) {
                    int start = (number * 4 ) + 2; 		// Figure out starting position
                    for ( int i = 0; i < 4; i++ ) { 		// Loop 4 times to get the 4 Bytes
                      storedCard[i] = EEPROM.read(start + i); 	// Assign values read from EEPROM to array
                  ///////////////////////////////////////// Add ID to EEPROM   ///////////////////////////////////
                  void writeID( byte a[] ) {
                    if ( !findID( a ) ) { 		// Before we write to the EEPROM, check to see if we have seen this card before!
                      int num = EEPROM.read(0); 		// Get the numer of used spaces, position 0 stores the number of ID cards
                      int start = ( num * 4 ) + 6; 	// Figure out where the next slot starts
                      num++; 								// Increment the counter by one
                      EEPROM.write( 0, num ); 		// Write the new count to the counter
                        EEPROM.write( start + j, a[j] ); 	// Write the array values to EEPROM in the right position
                      successWrite();
                      Serial.println(F("Succesfully added ID record to EEPROM"));
                    else {
                      failedWrite();
                      Serial.println(F("Failed! There is something wrong with ID or bad EEPROM"));
                  ///////////////////////////////////////// Remove ID from EEPROM   ///////////////////////////////////
                  void deleteID( byte a[] ) {
                    if ( !findID( a ) ) { 		// Before we delete from the EEPROM, check to see if we have this card!
                      failedWrite(); 			// If not
                    else {
                      int slot; 			// Figure out the slot number of the card
                      int start;			// = ( num * 4 ) + 6; // Figure out where the next slot starts
                      int looping; 		// The number of times the loop repeats
                      int j;
                      int count = EEPROM.read(0); // Read the first Byte of EEPROM that stores number of cards
                      slot = findIDSLOT( a ); 	// Figure out the slot number of the card to delete
                      start = (slot * 4) + 2;
                      looping = ((num - slot) * 4);
                      num--; 			// Decrement the counter by one
                      for ( j = 0; j < looping; j++ ) { 				// Loop the card shift times
                        EEPROM.write( start + j, EEPROM.read(start + 4 + j)); 	// Shift the array values to 4 places earlier in the EEPROM
                      for ( int k = 0; k < 4; k++ ) { 				// Shifting loop
                        EEPROM.write( start + j + k, 0);
                      successDelete();
                      Serial.println(F("Succesfully removed ID record from EEPROM"));
                  ///////////////////////////////////////// Check Bytes   ///////////////////////////////////
                  boolean checkTwo ( byte a[], byte b[] ) {
                    if ( a[0] != NULL ) 			// Make sure there is something in the array first
                      match = true; 			// Assume they match at first
                    for ( int k = 0; k < 4; k++ ) { 	// Loop 4 times
                      if ( a[k] != b[k] ) 		// IF a != b then set match = false, one fails, all fail
                        match = false;
                    if ( match ) { 			// Check to see if if match is still true
                      return true; 			// Return true
                    else  {
                      return false; 			// Return false
                  ///////////////////////////////////////// Find Slot   ///////////////////////////////////
                  int findIDSLOT( byte find[] ) {
                    for ( int i = 1; i <= count; i++ ) { 		// Loop once for each EEPROM entry
                      readID(i); 								// Read an ID from EEPROM, it is stored in storedCard[4]
                      if ( checkTwo( find, storedCard ) ) { 	// Check to see if the storedCard read from EEPROM
                        // is the same as the find[] ID card passed
                        return i; 				// The slot number of the card
                        break; 					// Stop looking we found it
                  ///////////////////////////////////////// Find ID From EEPROM   ///////////////////////////////////
                  boolean findID( byte find[] ) {
                        return true;
                      else {  	// If not, return false
                    return false;
                  ///////////////////////////////////////// Write Success to EEPROM   ///////////////////////////////////
                  // Flashes the green LED 3 times to indicate a successful write to EEPROM
                  void successWrite() {
                  ///////////////////////////////////////// Write Failed to EEPROM   ///////////////////////////////////
                  // Flashes the red LED 3 times to indicate a failed write to EEPROM
                  void failedWrite() {
                  ///////////////////////////////////////// Success Remove UID From EEPROM  ///////////////////////////////////
                  // Flashes the blue LED 3 times to indicate a success delete to EEPROM
                  void successDelete() {
                  ////////////////////// Check readCard IF is masterCard   ///////////////////////////////////
                  // Check to see if the ID passed is the master programing card
                  boolean isMaster( byte test[] ) {
                    if ( checkTwo( test, masterCard ) )
                      return true;
                      return false;
                   * Helper routine to dump a byte array as hex values to Serial.
