  3. RGB LED strip controller with FastLED
14 Posts 5 Posters 9.0k Views 5 Watching
  • rollercontainerR
    rollercontainerR
    rollercontainer
    I built a 1m x 1,5m accoustic absorber with Basotect for the ceiling in my living room. To generate ambient lighting, I installed a non-smart analog 5m LED strip on the top side. My first attempt was to use PWM from arduino which resultet in visual steps when do slow fading. Next approcach was a 12bit PWM motor shield, resulting in 4096 steps which were smooth but I couldn't use the real good FastLED library. So I ended up with a P9813 RGB MosFET Board from ebay which represents a single pixel. (But can easily chained for several strips in the room.) FastLED is dithering between the 256 steps of the arduino and produces very smooth transitions.
    Hardware:
    • Arduino Nano (~5€)
    • NRF24L01 (~2€)
    • P9813 RGB MosFet Board from ebay (Full Color RGB LED Strip Driver Sensor v1.1 for Arduino STM32 AVR P9813) (4,29€)
    • LM2596S DC-DC Step-Down Converter for 12V->5V (~1€)
    • 5m RGB LED Strip ( < 10€)
    • old 12V laptop power supply
    Software:
    My setup is a mqttClientGateway and a raspi with node-red.
    To change color, you can send a RRGGBB string to mysensors-in/node-id/0/1/0/40
    To change the fade time you can send a integer from 0 to 255 to mysensors-in/node-id/1/1/0/24
    To persist the current settings to eeprom you can send a "1" (meaning bool "true") to mysensors-in/node-id/2/1/0/2
    To set the brightness you can send 0 to 100 (V_PERCENTAGE) to mysensors-in/node-id/3/1/0/3
    https://github.com/rollercontainer/nanoP9813FastLEDMySensors/blob/master/main.cpp
    This code is working. Nevertheless it could be a lot better. It is posted, to help people take code lines or inspirations out of it. I think, I change the setup to esp8266 because of the OTA flash ability.
    Greetings
    • pansenP
      pansenP
      pansen
      I think you might have left out the LM2596 since the Nano linear regulator should be able to cope with 12V.
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
      micahM 1 Reply Last reply
        Many say it's better don't push those regulators to the limit if you are unsure about the quality 😁
        • pansenP pansen
          micahM
          micahM
          micah
          @pansen I've burned out a couple nano's and pro mini's by supplying what was supposedly 12v from a wall wart.
          So I would advise using a linear voltage regulator
          • pansenP
            pansenP
            pansen
            @micah @gohan Yeah I could imagine nasty spikes from a cheap power supply can fry the regulator. I still find an LM2596 overpowered for this. At least take a 7805 :P
            AWIA 1 Reply Last reply
              for 0.65€ a piece you don't go broke if you buy some LM2596 :)
              • micahM
                micahM
                micah
                Yeah I usually use some 78xx variant
                • pansenP pansen
                  AWIA
                  AWIA
                  AWI
                  @pansen Agree and price is one thing but I would prefer a linear regulator for its stability and noise.
                  pansenP 1 Reply Last reply
                    but linear regulator would waste a lot of energy/heat, wouldn't it?
                      micahM
                      micahM
                      micah
                      @gohan maybe, I don't know, I only pretend to be an electrical engineer in my spare time... Lol
                        well for powering a Nano there should not be that much heat dissipated, being a low power device
                        • AWIA AWI
                          pansenP
                          pansenP
                          pansen
                          wrote on last edited by pansen
                          @AWI Was about to say that ;) For a hobbyist it doesn't matter that much but switching regulators are quite nasty when it comes to EMI.
                          @gohan: A good rule of thumb is to assume that the voltage difference from input to output of the linear regulator will be converted to heat. So if you have a high current application or a high voltage difference a switching regulator is better. In case of running an Arduino (let's say it consumes 80mA@5V which is quite high) it's negligible: P=U*I=(12-5)*0.08=0.5W which should be dissipated without heatsink easily.
                          edit: ah you just answered yourself ;D
                          • pansenP pansen
                            AWIA
                            AWIA
                            AWI
                            @pansen To add to that... these step down Power converter(boards) are not really suited for low power applications. Their efficiency is likely (much) worse than a linear regulator.
                            • AWIA AWI
                              pansenP
                              pansenP
                              pansen
                              @AWI Ha, I forgot about that...I remembered that you actually need a minimum load on the output of the switching regulator for it to even run. I created a spreadsheet just taking into account the quiescent currents and assuming 70% effciency for the lm2596 (a "bit" optimistic. Datasheet says 80% at 3A load for 12V-5V operation). Quiescent current for the LM2596 is much higher.
                              Considering the mini pro takes about 12-20mA running, I am sure to opt for the 7805 or LM317 from now on ;) (If there is nothing else drawing current). I think nano etc are comparable but the FTDI USB to serial converter probably adds some current that the mini pro is missing.
                              0_1491471717305_upload-90fd958b-83f1-4af4-abbc-f4103ec1e2fc
                              0_1491471734938_analysis7805.xlsx
