  3. Office plant monitoring
223 Posts 39 Posters 228.1k Views 42 Watching
  • Fat FlyF Fat Fly
    @joshmosh said in Office plant monitoring:
    Where i find mfalkvidd's sketch ?
    At github, but be aware that this code is for MySensors 1.x. It does not work with MySensors 2.x.
      @ronnyandre a multimeter is unfortunately not sensitive enough to display if there is enough power during the short bursts when the radio is active.
      Most step-ups don't deliver power that is stable enough. You could try adding more/larger capacitors, but from what I have seen in the forum, people seldom get thing working reliably with a step-up. I have never tried using step-up myself, I use power directly from the batteries.
      If you haven't checked already, see the troubleshooting chart at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/
      ronnyandreR
      ronnyandreR
      ronnyandre
      @mfalkvidd Thanks for the quick answer! I also read on the page for battery powered sensors that the step up generates alot of noise that can interfere with the radio, and that a solution might be to add capacitators (which I already tried), but also powering the radio directly from batteries. I'll try that later today. Thanks! :smiley:
      And thank you for the link to the troubleshooting. It's now bookmarked! :wink:
      Newbie with RPi and Domoticz, trying to automate my home.
      • Fat FlyF
        Fat FlyF
        Fat Fly
        Please somebody help me add to skech one relay for water pump. I use this in Domoticz. I do not want build other hardware for this.It is possible ?
          Just copy the relay code from https://www.mysensors.org/build/relay and add it your sketch and make necessary changes to adapt it: like setting child_id in presentation
          Fat FlyF 1 Reply Last reply
            Fat FlyF
            Fat FlyF
            Fat Fly
            @gohan I make something this. Please look if all is right. My software writer skill is low. :) Some small errors. :)
            https://pastebin.com/8LWpgb8L
              because you are using old code, you need to convert it from libraries 1.5 to 2.x: there is a guide to do that
              • Fat FlyF
                Fat FlyF
                Fat Fly
                Can i use old libraries and gateway version 2.1 ?
                  You can downgrade libraries and use old examples, but I'd suggest to stick to the new version
                  • Fat FlyF
                    Fat FlyF
                    Fat Fly
                    @gohan said in Office plant monitoring:
                    I try but idonotknow. :)
                    • Fat FlyF
                      Fat FlyF
                      Fat Fly
                      @gohan
                      Please help with small errors. https://pastebin.com/VRXyT8Ut I try for library 2.x
                      • fhenrycoF
                        fhenrycoF
                        fhenryco
                        It's a pity that at least one sketch for the analog reading of moisture sensor is not v2 compatible and made available on the main page ... i have no idea if making it v2 compatible would be a hard job...even if it's just a question of changing some library calls i'm afraid i don't have the skill for that...
                        • mfalkviddM
                          My Bonsai tree humidity node celebrates 2 years on battery today!
                          During these two years, the gateway has received 146,528 updates on humidity level (and an additional 30,870 updates on voltage level).
                          The battery level has gone from 3.187V to 3.049, which means an average drop of 0,0058V per month. Assuming I let it go down to 2.34V (limit for 8MHz according to the datasheet) and that the voltage drop is linear, I should get (3.187-2.34)/0.0058 = 146 months = ~12 years. There are several error sources in this calculation, but it looks like battery life will be quite good.
                          Here are the voltage and humidity graphs for the last year.
                          As you can see, there was a problem in November. I was asked to verify the battery voltage reading by using a multimeter. When I opened the box to do that, I must have tripped something because the node got caught in some sort of loop, consuming battery. I restarted the node and the batteries recovered almost to the level they had before the problem occurred.
                          Last year's report: https://forum.mysensors.org/post/52232
                          gohanG 1 Reply Last reply
                            @mfalkvidd said in Office plant monitoring:
                            You wish!!! :D
                              You wish!!! :D
                              #221
                              @gohan no actually I don't. The voltage drop is normally a s-shaped curve that is very flat in the middle. That means I am experiencing a higher drop at the beginning. That's likely the reason that the prediction after 2 years is more than 10% longer battery life than the prediction after 1 year was.
                                Yes, it depends when the voltage starts to drop significantly, but unless you have tested another battery before it is hard to know in advance 😀
                                  @gohan alkaline batteries in general have been tested quite extensively and don't deviate much from the S-curve characteristics.
