  3. STM32?
STM32?
82 Posts 19 Posters 47.2k Views 19 Watching
    Well I probably confused with another Arduino board 😌
    • alowhumA alowhum
      Cool!
      • Cheaper
      • Faster
      • More memory
      • More storage
      • 5v and lots of 3V lines
      Any downsides? How stable is the 3V line? Does it use more power?
      V
      V
      VaZso
      wrote on last edited by VaZso
      @alowhum I use the same board as dev board and it works well, I had no problems with it using STM32's own libraries.
      It has I2C, SPI, UART, even USB and 5V-tolerant inputs and so on.
      I like it. :)
        but for a battery powered sleeping node it is better a mini pro that hasn't the usb chip that drains power, right?
        V 1 Reply Last reply
          @gohan
          This ST32 board doesn't have any usb chip, and doesn't need one, because the mcu already includes this feature.
          • alowhumA
            alowhumA
            alowhum
            This board just keeps getting better and better.
            Is there a way to try out this new functionality? I coincidentally could really use a 3.3 volt Arduino with micro-USB port.
            I don't like that the Pro Mini doesn't have a micro usb port for powering it. The Digispark Pro does have it, but I don't know if MySensors supports it. More importantly, it's twice as expensive.
            • alowhumA alowhum
              @alowhum a bit off topic, but I've bought a few micro usb connectors to be able to use the ubiquitous phone chargers to power Pro Minis.
              To try out the new functionality, order a few STM32. Then use the master MySensors branch from github. https://github.com/mysensors/MySensors/pull/795 will probably have been merged by the time your boards arrive :) If they haven't you can use tekka's branch.
                Also, little sidenote, it's low power mcu i think, maybe not pico like 328p. And i don't know about the mysensors sleep functions (not implemented yet i think).
                But that said, it's a nice competitive alternative, like others ARM mcus which are very versatile :yum: (a bit more advanced than simple 8bit 328p) .
                Big thx to @tekka for his work on this nice addition, you rock :+1:
                Digispark pro may run mysensors, for very simple, no big memory task as it's using a smaller mcu than 328p for instance (i don't remember if attiny85 implementation has already been released).
                alowhumA 1 Reply Last reply
                • scalzS scalz
                  alowhumA
                  alowhumA
                  alowhum
                  Cool! I'll try that with the one I have already. In my sketches I try to make a non-sleep option, so the lack of sleep should not be a problem. Heh, funny sentence.
                  Will I also need to install the STM32 library?
                    @alowhum
                    this is starting to be a problem for me..the lack of sleep :smile:
                    yes, i think you need to follow the howto you linked (for installing the core files)
                      V
                      V
                      VaZso
                      @gohan Regarding of battery powered system...
                      From STM32CubeMX power consumption calculator, it has the following current requirements:
                      In RUN mode:
                      • at 72MHz bus frequency, it needs 27 mA
                      • at 16MHz and HSI PLL, it needs 6.8 mA
                      • at 8 MHz and HSI, it needs 4 mA
                      • at 1 MHz and HSI, it needs 900 μA
                      • at 125 kHz and HSI, it needs 480 μA
                      In STANDBY mode with all clocks off, it needs 2 μA
                      In SLEEP mode:
                      • at 125 kHz bus frequency and HSI, it needs 410 μA
                      • at 1 MHz bus freq. and HSI, it needs 440 uA
                      • at 8 MHz, it needs 600 μA
                      Enabling the following peripherals, additional consumptions are (as for example):
                      • GPIOA needs 833.75 nA
                      • GPIOD needs 816.25 nA
                      • I2C needs 1.25 μA
                      • SPI1 needs 590 nA
                      • TIMER1 needs 2.92 μA
                      • TIMER2 needs 4.06 μA
                      • TIMER4 needs 3.99 μA
                      • USART1 needs 1.49 μA
                      • USART3 needs 1.53 μA
                      • USB needs 2.22 μA
                      • Window watchdog needs 312.5 nA
                      • Independent watchdog needs 1.71 μA
                      • ADC1 needs 162.19 μA
                      These are just some examples, not all possibilities and frequencies are listed here...
                      There are also lower power STM32 series anyway.
                        I'm curious because I saw these boards few months ago but I figured that community support was still in the early stages so I kind of didn't pay much attention to them and I preferred old but tested technology 😁
                        • alowhumA
                          alowhumA
                          alowhum
                          The patch has just been added to the Mysensors Development branch, so it's easier to try out.
                          I've created a guide on how to get started on the SMT32Duino forum.
                          • alowhumA
                            alowhumA
                            alowhum
                            Heh, the STM32 doesn't have a digital pin 2 it seems. Where is the NRF supposed to connect to instead?
                            • alowhumA alowhum
                              @alowhum looks like PA3: https://github.com/mysensors/MySensors/pull/795/commits/ac432acca3d7c58eb7c8f569dc562860605ea09f#diff-58c572256858a37808c4ebd0922b4060R50
                              • alowhumA
                                alowhumA
                                alowhum
                                That's odd. I thought I had it just figured out. I'm about to test this at the top of a sketch:
                                #define MY_RF24_CE_PIN PB0
                                #define MY_RF24_CS_PIN PA4
                                #define MY_RF24_MOSI_PIN PA7
                                #define MY_RF24_MISO_PIN PA6
                                #define MY_RF24_SCK_PIN PA5
                                #define MY_RF24_IRQ_PIN PB10
                                The fun thing is all the pins are almost in a row. Almost. And if the IRQ is A3, then one more pin would line up..
                                According to this image the IRQ is pin PB10 though:
                                http://wiki.stm32duino.com/images/a/ae/Bluepillpinout.gif
                                • alowhumA alowhum
                                  @alowhum sorry I misread your question. Don't know why, but I didn't see that you were talking about the NRF.
                                  IRQ is not used for the NRF on Arduino, so I supposed it is not used for STM32 either. There is nothing about IRQ in https://github.com/mysensors/MySensors/pull/795/commits/ac432acca3d7c58eb7c8f569dc562860605ea09f#diff-cf14b6301beb3a4dbaded9b95bb190feR487
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    Really? On the Arduino nano I'm always connecting it to pin 2. It says to do so in the guide?
                                    Anyway, I haven't been able to get it to work. Perhaps some of the developers van shed some light on how it's supposed to work?
                                    tekkaT mfalkviddM 2 Replies Last reply
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @alowhum
                                      Its first in recent (develop branch?) that interrupt usage with nRF24L01 have been enabled, and only in certain scenarios.
                                      • alowhumA alowhum
                                        tekkaT
                                        tekkaT
                                        tekka
                                        wrote on last edited by tekka
                                        #24
                                        @alowhum The MySensors RF24 driver is a polling driver (unless RX queuing is enabled), hence no IRQ required.
                                        I've successfully tested the RF24 radio with this wiring on a BluePill board using MySensors 2.2.0-beta:
                                        CLK -> PA5
                                        MISO -> PA6
                                        MOSI ->PA7
                                        CSN -> PA4
                                        CE -> PB0
                                        do not forget to set:
                                        gohanG 1 Reply Last reply
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          #25
                                          Hmm, that's pretty much what I had.
                                          Could you perhaps share your example sketch?
                                          // It's working now! Turns out I had to set the radio to low power..
                                          tekkaT 1 Reply Last reply
