  2. Announcements
  3. 💬 Atmospheric Pressure Sensor
pressurebmp085
60 Posts 22 Posters 37.7k Views 19 Watching
  • E
    E
    emc2
    BME280 is quite nice. I got one last year that I added to my gateway and it worked flawlessly since then.
    If you remove the gateway/esp8266 top part you should be able to directly use code from https://github.com/emc2cube/MyWeatherGatewayESP8266 (which was updated from this one anyway)
    • HeinzH
      HeinzH
      Heinz
      I just ordered one at ebay...
      Nice to see that other weatherstations make use of this code.
      • Luc3asL
        Luc3asL
        Luc3as
        I tried to modify the weather forecast script to run each 5 minutes instead of every minute but now I am getting strange forecasts and sometimes unknown conditions.
        Doesn't anybody tried to accomplish this ?
        D 1 Reply Last reply
        • boblasureB
          boblasureB
          boblasure
          So I added the My Sensors board file, added the my sensors libary through library manager, coped the adafruit library and tried to compile. Arduino: 1.8.1 (Windows 8.1), Board: "Arduino Mini, ATmega328"
          C:\Users\eddy\Documents\Arduino\bmpTest\bmpTest.ino: In function 'void setup()':
          bmpTest:95: error: 'getConfig' was not declared in this scope
          exit status 1
          Did I miss something?
          • boblasureB
            boblasureB
            boblasure
            Okay, I changed the library to version 2.0.0 and it now compiles.
            • boblasureB boblasure
              @boblasure I am not sure why, but the name of getConfig was changed. See https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed/ if you want to upgrade to 2.1.1 again.
              • Luc3asL Luc3as
                DavidZH
                @Luc3as
                The forecast script is meant to be running every minute to collect the averaging data. If you run it every 5 minutes, you need to change the dividers in the script to come to a hPa/h value that actually makes sense.
                • ghislainG
                  ghislainG
                  ghislain
                  i've got a problem, pressure always stay to 1013 mbar and i'm at 350m of altitude. Something is wrong but what ? I test the BMP180 alone and it said the good value.
                  • ghislainG
                    ghislainG
                    ghislain
                    wrote on last edited by ghislain
                    I found some problems in code. I did make some change to be able to get value. I replace "float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;" by "float pressure = bmp.readPressure() / 100 ;"
                    I'll make a PR on GitHub when everything will be well tested. :)
                    • James FlosseJ
                      James FlosseJ
                      James Flosse
                      Hi, i've a problem with the bmp180 with domoticz. I use raspberry pi with domoticz and mysensor v2 and nrf24 on gpio, i receive data but i think is wrong. The temperature is 31°C and pressure is 728. I put my altitude in the sketch.
                      Can you help me?
                      Best regards.
                      • James FlosseJ James Flosse
                        Can you help me?
                        Best regards.
                        Welcome to the MySensors community @James-Flosse !
                        Could you post your sketch and debug output from the node and the gateway?
                        If you haven't looked at it already, https://www.mysensors.org/build/debug#enabling-debug-logging has information on how to enable debug logging.
                        • James FlosseJ
                          James FlosseJ
                          James Flosse
                          wrote on last edited by James Flosse
                          Hi @mfalkvidd. This is the debug output and my code
                          2269 MCO:REG:REQ
                          2277 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          2287 TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          2293 MCO:PIM:NODE REG=1
                          2295 MCO:BGN:STP
                          2306 MCO:BGN:INIT OK,TSP=1
                          Forecast at minute 1 dP/dt = 0.00kPa/h --> unknown
                          Temperature = 31.00 *C
                          Pressure = 728.00 hPa
                          Forecast = unknown
                          2359 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:31.0
                          2369 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:728
                          2381 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
                          2387 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          2394 MCO:SLP:TPD
                          #include <Adafruit_BMP085.h>
                          #define BARO_CHILD 0
                          #define TEMP_CHILD 1
                          const float ALTITUDE = 688; // <-- adapt this value to your own location's altitude.
                          // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
                          const unsigned long SLEEP_TIME = 60000;
                          const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                          enum FORECAST
                              STABLE = 0,            // "Stable Weather Pattern"
                              SUNNY = 1,            // "Slowly rising Good Weather", "Clear/Sunny "
                              CLOUDY = 2,            // "Slowly falling L-Pressure ", "Cloudy/Rain "
                              UNSTABLE = 3,        // "Quickly rising H-Press",     "Not Stable"
                              THUNDERSTORM = 4,    // "Quickly falling L-Press",    "Thunderstorm"
                              UNKNOWN = 5            // "Unknown (More Time needed)
                          Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
                          float lastPressure = -1;
                          float lastTemp = -1;
                          int lastForecast = -1;
                          const int LAST_SAMPLES_COUNT = 5;
                          float lastPressureSamples[LAST_SAMPLES_COUNT];
                          // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
                          // get kPa/h be dividing hPa by 10
                          #define CONVERSION_FACTOR (1.0/10.0)
                          int minuteCount = 0;
                          bool firstRound = true;
                          // average value is used in forecast algorithm.