                  void printHex(byte *buffer, byte bufferSize) {
                    for (byte i = 0; i < bufferSize; i++) {
                      Serial.print(buffer[i] < 0x10 ? " 0" : " ");
                      Serial.print(buffer[i], HEX);
                  //void presentation()  {
                  //  sendSketchInfo("RFID Lock", "1.0");
                  //  present(CHILD_ID, S_LOCK);
                  void before() {
                    Tnx, I'll try in the next days.
                    Ps I edited your post with the correct tag for the code
                    • Aron SjöbergA
                      Aron SjöbergA
                      Aron Sjöberg
                      Help!
                      I have a RFID RC522 module I'm trying to use instead of the PN532 NFC RFID Reader/Writer Module used in the RFID Lock Sensor example (https://www.mysensors.org/build/rfid).
                      I thought I could use the sketch above posted by @martins but I get the following error message. I'm a newbie so I don't really know what I'm doing wrong?
                      Arduino: 1.8.1 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
                      C:\Users\arons\Documents\Arduino\Vera_RFID-RC522\Vera_RFID-RC522.ino: In function 'int getID()':
                      Vera_RFID-RC522:259: error: return-statement with no value, in function returning 'int' [-fpermissive]
                           return;
                      exit status 1
                      • Aron SjöbergA Aron Sjöberg
                        Help!
                             return;
                        exit status 1
                        martinsM
                        martinsM
                        martins
                        @Aron-Sjöberg said in RFID and NRF24L01 Wireless Network Coding Issues:
                        int getID()
                        Change that line in the getID() function to return 0;
                        PlantexP 1 Reply Last reply
                        • martinsM martins
                          int getID()
                          PlantexP
                          PlantexP
                          Plantex
                          @martins
                          Could You please explain what do You mean by "Change that line in the getID() function to return 0;"
                          I am trying to run the sketch but I have the same problem as @Aron-Sjöberg.
                          Could You let me know which MFC library version I should use ?
                          • IspandyI
                            IspandyI
                            Ispandy
                            Hi everyone,
                            I have problem on RFID sketch, when i scan the card its unlock the door but when i switch from openhab its not unlock.
                            the sketch is
                               Example sketch/program showing An Arduino Door Access Control featuring RFID, EEPROM, Relay
                               This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
                               This example showing a complete Door Access Control System
                              Simple Work Flow (not limited to) :
                              +----------------------------------->READ TAGS+^------------------------------------------+
                              |                         +----v-----+        +-----v----+                                |
                              |                         |MASTER TAG|        |OTHER TAGS|                                |
                              |                      +-----v---+        +----v----+   +----v------+                     |
                              |         +------------+READ TAGS+---+    |KNOWN TAG|   |UNKNOWN TAG|                     |
                              |    +----v-----+   +----v----+   +--v--------+     +-v----------+  +------v----+         |
                              |    |MASTER TAG|   |KNOWN TAG|   |UNKNOWN TAG|     |GRANT ACCESS|  |DENY ACCESS|         |
                              |       +----+     +----v------+     +--v---+             |               +--------------->
                              +-------+EXIT|     |DELETE FROM|     |ADD TO|             |                               |
                                      +----+     |  EEPROM   |     |EEPROM|             |                               |
                               Use a Master Card which is act as Programmer then you can able to choose card holders who will granted access or not
                             * **Easy User Interface**
                               Just one RFID tag needed whether Delete or Add Tags. You can choose to use Leds for output or Serial LCD module to inform users.
                             * **Stores Information on EEPROM**
                               Information stored on non volatile Arduino's EEPROM memory to preserve Users' tag and Master Card. No Information lost
                               if power lost. EEPROM has unlimited Read cycle but roughly 100,000 limited Write cycle.
