  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • U user2684
    @BeniK said in NodeManager: plugin for a rapid development of battery-powered sensors:
    PRES I=1 T=6
    PRES I=2 T=6
    PRES I=3 T=7
    Hi, the sensors are all presented correctly, child id 1 is type temperature (6, the DS18B20), child id 2 is type temperature (6, the DHT22), child id 3 is type humidity (7, the DHT22).
    What it looks like from the logs is that it hangs after sending out the temperature of child id 2, never get to child id 3 so never goes to sleep.
    I wonder if having both DHT and DS18B20 together would consume too much memory causing the sketch to halt. When you compile it, what is the percentage of program storage space and dynamic memory used? For those sensors the objects are allocated dynamically so when getting closer to the memory limit strange behaviors can happen.
    Try also disabling NodeManager's debug (#define DEBUG 0) and all the other modules you are not using (e.g. MODULE_ANALOG_INPUT, MODULE_DIGITAL_INPUT, etc.). All of this should help saving additional memory. Then check on your controller if you get the humidity as well and if the node goes to sleep.
    BeniKB
    BeniKB
    BeniK
    @user2684 Hi and thank you for the prompt response!
    The % of memory used is 83% of program storage space and 63% of dynamic memory.
    Sketch uses 25580 bytes (83%) of program storage space. Maximum is 30720 bytes.
    Global variables use 1307 bytes (63%) of dynamic memory, leaving 741 bytes for local variables. Maximum is 2048 bytes.
    Heading right now to try to compile without the non-needed modules and try again.
    • B bilbolodz
      @user2684 said in NodeManager: plugin for a rapid development of battery-powered sensors:
      In this way the same device address will always get the same child id and if a sensor will be unavailable, it will not mess up the other child IDs. Is this something which can be done or am I missing something? Far from saying it is elegant of course...
      Of course that it's solution but hardcoding addresses into sketch as you said "it's far from elegant"..... The good idea (in my opinion) is to put addresses into array stored in eeprom. The ideal solution would be to have possibility put addresses into eeprom by mysensors controller ;-)
      U
      U
      user2684
      wrote on last edited by user2684
      #68
      @bilbolodz said in NodeManager: plugin for a rapid development of battery-powered sensors:
      Ok got it, just wanted to be sure that what I had in mind, despite being awful, was kind of feasible. Now let me try to understand better what you have in mind: you store in eeprom the the addresses, then call registerSensor() and the for DS18B20, it will retrieve from there the addresses and do the mapping automatically instead of being you doing in the sketch what I listed before. Is it correct? If so, despite some obvious complexity, does not require a special registerSensor() (which would be great).
      As a side note, having the controller storing something into the EEPROM is not something extremely difficult to implement, I can add an additional V_CUSTOM message so achieve this since I can imagine may be helpful for this and other use cases (https://github.com/mysensors/NodeManager/issues/53)
      B 1 Reply Last reply
      • U user2684
        B
        B
        bilbolodz
        @user2684 Yes, that could be nice solution.
        U 1 Reply Last reply
        • B bilbolodz
          U
          U
          user2684
          Cool, I'll track it down (https://github.com/mysensors/NodeManager/issues/54) so you can see when I'll get into it.
          • U user2684
            PRES I=1 T=6
            PRES I=2 T=6
            PRES I=3 T=7
            BeniKB
            BeniKB
            BeniK
            @user2684 You were right! Definately a memory problem. Disabled the non-needed modules and everything is working as it should!
            REG I=1 P=3 P=6 T=0
            REG I=2 P=4 P=6 T=0
            REG I=3 P=4 P=7 T=1
            NodeManager v1.4
            INT1 M=255
            INT2 M=255
            RADIO OK
            PRES I=200, T=23
            PRES I=201, T=30
            BATT V=3.44 P=100
            SEND D=0 I=201 C=0 T=38 S= I=0 F=3.44
            PRES I=1 T=6
            PRES I=2 T=6
            PRES I=3 T=7
            READY
            MY I=199 M=1
            DS18B20 I=1 T=44.19
            SEND D=0 I=1 C=0 T=0 S= N=0 F=44.19
            DHT I=2 T=24.40
            SEND D=0 I=2 C=0 T=0 S= N=0 F=24.40
            DHT I=3 H=35.50
            SEND D=0 I=3 C=0 T=1 S= N=0 F=35.50
            SLEEP 60s
            Many many many THANKS for the help!
