  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
    I think relay is the pir sensor you are looking for.
    • mar.conteM mar.conte
      @gohan
      node
      40 MCO:BGN:BFR
      REG I=1 P=3 P=6 T=0
      NodeManager v1.4
      INT1 M=255
      INT2 M=255
      59 TSM:INIT
      135 TSF:WUR:MS=0
      155 TSM:INIT:TSP OK
      176 TSM:INIT:STATID=100
      202 TSF:SID:OK,ID=100
      225 TSM:FPAR
      370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      2301 TSF:MSG:FPAR OK,ID=0,D=1
      2447 TSM:FPAR:OK
      2463 TSM:ID
      2478 TSM:ID:OK
      2492 TSM:UPL
      2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
      3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      3737 TSF:MSG:PONG RECV,HP=1
      3768 TSM:UPL:OK
      3784 TSM:READY:ID=100,PAR=0,DIS=1
      3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
      4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
      6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
      6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
      RADIO OK
      PRES I=200, T=23
      7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
      PRES I=201, T=30
      7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
      BATT V=3.25 P=93
      SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
      7469 !MCO:SND:NODE NOT REG
      7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
      PRES I=1 T=6
      7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
      READY
      7868 MCO:REG:REQ
      7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
      9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      9078 MCO:PIM:NODE REG=1
      9105 MCO:BGN:STP
      MY I=100 M=1
      9123 MCO:BGN:INIT OK,TSP=1
      THER I=1 V=354.00 T=40.05
       M=1
      SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
      9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
      SLEEP 3600s
      9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
      9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
      9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      9666 !TSF:MSG:LEN,0!=8
      10108 MCO:SLP:TPD```
      Gateway
      0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;TSF:MSG:BC
      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
      0;255;3;0;9;TSF:PNG:SEND,TO=0
      0;255;3;0;9;TSF:CKU:OK
      0;255;3;0;9;TSF:MSG:GWL OK
      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
      0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
      0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
      0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
      0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
      0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
      U
      U
      user2684
      @mar.conte your configuration looks correct, SENSOR_MOTION is what you want to use indeed. However, the logs are saying NodeManager is presenting the sensor as S_TEMP so the issue is on NodeManager's side also because looks like SensorThermistor has been instantiated but if I look at the code, there is no way this should happen.I'll try to setup something similar to see if I can reproduce the behavior. Very stupid question: are you sure you have uploaded successfully that sketch and it is not an old one? I really cannot explain it otherwise at a first look...
      mar.conteM 1 Reply Last reply
      • B bilbolodz
        @user2684 said in NodeManager: plugin for a rapid development of battery-powered sensors:
        This is available for all the sensors. So in the case of multiple DS18B20 you need to register them all in the usual way ( registerSensor(SENSOR_DS18B20,pin)) then assign the child id you like just after so in case one is lost, you still have a static mapping. The alternative would have been to provide a special registerSensor only for DS18B20 which I don't like that much. Any other better alternative of course is more than welcome!
        Thanks for support but actually in case of multiple DS18B20 your "general solution" is not very useful..... It require manual checking ID (first it IDs need to bs stored in EEPROM) renaming child id sensor in case of change and so on. In my private opinion it could be better add special registerSensor() function which takes pin and DS18B20 ID and register sensor (or not). Please consider these.
        U
        U
        user2684
        @bilbolodz having a special registerSensor() for DS18B20 is for sure feasible but I'll leave it as the last option. Are you sure you need to store something in the eeprom? The way I imaged it was something like this, all within the sketch:
        • register the DS18B20 sensors with one line. registerSensor() returns the child id of the last sensor so I know how many have been detected.
        • cycle through the DS18B20 sensors found with getSensor(index)
        • for each sensor, call of getDeviceAddress(), if the address equals to a hard-coded address, renameSensor() to a fixed id.
