  2. Announcements
  3. 💬 Building an Ethernet Gateway
133 Posts 42 Posters 104.4k Views 35 Watching
  • WizarDEADW
    WizarDEADW
    WizarDEAD
    Hello guys,
    Can anyone help me with modify this to work with W5500 Ethernet module?
    Please advice us what need to be modified and why it needs to be modified.
    Thanks you very much.
    • WizarDEADW WizarDEAD
      Hello guys,
      #25
      @WizarDEAD the information in https://forum.mysensors.org/topic/2901/my-ethernet-gateway-board-w5500 might be useful.
      • Chucky_69C
        Chucky_69C
        Chucky_69
        Hi Guys,
        I'm using a Wiznet W5100 Ethernet module.
        The pins are described as following (I added a numbering myself:
        0_1487281914650_upload-a05aa788-d1ac-4ef0-b42a-7ad6b28b6e9c
        The MySensors Gateway uses different terms, am I 'translating' them correctly?
        0_1487282198655_upload-1949b0d7-52ae-4059-a4e3-e68941dafbe4
        C 1 Reply Last reply
        • Chucky_69C Chucky_69
          Hi Guys,
          C
          C
          Cansher
          @Chucky_69
          Looks right!
          • fifoF
            fifoF
            fifo
            My WizNET (W5100) Ethernet module had to be connected to 5v pin on arduino as the 3.3v would only allow ping but not function properly.
            E 1 Reply Last reply
            • AndrewZA
              AndrewZA
              AndrewZ
              wrote on last edited by AndrewZ
              #29
              Maybe I just overlooked that, but is it possible to statically define netmask and gateway in the sketch? I'm using ENC28J60.
              • AndrewZA AndrewZ
                @AndrewZ I think you can use
                MY_IP_GATEWAY_ADDRESS
                MY_IP_SUBNET_ADDRESS
                AndrewZA 1 Reply Last reply
                  AndrewZA
                  AndrewZA
                  AndrewZ
                  #31
                  @mfalkvidd , yes I also found this in MQTT GW example, thanks.
                  This seems to be not working on my ENC28J60 - as I can see the the default gateway setting is not taken into account. I will test with W5100.
                  Edit: I confirm that these settings work properly with W5100, just tested.
                  • H
                    H
                    hoggin
                    I just spent a long time troubleshooting my problems trying to set this up and I thought I would share. I followed this tutorial and everything was a breeze except my unit kept rebooting and I couldn't figure out why. I thought for the longest time it was the power supply but it ended up being the version of Arduino IDE I was using. I found some answers https://forum.mysensors.org/topic/4628/solved-mysensors-2-0-ethernet-gateway-enc28j60-restart-ip-issue/46 and https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time that got me down the right path. I downgraded to "Arduino IDE 1.6.11" and that worked. I completely uninstalled arduino from my system and just started over with the older version. I assembled everything as I had done before and it just fired right up. The mysensors library I used was 2.0.0 and again it all worked perfectly. I was amazed. I didnt have to comment out the debug or do anything other than follow the tutorial EXCEPT only use 1.6.11 to upload it all.
                    Hope this helps someone in the future.
                    rejoe2R 1 Reply Last reply
                    • H hoggin
                      rejoe2R
                      rejoe2R
                      rejoe2
                      @hoggin At least according to my experience, just downgrading the AVR Board Definitions to <=1.6.11 using the Board-Manager within an recent version of the IDE should have done the trick; downgrade of the other libs including mysensors (2.1.1) was not necessary.
                      In Addition: For the serial Gateways this kind of trouble seems to be solved since version 1.6.18 of the AVR-Board definitions (shipped since several weeks).
                      H 1 Reply Last reply
                      • rejoe2R rejoe2
                        H
                        H
                        hoggin
                        @rejoe2 Perhaps you are correct. I am not nearly as well versed in this stuff as others. I was working on the Ethernet project so I didn't spend much time messing with the serial end of it.
