  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
  • S Samuel235
    @mar.conte - Your question isn't very clear. If you're asking what the name means its broken down as:
    8mhz - Crystal speed/frequency
    38k4 - 38400 upload speed
    D13 - Pin 13 to flash the LED (if needed) just for visual indication that the bootloader has been burnt/installed.
    Not sure if that is what you meant but I could only assume. If not then please attempt to explain a little clearly for us :)
    Hope that sorts your problem!
    mar.conteM
    mar.conteM
    mar.conte
    @Samuel235
    Sorry for my english, your answer is ok Tanks you
    S 1 Reply Last reply
    • mar.conteM mar.conte
      @Samuel235
      Samuel235
      @mar.conte - Its okay, i understood you, just about ;)
      Now just apply that description to all of the other bootloader varients that the great @Gertsanders has provided us with :)
      MySensors 2.1.1
      • mar.conteM
        mar.conteM
        mar.conte
        Help!!!
        I have upload bootloader 8mhz 38k bod 2,7 and internal clock with sketch j gammon!!!
        Consumption 2 mh!!!
        Why?
        Tanks
          Samuel235
          I'm sorry, i don't understand the issue at hand.... Could you attempt to explain any clearer?
          MySensors 2.1.1
          mar.conteM 1 Reply Last reply
          • mar.conteM
            mar.conteM
            mar.conte
            • S Samuel235
              mar.conteM
              mar.conteM
              mar.conte
              @Samuel235
              Hy
              My project is simple atmega328 with internal clock 8 mhz in powerdown mode end rfm69 hw which send to gateway when pir motion is high powered all with 2 aa battery.
              The First test what i do is in breadboard atmega328 with optiboot 6.2 ( i have upload bootloader 8mhz internal , 38vk, bod 2v7) and simple sketch j gammon: result no microampere but around 2/5 mah in sleep mode;
              alexsh1A 1 Reply Last reply
                @Samuel235
                Hy
                alexsh1A
                alexsh1A
                alexsh1
                @mar.conte I'm not familiar with the sketch you mentioned. The best is to use the voltmeter and oscillograph to determine consumption.
                Why do you have BOD 2.7v? I do not have any BOD - this would let a node to run on two batteries until voltage drops to below 1.9V
                • alexsh1A alexsh1
                  mar.conteM
                  mar.conteM
                  mar.conte
                  @alexsh1
                  I have only voltmeter extec, can i mesure ua?
                  Can you send simple sketch for deep sleep ?
                  S alexsh1A 2 Replies Last reply
                    @alexsh1
                    Samuel235
                    @mar.conte - Are you basically saying that your hardware is using too much power to enable you to run on battery for any substantial time?
                    MySensors 2.1.1
                    • S Samuel235
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @Samuel235
                      Yes, i want obtain few micro amp but its two month wich i try without result.....
                        @Samuel235
                        tonnerre33T
                        tonnerre33T
                        tonnerre33
                        #148
                        @mar.conte Which skecth did you use ?
                        Did you have radio errors in your log ?
                          Samuel235
                          Could you please either include your sketch here or give us a link to the example sketch that you used please.
                          MySensors 2.1.1
                          • S Samuel235
                            mar.conteM
                            mar.conteM
                            mar.conte
                            wrote on last edited by mar.conte
                            #150
                            @Samuel235
                            Resolved
                            I have try with sketc j gammon https://www.gammon.com.au/forum/?id=11497
                            And the problem are pir input (model hrc-501)
                            Are ever high and the cpu dont go in sleep.
                            I have remove pir and all ok the atmega run 20 uah very good.
                            Can you advise a good pir wich run to 3,3 V for my project?