        In this way the same device address will always get the same child id and if a sensor will be unavailable, it will not mess up the other child IDs. Is this something which can be done or am I missing something? Far from saying it is elegant of course...
        B 1 Reply Last reply
        • U user2684
          B
          B
          bilbolodz
          Of course that it's solution but hardcoding addresses into sketch as you said "it's far from elegant"..... The good idea (in my opinion) is to put addresses into array stored in eeprom. The ideal solution would be to have possibility put addresses into eeprom by mysensors controller ;-)
          U 1 Reply Last reply
          • BeniKB BeniK
            Needles to say and re-say this is really a much needed plugin for us beginners!
            Made a bunch of battery operating nodes with only DHT22 and all are working flawlessly.
            Today I tried making a node using a DS18B20 and DHT22. DS18B20 connected to digital pin 3 and DHT22 to digital pin 4. Both sensors have 10K resistors between their vcc and data lines (tried without resistors but none of the sensors worked).
            Sketch compiles and uploads fine to a Arduino Pro Mini 328 3.3v 8MHz. It also connects to the gateway, but I run into some problems;
            The first one being that watching from the serial debug, the node strarts up, connects to the gateway, reports some data and then hangs. No more activity from the node watching on the serial debug.
            The second one is that the node never sleeps - Activity led on Arduino Pro Mini remains lit.
            The last one is that DS18B20 reports the Temp to the gateway but DHT22 reports only Temp and not the Humidity. Tried changing pins for the sensors, but the same.
            Connection logs (from the serial interface) are as follows:
            REG I=1 P=3 P=6 T=0
            REG I=2 P=4 P=6 T=0
            REG I=3 P=4 P=7 T=1
            NodeManager v1.4
            INT1 M=255
            INT2 M=255
            RADIO OK
            PRES I=200, T=23
            PRES I=201, T=30
            BATT V=3.44 P=100
            SEND D=0 I=201 C=0 T=38 S= I=0 F=3.44
            PRES I=1 T=6
            PRES I=2 T=6
            PRES I=3 T=7
            READY
            MY I=199 M=1
            DS18B20 I=1 T=47.75
            SEND D=0 I=1 C=0 T=0 S= N=0 F=47.75
            DHT I=2 T=25.00
            SEND D=0 I=2 C=0 T=0 S= N=0 F=25.00
            And the sketch I use is as follows:
            NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects.
            NodeManager includes the following main components:
            - Sleep manager: allows managing automatically the complexity behind battery-powered sensors spending most of their time sleeping
            - Power manager: allows powering on your sensors only while the node is awake
            - Battery manager: provides common functionalities to read and report the battery level
            - Remote configuration: allows configuring remotely the node without the need to have physical access to it
            - Built-in personalities: for the most common sensors, provide embedded code so to allow their configuration with a single line
            Documentation available on: https://github.com/mysensors/NodeManager
            // load user settings
            #include "config.h"
            // load MySensors library
            // load NodeManager library
            #include "NodeManager.h"
            // create a NodeManager instance
            NodeManager nodeManager;
            // before
            void before() {
              Serial.begin(MY_BAUD_RATE);
               * Register below your sensors
                nodeManager.setBatteryMin(2.0);
                nodeManager.setBatteryMax(3.3);
                nodeManager.setSleep(SLEEP,60,SECONDS);
                nodeManager.registerSensor(SENSOR_DS18B20,3);
                nodeManager.registerSensor(SENSOR_DHT22,4);
               * Register above your sensors
              nodeManager.before();
            // presentation
            	sendSketchInfo(SKETCH_NAME,SKETCH_VERSION);
              nodeManager.presentation();
            // setup
              nodeManager.setup();
            // loop
              nodeManager.loop();
            // receive
              nodeManager.receive(message);
            Also on config.h I have enabled DS18B20 and DHT22 modules.
            Really, any help would be welcome!
            Thanks all in advance!
