  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
  • D
    DavidZH
    I have tried with your bootloader on 16MHz and 8 MHz with crystal.
    8MHz, crystal, 1V8
    Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
    Sketch uses 16,680 bytes (51%) of program storage space. Maximum is 32,256 bytes.
    Global variables use 942 bytes (45%) of dynamic memory, leaving 1,106 bytes for local variables. Maximum is 2,048 bytes.
    16MHz, crystal, 1V8
    Sketch uses 16,694 bytes (51%) of program storage space. Maximum is 32,256 bytes.
    So the 16Mhz file is actally even a bit bigger. I also tried if changing the BOD voltage would change anything, but nope on that.
    Might be something to look into in a spare hour.
    • mar.conteM
      mar.conteM
      mar.conte
      hy,
      can anyone tell me what is the word near cpu 8mhz-38k4-d13 etc..??
      tanks
      S 1 Reply Last reply
      • mar.conteM mar.conte
        hy,
        tanks
        Samuel235
        @mar.conte - Your question isn't very clear. If you're asking what the name means its broken down as:
        8mhz - Crystal speed/frequency
        38k4 - 38400 upload speed
        D13 - Pin 13 to flash the LED (if needed) just for visual indication that the bootloader has been burnt/installed.
        Not sure if that is what you meant but I could only assume. If not then please attempt to explain a little clearly for us :)
        Hope that sorts your problem!
        MySensors 2.1.1
        mar.conteM 1 Reply Last reply
        • S Samuel235
          mar.conteM
          mar.conteM
          mar.conte
          @Samuel235
          Sorry for my english, your answer is ok Tanks you
            @Samuel235
            Samuel235
            @mar.conte - Its okay, i understood you, just about ;)
            Now just apply that description to all of the other bootloader varients that the great @Gertsanders has provided us with :)
            MySensors 2.1.1
            • mar.conteM
              mar.conteM
              mar.conte
              Help!!!
              I have upload bootloader 8mhz 38k bod 2,7 and internal clock with sketch j gammon!!!
              Consumption 2 mh!!!
              Why?
              Tanks
                Samuel235
                I'm sorry, i don't understand the issue at hand.... Could you attempt to explain any clearer?
                MySensors 2.1.1
                • mar.conteM
                  mar.conteM
                  mar.conte
                  • S Samuel235
                    mar.conteM
                    mar.conteM
                    mar.conte
                    @Samuel235
                    Hy
                    My project is simple atmega328 with internal clock 8 mhz in powerdown mode end rfm69 hw which send to gateway when pir motion is high powered all with 2 aa battery.
                    The First test what i do is in breadboard atmega328 with optiboot 6.2 ( i have upload bootloader 8mhz internal , 38vk, bod 2v7) and simple sketch j gammon: result no microampere but around 2/5 mah in sleep mode;
                    alexsh1A 1 Reply Last reply
                      @Samuel235
                      Hy
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @mar.conte I'm not familiar with the sketch you mentioned. The best is to use the voltmeter and oscillograph to determine consumption.
                      Why do you have BOD 2.7v? I do not have any BOD - this would let a node to run on two batteries until voltage drops to below 1.9V
                      • alexsh1A alexsh1
                        mar.conteM
                        mar.conteM
                        mar.conte
                        @alexsh1
                        I have only voltmeter extec, can i mesure ua?
                        Can you send simple sketch for deep sleep ?
                        S alexsh1A 2 Replies Last reply
                          @alexsh1
                          Samuel235
                          @mar.conte - Are you basically saying that your hardware is using too much power to enable you to run on battery for any substantial time?
                          MySensors 2.1.1
                          • S Samuel235
                            mar.conteM
                            mar.conteM
                            mar.conte
                            @Samuel235
                            Yes, i want obtain few micro amp but its two month wich i try without result.....
                              @Samuel235
                              tonnerre33T
                              tonnerre33T
                              tonnerre33
                              #148
                              @mar.conte Which skecth did you use ?
