  2. Bug Reports
  3. Multiple sensor node freeze
15 Posts 5 Posters 8.0k Views 5 Watching
    Mihai
    I succeed to retrieve the error message!
    Setup: MQTT gateway connected via Ethernet to the broker, only one node in the same MySensors network (development), HomeAssistant, switching very aggressive a group of 4 switches, in my sketch each message is sent three times with wait() between them.
    The last few messages are:
    read: 0-0-10 s=4,c=1,t=2,pt=0,l=3,sg=0:OFF
    send: 10-10-0-0 s=4,c=1,t=2,pt=0,l=3,sg=0,st=fail:OFF
    send: 10-10-0-0 s=4,c=1,t=2,pt=0,l=3,sg=0,st=ok:OFF
    read: 0-0-10 s=9,c=1,t=2,pt=0,l=3,sg=0:OFF
    send: 10-10-0-0 s=9,c=1,t=2,pt=0,l=3,sg=0,st=fail:OFF
    send: 10-10-0-0 s=9,c=1,t=2,pt=0,l=3,sg=0,st=ok:OFF
    read: 0-0-10 s=1,c=1,t=2,pt=0,l=2,sg=0:ON
    send: 10-10-0-0 s=1,c=1,t=2,pt=0,l=2,sg=0,st=fail:ON
    send: 10-10-0-0 s=1,c=1,t=2,pt=0,l=2,sg=0,st=ok:ON
    read: 0-0-10 s=2,c=1,t=2,pt=0,l=2,sg=0:ON
    send: 10-10-0-0 s=2,c=1,t=2��J*���+�x00�=fail:ON
    send: 10-10-0-0 s=2,c=1,t=2,pt=0,l=2,sg=�+��	99rex00x00��0-10 s=4,c=1,t=2,pt=0,l=2,sg=0:ON
    setIK`}Starting repeater (RNNRA-, 2.0.0-beta)
    Radio init failed. Check wiring.
    The gateway and node was not moved at all. Resetting the node from the power (keep its position to check if the wires made some problem) the node come back alive. Shaking the node while change switches from interface less aggressive: the node continue to works fine.
    Sending again a lot of messaged by changing the switches it gives some errors from time to time, but it recover from them and continue to work:
    send: 10-10-�0 s=4,c=1,t=2,pt=0,l=3,sg=0,st=ok:OFF
    read: 0-0-10 s=9,c=1,t=�Jx000,l=3,sg=0:OFF
    send: 10-10-0-0 s=9,,�|΢x00�x00x00x00�Y�x00�3�]x00�(Starting repeater (RNNRA-, 2.0.0-beta)
    Radio init successful.
    send: 10-10-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
    send: 10-10-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=ok:2.0.0-beta
    send: 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    read: 0-0-10 s=4,c=1,t=2,pt=0,l=2,sg=0:ON
    So from time to time, after a burst of messages, some messages have some errors and the node made a init of radio and some times it doesn't succeed to recover from there to start over, it blocks itself.
      Mihai
      While monitor also the NRF25 power (from other source than Arduino itself) I see it get ~11-13mA while working and goes to zero when the node blocks.
        Mihai
        I have tested 4 switches/relays on the gateway and they work fine, no blocking during stress test (mostly group switch, like I did for node test).
          Mihai
          wrote on last edited by Mihai
          I have checked the free memory of a node based on http://playground.arduino.cc/Code/AvailableMemory , the results are the following:
          While normal usage, low messages rate, the measurement is the following and it remains constant:
          freeMemory()=825
          After a burst of messages, the time when it doesn't block (I mention that because it blocks quite often while handling many messages) I got this:
          freeMemory()=2195
          Other measurement close to blocking point:
          freeMemory()=-28671
          freeMemory()=-27900
          freeMemory()=-27900
          freeMemory()=-27900
          freeMemory()=-27900
          freeMemory()=25761
          The problem could be related to variables that exceed their memory limits or loose free memory by fragment it and not able to recover.
          I observed once after some errors I got Radio init successful and the freeMemory get back its value of 825 in my case.
          parachutesjP 1 Reply Last reply
          • M Mihai
            freeMemory()=825
            freeMemory()=2195
            freeMemory()=-28671
            freeMemory()=-27900
            freeMemory()=-27900
            freeMemory()=-27900
            freeMemory()=-27900
            freeMemory()=25761
            parachutesjP
            parachutesjP
            parachutesj
            @Mihai
            I might have the same issue. I have nodes with 4 and 6 relays on them and they stop communicating with the gateway from time to time. It still functions when pressing the physical buttons attached to the arduino, only communication hangs. After power off/on it works again.
            This only happens on nodes with more than one message.
            I am using 1.5.4 and never saw anything in logs.
            What kind of delay did you use? Was anything changed in the meantime on the code?
            • parachutesjP parachutesj
              @Mihai
              Mihai
              @parachutesj Inserting just Delay() into the code doesn't help always, while it may insert some other troubles, but trying to send messages with some other line code between next sending help a little bit.
              My error messages was revealed after a lot of testing and stress of the nodes.
              I am waiting for the MySensors library improving, I saw a lot of work there, so I will keep the actual config, minimize the testing nights for now. Of course I am hard resetting nodes from time to time, when they fail to respond. The gateway seems to works fine.
              • M Mihai
                parachutesjP
                parachutesjP
                parachutesj
                @Mihai
                Thank you. I added a delay of 2 sec into my controller rules. This does not harm, those rules are really not time critical. Will see if this changes something at the end.
                Resetting nodes does not seem to be an permanent option as most of them are behind my switches in the wall and do not want to open that all the time.
                • siodS
                  siodS
                  siod
                  Hi guys,
                  can you report an update? I also have problems with freezing nodes, did you find a solution?
                  Thank you!!
                  still learning...
                  • siodS siod
                    Hi guys,
                    Thank you!!
                    parachutesjP
                    parachutesjP
                    parachutesj
                    @siod I changed most of the power supplies for the nodes with relays. Seems to be fixed. All simple switches or sensors with temp etc. never hang. It is only with actuators and relays. Also upgrading to latest version might have improved the situation. But I am almost certain that I had a few bad power supplies.
                      I read other times that relays can cause some power fluctuations that can cause problems.
                      12.5k
