  2. Feature Requests
  3. Domoticz full integration
Scheduled Pinned Locked Moved Feature Requests
79 Posts 26 Posters 77.6k Views 11 Watching
  • AWIA AWI
    @GaryStofer You should change the "Switch type" in the GUI (edit sensor -> switchtype -> motion sensor) to change between the different switch types. The naming of the sensors like "lighting 2" is a Domoticz thing coming from history. It is better to ignore this.
    I don't know yhy the "last seen" never changes if you see the changes in the log file. Better to address these things on the Domoticz forum.
    The implementation is compiled in the Domoticz code (although I am using my own script for now)
    G
    G
    GaryStofer
    wrote on last edited by GaryStofer
    #68
    Yes, changing the "switch type" to Motion helped a great deal. I would never have thought of a motion detector to be considered a switch. I guess it works in a backwards kind of way. I get the source on my RPi next and have fun with that and trying to figure out why the simplest of Blockly events all fail to execute with error message. Have not found much deliberate documentation on their site, such is opens source I guess ..... Seems to be snappy though.
    How is your own script tying into the system?
    G
    AWIA 1 Reply Last reply
    • G GaryStofer
      G
      AWIA
      AWIA
      AWI
      @GaryStofer I suggest you put a screen dump on the Domoticz forum for the Blockly issue. Lot's of helping hands over there. My "own script" is a Python interface to Domoticz, It works well but has a separate "database" (.csv file ;)) to store all the sensor to domoticz bindings. It makes everything very flexible and complete but installation etc. is a bit of a pain... I still use it because of missing functionality to "read" values from Domoticz. If you want I can update the version on GitHub.
      • AWIA AWI
        Status of native Domoticz MySensors support:: For the ones who are interested @GizMoCuz did a great job in building native MySensors support in Domoticz. As documentation is lagging behind ;) I have examined the code and come up with a basic understanding of functionality.
        First of all: you need the beta version of Domoticz (can be enabled in setup->settings) for now to get MySensors support. By enabling the MySensors hardware (setup->hardware) you can enable MySensors USB/ LAN interface.
        The supported "V" types as of today for "SET" (read from the code):
        V_TEMP:, V_HUM, V_PRESSURE, V_VARx, V_TRIPPED, V_ARMED, V_LOCK_STATUS, V_LIGHT, V_DIMMER, V_DUST_LEVEL, V_WATT, V_KWH, V_DISTANCE, V_FLOW, V_VOLUME:, V_WIND, V_GUST, V_DIRECTION, V_LIGHT_LEVEL,:V_FORECAST,: V_VOLTAGE, V_UV, (so almost all )
        The list for 'REQ' is (and will be.?) limited to V_LIGHT, V_DIMMER and V_VAR types. If anyone needs more please address this on the Domticz forum as I am out of arguments.
        Be aware that the MySensor support is beta, but very promissing.
        Mickey
        wrote on last edited by Mickey
        #70
        are the V_VARx types realy supported? because I can run domoticz with V_DISTANCE , V_TEMP:, V_HUM, V_PRESSURE etc but V_VARx types only showed on the log but not recognized on the devices list...
        • M Mickey
          AWIA
          AWIA
          AWI
          wrote on last edited by AWI
          #71
          @Mickey It is supposed to be supported. Have a look at the Domoticz code. I also remember seeing a discussion on the Domoticz forum.
            Mickey
            maybe the V_VAR value sending node need to send some kind of values to be recognized beside the first recognition packets? because in the relay node there was a problem with the mysensors build section basic sketch that domoticz didnt recognize until I change the sketch and made a call to gateway with relay pin status for it to recognize the node...
            • V
              V
              vikasjee
              Is there a fully functional domoticz integration now?
              • P
                P
                pjr
                Almost.. some S_HVAC "enum" messages arent supported.
                • siklosiS
                  siklosiS
                  siklosi
                  Are there any plans and is it possible at all to implement ota fw update through domoticz?
                  • alowhumA
                    alowhumA
                    alowhum
                    What's the current state of integration? Are the data types supported now?
                    • qqlapralineQ
                      qqlapralineQ
                      qqlapraline
                      I think so ! :)
                      Have a look here.
                      QQ.
                        If you install beta version of domoticz you can add both ethernet and mqtt gateways and lots of types are supported
                        • P
                          P
                          pjr
                          wrote on last edited by pjr
                          #79
                          V_HVAC_FLOW_MODE, V_HVAC_SPEED and V_HVAC_FLOW_STATE handling still missing.
                          No smartSleep implementation yet.