                              Did you have radio errors in your log ?
                                Samuel235
                                Could you please either include your sketch here or give us a link to the example sketch that you used please.
                                MySensors 2.1.1
                                • S Samuel235
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  wrote on last edited by mar.conte
                                  #150
                                  @Samuel235
                                  Resolved
                                  I have try with sketc j gammon https://www.gammon.com.au/forum/?id=11497
                                  And the problem are pir input (model hrc-501)
                                  Are ever high and the cpu dont go in sleep.
                                  I have remove pir and all ok the atmega run 20 uah very good.
                                  Can you advise a good pir wich run to 3,3 V for my project?
                                  Tanks
                                    @Samuel235
                                    Resolved
                                    Tanks
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    #151
                                    @mar.conte
                                    im not sure why pir with simple test like this http://playground.arduino.cc/Code/PIRsense is ok
                                    but with my sketch the cpu reset forever
                                    #include <Arduino.h>            // assumes Arduino IDE v1.0 or greater
                                    #include <avr/sleep.h>
                                    #include <avr/wdt.h>
                                    #include <avr/power.h>
                                    #include <avr/io.h>
                                    ISR (PCINT2_vect)
                                      // handle pin change interrupt for D0 to D7 here
                                    }  // end of PCINT2_vect
                                    const unsigned long WAIT_TIME = 4000;
                                     const byte  LED =8 ;
                                     const byte  LED2 =9 ;
                                    int  wakepin =3 ;
                                      unsigned long lastSleep;
                                    volatile boolean motionDetected=false;
                                    float batteryVolts = 5;
                                    char BATstr[10]; //longest battery voltage reading message = 9chars
                                    char sendBuf[32];
                                    byte sendLen;
                                    void checkBattery(void);
                                    #include <RFM69.h>    //get it here: https://www.github.com/lowpowerlab/rfm69
                                    // *********** IMPORTANT SETTINGS - YOU MUST CHANGE/ONFIGURE TO FIT YOUR HARDWARE *************
                                    #define NETWORKID     100  // The same on all nodes that talk to each other
                                    #define NODEID        2    // The unique identifier of this node
                                    #define RECEIVER      1    // The recipient of packets
                                    //Match frequency to the hardware version of the radio on your Feather
                                    //#define FREQUENCY     RF69_433MHZ
                                    //#define FREQUENCY     RF69_868MHZ
                                    #define ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
                                    #define IS_RFM69HW   true // set to 'true' if you are using an RFM69HCW module
                                    #define SERIAL_BAUD   115200
                                    #define RFM69_CS      10
                                    #define RFM69_IRQ     2
                                    #define RFM69_IRQN    0  // Pin 2 is IRQ 0!
                                    #define RFM69_RST     9
                                    int16_t packetnum = 0;  // packet counter, we increment per xmission
                                    RFM69 radio = RFM69(RFM69_CS, RFM69_IRQ, IS_RFM69HW, RFM69_IRQN);
                                    void setup () {
                                      pinMode (wakepin,INPUT);
                                        pinMode(LED, OUTPUT);
                                         pinMode(LED2, OUTPUT);
                                           digitalWrite(wakepin,HIGH);
                                      char buff[50];
                                      Serial.begin(SERIAL_BAUD);
                                      Serial.println("Arduino RFM69HCW Transmitter");
                                      // Hard Reset the RFM module
                                      pinMode(RFM69_RST, OUTPUT);
                                      digitalWrite(RFM69_RST, HIGH);
                                      delay(100);
                                      digitalWrite(RFM69_RST, LOW);
                                      delay(100);
                                      // Initialize radio
                                      radio.initialize(FREQUENCY,NODEID,NETWORKID);
                                      if (IS_RFM69HW) {
                                        radio.setHighPower();    // Only for RFM69HCW & HW!
