  3. Home Assistant
  4. rpi+mqtt+hass: persistence_file - file does not exist or is not readable
12 Posts 3 Posters 4.1k Views 3 Watching
  • M Offline
    M Offline
    monkee
    Hey guys,
    I have tried a lot but I am running out of ideas:
    Mar 28 23:48:02 raspberrypi hass[4183]: #033[0m
    Mar 28 23:48:02 raspberrypi hass[4183]: #033[32m17-03-28 23:48:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=introduction>#033[0m
    Mar 28 23:48:02 raspberrypi hass[4183]: #033[32m17-03-28 23:48:02 INFO (MainThread) [homeassistant.bootstrap] Setting up recorder#033[0m
    Mar 28 23:48:02 raspberrypi hass[4183]: #033[32m17-03-28 23:48:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>#033[0m
    Mar 28 23:48:02 raspberrypi hass[4183]: #033[32m17-03-28 23:48:02 INFO (MainThread) [homeassistant.bootstrap] Setting up logger#033[0m
    Mar 28 23:48:02 raspberrypi hass[4183]: #033[33m17-03-28 23:48:02 WARNING (Thread-5) [homeassistant.components.emulated_hue] Listen IP address not specified, auto-detected address is 192.168.1.9#033[0m
    Mar 28 23:48:07 raspberrypi hass[4183]: #033[33m17-03-28 23:48:07 WARNING (Thread-1) [mysensors.mysensors] File does not exist or is not readable: /home/homeassistant/.homeassistant/mysensors.json#033[0m
    Mar 28 23:48:07 raspberrypi hass[4183]: #033[33m17-03-28 23:48:07 WARNING (Thread-1) [mysensors.mysensors] Trying backup file: /home/homeassistant/.homeassistant/mysensors.json.bak#033[0m
    Mar 28 23:48:07 raspberrypi hass[4183]: #033[33m17-03-28 23:48:07 WARNING (Thread-1) [mysensors.mysensors] File does not exist or is not readable: /home/homeassistant/.homeassistant/mysensors.json.bak#033[0m
    Mar 28 23:48:07 raspberrypi hass[4183]: #033[33m17-03-28 23:48:07 WARNING (Thread-1) [mysensors.mysensors] Failed to load sensors from file: /home/homeassistant/.homeassistant/mysensors.json#033[0m
    Mar 28 23:48:18 raspberrypi hass[4183]: #033[32m17-03-28 23:48:18 INFO (Thread-14) [mysensors.mysensors] Setting up initial MQTT topic subscription#033[0m
    Mar 28 23:48:18 raspberrypi hass[4183]: #033[36m17-03-28 23:48:18 DEBUG (Thread-14) [mysensors.mysensors] Subscribing to: P/+/+/0/+/+#033[0m
    Mar 28 23:48:18 raspberrypi hass[4183]: #033[36m17-03-28 23:48:18 DEBUG (Thread-14) [mysensors.mysensors] Subscribing to: P/+/+/3/+/+#033[0m
    415 mysensors:
    416   gateways:
    417     - device: mqtt
    418       persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
    419 #      persistence_file: '/home/pi/mysensors.json'
    420 #      persistence_file: '/tmp/mysensors-moist.json'
    421       #topic_in_prefix: 'mygateway1-out'
    422       topic_in_prefix: 'P'
    423       #topic_out_prefix: 'mygateway1-in'
    424       topic_out_prefix: 'S'
    425   debug: true
    426   optimistic: false
    427   persistence: true
    428   retain: true
    429   version: 2.0
    Anybody knows why I cant create the persistance file?
    • M monkee
      Hey guys,
      415 mysensors:
      416   gateways:
      417     - device: mqtt
      425   debug: true
      428   retain: true
      429   version: 2.0
      martinhjelmareM Offline
      martinhjelmare
      @monkee
      Hi!
