  3. STM32?
STM32?
82 Posts 19 Posters 47.4k Views 19 Watching
    @gohan
    This ST32 board doesn't have any usb chip, and doesn't need one, because the mcu already includes this feature.
    • alowhumA
      alowhumA
      alowhum
      This board just keeps getting better and better.
      Is there a way to try out this new functionality? I coincidentally could really use a 3.3 volt Arduino with micro-USB port.
      I don't like that the Pro Mini doesn't have a micro usb port for powering it. The Digispark Pro does have it, but I don't know if MySensors supports it. More importantly, it's twice as expensive.
      • alowhumA alowhum
        @alowhum a bit off topic, but I've bought a few micro usb connectors to be able to use the ubiquitous phone chargers to power Pro Minis.
        To try out the new functionality, order a few STM32. Then use the master MySensors branch from github. https://github.com/mysensors/MySensors/pull/795 will probably have been merged by the time your boards arrive :) If they haven't you can use tekka's branch.
          Also, little sidenote, it's low power mcu i think, maybe not pico like 328p. And i don't know about the mysensors sleep functions (not implemented yet i think).
          But that said, it's a nice competitive alternative, like others ARM mcus which are very versatile :yum: (a bit more advanced than simple 8bit 328p) .
          Big thx to @tekka for his work on this nice addition, you rock :+1:
          Digispark pro may run mysensors, for very simple, no big memory task as it's using a smaller mcu than 328p for instance (i don't remember if attiny85 implementation has already been released).
          alowhumA 1 Reply Last reply
          • scalzS scalz
            alowhumA
            alowhumA
            alowhum
            Cool! I'll try that with the one I have already. In my sketches I try to make a non-sleep option, so the lack of sleep should not be a problem. Heh, funny sentence.
            Will I also need to install the STM32 library?
              @alowhum
              this is starting to be a problem for me..the lack of sleep :smile:
              yes, i think you need to follow the howto you linked (for installing the core files)
                but for a battery powered sleeping node it is better a mini pro that hasn't the usb chip that drains power, right?
                V
                V
                VaZso
                wrote on last edited by VaZso
                @gohan Regarding of battery powered system...
                From STM32CubeMX power consumption calculator, it has the following current requirements:
                In RUN mode:
                • at 72MHz bus frequency, it needs 27 mA
                • at 16MHz and HSI PLL, it needs 6.8 mA
                • at 8 MHz and HSI, it needs 4 mA
                • at 1 MHz and HSI, it needs 900 μA
                • at 125 kHz and HSI, it needs 480 μA
                In STANDBY mode with all clocks off, it needs 2 μA
                In SLEEP mode:
                • at 125 kHz bus frequency and HSI, it needs 410 μA
                • at 1 MHz bus freq. and HSI, it needs 440 uA
                • at 8 MHz, it needs 600 μA
                Enabling the following peripherals, additional consumptions are (as for example):
                • GPIOA needs 833.75 nA
                • GPIOD needs 816.25 nA
                • I2C needs 1.25 μA
                • SPI1 needs 590 nA
                • TIMER1 needs 2.92 μA
                • TIMER2 needs 4.06 μA
                • TIMER4 needs 3.99 μA
                • USART1 needs 1.49 μA
                • USART3 needs 1.53 μA
                • USB needs 2.22 μA
                • Window watchdog needs 312.5 nA
                • Independent watchdog needs 1.71 μA
                • ADC1 needs 162.19 μA
                These are just some examples, not all possibilities and frequencies are listed here...
                There are also lower power STM32 series anyway.
                  I'm curious because I saw these boards few months ago but I figured that community support was still in the early stages so I kind of didn't pay much attention to them and I preferred old but tested technology 😁
                  • alowhumA
                    alowhumA
                    alowhum
                    The patch has just been added to the Mysensors Development branch, so it's easier to try out.
                    I've created a guide on how to get started on the SMT32Duino forum.