            U
            U
            user2684
            @BeniK said in NodeManager: plugin for a rapid development of battery-powered sensors:
            PRES I=1 T=6
            PRES I=2 T=6
            PRES I=3 T=7
            Hi, the sensors are all presented correctly, child id 1 is type temperature (6, the DS18B20), child id 2 is type temperature (6, the DHT22), child id 3 is type humidity (7, the DHT22).
            What it looks like from the logs is that it hangs after sending out the temperature of child id 2, never get to child id 3 so never goes to sleep.
            I wonder if having both DHT and DS18B20 together would consume too much memory causing the sketch to halt. When you compile it, what is the percentage of program storage space and dynamic memory used? For those sensors the objects are allocated dynamically so when getting closer to the memory limit strange behaviors can happen.
            Try also disabling NodeManager's debug (#define DEBUG 0) and all the other modules you are not using (e.g. MODULE_ANALOG_INPUT, MODULE_DIGITAL_INPUT, etc.). All of this should help saving additional memory. Then check on your controller if you get the humidity as well and if the node goes to sleep.
            BeniKB 2 Replies Last reply
            • U user2684
              PRES I=1 T=6
              PRES I=2 T=6
              PRES I=3 T=7
              BeniKB
              BeniKB
              BeniK
              @user2684 Hi and thank you for the prompt response!
              The % of memory used is 83% of program storage space and 63% of dynamic memory.
              Sketch uses 25580 bytes (83%) of program storage space. Maximum is 30720 bytes.
              Global variables use 1307 bytes (63%) of dynamic memory, leaving 741 bytes for local variables. Maximum is 2048 bytes.
              Heading right now to try to compile without the non-needed modules and try again.
              • B bilbolodz
                U
                U
                user2684
                wrote on last edited by user2684
                #68
                @bilbolodz said in NodeManager: plugin for a rapid development of battery-powered sensors:
                Ok got it, just wanted to be sure that what I had in mind, despite being awful, was kind of feasible. Now let me try to understand better what you have in mind: you store in eeprom the the addresses, then call registerSensor() and the for DS18B20, it will retrieve from there the addresses and do the mapping automatically instead of being you doing in the sketch what I listed before. Is it correct? If so, despite some obvious complexity, does not require a special registerSensor() (which would be great).
                As a side note, having the controller storing something into the EEPROM is not something extremely difficult to implement, I can add an additional V_CUSTOM message so achieve this since I can imagine may be helpful for this and other use cases (https://github.com/mysensors/NodeManager/issues/53)
                • U user2684
                  B
                  B
                  bilbolodz
                  @user2684 Yes, that could be nice solution.
                  • B bilbolodz
                    U
                    U
                    user2684
                    Cool, I'll track it down (https://github.com/mysensors/NodeManager/issues/54) so you can see when I'll get into it.
                    • U user2684
                      PRES I=1 T=6
                      PRES I=2 T=6
                      PRES I=3 T=7
                      BeniKB
                      BeniKB
                      BeniK
                      @user2684 You were right! Definately a memory problem. Disabled the non-needed modules and everything is working as it should!
                      REG I=1 P=3 P=6 T=0
                      REG I=2 P=4 P=6 T=0
                      REG I=3 P=4 P=7 T=1
                      NodeManager v1.4
                      INT1 M=255
                      INT2 M=255
                      RADIO OK
                      PRES I=200, T=23
                      PRES I=201, T=30
                      BATT V=3.44 P=100
                      PRES I=1 T=6
                      PRES I=2 T=6
                      PRES I=3 T=7
                      READY
                      MY I=199 M=1
                      DS18B20 I=1 T=44.19
                      SEND D=0 I=1 C=0 T=0 S= N=0 F=44.19
                      DHT I=2 T=24.40
                      SEND D=0 I=2 C=0 T=0 S= N=0 F=24.40
                      DHT I=3 H=35.50
                      SEND D=0 I=3 C=0 T=1 S= N=0 F=35.50
                      SLEEP 60s
                      Many many many THANKS for the help!
