  3. Relay / Motion Multisensor
motionrelaymultisensor
14 Posts 9 Posters 20.3k Views 4 Watching
  • RJ_MakeR RJ_Make
    @hek said:
    Nice! But you should probably isolate the high voltage parts a bit. We wouldn't want a MySensors related fire started.
    +1 on that one!
    Dalhoj
    @ServiceXp @hek Here just a little update
    I have now glued all parts to the box, and added a plastic cover over the part with 230V
    so now nothing should be able to touch and it looks a bit nicer.
      madmax
      Hello
      i want to make a similar project but i want to add a dht22 with this sketch
      have you a sketch with a dht because i have a problem with mine
      thanks
      D 1 Reply Last reply
      • M madmax
        Hello
        thanks
        Dalhoj
        @madmax good idea I have some DHT22 lying around. But I have not tried making a multi sensor with them.
        Have You tried the skech from the site, I tried it and it work on mine?
        • D Dalhoj
          madmax
          @Dalhoj i use this and it's working fine
          i want to include another relay and it's ok for me
          #include <SimpleTimer.h>
          #define CHILD_ID_HUM 1
          #define CHILD_ID_TEMP 2
          #define CHILD_ID_MOTION 3
          #define CHILD_ID_RELAY 4
          #define HUMIDITY_SENSOR_DIGITAL_PIN 19
          #define MOTION_SENSOR_DIGITAL_PIN 3
          #define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
          #define RELAY  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds) - 10mins
          DHT dht;
          SimpleTimer timer;
          float lastTemp;
          float lastHum;
          boolean lastTripped;
          boolean metric = true;
          MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
            gw.sendSketchInfo("HumTempRelayMotion", "1.0");
            gw.present(CHILD_ID_MOTION, S_MOTION);
            gw.present(CHILD_ID_RELAY, S_LIGHT);
            pinMode(RELAY, OUTPUT);
            digitalWrite(RELAY, gw.loadState(RELAY)?RELAY_OFF:RELAY_ON);
            //Serial.begin(9600);
            timer.setInterval(30000, getMeasure);
            timer.run();
            boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
            if (tripped != lastTripped) {
              lastTripped = tripped;
              Serial.print("M: ");
              Serial.println(tripped);
              gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
            if (message.type==V_LIGHT) {
               // Change relay state
               digitalWrite(message.sensor-CHILD_ID_RELAY+RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
               // Store state in eeprom
          void getMeasure() {
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              Serial.print("T: ");
            if (isnan(humidity)) {
                lastHum = humidity;
                Serial.print("H: ");
                Serial.println(humidity);
          • Ashley SavageA
            Ashley SavageA
            Ashley Savage
            hello, just looking to use this project to try and set up a motion triggered sprinkler to scare away some rabbits eating my plants and grass. Thinking of the relay triggering a 24v valve, my only problem is how do I extend the time the replay is closed, thinking I only need to spray water for 5-10secs... any tips would be greatly appreciated.
            thanks
            Ashley SavageA 1 Reply Last reply
            • Tomasz PazioT
              Tomasz PazioT
              Tomasz Pazio
              wrote on last edited by Tomasz Pazio
              Guys, I would like to use this sketch with dht but on Uno and with 8 relays and use analog pins...
              Should I Just change part:
              #define RELAY 8
              To
              #define RELAY A0
              • GertSandersG
                GertSandersG
                GertSanders
                This project got me inspired, so I made this:
                Same PIR, no relay on this board yet. To test the principle (and sketch) I used a red LED. The kicker is that I can send an SMS ("LED ON") to this board to switch on the LED, and another (... "LED OFF" tada !) to switch it back off. I can ask "STAT?" and it sends me an SMS with the status of all analog/digital ports. And when the PIR "fires" I get a prowl message via Domoticz. Call me a kid, blame the glas of wine I just had, but this is super fun !!!!!
                • Ashley SavageA Ashley Savage
                  thanks
                  Ashley SavageA
                  Ashley SavageA
                  Ashley Savage
                  @Ashley-Savage
                  ah mis read the code... build circuit and sorted my timer via my vera with a timer to switch off relay after 5 secs...
                  • N
                    N
                    nihilo83
                    Has anyone the code for mysensors 2.1?
                    It doesnt work for me in 2.1 :/
                    Please help
                    N 1 Reply Last reply
                    • N nihilo83
                      Please help
                      N
                      N
                      nihilo83
                      I need your help pls :/
