  3. ... using two Gateways
25 Posts 5 Posters 6.4k Views 3 Watching
    @gohan not without some sort of filtering
    The two gateways would have the same id (0) and forwarding messages with destination 0 would probably confuse the other gateway.
    There would probably also be some extra routing mechanism, to be able to handle routing between the two networks. To nodes on "network 1", it would have to look like gateway 2 is a repeater which is routing messages for all nodes in "network 2", and the other way around.
    @mfalkvidd
    Of course some changes would have to be made. I was only brainstorming about what could be the less complex way
      zzz-teoZ
      zzz-teoZ
      zzz-teo
      @mfalkvidd
      hmm... that is more complicated than i thought!
      seems that need a repeater NRF to RS485 to handle the "INTERNAL" trafic also and not two Gateways ...:confused: :dizzy_face:
      mfalkviddM gohanG 2 Replies Last reply
      • zzz-teoZ zzz-teo
        @mfalkvidd
        @zzz-teo well, if it was easy it would probably already be supported ;-)
        zzz-teoZ 1 Reply Last reply
          zzz-teoZ
          zzz-teoZ
          zzz-teo
          @mfalkvidd
          ... sure! and since i'm not qualified for such task, hope this topic to alert someone and build it!
          • zzz-teoZ zzz-teo
            @mfalkvidd
            @zzz-teo what exactly are you trying to accomplish with the repeater?
              zzz-teoZ
              zzz-teoZ
              zzz-teo
              @gohan ...to have a wired backbone in a bigger vertical installation, each level has a repeater for level wireless connectivity.
                I guess at the moment you can only use repeater nodes and or use longer range radio modules
                  zzz-teoZ
                  zzz-teoZ
                  zzz-teo
                  @gohan
                  ... yes this is the only solution ... but using long range modules the network is exposed to neighborhoods and may someone be motivated to play with it!
                  By using RS485 backbone the exposed level is reduced. (as well as EMI exposure).
                  ... and by using repeaters may not be stable due to area division by Slabs.
                    That's why encryption and signing have been invented 😁
                    • zzz-teoZ
                      zzz-teoZ
                      zzz-teo
                      :laughing:
