  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • sundberg84S sundberg84
    @Sefi-Ninio - Yea I should. Im working on Rev 4 and there is more creepage both between primary (220) and secondary (5) and also internally in primary. Everything is ordered but nothing recieved yet, but let me give you a small peak:
    GertSandersG
    GertSandersG
    GertSanders
    @sundberg84
    Very nice board !
    • sundberg84S
      sundberg84S
      • Sefi NinioS
        Sefi NinioS
        Sefi Ninio
        SMD is easier with solder paste and hot air solder
        • sundberg84S
          sundberg84S
          #30
          This PCB has been updated to Rev 4.1 with the following changes:
          (Note that this thread contains the non SMD version)
          • Complete redesign of traces to improve size and stability.
          • Nrf24l01+ now on the bottom side to make more room (with hope not RF disturbace from HLK or AC traces).
          • Added silkmask with AC-DC seperation (Rev 4.1 > 5mm)
          • AC clearance 2.5mm minimum
          • Changed one AC trace from botton to top to increace creepage and changed milling
          • MysX 2.3 + Analog IO
          • Safety recommendations: This PCB meets the criteria of pollution level II (2,5mm (Basic) AC seperation and 5mm (Reinforced) AC-DC sepertion) and can be used "where only non-conductive contamination occurs. However, occasional temporary conductivity must be expected as a result of moisture condensation." Always use a sealed case to avoid contamination. Always read disclaimer.txt before using this PCB.
          Images on https://www.openhardware.io/view/13/In-Wall-ACDC-Pcb-for-MySensors has been updated.
          Please wait for PCB house to update to new gerber files before ordering (It should say M.Rev 2 (Manufacturer rev 2) for latest revision when selecting PCB house)
          Im currently testing this rev...
          If you want to be 100% sure, download and prev. revision.
          • carthiqueC
            carthiqueC
            carthique
            Can someone please suggest replacement parts for the 110v variant of this board.
            Karthik
            • carthiqueC carthique
              Karthik
              sundberg84S
              sundberg84S
              @carthique - You need a 110 v varistor maybe something like: http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT&rmvSB=true. Fuses and other components is the same.
              • ashwayA
                ashwayA
                ashway
                @sundberg84, when I go to the order form, the revision there is M.Rev3. Which version of PCB does that manufacturer revision correspond to - 3.1 or 4.1???
                • ashwayA ashway
                  sundberg84S
                  sundberg84S
                  @ashway - this is correct/latest version. The manufacturer rev 3 equals the latest 4.1.
                    shabba
                    Excuse the possibly silly question but the buy options is PCBs only? Or does it come with the housing too?
                    • S shabba
                      sundberg84S
                      sundberg84S
                      @shabba - PCB only.
                      I recommend using 3dhubs.com and find a local 3d printer for the case.
                      Files (.stl) attached in the project.
                      J 1 Reply Last reply
                        shabba
                        @sundberg84 thanks - I had a look in the design files and I think I covered the comments but could not find a .stl file.
                        • S shabba
                          sundberg84S
                          sundberg84S
                          @shabba - sorry you are right.
                          If i remember right I removed it because I wasnt 100% sure it would be ok going from 4.0 to 4.1 on the pcb.
                          Let me have a look and post it asap.
                          • bmokenaB
                            bmokenaB
                            bmokena
                            Hi sundberg84,
                            I bought 10 of these PCBs. So can I use this PCB, add a relay and fuse and use it inside the wall to control light switches? or should I go rather go for the other PCB "In Wall AC/DC Pcb (with Relay) for MySensors (SMD)" ?
                            Bob
                            • bmokenaB bmokena
                              Hi sundberg84,
                              Bob
                              sundberg84S
                              sundberg84S
                              @bmokena - if it fits, that should be ok. This PCB is made a more generic pcb so you can add any sensor/accuator to it including a relay. Use the MysX i/o and you can controll your relay through D3 for example.
                                @shabba - PCB only.
                                J
                                J
                                johmei
                                @sundberg84
                                Hi, do you have any local Swedish printing services to recommend?
                                Ps. Got the PCBs from Pcbway yesterday and man was I surprised how small they were. Looks great and hope to get some nodes up and running soon, once all components get here.
                                • J johmei
                                  @sundberg84
                                  sundberg84S
                                  sundberg84S
                                  @johmei - sorry, I wish i had any good recommendations for local PCB service.
                                  The only research I have done leads me to that they are VERY expensive compared to these 10x10 chinese.
                                  Good luck with your build! Images are always appreciated! ;)
                                  • J
                                    J
                                    johmei
                                    @sundberg84 - Thanks, but I was thinking about 3D printing services for boxes, cases and mounts in very small series (maybe even singles)?!
                                    Regarding images we'll see if I manage to get any AC stuff going anytime soon. I have a lot of respect for AC and probably want to get to know the Arduino platform a bit more first. Got my first couple of regular DC nodes running yesterday and they have been running really well for 12 hours now (impressed of the small nrf24+ radio range). So many ideas to explore. =)
                                    Actually ordered a set of your newbie PCBs a few days after my In wall AC PCB order so there will be a lot your autograph around my house..
                                    • J johmei
                                      sundberg84S
                                      sundberg84S
                                      @johmei - haha, I hope they will help you some in your quest for HA. About 3d printing I use 3dhubs.com and have tried different once and been satisfied. Go for one at your location if you want to pick up. I use one in Kalmar with shipping I can recommend.
                                      • J
                                        J
                                        johmei
                                        Can't help myself but have to see if I can get a AC node going. question regarding capacitors: C1 is specified as 10uF in the circuit diagram but the BOM states 0,1, 1,0, 4,7 uF capacitors. What is the recommendation from the creator? Thanks
                                        • J johmei
                                          sundberg84S
                                          sundberg84S
                                          @johmei - you are right and the BOM is updated.
                                          C1 should be a 10uF in my schematics, but its optional. Its recommended to have one higher and one 0.1uF capacitor with the voltage regulator since they can help avoiding spikes and drops.