                            Tanks
                              @Samuel235
                              Resolved
                              Tanks
                              mar.conteM
                              mar.conteM
                              mar.conte
                              #151
                              @mar.conte
                              im not sure why pir with simple test like this http://playground.arduino.cc/Code/PIRsense is ok
                              but with my sketch the cpu reset forever
                              #include <Arduino.h>            // assumes Arduino IDE v1.0 or greater
                              #include <avr/sleep.h>
                              #include <avr/wdt.h>
                              #include <avr/power.h>
                              #include <avr/io.h>
                              ISR (PCINT2_vect)
                                // handle pin change interrupt for D0 to D7 here
                              }  // end of PCINT2_vect
                              const unsigned long WAIT_TIME = 4000;
                               const byte  LED =8 ;
                               const byte  LED2 =9 ;
                              int  wakepin =3 ;
                                unsigned long lastSleep;
                              volatile boolean motionDetected=false;
                              float batteryVolts = 5;
                              char BATstr[10]; //longest battery voltage reading message = 9chars
                              char sendBuf[32];
                              byte sendLen;
                              void checkBattery(void);
                              #include <RFM69.h>    //get it here: https://www.github.com/lowpowerlab/rfm69
                              // *********** IMPORTANT SETTINGS - YOU MUST CHANGE/ONFIGURE TO FIT YOUR HARDWARE *************
                              #define NETWORKID     100  // The same on all nodes that talk to each other
                              #define NODEID        2    // The unique identifier of this node
                              #define RECEIVER      1    // The recipient of packets
                              //Match frequency to the hardware version of the radio on your Feather
                              //#define FREQUENCY     RF69_433MHZ
                              //#define FREQUENCY     RF69_868MHZ
                              #define ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
                              #define IS_RFM69HW   true // set to 'true' if you are using an RFM69HCW module
                              #define SERIAL_BAUD   115200
                              #define RFM69_CS      10
                              #define RFM69_IRQ     2
                              #define RFM69_IRQN    0  // Pin 2 is IRQ 0!
                              #define RFM69_RST     9
                              int16_t packetnum = 0;  // packet counter, we increment per xmission
                              RFM69 radio = RFM69(RFM69_CS, RFM69_IRQ, IS_RFM69HW, RFM69_IRQN);
                              void setup () {
                                pinMode (wakepin,INPUT);
                                  pinMode(LED, OUTPUT);
                                   pinMode(LED2, OUTPUT);
                                     digitalWrite(wakepin,HIGH);
                                char buff[50];
                                Serial.begin(SERIAL_BAUD);
                                Serial.println("Arduino RFM69HCW Transmitter");
                                // Hard Reset the RFM module
                                pinMode(RFM69_RST, OUTPUT);
                                digitalWrite(RFM69_RST, HIGH);
                                delay(100);
                                digitalWrite(RFM69_RST, LOW);
                                delay(100);
                                // Initialize radio
                                radio.initialize(FREQUENCY,NODEID,NETWORKID);
                                if (IS_RFM69HW) {
                                  radio.setHighPower();    // Only for RFM69HCW & HW!
                                radio.setPowerLevel(31); // power output ranges from 0 (5dBm) to 31 (20dBm)
                                radio.encrypt(ENCRYPTKEY);
                                Serial.print("\nTransmitting at ");
                                Serial.print(FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
                                Serial.println(" MHz");
                              uint16_t batteryReportCycles=0;
                              void loop ()
                                 //rf();
                                sleepNow();
                                 rf();
                               //radio.sleep();
                                              // sleep function called here
                               radio.sleep();
                              void wake ()
                               // cancel sleep as a precaution
                                //sleep_disable();
                                // precautionary while we do other stuff
                               detachInterrupt (1);
                              }  // end of wake
                              void sleepNow()
                                 if (millis () - lastSleep >= WAIT_TIME)
                                  lastSleep = millis ();
                                  byte old_ADCSRA = ADCSRA;
                                  // disable ADC
                                  ADCSRA = 0;
                                  // pin change interrupt (example for D0)
                                  PCMSK2 |= bit (PCINT16); // want pin 0
                                  PCIFR  |= bit (PCIF2);   // clear any outstanding interrupts
                                  PCICR  |= bit (PCIE2);   // enable pin change interrupts for D0 to D7
                                  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                                  power_adc_disable();
                                  power_spi_disable();
                                  power_timer0_disable();
                                  power_timer1_disable();
                                  power_timer2_disable();
                                  power_twi_disable();
                                //PORTB = 0x00;
                                  UCSR0B &= ~bit (RXEN0);  // disable receiver
                                  UCSR0B &= ~bit (TXEN0);  // disable transmitter
                                  sleep_enable();
                                  noInterrupts ();
                                attachInterrupt (1, wake,HIGH);
                                  digitalWrite (LED, LOW);
                                interrupts ();
                                  sleep_cpu ();
                                 digitalWrite (LED, HIGH);
                                  sleep_disable();
                                  power_all_enable();
                                  ADCSRA = old_ADCSRA;
                                  PCICR  &= ~bit (PCIE2);   // disable pin change interrupts for D0 to D7
                                  UCSR0B |= bit (RXEN0);  // enable receiver
                                  UCSR0B |= bit (TXEN0);  // enable transmitter
                                }  // end of time to sleep
                              void rf()
                               char radiopacket[20] = "Hello World #";
                                itoa(packetnum++, radiopacket+13, 10);
                                Serial.print("Sending "); Serial.println(radiopacket);
                                if (!radio.sendWithRetry(RECEIVER, radiopacket, strlen(radiopacket))) { //target node Id, message as string or byte array, message length
                                  Serial.println("OK");
                                radio.receiveDone(); //put radio in RX mode
                                Serial.flush(); //make sure all serial data is clocked out before sleeping the MCU
                                Samuel235
                                Firstly, i can't read the structure the way you have posted your sketch. You should use the code function in the reply, the icon looks like "</>" above where you make your reply. Put your code in there for us to have any chance of reading it at all.
