  3. DHT11 Arduino pro mini no temp readings
13 Posts 5 Posters 5.3k Views 4 Watching
  • tonnerre33T
    tonnerre33T
    tonnerre33
    Hi, which sensor do you use ?
    A DHT put on a pcb or without pcb ?
    If you haven't a DHT with pcb, you need to put a 5k resistor between pin 1 and 2 of the DHT ;)
    More information here : https://www.mysensors.org/dl/57c3ec0c4d04abe84cd93e0f/design/DHT11.pdf
    • tonnerre33T tonnerre33
      Mr_sensor
      @tonnerre33 No I have one with pcb.
      • M Mr_sensor
        Mr_sensor
        @Mr_sensor Stil get the message
        Failed reading temperature from DHT!
        Failed reading humidity from DHT
        Also tried it with an dh22 I had (included a pull-up resistor between vcc and data) but get the same result. What can I do to get this working?
        If I use the arduino pro mini for an other sensor they are working fine (tested with a magnet-reed switch).
          have you set all the waiting/delay times and the initialization before reading the temperature (as seen in the examples)?
            Mr_sensor
            This is the sketch I'm using.
             * Version 1.0: Henrik EKblad
             * sensor using a DHT11/DHT-22.
            #define MY_NODE_ID 2
            #define MY_PARENT_NODE_ID 0
            // Enable debug prints
            //#define MY_RS485
            #define DHT_DATA_PIN 3
            #define SENSOR_TEMP_OFFSET 0
            static const uint64_t UPDATE_INTERVAL = 60000;
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            float lastTemp;
            float lastHum;
            uint8_t nNoUpdatesTemp;
            uint8_t nNoUpdatesHum;
            bool metric = true;
            DHT dht;
              sendSketchInfo("TemperatureAndHumidity", "1.1");
              present(CHILD_ID_HUM, S_HUM);
              dht.readSensor(true);
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                // Reset no updates counter
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                Serial.print("T: ");
                nNoUpdatesTemp++;
              if (isnan(humidity)) {
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                Serial.print("H: ");
                Serial.println(humidity);
                nNoUpdatesHum++;
              sleep(UPDATE_INTERVAL);
              Mr_sensor
              since I did not get these Dht11 or Dht22 working, I decided to try an other sensor type to see if that would work better.
              So I connected a HTU21D sensor and included the library from sparkfun. Using there demo sketch I can see the sensor is working fine:
              HTU21D Example!
              Time:192 Temperature:20.8C Humidity:998.0%
              Time:1318 Temperature:20.8C Humidity:47.3%
              Time:2445 Temperature:20.7C Humidity:47.4%
              Time:3571 Temperature:20.7C Humidity:47.4%
              Time:4698 Temperature:20.7C Humidity:47.5%
              Time:5824 Temperature:20.7C Humidity:47.5%
              Time:6948 Temperature:20.7C Humidity:47.6%
              Time:8075 Temperature:20.7C Humidity:47.6%
              Time:9201 Temperature:20.7C Humidity:47.6%
              But when I include the "adapted" Mysensors sketch I found here in the forum it seems the temperatures are not read or something else is wrong?