                        • H hoggin
                          rejoe2R
                          rejoe2R
                          rejoe2
                          @hoggin I don't have experience with the ethernet part and just wanted to point out that your solution may be a little "overdone" (but I'm not sure about that).
                          Anyhow: Perhaps you should add a remark wrt. to this to your other post doubling the info you wrote here to avoid others doing tho long round instead of the direct way?
                          • H
                            H
                            hoggin
                            @rejoe2 I think you are suggesting that I create a link between this post and the other one. Here Hopefully this will direct people to more information regarding the rebooting issue i faced.
                            • H hoggin
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @hoggin The post I had in mind is this one: https://forum.mysensors.org/topic/6149/ethernet-gateway-shows-up-on-vera-but-doens-t-want-to-include-devices/17#
                              I am going to post a similar answer also there.
                              • H
                                H
                                hoggin
                                @rejoe2 Sounds good.
                                • R
                                  R
                                  RWoerz
                                  I have a Vera but I'm moving some of my stuff over to OpenHab. So on one side I was using the standard W5100 GateWay on the other I need the MQTT GateWay. The major difference is in the "define MY_PORT" one is 5003 and the other is 1883. Is there a way to do both? Thanks.
                                    @mpp said:
                                    Would it be possible to build an MQTT gateway using the ESP8266 WiFi Gateway?
                                    Yes, the MQTT gateway works on ESP as well.
                                    mppM
                                    mppM
                                    mpp
                                    @hek just tested the gateway sketch on an esp with an rfm69 and it looks really promising. Would it be possible to communicate with moteino's or do I have to create arduino+rfm69 nodes running the mysensor sketch?
                                    MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
                                    • mppM mpp
                                      #41
                                      @mpp according to this:
                                      Moteino is a low power wireless Arduino compatible development platform based on the popular ATmega328p chip used in the Arduino-UNO, making it 100% compatible with the Arduino IDE (programming environment) ... They are compatible with any other Arduino clones that use the popular HopeRF RFM69 transceiver
                                      so they should work just fine. Just upload one of the MySensors example sketches to the moteino and try.
                                        Just for sharing, yesterday I was playing around and I tried to make an ethernet gateway with a UNO with w5100 shield and a nrf24 radio, then I attached a DHT11 sensor to it; when I compiled the sketch I had to disable the MY_DEBUG otherwise the I could not upload it to the UNO as it was using 102% of available memory and even with no debug the Arduino IDE was giving me warning about low ram memory available that could make system unstable. I then removed the NRF24 part as I didn't need it at the moment and the sketch compiled smoothly.
                                        It looks like the MEGA2560 could be a better candidate if you want to make a gateway with some sensors.
                                          Sensibelchen
                                          wrote on last edited by Sensibelchen
                                          #43
                                          Solved: challenge with requesttime
                                          Update: mysensors adapter 1.0.7 for ioBroker solved the issue.
                                          Challenge:
                                          my arduino node20 is requesting epoch time. W5100 gateway forwards message to controller (ioBroker). This is the gateways console in debug:
                                          0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                                          0;255;3;0;9;Eth: 20;255;3;1;I_TIME;1491770622
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=0,pt=0,l=10,sg=0,ft=0,st=OK:1491770622
                                          0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=0,pt=0,l=10,sg=0:1491770622
                                          0;255;3;0;9;TSF:MSG:ACK
                                          The parser helps with the interpretation:
                                          1. request from node20 (Arduino) t=1 (=I_TIME)
                                          2. gateway receives epoch time from controller (ioBroker)
                                          3. gateway forwards info to node20. BUT: now with t=0 (=I_BATTERY_LEVEL)!!!!!!!!!!!!!!!
                                          4. node20 confirms battery level (and still doesn't know the time)
                                          I'm using the ordinary gateway for W5100. Sensordata moves flawless to the controller but forwarding the time seems to be broken.
                                          Any idea? Thank you in advance.
