  2. Announcements
  3. 💬 Atmospheric Pressure Sensor
pressurebmp085
60 Posts 22 Posters 37.7k Views 19 Watching
  • Luc3asL
    Luc3asL
    Luc3as
    I tried to modify the weather forecast script to run each 5 minutes instead of every minute but now I am getting strange forecasts and sometimes unknown conditions.
    Doesn't anybody tried to accomplish this ?
    D 1 Reply Last reply
    • boblasureB
      boblasureB
      boblasure
      So I added the My Sensors board file, added the my sensors libary through library manager, coped the adafruit library and tried to compile. Arduino: 1.8.1 (Windows 8.1), Board: "Arduino Mini, ATmega328"
      C:\Users\eddy\Documents\Arduino\bmpTest\bmpTest.ino: In function 'void setup()':
      bmpTest:95: error: 'getConfig' was not declared in this scope
      exit status 1
      Did I miss something?
      • boblasureB
        boblasureB
        boblasure
        Okay, I changed the library to version 2.0.0 and it now compiles.
        • boblasureB boblasure
          @boblasure I am not sure why, but the name of getConfig was changed. See https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed/ if you want to upgrade to 2.1.1 again.
          • Luc3asL Luc3as
            DavidZH
            @Luc3as
            The forecast script is meant to be running every minute to collect the averaging data. If you run it every 5 minutes, you need to change the dividers in the script to come to a hPa/h value that actually makes sense.
            • ghislainG
              ghislainG
              ghislain
              i've got a problem, pressure always stay to 1013 mbar and i'm at 350m of altitude. Something is wrong but what ? I test the BMP180 alone and it said the good value.
              • ghislainG
                ghislainG
                ghislain
                wrote on last edited by ghislain
                I found some problems in code. I did make some change to be able to get value. I replace "float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;" by "float pressure = bmp.readPressure() / 100 ;"
                I'll make a PR on GitHub when everything will be well tested. :)
                • James FlosseJ
                  James FlosseJ
                  James Flosse
                  Hi, i've a problem with the bmp180 with domoticz. I use raspberry pi with domoticz and mysensor v2 and nrf24 on gpio, i receive data but i think is wrong. The temperature is 31°C and pressure is 728. I put my altitude in the sketch.
                  Can you help me?
                  Best regards.
                  • James FlosseJ James Flosse
                    Can you help me?
                    Best regards.
                    Welcome to the MySensors community @James-Flosse !
                    Could you post your sketch and debug output from the node and the gateway?
                    If you haven't looked at it already, https://www.mysensors.org/build/debug#enabling-debug-logging has information on how to enable debug logging.
                    • James FlosseJ
                      James FlosseJ
                      James Flosse
                      wrote on last edited by James Flosse
                      Hi @mfalkvidd. This is the debug output and my code
                      2269 MCO:REG:REQ
                      2277 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      2287 TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      2293 MCO:PIM:NODE REG=1
                      2295 MCO:BGN:STP
                      2306 MCO:BGN:INIT OK,TSP=1
                      Forecast at minute 1 dP/dt = 0.00kPa/h --> unknown
                      Temperature = 31.00 *C
                      Pressure = 728.00 hPa
                      Forecast = unknown
                      2359 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:31.0
                      2369 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:728
                      2381 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
                      2387 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      2394 MCO:SLP:TPD
                      #include <Adafruit_BMP085.h>
                      #define BARO_CHILD 0
                      #define TEMP_CHILD 1
                      const float ALTITUDE = 688; // <-- adapt this value to your own location's altitude.
                      // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
                      const unsigned long SLEEP_TIME = 60000;
                      const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                      enum FORECAST
                          STABLE = 0,            // "Stable Weather Pattern"
                          SUNNY = 1,            // "Slowly rising Good Weather", "Clear/Sunny "
                          CLOUDY = 2,            // "Slowly falling L-Pressure ", "Cloudy/Rain "
                          UNSTABLE = 3,        // "Quickly rising H-Press",     "Not Stable"
                          THUNDERSTORM = 4,    // "Quickly falling L-Press",    "Thunderstorm"
                          UNKNOWN = 5            // "Unknown (More Time needed)
                      Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
                      float lastPressure = -1;
                      float lastTemp = -1;
                      int lastForecast = -1;
                      const int LAST_SAMPLES_COUNT = 5;
                      float lastPressureSamples[LAST_SAMPLES_COUNT];
                      // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
                      // get kPa/h be dividing hPa by 10
                      #define CONVERSION_FACTOR (1.0/10.0)
                      int minuteCount = 0;
                      bool firstRound = true;
                      // average value is used in forecast algorithm.
                      float pressureAvg;
                      // average after 2 hours is used as reference value for the next iteration.
                      float pressureAvg2;
                      float dP_dt;
                      bool metric;
                      MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
                          if (!bmp.begin())
                              Serial.println("Could not find a valid BMP085 sensor, check wiring!");
                              while (1) {}
                      void presentation()  {
                        sendSketchInfo("Pressure Sensor", "1.1");
                        // Register sensors to gw (they will be created as child devices)
                        present(BARO_CHILD, S_BARO);
                        present(TEMP_CHILD, S_TEMP);
                          float temperature = bmp.readTemperature();
                          if (!metric)
                              // Convert to fahrenheit
                              temperature = temperature * 9.0 / 5.0 + 32.0;
                          int forecast = sample(pressure);
                          Serial.print("Temperature = ");
                          Serial.print(temperature);
                          Serial.println(metric ? " *C" : " *F");
                          Serial.print("Pressure = ");
                          Serial.print(pressure);
                          Serial.println(" hPa");
                          Serial.print("Forecast = ");
                          if (temperature != lastTemp)
                              send(tempMsg.set(temperature, 1));
                              lastTemp = temperature;
                          if (pressure != lastPressure)
                              send(pressureMsg.set(pressure, 0));
                              lastPressure = pressure;
                          if (forecast != lastForecast)
                              send(forecastMsg.set(weather[forecast]));
                              lastForecast = forecast;
                          sleep(SLEEP_TIME);
                      float getLastPressureSamplesAverage()
                          float lastPressureSamplesAverage = 0;
                          for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                              lastPressureSamplesAverage += lastPressureSamples[i];
                          lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                          return lastPressureSamplesAverage;
                      // Algorithm found here
                      // Pressure in hPa -->  forecast done by calculating kPa/h
                      int sample(float pressure)
                          // Calculate the average of the last n minutes.
                          int index = minuteCount % LAST_SAMPLES_COUNT;
                          lastPressureSamples[index] = pressure;
                          minuteCount++;
                          if (minuteCount > 185)
                              minuteCount = 6;
                          if (minuteCount == 5)
                              pressureAvg = getLastPressureSamplesAverage();
                          else if (minuteCount == 35)
                              float lastPressureAvg = getLastPressureSamplesAverage();
                              float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                                  dP_dt = change * 2; // note this is for t = 0.5hour
                                  dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                          else if (minuteCount == 65)
                                  dP_dt = change; //note this is for t = 1 hour
                                  dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                          else if (minuteCount == 95)
                                  dP_dt = change / 1.5; // note this is for t = 1.5 hour
                                  dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                          else if (minuteCount == 125)
                              pressureAvg2 = lastPressureAvg; // store for later use.
                                  dP_dt = change / 2; // note this is for t = 2 hour
                                  dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                          else if (minuteCount == 155)
                                  dP_dt = change / 2.5; // note this is for t = 2.5 hour
                                  dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                          else if (minuteCount == 185)
                                  dP_dt = change / 3; // note this is for t = 3 hour
                                  dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                              pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                          int forecast = UNKNOWN;
                              forecast = UNKNOWN;
                          else if (dP_dt < (-0.25))
                              forecast = THUNDERSTORM;
                          else if (dP_dt > 0.25)
                              forecast = UNSTABLE;
                              forecast = CLOUDY;
                              forecast = SUNNY;
                          else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                              forecast = STABLE;
                              forecast = UNKNOWN;
                          // uncomment when debugging
                          Serial.print(F("Forecast at minute "));
                          Serial.print(minuteCount);
                          Serial.print(F(" dP/dt = "));
                          Serial.print(dP_dt);
                          Serial.print(F("kPa/h --> "));
                          return forecast;
                      2017-03-09 10:52:56.474 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 10:52:56.475 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 10:52:56.488 (GATEWAY) Temp (Temp)
                      2017-03-09 10:52:56.497 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:52:56.503 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:53:40.053 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 10:53:40.054 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 10:53:40.067 (GATEWAY) Temp (Temp)
                      2017-03-09 10:53:40.075 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:53:40.081 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:54:14.102 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 10:54:14.104 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 10:54:14.148 (GATEWAY) Temp (Temp)
                      2017-03-09 10:54:14.162 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:54:14.172 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:54:26.662 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 10:54:26.664 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 10:54:26.676 (GATEWAY) Temp (Temp)
                      2017-03-09 10:54:26.685 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:54:26.691 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:54:44.122 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 10:54:44.123 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 10:54:44.136 (GATEWAY) Temp (Temp)
                      2017-03-09 10:54:44.145 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:54:44.150 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:54:50.417 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 10:54:51.225 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 10:54:51.227 (GATEWAY) Temp (Temp)
                      2017-03-09 10:54:51.236 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:54:51.242 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:55:55.513 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:58:05.600 (GATEWAY) Temp (Temp)