            • BeniKB
              BeniKB
              BeniK
              @user2684 By the way I am alsy trying to implement the forecasting algorithm for BME280 sensor (from here) into the BME280 section of NodeManager.cpp and Nodemanager.h but until now no joy. Maybe I am trying to do something complicated for me as a beginner into this, but I always like to learn by trial and error. Any advice you could give me to be able to implement the forecasting algorithm?
              • BeniKB BeniK
                REG I=1 P=3 P=6 T=0
                REG I=2 P=4 P=6 T=0
                REG I=3 P=4 P=7 T=1
                NodeManager v1.4
                INT1 M=255
                INT2 M=255
                RADIO OK
                PRES I=200, T=23
                PRES I=201, T=30
                BATT V=3.44 P=100
                PRES I=1 T=6
                PRES I=2 T=6
                PRES I=3 T=7
                READY
                MY I=199 M=1
                DS18B20 I=1 T=44.19
                DHT I=2 T=24.40
                DHT I=3 H=35.50
                SLEEP 60s
                U
                U
                user2684
                Great! I feel like there are a lot of optimizations that can be done to prevent this and other weird behaviors (tracked already with https://github.com/mysensors/NodeManager/issues/28).
                I'd need a real programmer's review sooner or later because I'm sure the way I am e.g. comparing and manipulating strings are far from being efficient...
                • BeniKB BeniK
                  U
                  U
                  user2684
                  Great idea! I wonder if the issue you are facing is due to different libraries being used (I'm using Adafruit's library, not the one from MySensors examples folder, not sure if they are different). I'll give it a try as well (https://github.com/mysensors/NodeManager/issues/56), but please let me know if you'll find the way to have it working and I'll make it part of the main code base.
                  • U user2684
                    @mar.conte your configuration looks correct, SENSOR_MOTION is what you want to use indeed. However, the logs are saying NodeManager is presenting the sensor as S_TEMP so the issue is on NodeManager's side also because looks like SensorThermistor has been instantiated but if I look at the code, there is no way this should happen.I'll try to setup something similar to see if I can reproduce the behavior. Very stupid question: are you sure you have uploaded successfully that sketch and it is not an old one? I really cannot explain it otherwise at a first look...
                    mar.conteM
                    mar.conteM
                    mar.conte
                    @user2684
                    all ok now is s_motion but is ever tripped high!!!why?
                    M.C.
                    • mar.conteM mar.conte
                      @user2684
                      U
                      U
                      user2684
                      @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
                      Default behavior is triggering on RISING but this can be changed with setMode() and setInitial(). Also ensure you are using pin 3 on a pro mini to have a valid interrupt. What is the behavior you are experiencing?
                      mar.conteM 2 Replies Last reply
                      • U user2684
                        mar.conteM
                        mar.conteM
                        mar.conte
                        @user2684
                        for istance Sensorswitch what is code?
                        M.C.
                        • U user2684
                          mar.conteM
                          mar.conteM
                          mar.conte
                          @user2684
                          it's ok this code?
                          NodeManager nodeManager;
                          SensorSwitch swiTch(1,3);
                          // before
                          void before() {
                            Serial.begin(MY_BAUD_RATE);
                             * Register below your sensors
                          swiTch.setMode(0);
                          swiTch.setInitial(0);
                          swiTch.setTriggerTime(4000);
                            nodeManager.setSleep(SLEEP,60,MINUTES);
                            nodeManager.registerSensor(SENSOR_MOTION,3);```
                          M.C.
                            @user2684
                            it's ok this code?
                            // before
                            void before() {
                            swiTch.setMode(0);
                            U
                            U
                            user2684
                            @mar.conte sorry I'm not sure I have understood what you want to achieve. Do you have a motion sensor which is HIGH by default and when triggers goes LOW? Is this what you need?
                            mar.conteM 1 Reply Last reply
                            • U user2684
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @user2684
                              Hello, I have a simple pir hcr501 that normally does not send output to pin 3 (so low) but when there is movement becomes HIGH, then my CPU goes to sleep for 60 minutes; the hardware is well configured because this setup I used it with the official mysensors sketches for pir motion; I do not understand why the domoticz controller is always the pir HIGH and does not go into sleep the MCU, thanks
                              M.C.
                                @user2684
                                U
                                U
                                user2684
                                Ok, so you don't need any customization in NodeManager since this is meeting the default behavior (LOW by default and triggering on HIGH), sorry for the wrong advice. Let's have a look at the sensor's logs then to see why the node is waking up continuously.
