  3. Need a bid of help...
15 Posts 3 Posters 3.5k Views 3 Watching
  • R Offline
    R Offline
    Rene046
    Hi there i'm working on my first project.
    got some code working fine, but would like to try to add an BMP180 or 280 into the sketch.
    I.m working with the latest version of my sensors. 2.1
    It would be nice to include a forecast but that a bid to hard for me at this moment.
    so far i found a sample of a weather station, ith forecast, but im not shure if i need more sensors like a dht then.
    Maybe some could give a sample or advice.
    #include <BH1750.h>
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
    #define CHILD_ID_BATTERY 4
    #define CHILD_ID_SOLAR 6
    #define CHILD_ID_LIGHT 1
    BH1750 lightSensor;
    int oldBatteryPcnt = 0;
    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
    MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
    uint16_t lastlux;  //lux
    void setup(){
    	analogReference(INTERNAL1V1);
    	analogReference(INTERNAL);
    	sendSketchInfo("Battery Meter", "2.0");
    	// get the battery Voltage
    	int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
      delay(1000);
      int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
      delay(100);
      delay(1000);
      int sensorValueS = analogRead(SOLAR_SENSE_PIN);
      delay(1000);
    #ifdef MY_DEBUG
    	Serial.print("Battery Voltage2: ");
      Serial.println(sensorValue2);
      Serial.print("Battery Voltage1: ");
      Serial.println(sensorValue1);
      Serial.println(sensorValue);
      Serial.print("Solar Voltage: ");
      Serial.println(sensorValueS);
      const float vRef = 4.200/ 1.05/ 1023 ;
      float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
      float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
    #ifdef MY_DEBUG
    	Serial.print(batteryV);
    	Serial.println(" V");
    send(msgbatt.set(batteryV ,2));
      Serial.print(batteryS);
    send(msgsolar.set(batteryS ,2));
    	Serial.print(batteryPcnt);
    	Serial.println(" %");
    		// Power up radio after sleep
    		oldBatteryPcnt = batteryPcnt;
      Serial.println(lux);
      if (lux != lastlux) {
          send(msg.set(lux));
          lastlux = lux;
    	sleep(SLEEP_TIME);
    R 1 Reply Last reply
    • R Rene046
      #include <BH1750.h>
      BH1750 lightSensor;
      void setup(){
        delay(1000);
        delay(100);
        delay(1000);
        delay(1000);
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
            send(msg.set(lux));
            lastlux = lux;
      	sleep(SLEEP_TIME);
      R Offline
      R Offline
      Rene046
      @Rene046 said in Need a bid of help...:
      #include <BH1750.h>
      BH1750 lightSensor;
      void setup(){
        delay(1000);
        delay(100);
        delay(1000);
        delay(1000);
      #ifdef MY_DEBUG
      #ifdef MY_DEBUG
            send(msg.set(lux));
            lastlux = lux;
      	sleep(SLEEP_TIME);
      i forget to tell i have an bmp180 and a bme280 available
      • R Offline
        R Offline
        Rene046
        What are the read command for an bme280
        float temperature = bme.readTemperature();
        float humidity = bme.readHumidity();
        float pressure= bme.readPressure()
        • R Offline
          R Offline
          Rene046
          wrote on last edited by Rene046
          this is what i got s far...
          mysensor.readTempC() and bmp.readTemperature(); both not working.
          now i got it accepted but my working sketch peaces give problems.
          #include <BH1750.h>
          //#include <Adafruit_BME280.h>
          //#include <SparkFunBME280.h>
          #include <BME280_MOD-1022.h>
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 2
          #define CHILD_ID_BARO 3
          BH1750 lightSensor;
          MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP);
          MyMessage msgPres(CHILD_ID_BARO,V_PRESSURE);
          void setup(){
            present(CHILD_ID_BARO, S_BARO);
            present(CHILD_ID_HUM, S_HUM);
            delay(1000);
            delay(100);
            delay(1000);
            delay(1000);
            // Read out the data - must do this before calling the getxxxxx routines
            BME280.readMeasurements();
            // get temperature from BME280
            float temperature = BME280.getTemperatureMostAccurate();
            // get humidity from BME280
            float humidity = BME280.getHumidityMostAccurate();
            // get pressure from BME280
            float pressure = BME280.getPressureMostAccurate();
          #ifdef MY_DEBUG
          Serial.print("Buiten Temp: ");
            Serial.print(temperature);
            Serial.println(" Celcius");
          Serial.print("Vochtigheid: ");
            Serial.print(humidity);
            Serial.println(" ?");
          Serial.print("Buiten Druk: ");
            Serial.print(pressure);
          send(msgPres.set(pressure, 2));
                send(msg.set(lux));
                lastlux = lux;
          	sleep(SLEEP_TIME);
            Take a look at nodemanager, it will simplify your life ☺️
              R Offline
              R Offline
              Rene046
              @gohan
              Hi Gohan.
              Im still learning .. nodemanager ????
              Features
              Manage all the aspects of a sleeping cycle by leveraging smart sleep
              Allow configuring the sleep mode and the sleep duration remotely
              Allow waking up a sleeping node remotely at the end of a sleeping cycle
              Allow powering on each connected sensor only while the node is awake to save battery
              Report battery level periodically and automatically
              Calculate battery level without requiring an additional pin and the resistors
              Report battery voltage through a built-in sensor
              Can report battery level on demand
              Allow rebooting the board remotely
              Provide out-of-the-box sensors personalities and automatically execute their main task at each cycle
              it looks intresting but i just started...
                For beginners it's easier, it cuts down code quite a lot
                  R Offline
                  R Offline
                  Rene046
                  @gohan
                  Do you have a sample or could you help me starting with the sketch i already have ?
                  • R Rene046
                    @gohan
                    R Offline
                    R Offline
                    Rene046
                    @gohan
                    i installed nodemanager i think ...lol
                    • R Offline
                      R Offline
                      Rene046
                        maybe you set the something wrong in the sleep settings, but without seeing your code it's hard to give you an answer :)
                        • R Offline
                          R Offline
                          Rene046
                          Found it i connected the BME280 in the BH1750 line after removing i worked again....
                          the sketch could not work without Seeing the BH1750.
                          my code is in my first post on top of this topic.
                            Yes, but I wanted to see if you made the modifications to run the nodemanager
                            • R Offline
                              R Offline
                              Rene046
                              nope i dont even know where to start....
                              • alowhumA Offline
                                alowhumA Offline
                                alowhum
                                Try this code:
                                https://github.com/flatsiedatsie/MySensorsArduinoExamples/blob/5c84100098352bab6db4b9c86e76db79842131ec/examples/WeatherStationSensor/WeatherStationSensor.ino
                                12.1k
