  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
  • Arnold ŠlepetisA Arnold Šlepetis
    I am using dht22 outside. Does any one know how to change to whole number not decimal. The temperature outside change a lot. Let say temp 20.2 changed to 20.4 and still sends to getaway . If I do "send(msgTemp.set(temperature, 0));" and still receive both times 20 and 20, and I want only if change to 21 or 19.
    #69
    @Arnold-Šlepetis change
    float lastTemp;
    to
    signed int lastTemp;
    and
    to
    signed int temperature = dht.getTemperature() + 0.5; // Add 0.5 to get correct rounding
    and
    to
    temperature = dht.toFahrenheit(temperature) + 0.5;
    and
    to
    send(msgTemp.set(temperature));
    You might also have to handle the isnan test.
    Arnold ŠlepetisA 1 Reply Last reply
      float lastTemp;
      to
      and
      to
      and
      to
      and
      to
      Arnold ŠlepetisA
      Arnold ŠlepetisA
      Arnold Šlepetis
      @mfalkvidd Thanks. It works like a charm
      • J
        J
        jwosnick
        wrote on last edited by jwosnick
        #71
        I've made a bit of an unusual observation in relationship to this script. I am running a fairly stripped-down version of it, but with the "standard" (not MySensors-customized) DHT library and its associated functions.
        Here is the code:
        // Enable debug prints
        //#define MY_RS485
        #define MY_NODE_ID 47
        #define DHT_DATA_PIN 5
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 10000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        bool metric = true;
        DHT dht(DHT_DATA_PIN, DHT22);
        float temperature;
        float humidity;
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          delay(100);
          temperature = dht.readTemperature();
          if (isnan(temperature))
            send(msgTemp.set(temperature,0));
            #ifdef MY_DEBUG
            Serial.print("T: ");
          humidity = dht.readHumidity();
          if (isnan(humidity))
            Serial.println("Failed reading humidity from DHT!");
            send(msgHum.set(humidity,1));
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
          sleep(UPDATE_INTERVAL);
        I find that if I leave the last line as
        then the sensor node ends up sending the same temperature and humidity values, over and over again, even if the actual humidity and temperature change.
        However, if I change the last line to
        delay(UPDATE_INTERVAL);
        then everything works as expected.
        This is with known good DHT22 units, so I suspect there is something funny about the sleep() function and the operation of the standard (not customized) DHT library.
        It took a lot of poking around to discover this, but is this in fact the reason why the MySensors customized DHT library is required for this script? Is that library necessary to make sleep() and DHT temperature measurements play nicely together?
          What libraries versions are you using?
          • J jwosnick
            Here is the code:
            //#define MY_RS485
            bool metric = true;
            float temperature;
            float humidity;
              delay(100);
                #ifdef MY_DEBUG
                #ifdef MY_DEBUG
            @jwosnick the example sketch has this:
            dht.readSensor(true);
            which is missing in your sketch. The comment suggests that it might be relevant.
            J 1 Reply Last reply
              J
              J
              jwosnick
              @mfalkvidd
              Yes, absolutely. But it appears that the dht.readSensor() function is not actually part of the standard DHT library, but rather something that only appears in the MySensors-customized version of it. I'm trying to get a handle on why there is a need for a customized library.
              • J jwosnick
                @mfalkvidd
                @jwosnick seems like the most recent version of the original library calls readSensor when getTemperature is called.
                Maybe the most recent version can be used if the MySensors example sketch is rewritten to just use getTemperature? Would it be possible for you to test this? It would be great if we could get rid of the MySensors-custimized version of the library and just let people install the standard DHT library.
                  J
                  J
                  jwosnick
                  @mfalkvidd said in 💬 Air Humidity Sensor:
                  Yes, it does... but somehow that function is not "exposed" to the outside world. With a standard DHT test sketch (nothing to do with MySensors) calling readSensor throws an error.
                  mfalkviddM A 2 Replies Last reply
                  • J jwosnick
                    @jwosnick yes. But since readSensor is called inside getTemperature, there should be no need to call it manually.
                    • J jwosnick
                      avgays
                      @jwosnick
                      As your set sensor model
                      it looks like you use "Adafruit DHT-sensor-library".
                      It's need dht.begin(); in setup(){ } which is missing in your sketch
                      J 2 Replies Last reply
                      • A avgays
                        @jwosnick
                        J
                        J
                        jwosnick
                        @avgays
                        Good catch -- thanks. Yes, that is the library I am using.
                        Despite omitting that line, the script above works fine as long as the last line is a delay() function and not sleep(). If I use sleep(), it in fact appears to work, but sends the same temperature and humidity over and over again. So it is something about the sleep() function.
                        I will add in the dht.begin() and then put sleep() back in and see what happens.
                        • A avgays
                          @jwosnick
                          J
                          J
                          jwosnick
                          @avgays Confirmed that even with dht.begin(); the script still sends the same temp and humidity info, over and over again, as long as the sleep() function is in there. As soon as sleep() is replaced by delay() it all works properly.
                          So I conclude from this that the MySensors-customized version of the DHT library must have something in it to make sleep() play nicely with the DHT unit. I wish I knew what that was. It would be ideal if this sensor (and the Dallas Semiconductor one) could be used with the MySensors system with their standard libraries.
                          • J jwosnick
                            avgays
                            @jwosnick
                            Very strange as in my case this library work well with sleep() on battery-powered node.
                            Look like it's nessesary to add delay(2000); before or after sleep() as sleep mode stops all timers, so
                            currenttime - _lastreadtime =0
                            and function returns with no new measurements.
                            • DigdoggerD
                              DigdoggerD
                              Digdogger
                              I would like to use this example and reduce power consumtion by removing the regulator on the mini Pro and the power led.
                              If we remove the regulator, we can power the board with 3V on Vcc. It will be OK for the mini pro and the NRF but the DHT22 needs 3.3V minimum. The solution will consist to use a step up boost module. What is the current consumtion of the step up boost?
                              AWIA J 2 Replies Last reply
                                I don't know about DHT22, but NRF24 can work down to 1.8 or 1.9V so you can connect it directly to battery (take a look ad EasyPCB)
                                • DigdoggerD Digdogger
                                  AWIA
                                  AWIA
                                  AWI
                                  wrote on last edited by AWI
                                  #84
                                  @Digdogger it's better to get rid of the DHT and use something more reliable and operating at lower voltages. Like si7021, sht21 or Bme280
                                  • DigdoggerD
                                    DigdoggerD
                                    Digdogger
                                    Thanx for your answers. @AWI, the BME280 looks great and not expansive i will replace the DHT by this one. Thank you.
                                      J
                                      J
                                      jwosnick
                                      @Digdogger
                                      Out of curiosity, do you expect there to be a big savings in power consumption by removing the regulator and power LED? I've never used the Mini Pro (the smallest I get to is the Nano) but I understand it already is very efficient with power usage.
                                      gohanG mfalkviddM 2 Replies Last reply
                                      • DigdoggerD
                                        DigdoggerD
                                        Digdogger
                                        @jwosnick: please take a look here: http://www.home-automation-community.com/arduino-low-power-how-to-run-atmega328p-for-a-year-on-coin-cell-battery/.
                                        You'll see that the current saving is significant (almost 40% saving)
                                        • J jwosnick
                                          @Digdogger
                                          @jwosnick
                                          Arduino is efficient for a live node, but for a battery powered sleeping node voltage regulators have a small drain on battery; led also consumes some power. The Nano has also the usb chip that is powered but not used that also increases battery drain. So, as rule of thumb, everything that is not really used/necessary will drain some battery over time.