                      2017-03-09 10:58:05.608 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 10:59:10.651 (GATEWAY) Temp (Temp)
                      2017-03-09 11:01:20.704 (GATEWAY) Temp (Temp)
                      2017-03-09 11:02:00.701 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 11:02:00.702 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 11:02:00.715 (GATEWAY) Temp (Temp)
                      2017-03-09 11:02:00.723 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:00.728 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:31.650 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 11:02:31.652 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 11:02:31.664 (GATEWAY) Temp (Temp)
                      2017-03-09 11:02:31.673 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:31.678 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:38.872 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 11:02:38.873 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 11:02:38.886 (GATEWAY) Temp (Temp)
                      2017-03-09 11:02:38.894 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:38.900 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:41.863 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 11:02:41.864 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 11:02:41.887 (GATEWAY) Temp (Temp)
                      2017-03-09 11:02:41.895 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:41.901 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:49.208 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 11:02:49.209 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 11:02:49.232 (GATEWAY) Temp (Temp)
                      2017-03-09 11:02:49.240 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:02:49.245 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:03:54.286 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:04:59.319 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:06:04.359 (GATEWAY) Temp (Temp)
                      2017-03-09 11:06:04.368 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:06:36.109 MySensors: Node: 3, Sketch Name: Pressure Sensor
                      2017-03-09 11:06:36.111 MySensors: Node: 3, Sketch Version: 1.1
                      2017-03-09 11:06:36.123 (GATEWAY) Temp (Temp)
                      2017-03-09 11:06:36.132 (GATEWAY) General/Barometer (Baro)
                      2017-03-09 11:06:36.137 (GATEWAY) General/Barometer (Baro)
                      • mfalkviddM
                        The node sends the data received from the bmp180, so everything seems to be correct. Could you clarify what you expected?
                        • James FlosseJ
                          James FlosseJ
                          James Flosse
                          The pressure and temperature is incorrect xD. sorry, i have 20°C in my room and the METAR of the near airport say 1016 hPa.
                            @James-Flosse thanks :)
                            Strange problem. Is the bmp getting stable power? Maybe it is defective? You don't happen to have another bmp to compare with?
                            • James FlosseJ
                              James FlosseJ
                              James Flosse
                              Only bmp180 connected to arduino and i have test with 3 other :s
                              • ghislainG
                                ghislainG
                                ghislain
                                #24
                                Hi, i'm using this sketch and I had to modify it a little bit. But i'm at work and i haven't it.
                                You defined the altitude to 688 meters in you sketch, are you sure, you said you're at 1014mbars. If you're really at 700m you should be near 930mbars not 1014mbars.
                                • James FlosseJ
                                  James FlosseJ
                                  James Flosse
                                  Ok i defined the altitude by my own (225 meters) but i have the same pressure and temperature :S
                                  • ghislainG
                                    ghislainG
                                    ghislain
                                    Too bad, can you upload a basic example sketch in the library adafruit to read pressure and temperature, just to be sure there is the same behavior.
                                    • James FlosseJ
                                      James FlosseJ
                                      James Flosse
                                      #include <Adafruit_Sensor.h>
                                      #include <Adafruit_BMP085_U.h>
                                      Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
                                      void setup(void)
                                        Serial.begin(9600);
                                        Serial.println("Pressure Sensor Test"); Serial.println("");
                                        /* Initialise the sensor */
                                        if(!bmp.begin())
                                          /* There was a problem detecting the BMP085 ... check your connections */
                                          Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
                                          while(1);
                                      void loop(void)
                                        /* Get a new sensor event */
                                        sensors_event_t event;
                                        bmp.getEvent(&event);
                                        /* Display the results (barometric pressure is measure in hPa) */
                                        if (event.pressure)
                                          /* Display atmospheric pressure in hPa */
                                          Serial.print("Pressure: "); Serial.print(event.pressure); Serial.println(" hPa");
                                          Serial.println("Sensor error");
                                        delay(250);
                                      Pressure: 756.46 hPa
                                      Pressure: 756.47 hPa
                                      Pressure: 756.49 hPa
                                      Pressure: 756.44 hPa
                                      Pressure: 756.41 hPa
                                      Pressure: 756.42 hPa
                                      Pressure: 756.39 hPa
                                      Pressure: 756.38 hPa
                                      Pressure: 756.40 hPa
                                      Pressure: 756.34 hPa
                                      Pressure: 756.22 hPa
                                      Pressure: 756.33 hPa
                                      Pressure: 756.37 hPa
                                      same pressure
                                      • ghislainG
                                        ghislainG
                                        ghislain
                                        Where did you buy your bmp180 ? you said the 3 you have make the same behavior ? something is wrong with the BMP sensor.
                                        • James FlosseJ
                                          James FlosseJ
                                          James Flosse
                                          I bought it in banggood, but it work's before...