                    • alowhumA
                      alowhumA
                      alowhum
                      Heh, the STM32 doesn't have a digital pin 2 it seems. Where is the NRF supposed to connect to instead?
                      • alowhumA alowhum
                        @alowhum looks like PA3: https://github.com/mysensors/MySensors/pull/795/commits/ac432acca3d7c58eb7c8f569dc562860605ea09f#diff-58c572256858a37808c4ebd0922b4060R50
                        • alowhumA
                          alowhumA
                          alowhum
                          That's odd. I thought I had it just figured out. I'm about to test this at the top of a sketch:
                          #define MY_RF24_CE_PIN PB0
                          #define MY_RF24_CS_PIN PA4
                          #define MY_RF24_MOSI_PIN PA7
                          #define MY_RF24_MISO_PIN PA6
                          #define MY_RF24_SCK_PIN PA5
                          #define MY_RF24_IRQ_PIN PB10
                          The fun thing is all the pins are almost in a row. Almost. And if the IRQ is A3, then one more pin would line up..
                          According to this image the IRQ is pin PB10 though:
                          http://wiki.stm32duino.com/images/a/ae/Bluepillpinout.gif
                          • alowhumA alowhum
                            @alowhum sorry I misread your question. Don't know why, but I didn't see that you were talking about the NRF.
                            IRQ is not used for the NRF on Arduino, so I supposed it is not used for STM32 either. There is nothing about IRQ in https://github.com/mysensors/MySensors/pull/795/commits/ac432acca3d7c58eb7c8f569dc562860605ea09f#diff-cf14b6301beb3a4dbaded9b95bb190feR487
                            • alowhumA
                              alowhumA
                              alowhum
                              Really? On the Arduino nano I'm always connecting it to pin 2. It says to do so in the guide?
                              Anyway, I haven't been able to get it to work. Perhaps some of the developers van shed some light on how it's supposed to work?
                              tekkaT mfalkviddM 2 Replies Last reply
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @alowhum
                                Its first in recent (develop branch?) that interrupt usage with nRF24L01 have been enabled, and only in certain scenarios.
                                • alowhumA alowhum
                                  tekkaT
                                  tekkaT
                                  tekka
                                  wrote on last edited by tekka
                                  #24
                                  @alowhum The MySensors RF24 driver is a polling driver (unless RX queuing is enabled), hence no IRQ required.
                                  I've successfully tested the RF24 radio with this wiring on a BluePill board using MySensors 2.2.0-beta:
                                  CLK -> PA5
                                  MISO -> PA6
                                  MOSI ->PA7
                                  CSN -> PA4
                                  CE -> PB0
                                  do not forget to set:
                                  gohanG 1 Reply Last reply
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    #25
                                    Hmm, that's pretty much what I had.
                                    Could you perhaps share your example sketch?
                                    // It's working now! Turns out I had to set the radio to low power..
                                    tekkaT 1 Reply Last reply
                                    • alowhumA alowhum
                                      @alowhum said in STM32?:
                                      Well the guide also says "The IRQ is currently not used by the MySensors library so it can be left un-connected."
                                      • alowhumA alowhum
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @alowhum Perfect!
                                        • PhracturedBlueP
                                          PhracturedBlueP
                                          PhracturedBlue
                                          FYI, I didn't check the work done by tekka, but I didn't file a pull request for my 'sleep' code. I have support for using low power mode (reduce current from ~40mA to 4mA during sleep) but I had issues with reliable wakeup, so I've just switched my code to all using delay loops.
                                          Initially I was using these boards for my sensors, but there is very little benefit compared to a 3.,3V pro-mini for my usage cases, and the power is 10x more when running (and 100x more when idle without my sleep patches that don't work)
                                          I don't have any sensors that need the extra horsepower of the STM32 personally. The one benefit I did realize is having a USB serial port which removes the need for USB->TTL.
                                          F 1 Reply Last reply
                                          12.5k