                             * **Security**
                               To keep it simple we are going to use Tag's Unique IDs. It's simple and not hacker proof.
                               @license Released into the public domain.
                               Typical pin layout used:
                                           MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
                                           Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
                               Signal      Pin          Pin           Pin       Pin        Pin              Pin
                               RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
                               SPI SS      SDA(SS)      10            53        D10        10               10
                               SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
                               SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
                               SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
                            #define MY_RADIO_RF24
                            #define MY_NODE_ID 50
                              Instead of a Relay you may want to use a servo. Servos can lock and unlock door locks too
                              Relay will be used by default
                            #define RFID 1
                            // #include <Servo.h>
                              For visualizing whats going on hardware we need some leds and to control door lock a relay and a wipe button
                              (or some other hardware) Used common anode led,digitalWriting HIGH turns OFF led Mind that if you are going
                              to use common cathode led or just seperate leds, simply comment out #define COMMON_ANODE,
                            //#define COMMON_ANODE
                            #ifdef COMMON_ANODE
                            #define LED_ON LOW
                            #define LED_OFF HIGH
                            #define LED_ON HIGH
                            #define LED_OFF LOW
                            #define redLed 4    // Set Led Pins
                            #define greenLed 5
                            #define blueLed 6
                            #define relay 2       // Set Relay Pin
                            #define wipeB 3     // Button pin for WipeMode
                            bool programMode = false;  // initialize programming mode to false
                            uint8_t successRead;    // Variable integer to keep if we have Successful Read from Reader
                            byte dumpedCard[4];
                            static const uint8_t MAGIC = 168;
                            #define SS_PIN 8
                            #define RST_PIN 7
                            void before() {
                               //Arduino Pin Configuration
                              pinMode(redLed, OUTPUT);
                              pinMode(greenLed, OUTPUT);
                              pinMode(blueLed, OUTPUT);
                              pinMode(wipeB, INPUT_PULLUP);   // Enable pin's pull up resistor
                              pinMode(relay, OUTPUT);
                              //Be careful how relay circuit behave on while resetting or power-cycling your Arduino
                              digitalWrite(relay, HIGH);    // Make sure door is locked
                              digitalWrite(redLed, LED_OFF);  // Make sure led is off
                              digitalWrite(greenLed, LED_OFF);  // Make sure led is off
                              digitalWrite(blueLed, LED_OFF); // Make sure led is off
                              Serial.begin(115200);  // Initialize serial communications with PC
                               Serial.println(F("Access Control v2.0"));   // For debugging purposes
                              checkWipe();
                              // Check if master card defined, if not let user choose a master card
                              // This also useful to just redefine the Master Card
                              // You can keep other EEPROM records just write other than MAGIC to EEPROM address 1
                              // EEPROM address 1 should hold magical number which is 'MAGIC'
                              if (loadState(1) != MAGIC) {
                                do {
                                  digitalWrite(blueLed, LED_ON);    // Visualize Master Card need to be defined
                                  delay(200);
                                  delay(200);
                                for ( uint8_t j = 0; j < 4; j++ ) {        // Loop 4 times
                                  saveState( 2 + j, readCard[j] );  // Write scanned PICC's UID to EEPROM, start from address 3
                                saveState(1, MAGIC);                  // Write to EEPROM we defined Master Card.
