  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • S shabba
    @sundberg84 thanks - I had a look in the design files and I think I covered the comments but could not find a .stl file.
    sundberg84S
    sundberg84S
    @shabba - sorry you are right.
    If i remember right I removed it because I wasnt 100% sure it would be ok going from 4.0 to 4.1 on the pcb.
    Let me have a look and post it asap.
    • bmokenaB
      bmokenaB
      bmokena
      Hi sundberg84,
      I bought 10 of these PCBs. So can I use this PCB, add a relay and fuse and use it inside the wall to control light switches? or should I go rather go for the other PCB "In Wall AC/DC Pcb (with Relay) for MySensors (SMD)" ?
      Bob
      • bmokenaB bmokena
        Hi sundberg84,
        Bob
        sundberg84S
        sundberg84S
        @bmokena - if it fits, that should be ok. This PCB is made a more generic pcb so you can add any sensor/accuator to it including a relay. Use the MysX i/o and you can controll your relay through D3 for example.
        • sundberg84S sundberg84
          @shabba - PCB only.
          I recommend using 3dhubs.com and find a local 3d printer for the case.
          Files (.stl) attached in the project.
          J
          J
          johmei
          @sundberg84
          Hi, do you have any local Swedish printing services to recommend?
          Ps. Got the PCBs from Pcbway yesterday and man was I surprised how small they were. Looks great and hope to get some nodes up and running soon, once all components get here.
          • J johmei
            @sundberg84
            sundberg84S
            sundberg84S
            @johmei - sorry, I wish i had any good recommendations for local PCB service.
            The only research I have done leads me to that they are VERY expensive compared to these 10x10 chinese.
            Good luck with your build! Images are always appreciated! ;)
            • J
              J
              johmei
              @sundberg84 - Thanks, but I was thinking about 3D printing services for boxes, cases and mounts in very small series (maybe even singles)?!
              Regarding images we'll see if I manage to get any AC stuff going anytime soon. I have a lot of respect for AC and probably want to get to know the Arduino platform a bit more first. Got my first couple of regular DC nodes running yesterday and they have been running really well for 12 hours now (impressed of the small nrf24+ radio range). So many ideas to explore. =)
              Actually ordered a set of your newbie PCBs a few days after my In wall AC PCB order so there will be a lot your autograph around my house..
              • J johmei
                sundberg84S
                sundberg84S
                @johmei - haha, I hope they will help you some in your quest for HA. About 3d printing I use 3dhubs.com and have tried different once and been satisfied. Go for one at your location if you want to pick up. I use one in Kalmar with shipping I can recommend.
                • J
                  J
                  johmei
                  Can't help myself but have to see if I can get a AC node going. question regarding capacitors: C1 is specified as 10uF in the circuit diagram but the BOM states 0,1, 1,0, 4,7 uF capacitors. What is the recommendation from the creator? Thanks
                  • J johmei
                    sundberg84S
                    sundberg84S
                    @johmei - you are right and the BOM is updated.
                    C1 should be a 10uF in my schematics, but its optional. Its recommended to have one higher and one 0.1uF capacitor with the voltage regulator since they can help avoiding spikes and drops.
                      smilvert
                      @sundberg84 Which housing are you using to this project? Can't find the stl-file. Does the 3dBoxWRelay.stl from the smd-project work here as well?
                      • S smilvert
                        sundberg84S
                        sundberg84S
                        @smilvert - No, Im not sure.
                        I have not made a 3d box to the new version - let me have a look at that. Im working all weekend but i will look into it asap.
                        • J
                          J
                          johmei
                          Looking at the images and schematics(V4.1) it looks like the 18B20 and LE33 are soldered in the wrong way?! old images or am I looking at this wrong?
                          Still waiting for slow blow fuses so not ready to test yet.
                          • J johmei
                            sundberg84S
                            sundberg84S
                            @johmei - some parts was supposed to be soldered from the bottom side, so it depends :)
                            Keep it in mind when you are building. I might have to make this more clear somehow on the PCB as well.
                            • J
                              J
                              johmei
                              Ok, I was reffering to the pictures of the assembled board. My half done Node (no AC) works well with the two components "the other way". confised Traced the PCB connections before testing with 5VDC. =) As long as everyone double checks what they are doing it is no problem.
                              • J johmei
                                sundberg84S
                                sundberg84S
                                @johmei - "everyone doublecheck what they are doing" = that is a problem ;)
                                I will make a note on the page and change whats needed for next rev, thanks for notising!
                                • J
                                  J
                                  johmei
                                  After quite a bit of abuse from resoldering components as I completely screwed up the order of things to get soldered I got the first couple of AC nodes running. These will be discarded once I get new Mini Pros to make fresh nodes without messing them up too much with my hot soldering iron. Been running them for 12 hours yesterday and everything seems fine. Great work on designing the PCBs @Sundberg84!
                                  One tip is to cool the thermal cutoffs well while soldering. I broke the first one cooling it with pliers + aligator clip. Next I used water soaked paper around components and legs with great results. Just be mindful not to soak "the wrong components".
                                  <blockquote class="imgur-embed-pub" lang="en" data-id="a/DBln7"><a href="//imgur.com/DBln7"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
                                  • J johmei
                                    sundberg84S
                                    sundberg84S
                                    @johmei - thank you! All tips for future revisions are appreciated! Let me know if I can do anything better and good luck with your nodes!
                                    • J
                                      J
                                      johmei
                                      I think the nodes seem to run really well with minimal produced heat. Do you think there will be a 3D case design for the latest version PCB? Unfortunately I have no knowledge in 3D design to contribute.
                                      • J johmei
                                        sundberg84S
                                        sundberg84S
                                        @johmei - sorry, its been on my list as you probably see above.
                                        I will try to make one asap!
                                        • sundberg84S
                                          sundberg84S
                                          Finally I made the changes to the silk-screen so the orientation of the LE33 and Dallas temp sensor is right.
                                          Project updated and sent new revision to PCB manufacturer. The right revision if you want to buy should be Rev 4 which is the latest files (PCB Rev 4.1)