                      • BeniKB
                        BeniKB
                        BeniK
                        @user2684 By the way I am alsy trying to implement the forecasting algorithm for BME280 sensor (from here) into the BME280 section of NodeManager.cpp and Nodemanager.h but until now no joy. Maybe I am trying to do something complicated for me as a beginner into this, but I always like to learn by trial and error. Any advice you could give me to be able to implement the forecasting algorithm?
                        • BeniKB BeniK
                          REG I=1 P=3 P=6 T=0
                          REG I=2 P=4 P=6 T=0
                          REG I=3 P=4 P=7 T=1
                          NodeManager v1.4
                          INT1 M=255
                          INT2 M=255
                          RADIO OK
                          PRES I=200, T=23
                          PRES I=201, T=30
                          BATT V=3.44 P=100
                          PRES I=1 T=6
                          PRES I=2 T=6
                          PRES I=3 T=7
                          READY
                          MY I=199 M=1
                          DS18B20 I=1 T=44.19
                          DHT I=2 T=24.40
                          DHT I=3 H=35.50
                          SLEEP 60s
                          U
                          U
                          user2684
                          Great! I feel like there are a lot of optimizations that can be done to prevent this and other weird behaviors (tracked already with https://github.com/mysensors/NodeManager/issues/28).
                          I'd need a real programmer's review sooner or later because I'm sure the way I am e.g. comparing and manipulating strings are far from being efficient...
                          • BeniKB BeniK
                            U
                            U
                            user2684
                            Great idea! I wonder if the issue you are facing is due to different libraries being used (I'm using Adafruit's library, not the one from MySensors examples folder, not sure if they are different). I'll give it a try as well (https://github.com/mysensors/NodeManager/issues/56), but please let me know if you'll find the way to have it working and I'll make it part of the main code base.
                            • U user2684
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @user2684
                              all ok now is s_motion but is ever tripped high!!!why?
                              M.C.
                                @user2684
                                U
                                U
                                user2684
                                @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
                                Default behavior is triggering on RISING but this can be changed with setMode() and setInitial(). Also ensure you are using pin 3 on a pro mini to have a valid interrupt. What is the behavior you are experiencing?
                                mar.conteM 2 Replies Last reply
                                • U user2684
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  @user2684
                                  for istance Sensorswitch what is code?
                                  M.C.
                                  • U user2684
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    @user2684
                                    it's ok this code?
                                    SensorSwitch swiTch(1,3);
                                    // before
                                    void before() {
                                    swiTch.setMode(0);
                                    swiTch.setInitial(0);
                                    swiTch.setTriggerTime(4000);
                                      nodeManager.setSleep(SLEEP,60,MINUTES);
                                      nodeManager.registerSensor(SENSOR_MOTION,3);```
                                    M.C.
                                      @user2684
                                      it's ok this code?
                                      // before
                                      void before() {
                                      swiTch.setMode(0);
                                      U
                                      U
                                      user2684
                                      @mar.conte sorry I'm not sure I have understood what you want to achieve. Do you have a motion sensor which is HIGH by default and when triggers goes LOW? Is this what you need?
                                      • U user2684
                                        mar.conteM
                                        mar.conteM
                                        mar.conte
                                        @user2684
                                        Hello, I have a simple pir hcr501 that normally does not send output to pin 3 (so low) but when there is movement becomes HIGH, then my CPU goes to sleep for 60 minutes; the hardware is well configured because this setup I used it with the official mysensors sketches for pir motion; I do not understand why the domoticz controller is always the pir HIGH and does not go into sleep the MCU, thanks
                                        M.C.
                                          @user2684
                                          U
                                          U
                                          user2684
                                          Ok, so you don't need any customization in NodeManager since this is meeting the default behavior (LOW by default and triggering on HIGH), sorry for the wrong advice. Let's have a look at the sensor's logs then to see why the node is waking up continuously.