                              for ( uint8_t i = 0; i < 4; i++ ) {          // Read Master Card's UID from EEPROM
                                masterCard[i] = loadState(2 + i);    // Write it to masterCard
                              Serial.println("");
                              Serial.println(F("Everything is ready"));
                              cycleLeds();    // Everything ready lets give user some feedback by cycling leds
                            //////////////////////////////////////// MySensors Presentation ///////////////////////////////
                            MyMessage lockMsg(RFID, V_LOCK_STATUS);
                              sendSketchInfo("RFID PintuBesi", "1.0");
                              present(RFID, S_LOCK);
                            void loop () {
                              do {
                                checkWipe();
                                if (programMode) {
                                  cycleLeds();              // Program Mode cycles through Red Green Blue waiting to read a new card
                                else {
                                  normalModeOn();     // Normal mode, blue Power LED is on, all others are off
                              while (!successRead);   //the program will not go further while you are not getting a successful read
                              if (programMode) {
                                if ( isMaster(readCard) ) { //When in program mode check First If master card scanned again to exit program mode
                                  return;
                                else {
                                    deleteID(readCard);
                                    writeID(readCard);
                              else {
                                if ( isMaster(readCard)) {    // If scanned card's ID matches Master Card's ID - enter program mode
                                  programMode = true;
                                  uint8_t count = loadState(0);   // Read the first Byte of EEPROM that
                                  Serial.println("");
                                else {
                                    denied();
                            void granted ( uint16_t setDelay) {
                              digitalWrite(blueLed, LED_OFF);   // Turn off blue LED
                              digitalWrite(redLed, LED_OFF);  // Turn off red LED
                              digitalWrite(greenLed, LED_ON);   // Turn on green LED
                              digitalWrite(relay, LOW);     // Unlock door!
                              send(lockMsg.set(false));
                              delay(setDelay);          // Hold door lock open for given seconds
                              digitalWrite(relay, HIGH);    // Relock door
                              send(lockMsg.set(true));
                              delay(1000);            // Hold green LED on for a second
                            void denied() {
                              digitalWrite(greenLed, LED_OFF);  // Make sure green LED is off
                              digitalWrite(blueLed, LED_OFF);   // Make sure blue LED is off
                              digitalWrite(redLed, LED_ON);   // Turn on red LED
                              delay(1000);
                            uint8_t getID() {
                              if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
                                return 0;
                              if ( ! mfrc522.PICC_ReadCardSerial()) {   //Since a PICC placed get Serial and continue
                                return 0;
                              for ( uint8_t i = 0; i < 4; i++) {  //
                              Serial.println("");
                              return 1;
                              if (v == 0x91)
                              else if (v == 0x92)
                              Serial.println("");
                                // Visualize system is halted
                            void cycleLeds() {
                              digitalWrite(redLed, LED_OFF);  // Make sure red LED is off
                              digitalWrite(greenLed, LED_ON);   // Make sure green LED is on
                              delay(200);
                              digitalWrite(blueLed, LED_ON);  // Make sure blue LED is on
                              delay(200);
                              digitalWrite(redLed, LED_ON);   // Make sure red LED is on
                              delay(200);
                              digitalWrite(blueLed, LED_ON);  // Blue LED ON and ready to read card
                              digitalWrite(redLed, LED_OFF);  // Make sure Red LED is off
                              digitalWrite(greenLed, LED_OFF);  // Make sure Green LED is off
                              digitalWrite(relay, HIGH);    // Make sure Door is Locked
                            void readID( uint8_t number ) {
                              uint8_t start = (number * 4 ) + 2;    // Figure out starting position
                              loadCard(start, storedCard);
                                uint8_t num = loadState(0);     // Get the numer of used spaces, position 0 stores the number of ID cards
                                uint8_t start = ( num * 4 ) + 6;  // Figure out where the next slot starts
                                saveState( 0, num );     // Write the new count to the counter
                                //for ( uint8_t j = 0; j < 4; j++ ) {   // Loop 4 times
                                //  saveState( start + j, a[j] );  // Write the array values to EEPROM in the right position
                                saveCard(start, a);
                                successWrite();
                              else {
                                failedWrite();
                              else {
                                uint8_t slot;       // Figure out the slot number of the card
                                uint8_t start;      // = ( num * 4 ) + 6; // Figure out where the next slot starts
                                uint8_t looping;    // The number of times the loop repeats
                                uint8_t j;
                                uint8_t count = loadState(0); // Read the first Byte of EEPROM that stores number of cards
                                  saveState( start + j, loadState(start + 4 + j));   // Shift the array values to 4 places earlier in the EEPROM
                                for ( uint8_t k = 0; k < 4; k++ ) {         // Shifting loop
                                  saveState( start + j + k, 0);
                                successDelete();
