  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
  • johnecyJ
    johnecyJ
    johnecy
    I have the dht22 sensor hooked up and working on a pro mini on pin 3 I get a normal temp reading but the humidity always stays at 1.0 does not read.
    • johnecyJ johnecy
      @johnecy https://forum.mysensors.org/topic/5978/temperature-and-humidity-dht22
      • D
        donhuan78p
        Hello everybody,
        hope, someone could help a newby :-)
        I've installed the MQTT - GW and would use the Air/Humidity - sensor. But it doesn't work properly.
        The Connection to the Gateway seems to be okay. But I get no Air/Humidity - Information.
        The sensor does not measure anything.
        I've tried to change the data - pin, I've tried the DHT11 and DHT22 - sensor. No choice.
        I'm getting mad :-)
        Thanks a lot.
          Have you tried the basic arduino sketch that prints data to serial port?
          • D
            donhuan78p
            thanks a lot for your answer.
            Yes, I did. It produced the Messages as excepted.
              So you'd better post your code so we can take a look at what is wrong with it.
              • D
                donhuan78p
                ...sorry, Typo.
                As expected :-)
                • D
                  donhuan78p
                  wrote on last edited by gohan
                  #67
                  ...no Problem:
                   * Version 1.0: Henrik EKblad
                   * sensor using a DHT11/DHT-22.
                  // Enable debug prints
                  //#define MY_RS485
                  #define DHT_DATA_PIN 2
                  #define SENSOR_TEMP_OFFSET 0
                  static const uint64_t UPDATE_INTERVAL = 30000;
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  float lastTemp;
                  float lastHum;
                  uint8_t nNoUpdatesTemp;
                  uint8_t nNoUpdatesHum;
                  bool metric = true;
                  DHT dht;
                    Serial.println("Presentation");
                    sendSketchInfo("TemperatureAndHumidity", "1.1");
                    present(CHILD_ID_HUM, S_HUM);
                    Serial.println("vor Presentation");
                    Serial.println("loop Anfang");
                    dht.readSensor(true);
                    if (isnan(temperature)) {
                      lastTemp = temperature;
                      if (!metric) {
                      // Reset no updates counter
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      Serial.print("T: ");
                      nNoUpdatesTemp++;
                    if (isnan(humidity)) {
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                     #ifdef MY_DEBUG
                      Serial.print("H: ");
                      Serial.println(humidity);
                      nNoUpdatesHum++;
                    sleep(UPDATE_INTERVAL);
                  • Arnold ŠlepetisA
                    Arnold ŠlepetisA
                    Arnold Šlepetis
                    I am using dht22 outside. Does any one know how to change to whole number not decimal. The temperature outside change a lot. Let say temp 20.2 changed to 20.4 and still sends to getaway . If I do "send(msgTemp.set(temperature, 0));" and still receive both times 20 and 20, and I want only if change to 21 or 19.
                    • Arnold ŠlepetisA Arnold Šlepetis
                      #69
                      @Arnold-Šlepetis change
                      float lastTemp;
                      to
                      signed int lastTemp;
                      and
                      to
                      signed int temperature = dht.getTemperature() + 0.5; // Add 0.5 to get correct rounding
                      and
                      to
                      temperature = dht.toFahrenheit(temperature) + 0.5;
                      and
                      to
                      send(msgTemp.set(temperature));
                      You might also have to handle the isnan test.
                      Arnold ŠlepetisA 1 Reply Last reply
                        float lastTemp;
                        to
                        and
                        to
                        and
                        to
                        and
                        to
                        Arnold ŠlepetisA
                        Arnold ŠlepetisA
                        Arnold Šlepetis
                        @mfalkvidd Thanks. It works like a charm
                        • J
                          J
                          jwosnick
                          wrote on last edited by jwosnick
                          #71
                          I've made a bit of an unusual observation in relationship to this script. I am running a fairly stripped-down version of it, but with the "standard" (not MySensors-customized) DHT library and its associated functions.
                          Here is the code:
                          //#define MY_RS485
                          #define MY_NODE_ID 47
                          #define DHT_DATA_PIN 5
                          static const uint64_t UPDATE_INTERVAL = 10000;
                          bool metric = true;
                          DHT dht(DHT_DATA_PIN, DHT22);
                          float temperature;
                          float humidity;
                            delay(100);
                            temperature = dht.readTemperature();
                              send(msgTemp.set(temperature,0));
                              #ifdef MY_DEBUG
                            humidity = dht.readHumidity();
                              Serial.println("Failed reading humidity from DHT!");
                              send(msgHum.set(humidity,1));
                              #ifdef MY_DEBUG
                          I find that if I leave the last line as
                          then the sensor node ends up sending the same temperature and humidity values, over and over again, even if the actual humidity and temperature change.
                          However, if I change the last line to
                          delay(UPDATE_INTERVAL);
                          then everything works as expected.
                          This is with known good DHT22 units, so I suspect there is something funny about the sleep() function and the operation of the standard (not customized) DHT library.
                          It took a lot of poking around to discover this, but is this in fact the reason why the MySensors customized DHT library is required for this script? Is that library necessary to make sleep() and DHT temperature measurements play nicely together?
                            What libraries versions are you using?
                            • J jwosnick
                              Here is the code:
                              //#define MY_RS485
                              bool metric = true;
                              float temperature;
                              float humidity;
                                delay(100);
                                  #ifdef MY_DEBUG
                                  #ifdef MY_DEBUG
                              @jwosnick the example sketch has this:
                              which is missing in your sketch. The comment suggests that it might be relevant.
                              J 1 Reply Last reply
                                J
                                J
                                jwosnick
                                @mfalkvidd
                                Yes, absolutely. But it appears that the dht.readSensor() function is not actually part of the standard DHT library, but rather something that only appears in the MySensors-customized version of it. I'm trying to get a handle on why there is a need for a customized library.
                                • J jwosnick
                                  @mfalkvidd
                                  @jwosnick seems like the most recent version of the original library calls readSensor when getTemperature is called.
                                  Maybe the most recent version can be used if the MySensors example sketch is rewritten to just use getTemperature? Would it be possible for you to test this? It would be great if we could get rid of the MySensors-custimized version of the library and just let people install the standard DHT library.
                                    J
                                    J
                                    jwosnick
                                    @mfalkvidd said in 💬 Air Humidity Sensor:
                                    Yes, it does... but somehow that function is not "exposed" to the outside world. With a standard DHT test sketch (nothing to do with MySensors) calling readSensor throws an error.
                                    mfalkviddM A 2 Replies Last reply
                                    • J jwosnick
                                      @jwosnick yes. But since readSensor is called inside getTemperature, there should be no need to call it manually.
                                      • J jwosnick
                                        avgays
                                        @jwosnick
                                        As your set sensor model
                                        it looks like you use "Adafruit DHT-sensor-library".
                                        It's need dht.begin(); in setup(){ } which is missing in your sketch
                                        J 2 Replies Last reply
                                        • A avgays
                                          @jwosnick
                                          J
                                          J
                                          jwosnick
                                          @avgays
                                          Good catch -- thanks. Yes, that is the library I am using.
                                          Despite omitting that line, the script above works fine as long as the last line is a delay() function and not sleep(). If I use sleep(), it in fact appears to work, but sends the same temperature and humidity over and over again. So it is something about the sleep() function.
                                          I will add in the dht.begin() and then put sleep() back in and see what happens.