                                • U user2684
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  @user2684
                                  @gohan
                                  node
                                  40 MCO:BGN:BFR
                                  REG I=1 P=3 P=6 T=0
                                  NodeManager v1.4
                                  INT1 M=255
                                  INT2 M=255
                                  59 TSM:INIT
                                  135 TSF:WUR:MS=0
                                  155 TSM:INIT:TSP OK
                                  176 TSM:INIT:STATID=100
                                  202 TSF:SID:OK,ID=100
                                  225 TSM:FPAR
                                  370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  2301 TSF:MSG:FPAR OK,ID=0,D=1
                                  2447 TSM:FPAR:OK
                                  2463 TSM:ID
                                  2478 TSM:ID:OK
                                  2492 TSM:UPL
                                  2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                  3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  3737 TSF:MSG:PONG RECV,HP=1
                                  3768 TSM:UPL:OK
                                  3784 TSM:READY:ID=100,PAR=0,DIS=1
                                  3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
                                  4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
                                  6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
                                  6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
                                  RADIO OK
                                  PRES I=200, T=23
                                  7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
                                  PRES I=201, T=30
                                  7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
                                  BATT V=3.25 P=93
                                  SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
                                  7469 !MCO:SND:NODE NOT REG
                                  7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
                                  PRES I=1 T=6
                                  7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
                                  READY
                                  7868 MCO:REG:REQ
                                  7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                                  9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  9078 MCO:PIM:NODE REG=1
                                  9105 MCO:BGN:STP
                                  MY I=100 M=1
                                  9123 MCO:BGN:INIT OK,TSP=1
                                  THER I=1 V=354.00 T=40.05
                                   M=1
                                  SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
                                  9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
                                  SLEEP 3600s
                                  9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                  9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
                                  9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  9666 !TSF:MSG:LEN,0!=8
                                  10108 MCO:SLP:TPD```
                                  Gateway
                                  0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  0;255;3;0;9;TSF:MSG:BC
                                  0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
                                  0;255;3;0;9;TSF:PNG:SEND,TO=0
                                  0;255;3;0;9;TSF:CKU:OK
                                  0;255;3;0;9;TSF:MSG:GWL OK
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                  0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
                                  0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
                                  0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
                                  0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
                                  0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
                                  0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
                                  0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
                                  0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
                                  0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
                                  0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
                                  M.C.
                                    @user2684
                                    @gohan
                                    node
                                    40 MCO:BGN:BFR
                                    REG I=1 P=3 P=6 T=0
                                    NodeManager v1.4
                                    INT1 M=255
                                    INT2 M=255
                                    59 TSM:INIT
                                    135 TSF:WUR:MS=0
                                    155 TSM:INIT:TSP OK
                                    225 TSM:FPAR
                                    2447 TSM:FPAR:OK
                                    2463 TSM:ID
                                    2478 TSM:ID:OK
                                    2492 TSM:UPL
                                    3768 TSM:UPL:OK
                                    RADIO OK
                                    PRES I=200, T=23
                                    PRES I=201, T=30
                                    BATT V=3.25 P=93
                                    PRES I=1 T=6
                                    READY
                                    7868 MCO:REG:REQ
                                    9105 MCO:BGN:STP
                                    MY I=100 M=1
                                     M=1
                                    SLEEP 3600s
                                    Gateway
                                    U
                                    U
                                    user2684
                                    @mar.conte there is something strange with this node. First of all the node is still presenting the temperature and not the motion sensor. Then I see a lot of failures during transmit but also while receiving (!TSF:MSG:LEN,0!=8). Are you sure you don't have something like two nodes with the same id?
                                    • U user2684
                                      mar.conteM
                                      mar.conteM
                                      mar.conte
                                      wrote on last edited by mar.conte
                                      #84
                                      @user2684
                                      hi, I noticed that the zero node has a child called S_Arduino_Repeater with an id equal to 255 child node, called 100 S_Arduino_Node, what do you recommend?
                                      smotion now appears I had mistakenly entered analog 0 on a wire that went to +Power
                                      M.C.
                                        @user2684
                                        U
                                        U
                                        user2684
                                        The node 0 is the gateway which presents itself as S_ARDUINO_REPEATER, the child id 255 is the broadcast address, the node id 100 is instead you node. This is all correct (with or without NodeManager). Glad to hear the motion sensor is now showing up. Is it still trigger continuously?
                                        • U user2684
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @user2684
                                          Yes trig again!!!
                                          M.C.