                            bool checkTwo ( byte a[], byte b[] ) {
                              for ( uint8_t k = 0; k < 4; k++ ) {   // Loop 4 times
                                if ( a[k] != b[k] ) {     // IF a != b then false, because: one fails, all fail
                                   return false;
                              return true;
                            uint8_t findIDSLOT( byte find[] ) {
                              for ( uint8_t i = 1; i <= count; i++ ) {    // Loop once for each EEPROM entry
                            bool findID( byte find[] ) {
                                if ( checkTwo( find, storedCard ) )    // Check to see if the storedCard read from EEPROM
                                  return true;
                              return false;
                              digitalWrite(greenLed, LED_OFF);  // Make sure green LED is on
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                              delay(200);
                            bool isMaster( byte test[] ) {
                              return checkTwo(test, masterCard);
                            bool monitorWipeButton(uint32_t interval) {
                              uint32_t now = (uint32_t)millis();
                              while ((uint32_t)millis() - now < interval)  {
                                // check on every half a second
                                if (((uint32_t)millis() % 500) == 0) {
                                  if (digitalRead(wipeB) != LOW)
                                    return false;
                              return true;
                            void saveCard(uint8_t startPos, byte *card) {
                                saveState( startPos + j, card[j] );  // Write scanned PICC's UID to EEPROM, start from address 3
                            void loadCard(uint8_t startPos, byte *card) {
                              for ( uint8_t i = 0; i < 4; i++ )    // Read Card's UID from EEPROM
                                card[i] = loadState(startPos + i);    // Write it to the card
                            void checkWipe() {
                              //Wipe Code - If the Button (wipeB) Pressed while setup run (powered on) it wipes EEPROM
                              if (digitalRead(wipeB) == LOW) {  // when button pressed pin should get low, button connected to ground
                                digitalWrite(redLed, LED_ON); // Red Led stays on to inform user we are going to wipe
                                Serial.println(F("Wipe Button Pressed"));
                                Serial.println(F("You have 10 seconds to Cancel"));
                                Serial.println(F("This will be remove all records and cannot be undone"));
                                bool buttonState = monitorWipeButton(10000); // Give user enough time to cancel operation
                                if (buttonState == true && digitalRead(wipeB) == LOW) {    // If button still be pressed, wipe EEPROM
                                  Serial.println(F("Starting Wiping EEPROM"));
                                   Serial.println(F("Starting Wiping"));
                                  saveState(0, 0 );     // light wipe. only erase number
                                  saveState(1, 0);      // light wipe. only erase magic number
                                  Serial.println(F("EEPROM Successfully Wiped"));
                                  digitalWrite(redLed, LED_OFF);  // visualize a successful wipe
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                  delay(200);
                                else {
                                  Serial.println(F("Wiping Cancelled")); // Show some feedback that the wipe button did not pressed for 15 seconds
                              if (message.type == V_LOCK_STATUS) {
                                // Change relay state
                                  if (!message.getBool()) {
                                  granted(300);
                            need advise, thanks
                            regards
                            • E
                              E
                              evb
                              @mfalkvidd, should this not be better receive it's own topic?
                              @Ispandy, does your node receives the message from openhab?
                              Change the code in the receive method to be able to serial print debug messages. Maybe openhab is not using the correction message type...
                              IspandyI 1 Reply Last reply
                              • E evb
                                IspandyI
                                IspandyI
                                Ispandy
                                @evb, thank you for the reply
                                In that sketch above the node doesn't receive message from openhab, but the other node using same message type "message.type == V_LOCK_STATUS" it does receive message from openhab.
                                E 1 Reply Last reply
                                • IspandyI Ispandy
                                  E
                                  E
                                  evb
                                  @Ispandy are you now speaking about 2 nodes?
                                  Did you add serial prints to be sure you don't receive anything. May you receive messages but not of the type V_LOCK_STATUS.
                                  You should explain more in detail how your setup is done, because for me it isn't clear
                                  • E evb
                                    IspandyI
                                    IspandyI
                                    Ispandy
                                    @evb yes i have 2 nodes (node 3 and node 50) all with MRFC522 right now, the node 3 is working perfectly but i dont like add and remove card system, I just want to change the part of the RFID sketch on node 3 using the sketch above, so i make one node for test (node 50) and put the code
                                    and
                                    to this
                                    and i add this to node 50
                                          granted(300);
                                        Serial.print(F("Lock status: "));
                                          Serial.print(F("Incoming msg type: "));
                                          Serial.print(message.type);
                                          Serial.print(F(" id: "));
                                          Serial.print(F(" content: "));
                                    nothing happen...
