  3. Home Assistant
  4. New nodes, new problems :/ Motion sensor [Solved]
10 Posts 4 Posters 4.3k Views 5 Watching
  • xydixX
    xydixX
    xydix
    wrote on last edited by xydix
    I have a new node, a motion sensor node with repeater.
    Sometimes, when another node change state and communicates through my new repeating node or if another node searching for a new parent, the new repeating node triggers the motion sensor.
    Another strange thing is, 3 times an hour the node triggers the motion.
    This is when i am not home.
    Check time stamp
    19:01 Motion Sensor TV 4 1 turned off
    19:01 Motion Sensor TV 4 1 turned on
    18:41 Motion Sensor TV 4 1 turned off
    18:41 Motion Sensor TV 4 1 turned on
    18:21 Motion Sensor TV 4 1 turned off
    18:21 Motion Sensor TV 4 1 turned on
    18:06 Väder changed to 2
    18:01 Motion Sensor TV 4 1 turned off
    18:01 Motion Sensor TV 4 1 turned on
    17:41 Motion Sensor TV 4 1 turned off
    17:41 Motion Sensor TV 4 1 turned on
    17:21 Motion Sensor TV 4 1 turned off
    17:21 Motion Sensor TV 4 1 turned on
    Just can't figure what makes it trigger on exact times.
    Even if i reset the node it triggers on same times.
    This is the sketch
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to create a node thay repeates messages
     * from nodes far from gateway back to gateway.
     * It is important that nodes that has enabled repeater mode calls
     * process() frequently. Repeaters should never sleep.
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 4
    #define MY_PARENT_NODE_ID 0
    //unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    boolean previousTripped = LOW;
    // Initialize motion message
      //Send the sensor node sketch version information to the gateway
      sendSketchInfo("Motion Sensor TV", "1.0");
      present(CHILD_ID, S_MOTION);
      //Serial.println(tripped);
      // Sensor must be HIGH and not yet sent the status of the sensor
      if ((tripped == HIGH) && (tripped != previousTripped) ) {
        send(msg.set(tripped ? "1" : "0")); // Send tripped value to gw
        previousTripped = tripped;
      // Is sensor low and not sent? Then send LOW to gateway
      if ((tripped == LOW) && (tripped != previousTripped)) {
    Even tried this sketch but i get the same result.
    // Enable debug prints
    int oldTripped = 0;
    int tripped = 0;
    void presentation()  {
    //Read digital motion value
    tripped = digitalRead(DIGITAL_INPUT_SENSOR);
    if (tripped != oldTripped){
      Serial.println("Motion");
      oldTripped = tripped;
      Power fluctuations during transmission can trigger pir sensor: try using a 47-100 uF capacitor to stabilize power
      • xydixX
        xydixX
        xydix
        Just tried it but still same problem.
        I am suspecting hardware issues but always same time stamp makes me wonder.
          you tell me if you notice some coincidences :D
          • Vladimir DobrikovV
            Vladimir DobrikovV
            Vladimir Dobrikov
            I had that problem when use ESP8266 as active WiFi source near PIR sensor..
            • xydixX xydix
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @xydix
              I also think it's the radio transmissions that causes the sensor to trigger. One thing that happens every 20 min by default is the gateway sends a discover request broadcast. This will force all repeaters to resend that broadcast. You can test to change the interval of this broadcast at the gateway and see if the false triggers timing follows.
              The setting is called MY_TRANSPORT_DISCOVERY_INTERVAL_MS. You can define this in the gateway sketch to override the default setting.
                If that is the case then it could still be a power issue
                  Vladimir DobrikovV
                  Vladimir Dobrikov
                  I'd suggest to add capacitors: 47uF for radio and for PIR. Maybe this way power will be more smooth
                  • xydixX
                    xydixX
                    xydix
                    Thank you @martinhjelmare for that answer. It explains it. i Can confirm this is the issue.
                    The pir i am using is this one, the mini pir.
                    http://www.ebay.com/itm/121880058682?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                    I tried another pir, the HC-SR501 (http://www.ebay.com/itm/201414880948?rmvSB=true)
                    This pir is working ok with the node as it is.
                    First i tried an 100uF capacitor as @gohan suggested, but it didn't help.
                    Now i tried an 470uF capacitor and it seems to be fine with the mini pir.
                    @Vladimir-Dobrikov my radio already got an 100uF for the 3,3V circuit.
                    Im am still testing but the node it seems fine for now.
                    Thank you all for the help.
                    • xydixX
                      xydixX
                      xydix
                      I guess this thread should be in the hardware forum.
                      But if someone find this thread i can share some pictures and the idea with this node.
                      I built it as a USB-stick with a USB-connector on a prototype PCB.
                      Not good looking but when i get my TV up on the wall you can't see it.
                      I use it to turn on light in the bathroom at night if my kids visit the toilet.
