  3. Need a bid of help...
15 Posts 3 Posters 3.7k Views 3 Watching
  • R Rene046
    Hi there i'm working on my first project.
    got some code working fine, but would like to try to add an BMP180 or 280 into the sketch.
    I.m working with the latest version of my sensors. 2.1
    It would be nice to include a forecast but that a bid to hard for me at this moment.
    so far i found a sample of a weather station, ith forecast, but im not shure if i need more sensors like a dht then.
    Maybe some could give a sample or advice.
    #include <BH1750.h>
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
    #define CHILD_ID_BATTERY 4
    #define CHILD_ID_SOLAR 6
    #define CHILD_ID_LIGHT 1
    BH1750 lightSensor;
    int oldBatteryPcnt = 0;
    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
    MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
    uint16_t lastlux;  //lux
    void setup(){
    	analogReference(INTERNAL1V1);
    	analogReference(INTERNAL);
    	sendSketchInfo("Battery Meter", "2.0");
    	// get the battery Voltage
    	int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
      delay(1000);
      int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
      delay(100);
      delay(1000);
      int sensorValueS = analogRead(SOLAR_SENSE_PIN);
      delay(1000);
    #ifdef MY_DEBUG
    	Serial.print("Battery Voltage2: ");
      Serial.println(sensorValue2);
      Serial.print("Battery Voltage1: ");
      Serial.println(sensorValue1);
      Serial.println(sensorValue);
      Serial.print("Solar Voltage: ");
      Serial.println(sensorValueS);
      const float vRef = 4.200/ 1.05/ 1023 ;
      float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
      float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
    #ifdef MY_DEBUG
    	Serial.print(batteryV);
    	Serial.println(" V");
    send(msgbatt.set(batteryV ,2));
      Serial.print(batteryS);
    send(msgsolar.set(batteryS ,2));
    	Serial.print(batteryPcnt);
    	Serial.println(" %");
    		// Power up radio after sleep
    		oldBatteryPcnt = batteryPcnt;
      Serial.println(lux);
      if (lux != lastlux) {
          send(msg.set(lux));
          lastlux = lux;
    	sleep(SLEEP_TIME);
    R
    R
    Rene046
    @Rene046 said in Need a bid of help...:
    #include <BH1750.h>
    BH1750 lightSensor;
    void setup(){
      delay(1000);
      delay(100);
      delay(1000);
      delay(1000);
    #ifdef MY_DEBUG
    #ifdef MY_DEBUG
          send(msg.set(lux));
          lastlux = lux;
    	sleep(SLEEP_TIME);
    i forget to tell i have an bmp180 and a bme280 available
    • R
      R
      Rene046
      What are the read command for an bme280
      float temperature = bme.readTemperature();
      float humidity = bme.readHumidity();
      float pressure= bme.readPressure()
      • R
        R
        Rene046
        wrote on last edited by Rene046
        this is what i got s far...
        mysensor.readTempC() and bmp.readTemperature(); both not working.
        now i got it accepted but my working sketch peaces give problems.
        #include <BH1750.h>
        //#include <Adafruit_BME280.h>
        //#include <SparkFunBME280.h>
        #include <BME280_MOD-1022.h>
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 2
        #define CHILD_ID_BARO 3
        BH1750 lightSensor;
        MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP);
        MyMessage msgPres(CHILD_ID_BARO,V_PRESSURE);
        void setup(){
          present(CHILD_ID_BARO, S_BARO);
          present(CHILD_ID_HUM, S_HUM);
          delay(1000);
          delay(100);
          delay(1000);
          delay(1000);
          // Read out the data - must do this before calling the getxxxxx routines
          BME280.readMeasurements();
          // get temperature from BME280
          float temperature = BME280.getTemperatureMostAccurate();
          // get humidity from BME280
          float humidity = BME280.getHumidityMostAccurate();
          // get pressure from BME280
          float pressure = BME280.getPressureMostAccurate();
        #ifdef MY_DEBUG
        Serial.print("Buiten Temp: ");
          Serial.print(temperature);
          Serial.println(" Celcius");
        Serial.print("Vochtigheid: ");
          Serial.print(humidity);
          Serial.println(" ?");
        Serial.print("Buiten Druk: ");
          Serial.print(pressure);
        send(msgPres.set(pressure, 2));
              send(msg.set(lux));
              lastlux = lux;
        	sleep(SLEEP_TIME);
          Take a look at nodemanager, it will simplify your life ☺️
          R 1 Reply Last reply
            R
            R
            Rene046
            @gohan
            Hi Gohan.
            Im still learning .. nodemanager ????
            Features
            Manage all the aspects of a sleeping cycle by leveraging smart sleep
            Allow configuring the sleep mode and the sleep duration remotely
            Allow waking up a sleeping node remotely at the end of a sleeping cycle
            Allow powering on each connected sensor only while the node is awake to save battery
            Report battery level periodically and automatically
            Calculate battery level without requiring an additional pin and the resistors
            Report battery voltage through a built-in sensor
            Can report battery level on demand
            Allow rebooting the board remotely
            Provide out-of-the-box sensors personalities and automatically execute their main task at each cycle
            it looks intresting but i just started...
              For beginners it's easier, it cuts down code quite a lot
                R
                R
                Rene046
                @gohan
                Do you have a sample or could you help me starting with the sketch i already have ?
                • R Rene046
                  @gohan
                  R
                  R
                  Rene046
                  @gohan
                  i installed nodemanager i think ...lol
                  • R
                    R
                    Rene046
                      maybe you set the something wrong in the sleep settings, but without seeing your code it's hard to give you an answer :)
                      • R
                        R
                        Rene046
                        Found it i connected the BME280 in the BH1750 line after removing i worked again....
                        the sketch could not work without Seeing the BH1750.
                        my code is in my first post on top of this topic.
                          Yes, but I wanted to see if you made the modifications to run the nodemanager
                          • R
                            R
                            Rene046
                            nope i dont even know where to start....
                            • alowhumA
                              alowhumA
                              alowhum
                              Try this code:
                              https://github.com/flatsiedatsie/MySensorsArduinoExamples/blob/5c84100098352bab6db4b9c86e76db79842131ec/examples/WeatherStationSensor/WeatherStationSensor.ino