                                    sketch Node 3
                                    // Enable debug prints
                                    #define MY_NODE_ID 3
                                    //#define MY_RF24_CHANNEL  10
                                    #define RF_INIT_DELAY   125
                                    #define ONE_SEC         1000
                                    #define PROG_WAIT       10
                                    #define HEARTBEAT       10
                                    #define BAUD            115200
                                    /*Pin definitions*/
                                    #define LED_PIN         4
                                    #define GARAGEPIN       2
                                    #define SWITCH_PIN      3
                                    #define RST_PIN   7   //  MFRC
                                    #define SS_PIN    8   //  MFRC
                                    MFRC522::Uid olduid;
                                    MFRC522::Uid masterkey = { 4,{ 0xEF,0xDB,0x8E,0x79 },0 };
                                    void       ShowCardData(MFRC522::Uid* uid);
                                    bool       sameUid(MFRC522::Uid* old, MFRC522::Uid* check);
                                    void       copyUid(MFRC522::Uid* src, MFRC522::Uid* dest);
                                    bool       isValidCard(MFRC522::Uid* uid);
                                    int        releasecnt = 0;
                                    //#define    CHILD_ID_ALARM    2
                                    #define    CHILD_ID_LOCK     1
                                    Bounce     debouncer = Bounce();
                                    int        oldSwitchValue = -1;
                                    int        switchValue = 0;
                                    long       timer = -1;
                                    bool       programmode = false;
                                    bool       ledon;
                                    int        programTimer = 0;
                                    bool       armed = true;
                                    unsigned long lastTime = 0;
                                    MyMessage  lockMsg(CHILD_ID_LOCK, V_LOCK_STATUS);
                                    //MyMessage  lockArmMsg(CHILD_ID_ALARM, V_ARMED);
                                    //MyMessage  wrongMsg(CHILD_ID_ALARM, V_TRIPPED);
                                    void before() {
                                      sendSketchInfo("RFID Garage", "1.1"); delay(RF_INIT_DELAY);
                                      present(CHILD_ID_LOCK, S_LOCK);      delay(RF_INIT_DELAY);
                                      //present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);
                                      Serial.begin(BAUD);   // Initialize serial communications with the PC
                                      pinMode(GARAGEPIN, OUTPUT);     // Initialise in/output ports
                                                      // Make sure MFRC will be disabled on the SPI bus
                                      /*pinMode(RST_PIN, OUTPUT);
                                      digitalWrite(SS_PIN, LOW);*/
                                      pinMode(LED_PIN, OUTPUT);
                                      digitalWrite(LED_PIN, LOW);
                                      // Setup the button
                                      pinMode(SWITCH_PIN, INPUT);
                                      // Activate internal pull-up
                                      digitalWrite(SWITCH_PIN, HIGH);
                                      debouncer.attach(SWITCH_PIN);
                                      debouncer.interval(5);
                                      // Init mysensors library
                                      /*sendSketchInfo("RFID Garage", "1.1"); delay(RF_INIT_DELAY);
                                      present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);*/
                                      recallEeprom();
                                      // Init MFRC RFID sensor
                                      SPI.begin();      // Init SPI bus
                                      mfrc522.PCD_Init();   // Init MFRC522
                                      //send(lockArmMsg.set(armed));
                                      Serial.println(F("Init done..."));
                                      timer++;
                                      delay(HEARTBEAT);
                                      debouncer.update();
                                      // Get the update value
                                      int switchValue = debouncer.read();
                                      if (switchValue != oldSwitchValue) {
                                        // Send in the new value
                                        Serial.print(F("Switch "));
                                        Serial.println(switchValue);
                                        if (switchValue && programmode) {
                                          lastTime = millis() / 1000;
                                        if (!switchValue && programmode && lastTime > 0) {
                                          if ((millis() / 1000) - lastTime > 3) {
                                            Serial.println(F("Reset all cards"));
                                            blinkFast(50);
                                          else {
                                            Serial.println(F("Program off"));
                                            storeEeprom();
                                        if (!switchValue) {
                                          programTimer = 0;
                                        oldSwitchValue = switchValue;
                                      if (programmode && ((timer % (ONE_SEC / HEARTBEAT)) == 0)) {
                                        ledon = !ledon;
                                        digitalWrite(LED_PIN, ledon);
                                        programTimer++;
                                        // Stop program mode after 20 sec inactivity
                                        if (programTimer > PROG_WAIT) {
                                          digitalWrite(LED_PIN, false);
                                          Serial.println(F("Program expired"));
                                      if ((timer % (200 / HEARTBEAT)) == 0) {
                                        // Look for new cards
                                        if (!mfrc522.PICC_IsNewCardPresent()) {
                                          if (releasecnt > 0) {
                                            releasecnt--;
                                            if (!releasecnt) {
                                              olduid.size = 0;
                                              Serial.println(F("release"));
                                          return;
                                        releasecnt = 5;