      The persistence file will be created automatically when the first updates come in from your sensor(s). The first time you start home assistant with mysensors activated, this log warning is expected.
        @monkee
        Hi!
        M Offline
        M Offline
        monkee
        @martinhjelmare
        Thank you for your reply.
        I am using the moisture sensor. https://www.mysensors.org/build/moisture
        I just copied the sketch. As far as I understand it, there are no changes necessary.
        This is some output from the Arduino Seriel Monitor:
        112455 TSM:ID:REQ
        112458 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        114465 !TSM:ID:FAIL
        114466 TSM:FAIL:CNT=6
        114468 TSM:FAIL:PDT
        124471 TSM:FAIL:RE-INIT
        124473 TSM:INIT
        124480 TSM:INIT:TSP OK
        124482 TSM:FPAR
        124485 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        124566 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        124571 TSF:MSG:FPAR OK,ID=0,D=1
        126493 TSM:FPAR:OK
        126494 TSM:ID
        126496 TSM:ID:REQ
        126499 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        128506 TSM:ID
        128507 TSM:ID:REQ
        128510 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        130518 TSM:ID
        130519 TSM:ID:REQ
        130522 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        132529 TSM:ID
        132530 TSM:ID:REQ
        132533 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        134540 !TSM:ID:FAIL
        134541 TSM:FAIL:CNT=7
        134544 TSM:FAIL:PDT
        194546 TSM:FAIL:RE-INIT
        194548 TSM:INIT
        194555 TSM:INIT:TSP OK
        194557 TSM:FPAR
        194561 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        194913 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        194918 TSF:MSG:FPAR OK,ID=0,D=1
        196569 TSM:FPAR:OK
        196570 TSM:ID
        196572 TSM:ID:REQ
        196575 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        198582 TSM:ID
        198583 TSM:ID:REQ
        198586 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        200593 TSM:ID
        200594 TSM:ID:REQ
        200597 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        202604 TSM:ID
        202605 TSM:ID:REQ
        202608 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        204615 !TSM:ID:FAIL
        204616 TSM:FAIL:CNT=7
        204618 TSM:FAIL:PDT
        This is some output from the mysgw.service
        ( tail -n 40 -F /var/log/syslog | grep mysgw)
        Mar 29 17:36:52 raspberrypi mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        Mar 29 17:36:52 raspberrypi mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
        Mar 29 17:37:56 raspberrypi mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Mar 29 17:37:56 raspberrypi mysgw: TSF:MSG:BC
        Mar 29 17:37:56 raspberrypi mysgw: TSF:MSG:FPAR REQ,ID=255
        Mar 29 17:37:56 raspberrypi mysgw: TSF:PNG:SEND,TO=0
        Mar 29 17:37:56 raspberrypi mysgw: TSF:CKU:OK
        Mar 29 17:37:56 raspberrypi mysgw: TSF:MSG:GWL OK
        Mar 29 17:37:56 raspberrypi mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        Mar 29 17:37:58 raspberrypi mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        Mar 29 17:37:58 raspberrypi mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
        Mar 29 17:38:02 raspberrypi mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        Mar 29 17:38:02 raspberrypi mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
        Mar 29 17:39:06 raspberrypi mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Mar 29 17:39:06 raspberrypi mysgw: TSF:MSG:BC
        Mar 29 17:39:06 raspberrypi mysgw: TSF:MSG:FPAR REQ,ID=255
        Mar 29 17:39:06 raspberrypi mysgw: TSF:PNG:SEND,TO=0
        Mar 29 17:39:06 raspberrypi mysgw: TSF:CKU:OK
        Mar 29 17:39:06 raspberrypi mysgw: TSF:MSG:GWL OK
        Mar 29 17:39:07 raspberrypi mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        Mar 29 17:39:08 raspberrypi mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        Mar 29 17:39:08 raspberrypi mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
        Mar 29 17:39:10 raspberrypi mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        Mar 29 17:39:10 raspberrypi mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
        Mar 29 17:39:12 raspberrypi mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        Mar 29 17:39:12 raspberrypi mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
        Mar 29 17:39:14 raspberrypi mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
        Mar 29 17:39:14 raspberrypi mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
        Can you help me understand those logs? As far as I interpret it, the moisture sensor runs (but gets no ID from time to time?!) (346778 !TSM:ID:FAIL)....