                          float pressureAvg;
                          // average after 2 hours is used as reference value for the next iteration.
                          float pressureAvg2;
                          float dP_dt;
                          bool metric;
                          MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
                              if (!bmp.begin())
                                  Serial.println("Could not find a valid BMP085 sensor, check wiring!");
                                  while (1) {}
                          void presentation()  {
                            sendSketchInfo("Pressure Sensor", "1.1");
                            // Register sensors to gw (they will be created as child devices)
                            present(BARO_CHILD, S_BARO);
                            present(TEMP_CHILD, S_TEMP);
                              float temperature = bmp.readTemperature();
                              if (!metric)
                                  // Convert to fahrenheit
                                  temperature = temperature * 9.0 / 5.0 + 32.0;
                              int forecast = sample(pressure);
                              Serial.print("Temperature = ");
                              Serial.print(temperature);
                              Serial.println(metric ? " *C" : " *F");
                              Serial.print("Pressure = ");
                              Serial.print(pressure);
                              Serial.println(" hPa");
                              Serial.print("Forecast = ");
                              if (temperature != lastTemp)
                                  send(tempMsg.set(temperature, 1));
                                  lastTemp = temperature;
                              if (pressure != lastPressure)
                                  send(pressureMsg.set(pressure, 0));
                                  lastPressure = pressure;
                              if (forecast != lastForecast)
                                  send(forecastMsg.set(weather[forecast]));
                                  lastForecast = forecast;
                              sleep(SLEEP_TIME);
                          float getLastPressureSamplesAverage()
                              float lastPressureSamplesAverage = 0;
                              for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                                  lastPressureSamplesAverage += lastPressureSamples[i];
                              lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                              return lastPressureSamplesAverage;
                          // Algorithm found here
                          // Pressure in hPa -->  forecast done by calculating kPa/h
                          int sample(float pressure)
                              // Calculate the average of the last n minutes.
                              int index = minuteCount % LAST_SAMPLES_COUNT;
                              lastPressureSamples[index] = pressure;
                              minuteCount++;
                              if (minuteCount > 185)
                                  minuteCount = 6;
                              if (minuteCount == 5)
                                  pressureAvg = getLastPressureSamplesAverage();
                              else if (minuteCount == 35)
                                  float lastPressureAvg = getLastPressureSamplesAverage();
                                  float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                                      dP_dt = change * 2; // note this is for t = 0.5hour
                                      dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                              else if (minuteCount == 65)
                                      dP_dt = change; //note this is for t = 1 hour
                                      dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                              else if (minuteCount == 95)
                                      dP_dt = change / 1.5; // note this is for t = 1.5 hour
                                      dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                              else if (minuteCount == 125)
                                  pressureAvg2 = lastPressureAvg; // store for later use.
                                      dP_dt = change / 2; // note this is for t = 2 hour
                                      dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                              else if (minuteCount == 155)
                                      dP_dt = change / 2.5; // note this is for t = 2.5 hour
                                      dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                              else if (minuteCount == 185)
                                      dP_dt = change / 3; // note this is for t = 3 hour
                                      dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                                  pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                              int forecast = UNKNOWN;
                                  forecast = UNKNOWN;
                              else if (dP_dt < (-0.25))
                                  forecast = THUNDERSTORM;
                              else if (dP_dt > 0.25)
                                  forecast = UNSTABLE;
                                  forecast = CLOUDY;
                                  forecast = SUNNY;
                              else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                                  forecast = STABLE;
                                  forecast = UNKNOWN;
                              // uncomment when debugging
                              Serial.print(F("Forecast at minute "));
                              Serial.print(minuteCount);
                              Serial.print(F(" dP/dt = "));
                              Serial.print(dP_dt);
                              Serial.print(F("kPa/h --> "));
                              return forecast;
                          2017-03-09 10:52:56.474 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 10:52:56.475 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 10:52:56.488 (GATEWAY) Temp (Temp)
                          2017-03-09 10:52:56.497 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:52:56.503 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:53:40.053 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 10:53:40.054 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 10:53:40.067 (GATEWAY) Temp (Temp)
                          2017-03-09 10:53:40.075 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:53:40.081 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:54:14.102 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 10:54:14.104 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 10:54:14.148 (GATEWAY) Temp (Temp)
                          2017-03-09 10:54:14.162 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:54:14.172 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:54:26.662 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 10:54:26.664 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 10:54:26.676 (GATEWAY) Temp (Temp)
                          2017-03-09 10:54:26.685 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:54:26.691 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:54:44.122 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 10:54:44.123 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 10:54:44.136 (GATEWAY) Temp (Temp)