                                        // Select one of the cards
                                        if (!mfrc522.PICC_ReadCardSerial()) {
                                          return;
                                        // Dump debug info about the card; PICC_HaltA() is automatically called
                                        //mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
                                        if (!olduid.size || !sameUid(&(mfrc522.uid), &olduid)) {
                                          ShowCardData(&(mfrc522.uid));
                                          copyUid(&(mfrc522.uid), &olduid);
                                          if (isValidCard(&olduid)) {
                                            OpenDoor(false);
                                          else {
                                            if (sameUid(&(mfrc522.uid), &masterkey)) {
                                              // Only switch in program mode when mastercard is found AND the program button is pressed
                                              if (switchValue) {
                                                Serial.println(F("Program mode"));
                                                programmode = true;
                                                programTimer = 0;
                                                lastTime = 0;
                                            else {
                                              if (programmode) {
                                                Serial.println(F("new card"));
                                                programTimer = 0;
                                                if (countValidCards < MAX_CARDS)
                                                  // Add card to list...
                                                  copyUid(&(mfrc522.uid), &validCards[countValidCards]);
                                                  countValidCards++;
                                                  blinkFast(15);
                                              else {
                                                Serial.println(F("Invalid card"));
                                                //if (armed) {
                                                 // send(wrongMsg.set(1));
                                                 // delay(2000);
                                                  //send(wrongMsg.set(0));
                                    void ShowCardData(MFRC522::Uid* uid) {
                                      Serial.print(F("Card UID:"));
                                      for (byte i = 0; i < uid->size; i++) {
                                        if (uid->uidByte[i] < 0x10) {
                                          Serial.print(F(" 0"));
                                        else {
                                          Serial.print(F(" "));
                                        Serial.print(uid->uidByte[i], HEX);
                                      Serial.println();
                                      dest->size = src->size;
                                      dest->sak = src->sak;
                                      for (byte i = 0; i < src->size; i++) {
                                        dest->uidByte[i] = src->uidByte[i];
                                      if (old->size != check->size) {
                                        return false;
                                      for (byte i = 0; i < old->size; i++) {
                                        if (old->uidByte[i] != check->uidByte[i]) {
                                          return false;
                                      return true;
                                      for (byte i = 0; i < countValidCards; i++) {
                                        if (validCards[i].size != uid->size) {
                                        for (int j = 0; j < uid->size; j++) {
                                          if (validCards[i].uidByte[j] != uid->uidByte[j]) {
                                          if (j == (uid->size - 1)) {
                                            return true;
                                      return false;
                                    void storeEeprom()
                                      byte address = 0;
                                      saveState(address++, countValidCards);
                                        saveState(address++, validCards[i].size);
                                        for (byte j = 0; j < 10; j++) {
                                          saveState(address++, validCards[i].uidByte[j]);
                                    void recallEeprom()
                                      byte address = 0;
                                      countValidCards = loadState(address++);
                                      if (countValidCards > MAX_CARDS) {
                                        Serial.println(F("Not a valid EEPROM reading set to default"));
                                        storeEeprom();
                                        return;
                                        validCards[i].size = loadState(address++);
                                          validCards[i].uidByte[j] = loadState(address++);
                                    void blinkFast(int times)
                                      for (int i = 0; i < times; i++) {
                                        ledon = !ledon;
                                        delay(100);
                                    void OpenDoor(bool fakeOpen)
                                      Serial.println(F("Open door!"));
                                      if (!fakeOpen) {
                                        digitalWrite(LED_PIN, HIGH);
                                        digitalWrite(GARAGEPIN, HIGH);
                                      delay(1000);
                                      if (!fakeOpen) {
                                        digitalWrite(GARAGEPIN, LOW);
                                      if (v == 0x91) {
                                      else if (v == 0x92) {
                                      else {
                                        Serial.print(F(" (unknown)"));
                                      Serial.println("");
                                          OpenDoor(false);
                                      /*else
                                        if (message.type == V_ARMED) {
                                          armed = message.getBool();
                                          Serial.print(F("Arm status: "));
                                    I'm not good at programming that's why I'm asking for help:expressionless: :expressionless:
                                    • IspandyI Ispandy
                                      and
                                      to this
                                            granted(300);
                                      nothing happen...