        Does my moisture sensor send updates? Does it work?
        Thank you!
        gohanG martinhjelmareM 3 Replies Last reply
        • M monkee
          @martinhjelmare
          112455 TSM:ID:REQ
          114465 !TSM:ID:FAIL
          114468 TSM:FAIL:PDT
          124473 TSM:INIT
          124482 TSM:FPAR
          126493 TSM:FPAR:OK
          126494 TSM:ID
          126496 TSM:ID:REQ
          128506 TSM:ID
          128507 TSM:ID:REQ
          130518 TSM:ID
          130519 TSM:ID:REQ
          132529 TSM:ID
          132530 TSM:ID:REQ
          134540 !TSM:ID:FAIL
          134544 TSM:FAIL:PDT
          194548 TSM:INIT
          194557 TSM:FPAR
          196569 TSM:FPAR:OK
          196570 TSM:ID
          196572 TSM:ID:REQ
          198582 TSM:ID
          198583 TSM:ID:REQ
          200593 TSM:ID
          200594 TSM:ID:REQ
          202604 TSM:ID
          202605 TSM:ID:REQ
          204615 !TSM:ID:FAIL
          204618 TSM:FAIL:PDT
          Thank you!
          @monkee If no ID set it can not work. Try running the clear eeprom sketch and reload your sketch and set ID 2 or 3
          • M monkee
            @martinhjelmare
            112455 TSM:ID:REQ
            114465 !TSM:ID:FAIL
            114468 TSM:FAIL:PDT
            124473 TSM:INIT
            124482 TSM:FPAR
            126493 TSM:FPAR:OK
            126494 TSM:ID
            126496 TSM:ID:REQ
            128506 TSM:ID
            128507 TSM:ID:REQ
            130518 TSM:ID
            130519 TSM:ID:REQ
            132529 TSM:ID
            132530 TSM:ID:REQ
            134540 !TSM:ID:FAIL
            134544 TSM:FAIL:PDT
            194548 TSM:INIT
            194557 TSM:FPAR
            196569 TSM:FPAR:OK
            196570 TSM:ID
            196572 TSM:ID:REQ
            198582 TSM:ID
            198583 TSM:ID:REQ
            200593 TSM:ID
            200594 TSM:ID:REQ
            202604 TSM:ID
            202605 TSM:ID:REQ
            204615 !TSM:ID:FAIL
            204618 TSM:FAIL:PDT
            Thank you!
            martinhjelmare
            @monkee
            If you have the controller connected, ie home assistant, it should answer the request for ID. That doesn't seem to happen.
              M Offline
              M Offline
              monkee
              wrote on last edited by monkee
              @gohan Did as you suggested (cleared the rom) and changed the line from "#define CHILD_ID 0" to "#define CHILD_ID 3". Now I get:
              3 TSM:INIT
              6 TSF:WUR:MS=0
              13 TSM:INIT:TSP OK
              15 !TSF:SID:FAIL,ID=0
              17 TSM:FAIL:CNT=1
              18 TSM:FAIL:PDT
              10021 TSM:FAIL:RE-INIT
              10023 TSM:INIT
              10031 TSM:INIT:TSP OK
              10033 !TSF:SID:FAIL,ID=0
              10035 TSM:FAIL:CNT=2
              10037 TSM:FAIL:PDT
              20040 TSM:FAIL:RE-INIT
              20042 TSM:INIT
              20049 TSM:INIT:TSP OK
              20051 !TSF:SID:FAIL,ID=0
              20054 TSM:FAIL:CNT=3
              20056 TSM:FAIL:PDT
              30059 TSM:FAIL:RE-INIT
              30061 TSM:INIT
              30068 TSM:INIT:TSP OK
              30070 !TSF:SID:FAIL,ID=0
              30072 TSM:FAIL:CNT=4
              @martinhjelmare
              I have the controller connected? Means I have started home-assistant on a rpi (connected with the sensor network i hope, as explained here https://www.mysensors.org/build/raspberry ) What could be wrong?
