  3. Need a bid of help...
15 Posts 3 Posters 3.7k Views 3 Watching
  • R
    R
    Rene046
    wrote on last edited by Rene046
    this is what i got s far...
    mysensor.readTempC() and bmp.readTemperature(); both not working.
    now i got it accepted but my working sketch peaces give problems.
    #include <BH1750.h>
    //#include <Adafruit_BME280.h>
    //#include <SparkFunBME280.h>
    #include <BME280_MOD-1022.h>
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
    #define CHILD_ID_BATTERY 4
    #define CHILD_ID_SOLAR 6
    #define CHILD_ID_LIGHT 1
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 2
    #define CHILD_ID_BARO 3
    BH1750 lightSensor;
    int oldBatteryPcnt = 0;
    MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP);
    MyMessage msgPres(CHILD_ID_BARO,V_PRESSURE);
    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
    MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
    uint16_t lastlux;  //lux
    void setup(){
    	analogReference(INTERNAL1V1);
    	analogReference(INTERNAL);
    	sendSketchInfo("Battery Meter", "2.0");
      present(CHILD_ID_BARO, S_BARO);
      present(CHILD_ID_HUM, S_HUM);
    	// get the battery Voltage
    	int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
      delay(1000);
      int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
      delay(100);
      delay(1000);
      int sensorValueS = analogRead(SOLAR_SENSE_PIN);
      delay(1000);
      // Read out the data - must do this before calling the getxxxxx routines
      BME280.readMeasurements();
      // get temperature from BME280
      float temperature = BME280.getTemperatureMostAccurate();
      // get humidity from BME280
      float humidity = BME280.getHumidityMostAccurate();
      // get pressure from BME280
      float pressure = BME280.getPressureMostAccurate();
    #ifdef MY_DEBUG
    	Serial.print("Battery Voltage2: ");
      Serial.println(sensorValue2);
      Serial.print("Battery Voltage1: ");
      Serial.println(sensorValue1);
      Serial.println(sensorValue);
      Serial.print("Solar Voltage: ");
      Serial.println(sensorValueS);
    Serial.print("Buiten Temp: ");
      Serial.print(temperature);
      Serial.println(" Celcius");
    Serial.print("Vochtigheid: ");
      Serial.print(humidity);
      Serial.println(" ?");
    Serial.print("Buiten Druk: ");
      Serial.print(pressure);
    send(msgPres.set(pressure, 2));
      Serial.print(batteryV);
      Serial.println(" V");
    send(msgbatt.set(batteryV ,2));
      Serial.print(batteryS);
    send(msgsolar.set(batteryS ,2));
      Serial.print(batteryPcnt);
      Serial.println(" %");
      const float vRef = 4.200/ 1.05/ 1023 ;
      float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
      float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
    		// Power up radio after sleep
    		oldBatteryPcnt = batteryPcnt;
      Serial.println(lux);
      if (lux != lastlux) {
          send(msg.set(lux));
          lastlux = lux;
    	sleep(SLEEP_TIME);
      Take a look at nodemanager, it will simplify your life ☺️
      R 1 Reply Last reply
        R
        R
        Rene046
        @gohan
        Hi Gohan.
        Im still learning .. nodemanager ????
        Features
        Manage all the aspects of a sleeping cycle by leveraging smart sleep
        Allow configuring the sleep mode and the sleep duration remotely
        Allow waking up a sleeping node remotely at the end of a sleeping cycle
        Allow powering on each connected sensor only while the node is awake to save battery
        Report battery level periodically and automatically
        Calculate battery level without requiring an additional pin and the resistors
        Report battery voltage through a built-in sensor
        Can report battery level on demand
        Allow rebooting the board remotely
        Provide out-of-the-box sensors personalities and automatically execute their main task at each cycle
        it looks intresting but i just started...
          For beginners it's easier, it cuts down code quite a lot
            R
            R
            Rene046
            @gohan
            Do you have a sample or could you help me starting with the sketch i already have ?
            • R Rene046
              @gohan
              R
              R
              Rene046
              @Rene046 said in Need a bid of help...:
              @gohan
              i installed nodemanager i think ...lol
              • R
                R
                Rene046
                  maybe you set the something wrong in the sleep settings, but without seeing your code it's hard to give you an answer :)
                  • R
                    R
                    Rene046
                    Found it i connected the BME280 in the BH1750 line after removing i worked again....
                    the sketch could not work without Seeing the BH1750.
                    my code is in my first post on top of this topic.
                      Yes, but I wanted to see if you made the modifications to run the nodemanager
                      • R
                        R
                        Rene046
                        nope i dont even know where to start....
                        • alowhumA
                          alowhumA
                          alowhum
                          Try this code:
                          https://github.com/flatsiedatsie/MySensorsArduinoExamples/blob/5c84100098352bab6db4b9c86e76db79842131ec/examples/WeatherStationSensor/WeatherStationSensor.ino