                                Secondly, I don't think that this is the place to be posting this issue. For a start, this isn't an issue relevant to the bootloader in this thread and secondly, it doesn't even have anything to do with MySensors.
                                MySensors 2.1.1
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @mar.conte yes, you can measure consumption (should be in uA) while sleeping with a good voltmeter.
                                  However, I really fail to understand what has Nick's sketch you mentioned to do with MySensors? I suppose some people here may be aware of sleeping issues, but again your problem has nothing to do with MySensors.
                                  Please see the following - it may help you troubleshoot your issue
                                  https://www.mysensors.org/build/battery
                                  • S Samuel235
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    @Samuel235
                                    I wanted to build my projects with mysensors, first of all I started with bootloader found in this section to try them with examples that I know because I do not know yet mysensors, I wanted to learn it so I took the liberty to insert code in your section. if you can figure out my problem thank you or I apologize for the trouble thanks
                                      Samuel235
                                      I get why you done it, but i don't understand why. You don't need to 'know' mysensors.... There is a getting started page, i suggest you take a few hours and read through everything. I'm not helping with an issue that is completely not related to mysensors while on the mysensors forum. Just simply for future readers of this thread that come here to solve their issue, if this thread is bloated out with over 10/20 replies that is not related to the question at hand its much harder for them to find their resolution here. I suggest contacting the author of the code himself as i'm pretty sure that your issue is not the bootloader.
                                      MySensors 2.1.1
                                      • S Samuel235
                                        mar.conteM
                                        mar.conteM
                                        mar.conte
                                        @Samuel235
                                        Thanks anyway, this section introduced me to some very interesting bootloader, at least with these bootloader I can get a few microamperes for my projects, I will take note of your good day and thank you tips
                                        • siodS
                                          siodS
                                          siod
                                          Hi guys,
                                          I am getting an errror when trying to burn the bootloader, any idea what´s wrong? Im using Arduino IDE 1.6.10 and these settings:
                                          0_1495966865551_upload-48973443-91a2-4504-a73b-96557383d6bf
                                          and that´s the error:
                                          avrdude: Version 6.3, compiled on Jun 22 2016 at 16:05:21
                                                   System wide configuration file is "T:\Programme\Arduino 1.6.10\hardware\tools\avr/etc/avrdude.conf"
                                                   Using Port                    : COM10
                                                   Programmer Type : STK500
                                                   Hardware Version: 2
                                                   Firmware Version: 1.18
                                                   Topcard         : Unknown
                                                   Vtarget         : 0.0 V
                                                   Varef           : 0.0 V
                                                   Oscillator      : Off
                                                   SCK period      : 0.1 us
                                          Reading | ################################################## | 100% 0.06s
                                          avrdude: erasing chip
                                          Writing | ################################################## | 100% 0.03s
                                          avrdude: verifying ...
                                          Writing |  ***failed;
                                          ################################################## | 100% 0.16s
                                          Fehler beim Brennen des Bootloaders.
                                          avrdude: verification error, first mismatch at byte 0x0000
                                                   0xfe != 0x06
                                          avrdude done.  Thank you.
                                          still learning...
