  3. N00b + MQTT gw + openHAB2
26 Posts 5 Posters 9.0k Views 5 Watching
    If you want to play with node red, at the moment it is not supporting mysensors over mqtt but only serial and ethernet. Then depending on the level of integration and automation you want to have, there are different solutions: if you want some basic control of Arduino IO ports over Internet with a nice app, you could use cayenne, but if you want to have multiple wireless sensors and automation you'd better stay with mysensors and domoticz and start getting some experience; later on you can start looking at more complex scenarios.
    MasMatM 1 Reply Last reply
      MasMatM
      MasMatM
      MasMat
      @gohan Totally agree.
      I'll push forward with your recommendations: ethernet+domoticz. After looking into Domo, I think it could serve me well for my purposes as a whole.
      Any ideas about the code for the gateway: udp? controller ip? relays?
      I will build one more Mysensors relay so I can verify radio working etc.
        Your sketch seems ok, just make it ethernet gateway instead of mqtt.
        UDP and controller IP are nor necessary.
        • Q
          Q
          Qu3Uk
          I use MQTT and Openhab2 - I find it more flexible then the Ethernet GW but yes you need to have a good understanding on all systems I suppose.
          Somethings to note
          • MySensors binding doesn't support MQTT gateway as far as I know, you need to use the MQTT binding and configure your OH items accordingly.
          • MySensors binding is in the IOT market place and not openhab-addons
          • You'll need to assign node ID to your nodes manually.
          Not entirely sure what your problem is here but don't think you've got all the right pieces for the puzzle yet.
          gohanG 1 Reply Last reply
          • Q Qu3Uk
            Somethings to note
            @Qu3Uk I remember that Mysensors binding works both ethernet and MQTT, but anyway ethernet is the best solution for beginners because you can use myscontroller to debug messages while connected to controller.
            Q E 2 Replies Last reply
              Q
              Q
              Qu3Uk
              @gohan Ah really? I've loosely been following last i saw there was a proof of concept mentioned.
                E
                E
                ericvdb
                wrote on last edited by ericvdb
                @gohan said in N00b + MQTT gw + openHAB2:
                With MQTT you can also debug using MQTT-Spy or MQTTLens or various other MQTT apps.
                MQTT is easy in interconnecting various systems without they have to know about each-other.
                As long as you have a MQTT broker (RabbitMQ, Mosquitto, ActiveMQ, ...) you're all set.
                In OpenHab in conf/services create a file called mqtt.cfg, and past the following:
                mqtt:broker.url=tcp://ip-address-of-mqttbroker:1883
                mqtt:broker.clientId=openhab
                mqtt:broker.retain=true
                mqtt:broker.async=false
                Then in your items file you can do:
                Switch Light_GV_Hall    			"Ceiling"       	(GV_Hall, Lights) {mqtt=">[broker:myhome/room/switch1:command:ON:1],>[broker:myhome/room/switch1:command:OFF:0],<[broker:myhome/room/switch1:state:ON:1],<[broker:myhome/room/switch1:state:OFF:0"}
                And now you can turn on/off the light from OpenHab as wel as from any other device that publishes to the same toppic (yes, even from MQTT-Spy and MQTTLens)
                • E ericvdb
                  @ericvdb I know, I am talking for a beginner perspective. The more advanced users know how to debug over mqtt and stuff
                  • MasMatM
                    MasMatM
                    MasMat
                    Update.
                    After much trying the Ethernet gw would not connect to Domoticz.
                    Then, tried my mqtt sketch again and presto! I have connection AND I can control the two relays on board the mqtt-gw.
                    Had a cold one...or four!
                    Thanks for the recommendations and help. I'm sure I will need more later on. Now I'm going to explore the Domoticz forum for answers.
                    Unless someone with the same setup can tell me why the lights are crossed (on = off in reality and off=light on)?
                      Depends on relay board
                      • MasMatM
                        MasMatM
                        MasMat
                        I just have the modules. low=relay on.
                        I think it would be easier to change it in Domoticz or do I have to change it in the sketches (I think this will be more work when I add new sensors and relays)?
                          Just do everything in code so you present relay status not pin status
                            MasMatM
                            MasMatM
                            MasMat
                            @gohan How do I do that? I tried reversing the:
                            #define RELAY_ON 0 // GPIO value to write to turn on attached relay
                            I switched around the 0 and 1 but no real change...
                              Did you get a debug log where you actually see the node receiving the message to change the relay status? Because setting the defines as you said should be correct
                              • MasMatM
                                MasMatM
                                MasMat
                                I see the mqtt message going out. I have to double check the 0 vs 1 in the messages.
                                I'm about to build another sensor that has only relays. So I will troubleshoot this code & mqtt to make it match.
                                  Actually I mean the serial debug of the node, not the mqtt log
                                    MasMatM
                                    MasMatM
                                    MasMat
                                    @gohan gonna examine that too before actually hooking it up. Thanks
