  3. 💬 MysXLedDimmer
💬 MysXLedDimmer
17 Posts 6 Posters 5.0k Views 5 Watching
  • T TimO
    @tbowmo I really like this (and your other) designs, because for a beginner like me, they are easy to modify and to extend.
    I'm currently designing a 3 channel Version with MYSX, but I'm not sure the IRLML2502 is suited for my task.
    The maximum continous load needed is 2 A at 12 V (~24 Watts LED). The voltage at the gate (from the atmega) is 3.3 V.
    According to the datasheet the maximum current for this part is 4 A (pulsed, with a given duty circle).
    I feel that this tiny little MOSFET is not capable to drive 12V and 2 A continous, but I'm not yet smart enough to calculate it.
    I'm currently using IRLIZ44N which work fine with ~5 V at the gate but for my new layout I will omit the 5V line and will use 3.3 V and therefore need to switch the MOSFET.
    So my questions:
    1. Have you thought (calculated) the current your design is capable to handle?
    2. Does someone has a link for me where the calculation for my "feelings" are described in an easy way? I know the difference between I, U & R (most of the times) but I'm no expert and still try to learn. ;-)
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    @TimO I think you are safe ;-) To translate this to I, U, & R, look at these pictures taken from the datasheet
    0_1489588981104_upload-06a955aa-a5df-4d95-a763-b3ca87ad4efc
    At 3V gate source -voltage Rds is less than 0.04 Ohm. With a current of 2A the dissipation in the FET will be I^2 * R = 2^2 * 0.04 = 160mW
    • AWIA AWI
      TimO
      @AWI Thank you! With a maximum rating of 1.25W for this tiny FET I'm indeed safe.
      @tbowmo I'm using MYSX_D4_INT for the third FET. I've looked at @Anticimex MySensors node where it is connected to Arduino Pin 3.
      AnticimexA 1 Reply Last reply
      • T TimO
        AnticimexA
        AnticimexA
        Anticimex
        @TimO I am pretty sure I don't have a board using MYSX 2.x
        • AnticimexA Anticimex
          TimO
          @Anticimex correct, but you have a board with MYSX 1.5 which I've studied. Sadly there is no other MYSX Atmega328p based board (yet).
          • T TimO
            AnticimexA
            AnticimexA
            Anticimex
            @TimO this is true. I am also the one that the main culprit of the MYSX pinout. I agree with @tbowmo and don't recall three pwm pins though. And I know for sure I have no pwm peripherals on my board, but perhaps I misunderstood your reference as a reply to @tbowmo's remark.
              TimO
              @Anticimex I'm sorry for the confusion! I've not found any mapping from the MYSX pins to the arduino pins, so I've looked into your board mentioned above and there I found out, that D4_INT is connected to PD3/D3 on the Atmega328p/Arduino Pro Mini. D3 is also capable of PWM. I know, this won't mean that D4_INT on other boards will be capable of PWM.
              • T TimO
                AnticimexA
                AnticimexA
                Anticimex
                @TimO I see. But the pin on MYSX you connected it to is not marked as pwm capable so if you have a daughter board that expect pwm on that pin it would not be "MYSX compatible" as in that it would not work on other MYSX motherboards.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @TimO
                  It's purely up to the person who is creating a board, how to map pins for the MysX connector! What is done on the board by @Anticimex is probably not what I would do, if I made a board.
                  What MysX states, is the capabilities the different pins should have, not how they are mapped to an atmega328, atsamd21, esp8266 or stm32 micro processor!
                  • T TimO
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @TimO my board maps the pin functions described by MYSX to corresponding pins on the atmega. That does not mean you have to map it just like that, but the principle of MYSX is that a daughter board can be designed based on the MYSX pin functions and therefore expect a motherboard to be able to provide the logic functions described by each pin.
                    • T
                      TimO
                      I do understand that! :D For a Atmega328 the possibility is high that D4_INT is mapped to D3.
                      The atsamd21 is capable of PWM on every pin?! (I've no experience with atsam).
                      I will only need two dimmer and one switch port. So, if I wanted my board to be "MYSX compatible" which digital output pin on the MYSX do you suggest to use? As it is a mother-/daughter board design I'm working on the complete 2.6 MYSX is available.
                      I'm tinkering on a LED dimmer daughter board that will be able to get stacked on top of a atmega328p motherboard. The atmega328p motherboard is based on the layout (size, position of MYSX ..) of the sensebender gateway. The idea is, that the daughterboard may be used on top of the sensebender gateway if a mcu with more horse power is needed, for example for a combination of gateway & sensors. The atmega328p based board is suited for simpler tasks.
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        Well, my board is fully compatible, but mind that it uses MYSX 1.x so you need to have a close look at the pinout of MYSX 2.x.
                        I am not sure what you mean with "which digital output pin on the MYSX". All pins marked 'D' are digital in nature. You can use anyone you want on your daughterboard.
                        Your mainboard is expected to connect for example, D4_INT to a pin that is capable of interrupts and digital IO. Which one, is up to you as motherboard designer.
                          TimO
                          @Anticimex okay! So I will stick to D4_INT for the third channel and it will be MYSX compatible as long as my daughter board uses it as digital io. In some combinations, like your MySensors node, the sensebender gateway and the board I'm working on it is also capable of PWM on this pin, but that is not how it is specified by the specification. That's okay for me!
                          I really like the idea of the MYSX and hope more boards will support it in the future!
                          • T TimO
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @TimO Yep, that sounds right. It will probably be quite common that the micro will have more capabilities on the various MYSX pins than the MYSX spec states the pin in question can handle, but I tried to spec MYSX to be as compatible as possible with a range of micros so it is quite "stupid" in it's pin featureset.
                            It is basically the same reasoning for the connector. It is large and bulky and hard to use in really small boards, but I wanted it to be easy to use, and easy to source. And it provide a nice debug interface when left unconnected. Tradeoffs, tradeoffs. :)
