  3. Can you mix RFM69 and RFM69H in one network?
6 Posts 3 Posters 1.9k Views 4 Watching
  • O Offline
    O Offline
    Omemanti
    I'm busy with the RFM69's atm.
    I got a serial gateway with a regular RFM69 and a node with RFM69. Both are working with eachother.
    I also got a ESP8266 gateway with RFM69H (wasnt paying attention while soldering) but the RFM69 node isn't connecting to this gateway.
    Might the "H" be the problem?
    • O Omemanti
      @Omemanti H has more output power, which means it will need a more powerful and stable power supply. Except that, with and without H are the same.
      • O Offline
        O Offline
        Omemanti
        Oke, thnx!
        Then I need to search somewhere else.
        It says that my radio is oke, so I guess the wiring was right..
        Ill connect an extra power supply then! maybe that works.
        mppM 1 Reply Last reply
        • O Omemanti
          Oke, thnx!
          mppM Offline
          mppM Offline
          mpp
          @Omemanti you'll need to uncomment this line for the RFM69H:
          #define MY_IS_RFM69HW // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
          I'm using Moteino's with and without H in the same network without issues.
          Now I'm trying to get into mysensors but I'm running into a lot of issues:
          • Node MCU with RFM69 keeps crashing after flasing it with the Gateway sketch
          • Flashing the same node with a blink script works but when I reset it or flash any larger sketch to it, it is running the old gateway sketch!
          • Can't seem to get a simple arduino pro mini to run with the RFM69
          I'd like to create a network of ESP8266 (Node MCU) + RFM69 MQTT gateway and Arduino Pro Mini + RMF69 nodes (and repeaters)
          Any tips how you got the ESP8266 or the Pro Mini working are welcome?
          MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
          mfalkviddM O 2 Replies Last reply
          • mppM mpp
            @mpp best way would probably be to start a new thread describing what you have done, what you expected to happen and what happened instead. Also see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for troubleshooting recommendations.
            • mppM mpp
              O Offline
              O Offline
              Omemanti
              @mpp
              Try reverting to MySensors 2.0.0 and update AVR to 1.6.18. made my node al lot more stable.