                                      sketch Node 3
                                      #define BAUD            115200
                                      /*Pin definitions*/
                                      #define LED_PIN         4
                                      #define GARAGEPIN       2
                                      int        releasecnt = 0;
                                      long       timer = -1;
                                      bool       ledon;
                                      bool       armed = true;
                                      void before() {
                                        // Setup the button
                                        recallEeprom();
                                        timer++;
                                        delay(HEARTBEAT);
                                        debouncer.update();
                                              blinkFast(50);
                                            else {
                                              storeEeprom();
                                          if (!switchValue) {
                                            programTimer = 0;
                                          ledon = !ledon;
                                          programTimer++;
                                              releasecnt--;
                                              if (!releasecnt) {
                                                olduid.size = 0;
                                            return;
                                          releasecnt = 5;
                                            return;
                                              OpenDoor(false);
                                            else {
                                                if (switchValue) {
                                                  programmode = true;
                                                  programTimer = 0;
                                                  lastTime = 0;
                                              else {
                                                if (programmode) {
                                                  programTimer = 0;
                                                    countValidCards++;
                                                    blinkFast(15);
                                                else {
                                                  //if (armed) {
                                                   // delay(2000);
                                          else {
                                        Serial.println();
                                          return false;
                                            return false;
                                        return true;
                                              return true;
                                        return false;
                                      void storeEeprom()
                                        byte address = 0;
                                      void recallEeprom()
                                        byte address = 0;
                                          storeEeprom();
                                          return;
                                          ledon = !ledon;
                                          delay(100);
                                        if (!fakeOpen) {
                                        delay(1000);
                                        if (!fakeOpen) {
                                        if (v == 0x91) {
                                        else {
                                        Serial.println("");
                                            OpenDoor(false);
                                        /*else
                                      E
                                      E
                                      evb
                                      @Ispandy what happens if you download the same sketch from the working node 3 tot your new node 50?
                                      Adapt of course the node-id!
                                      If it works we can exclude a hardware problem, then it must be a software problem.
                                      In that last case, we can check your sketch more deeply.
                                      • E evb
                                        IspandyI
                                        IspandyI
                                        Ispandy
                                        @evb thank you for the response, and sorry for late reply.
                                        As I mentioned above, that node 3 is running as it should, and I've copied it to node 50 and it's also running normally. The problem is on sketch node 50 when i click the switch in openhab the relay doesn't respond but when i scan the card on rfid, the relay responds. Unlike node 3, the relay responds to both card scans and openhab.
                                        Regards,
                                        • IspandyI Ispandy
                                          Regards,
                                          E
                                          E
                                          evb
                                          @Ispandy, let resume some things because I'm lost
                                          You copied the sketch code from node 3 (= correctly running node with cardscans and remote control from openhab) to node 50 and you adapted the node id.
                                          This same sketch on node 50 is running correctly with cardscans but not with openhab? Correct?
                                          If above is correct: somewhere your openhab configuration for this node 50 is not correct. You say that node 50 is never receiving the openhab command, so there is a problem with your openhab configuration for node 50.