                                      radio.setPowerLevel(31); // power output ranges from 0 (5dBm) to 31 (20dBm)
                                      radio.encrypt(ENCRYPTKEY);
                                      Serial.print("\nTransmitting at ");
                                      Serial.print(FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
                                      Serial.println(" MHz");
                                    uint16_t batteryReportCycles=0;
                                    void loop ()
                                       //rf();
                                      sleepNow();
                                       rf();
                                     //radio.sleep();
                                                    // sleep function called here
                                     radio.sleep();
                                    void wake ()
                                     // cancel sleep as a precaution
                                      //sleep_disable();
                                      // precautionary while we do other stuff
                                     detachInterrupt (1);
                                    }  // end of wake
                                    void sleepNow()
                                       if (millis () - lastSleep >= WAIT_TIME)
                                        lastSleep = millis ();
                                        byte old_ADCSRA = ADCSRA;
                                        // disable ADC
                                        ADCSRA = 0;
                                        // pin change interrupt (example for D0)
                                        PCMSK2 |= bit (PCINT16); // want pin 0
                                        PCIFR  |= bit (PCIF2);   // clear any outstanding interrupts
                                        PCICR  |= bit (PCIE2);   // enable pin change interrupts for D0 to D7
                                        set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                                        power_adc_disable();
                                        power_spi_disable();
                                        power_timer0_disable();
                                        power_timer1_disable();
                                        power_timer2_disable();
                                        power_twi_disable();
                                      //PORTB = 0x00;
                                        UCSR0B &= ~bit (RXEN0);  // disable receiver
                                        UCSR0B &= ~bit (TXEN0);  // disable transmitter
                                        sleep_enable();
                                        noInterrupts ();
                                      attachInterrupt (1, wake,HIGH);
                                        digitalWrite (LED, LOW);
                                      interrupts ();
                                        sleep_cpu ();
                                       digitalWrite (LED, HIGH);
                                        sleep_disable();
                                        power_all_enable();
                                        ADCSRA = old_ADCSRA;
                                        PCICR  &= ~bit (PCIE2);   // disable pin change interrupts for D0 to D7
                                        UCSR0B |= bit (RXEN0);  // enable receiver
                                        UCSR0B |= bit (TXEN0);  // enable transmitter
                                      }  // end of time to sleep
                                    void rf()
                                     char radiopacket[20] = "Hello World #";
                                      itoa(packetnum++, radiopacket+13, 10);
                                      Serial.print("Sending "); Serial.println(radiopacket);
                                      if (!radio.sendWithRetry(RECEIVER, radiopacket, strlen(radiopacket))) { //target node Id, message as string or byte array, message length
                                        Serial.println("OK");
                                      radio.receiveDone(); //put radio in RX mode
                                      Serial.flush(); //make sure all serial data is clocked out before sleeping the MCU
                                      Samuel235
                                      Firstly, i can't read the structure the way you have posted your sketch. You should use the code function in the reply, the icon looks like "</>" above where you make your reply. Put your code in there for us to have any chance of reading it at all.
                                      Secondly, I don't think that this is the place to be posting this issue. For a start, this isn't an issue relevant to the bootloader in this thread and secondly, it doesn't even have anything to do with MySensors.
                                      MySensors 2.1.1
                                        @alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @mar.conte yes, you can measure consumption (should be in uA) while sleeping with a good voltmeter.
                                        However, I really fail to understand what has Nick's sketch you mentioned to do with MySensors? I suppose some people here may be aware of sleeping issues, but again your problem has nothing to do with MySensors.
                                        Please see the following - it may help you troubleshoot your issue
                                        https://www.mysensors.org/build/battery
                                        • S Samuel235
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @Samuel235
                                          I wanted to build my projects with mysensors, first of all I started with bootloader found in this section to try them with examples that I know because I do not know yet mysensors, I wanted to learn it so I took the liberty to insert code in your section. if you can figure out my problem thank you or I apologize for the trouble thanks