              This is what is in the log file in a ongoing loop:
              MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1
              4 TSM:INIT
              4 TSF:WUR:MS=0
              12 TSM:INIT:TSP OK
              14 TSM:INIT:STATID=2
              16 TSF:SID:OK,ID=2
              18 TSM:FPAR
              18 TSM:FPAR:STATP=0
              20 TSM:ID
              22 TSM:ID:OK
              22 TSM:UPL
              28 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              47 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              53 TSF:MSG:PONG RECV,HP=1
              55 TSM:UPL:OK
              57 TSM:READY:ID=2,PAR=0,DIS=1
              63 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              75 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              86 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              96 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2107 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:Humidity
              2119 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
              2129 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2140 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              2146 MCO:REG:REQ
              2164 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              2220 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              2226 MCO:PIM:NODE REG=1
              2228 MCO:BGN:INIT OK,TSP=1
              2 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1
              6 TSM:INIT
              6 TSF:WUR:MS=0
              14 TSM:INIT:TSP OK
              16 TSM:INIT:STATID=2
              18 TSF:SID:OK,ID=2
              20 TSM:FPAR
              20 TSM:FPAR:STATP=0
              22 TSM:ID
              24 TSM:ID:OK
              26 TSM:UPL
              30 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              57 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              63 TSF:MSG:PONG RECV,HP=1
              67 TSM:UPL:OK
              67 TSM:READY:ID=2,PAR=0,DIS=1
              73 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              92 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              102 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              112 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2121 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:Humidity
              2134 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
              2144 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2154 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              2160 MCO:REG:REQ
              2234 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              2240 MCO:PIM:NODE REG=1
              2242 MCO:BGN:INIT OK,TSP=1
              This is the sketch I use now I had to adopt it since it seemed to be for an older version of Mysensors. I'm no programmer so it might be messed up somehow :)
               HTU21D Humidity Sensor
               Hardware Connections (Breakoutboard to Arduino):
               -VCC = 3.3V
               -GND = GND
               -SDA = A4 (use inline 330 ohm resistor if your board is 5V)
               -SCL = A5 (use inline 330 ohm resistor if your board is 5V)
              //#define MY_RS485
              #include "SparkFunHTU21D.h"
              //static const uint8_t FORCE_UPDATE_N_READS = 10;
              float lastTemp;
              float lastHum;
              boolean metric = true;
                sendSketchInfo("Humidity", "2.0");
                //metric = getControllerConfig().isMetric;
              unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
              HTU21D myHumidity;
                float temperature = myHumidity.readTemperature();
                //if (!metric) {
                //    temperature = (temperature * 1.8) + 32.0;
                float humidity = myHumidity.readHumidity();
              Can anyone advise me on the code and the error log so I understand what's going on and what needs to be done to get it working? Thanks a lot.
              W.
              • M Mr_sensor
                HTU21D Example!
                4 TSM:INIT
                4 TSF:WUR:MS=0
                12 TSM:INIT:TSP OK
                16 TSF:SID:OK,ID=2
                18 TSM:FPAR
                18 TSM:FPAR:STATP=0
                20 TSM:ID
                22 TSM:ID:OK
                22 TSM:UPL
                55 TSM:UPL:OK
                2146 MCO:REG:REQ
                6 TSM:INIT
                6 TSF:WUR:MS=0
                14 TSM:INIT:TSP OK
                18 TSF:SID:OK,ID=2
                20 TSM:FPAR
                20 TSM:FPAR:STATP=0
                22 TSM:ID
                24 TSM:ID:OK
                26 TSM:UPL
                67 TSM:UPL:OK
                2160 MCO:REG:REQ
                 -VCC = 3.3V
                 -GND = GND
                //#define MY_RS485
                float lastTemp;
                float lastHum;
                HTU21D myHumidity;
                  //if (!metric) {
                W.
                @Mr_sensor I think you need to add
                    myHumidity.begin();
                Without that, the sensor/sensor library is not initialized.
                (I looked at sparkfun's example sketch)
                  Mr_sensor
                  wrote on last edited by Mr_sensor
                  :) Great! That helped a lot. I Kicked that out when reading the Converting a sketch from 1.5 to 2.x article.
                  4911 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.4
                  4954 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:50.2
                  4962 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  4968 MCO:SLP:TPD
                  Now I only have to find out what to use for mqtt to read this sensor values. Thats still not very clear to me:
                  Guess it would be something like:
                  mygateway1-out/2/2/0/0/ or 2/2/0/0/1 ?
                  Would it be possible to have something like this:
                  mygateway-out/2/2/Temperature ?
                    Mr_sensor
                    Ok found out what topic is send to mqtt turned out to be:
                    mygateway1-out/2/1/1/0/1 or mygateway1-out/2/0/1/0/1
                    How to get an % and "C" to this topic value?
                      Just use any mqtt client and subscribe to topic # , you will be able to see all messages and pick the one you are looking for
                      12.5k