              gohanG martinhjelmareM 2 Replies Last reply
              • M monkee
                3 TSM:INIT
                6 TSF:WUR:MS=0
                13 TSM:INIT:TSP OK
                17 TSM:FAIL:CNT=1
                18 TSM:FAIL:PDT
                10023 TSM:INIT
                10037 TSM:FAIL:PDT
                20042 TSM:INIT
                20056 TSM:FAIL:PDT
                30061 TSM:INIT
                @martinhjelmare
                @monkee
                it still tries to assign ID 0. Don't you have another arduino to try just to be safe?
                • M monkee
                  3 TSM:INIT
                  6 TSF:WUR:MS=0
                  13 TSM:INIT:TSP OK
                  17 TSM:FAIL:CNT=1
                  18 TSM:FAIL:PDT
                  10023 TSM:INIT
                  10037 TSM:FAIL:PDT
                  20042 TSM:INIT
                  20056 TSM:FAIL:PDT
                  30061 TSM:INIT
                  @martinhjelmare
                  martinhjelmare
                  @monkee
                  Child id is not the same as node id. Use MY_NODE_ID if you want to set a static node id in the sketch.
                  gohanG 1 Reply Last reply
                  • M monkee
                    @martinhjelmare
                    112455 TSM:ID:REQ
                    114465 !TSM:ID:FAIL
                    114468 TSM:FAIL:PDT
                    124473 TSM:INIT
                    124482 TSM:FPAR
                    126493 TSM:FPAR:OK
                    126494 TSM:ID
                    126496 TSM:ID:REQ
                    128506 TSM:ID
                    128507 TSM:ID:REQ
                    130518 TSM:ID
                    130519 TSM:ID:REQ
                    132529 TSM:ID
                    132530 TSM:ID:REQ
                    134540 !TSM:ID:FAIL
                    134544 TSM:FAIL:PDT
                    194548 TSM:INIT
                    194557 TSM:FPAR
                    196569 TSM:FPAR:OK
                    196570 TSM:ID
                    196572 TSM:ID:REQ
                    198582 TSM:ID
                    198583 TSM:ID:REQ
                    200593 TSM:ID
                    200594 TSM:ID:REQ
                    202604 TSM:ID
                    202605 TSM:ID:REQ
                    204615 !TSM:ID:FAIL
                    204618 TSM:FAIL:PDT
                    Thank you!
                    martinhjelmare
                    @monkee
                    I see a problem. Your topic prefix reported in the gateway log is not the same as the prefixes you have set in the home assistant config for mysensors.
                      @monkee
                      @martinhjelmare said in rpi+mqtt+hass: persistence_file - file does not exist or is not readable:
                      @monkee
                      woops, I missed that. I answered while at work and I was in a hurry :D
                        @monkee
                        M Offline
                        M Offline
                        monkee
                        @gohan
                        New Arduino wired and conncted, uploaded sketch, etc.
                        Same result.
                        @martinhjelmare
                        I changed the hass cfg to:
                        417 mysensors:
                        418   gateways:
                        419     - device: mqtt
                        420       persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
                        421       topic_in_prefix: 'mysensors-out'
                        422       topic_out_prefix: 'mysensors-in'
                        Now its the same as reported in the gateway log...
                        Its working. Thanks guys!
                        One last question, just to be clear:
                        Its fine to have "#define CHILD_ID 0", right?
                          that is used later in the presentation