                          2017-03-09 10:54:44.145 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:54:44.150 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:54:50.417 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 10:54:51.225 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 10:54:51.227 (GATEWAY) Temp (Temp)
                          2017-03-09 10:54:51.236 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:54:51.242 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:55:55.513 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:58:05.600 (GATEWAY) Temp (Temp)
                          2017-03-09 10:58:05.608 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 10:59:10.651 (GATEWAY) Temp (Temp)
                          2017-03-09 11:01:20.704 (GATEWAY) Temp (Temp)
                          2017-03-09 11:02:00.701 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 11:02:00.702 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 11:02:00.715 (GATEWAY) Temp (Temp)
                          2017-03-09 11:02:00.723 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:00.728 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:31.650 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 11:02:31.652 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 11:02:31.664 (GATEWAY) Temp (Temp)
                          2017-03-09 11:02:31.673 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:31.678 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:38.872 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 11:02:38.873 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 11:02:38.886 (GATEWAY) Temp (Temp)
                          2017-03-09 11:02:38.894 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:38.900 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:41.863 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 11:02:41.864 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 11:02:41.887 (GATEWAY) Temp (Temp)
                          2017-03-09 11:02:41.895 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:41.901 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:49.208 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 11:02:49.209 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 11:02:49.232 (GATEWAY) Temp (Temp)
                          2017-03-09 11:02:49.240 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:02:49.245 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:03:54.286 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:04:59.319 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:06:04.359 (GATEWAY) Temp (Temp)
                          2017-03-09 11:06:04.368 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:06:36.109 MySensors: Node: 3, Sketch Name: Pressure Sensor
                          2017-03-09 11:06:36.111 MySensors: Node: 3, Sketch Version: 1.1
                          2017-03-09 11:06:36.123 (GATEWAY) Temp (Temp)
                          2017-03-09 11:06:36.132 (GATEWAY) General/Barometer (Baro)
                          2017-03-09 11:06:36.137 (GATEWAY) General/Barometer (Baro)
                          • mfalkviddM
                            The node sends the data received from the bmp180, so everything seems to be correct. Could you clarify what you expected?
                            • James FlosseJ
                              James FlosseJ
                              James Flosse
                              The pressure and temperature is incorrect xD. sorry, i have 20°C in my room and the METAR of the near airport say 1016 hPa.
                                @James-Flosse thanks :)
                                Strange problem. Is the bmp getting stable power? Maybe it is defective? You don't happen to have another bmp to compare with?
                                • James FlosseJ
                                  James FlosseJ
                                  James Flosse
                                  Only bmp180 connected to arduino and i have test with 3 other :s
                                  • ghislainG
                                    ghislainG
                                    ghislain
                                    #24
                                    Hi, i'm using this sketch and I had to modify it a little bit. But i'm at work and i haven't it.
                                    You defined the altitude to 688 meters in you sketch, are you sure, you said you're at 1014mbars. If you're really at 700m you should be near 930mbars not 1014mbars.
                                    • James FlosseJ
                                      James FlosseJ
                                      James Flosse
                                      Ok i defined the altitude by my own (225 meters) but i have the same pressure and temperature :S
                                      • ghislainG
                                        ghislainG
                                        ghislain
                                        Too bad, can you upload a basic example sketch in the library adafruit to read pressure and temperature, just to be sure there is the same behavior.
                                        • James FlosseJ
                                          James FlosseJ
                                          James Flosse
                                          #include <Adafruit_Sensor.h>
                                          #include <Adafruit_BMP085_U.h>
                                          Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
                                          void setup(void)
                                            Serial.begin(9600);
                                            Serial.println("Pressure Sensor Test"); Serial.println("");
                                            /* Initialise the sensor */
                                            if(!bmp.begin())
                                              /* There was a problem detecting the BMP085 ... check your connections */
                                              Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
                                              while(1);
                                          void loop(void)
                                            /* Get a new sensor event */
                                            sensors_event_t event;
                                            bmp.getEvent(&event);
                                            /* Display the results (barometric pressure is measure in hPa) */
                                            if (event.pressure)
                                              /* Display atmospheric pressure in hPa */
                                              Serial.print("Pressure: "); Serial.print(event.pressure); Serial.println(" hPa");
                                              Serial.println("Sensor error");
                                            delay(250);
                                          Pressure: 756.46 hPa
                                          Pressure: 756.47 hPa
                                          Pressure: 756.49 hPa
                                          Pressure: 756.44 hPa
                                          Pressure: 756.41 hPa
                                          Pressure: 756.42 hPa
                                          Pressure: 756.39 hPa
                                          Pressure: 756.38 hPa
                                          Pressure: 756.40 hPa
                                          Pressure: 756.34 hPa
                                          Pressure: 756.22 hPa
                                          Pressure: 756.33 hPa
                                          Pressure: 756.37 hPa
                                          same pressure
