  3. Pro Mini + RFM node and ESP8266 + RFM gateway not working
5 Posts 3 Posters 1.5k Views 3 Watching
  • mppM Offline
    mppM Offline
    mpp
    wrote on last edited by mpp
    So I connected the radio to the ESP and the Pro Mini as described.
    Installed the DHT sketch on the Pro Mini and added:
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RFM69_NETWORKID 99
    The Serial output:
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,Starting sensor (RRNNA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    Installed the default ESP MQTT gateway sketch on the ESP and added:
    #define MY_RF69_IRQ_PIN D1
    #define MY_RF69_SPI_CS D8
    The serial output:
    K⸮⸮q⸮⸮0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    scandone
    state: 0 -> 2 (b0)
    f 0, state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 3
    cnt
    scandone
    connected with MPPort, channel 6
    dhcp client start...
    .............ip:192.168.0.219,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.219
    IP: 192.168.0.219
    0;255;3;0;9;MQTT connected
    pm open,type:2 0
    0;255;3;0;9;TSP:SANCHK:OK
    I'm seeing the initial message in mqtt but not the messages from the node: mygateway1-out/0/255/0/0/18 2.1.1
    Any idea what could be going wrong?
    MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
      #define MY_RFM69_NETWORKID 99set your preferred network id if needed
      You forgot to leave the // after the 99 and I think it can cause some problems
      mppM 1 Reply Last reply
        mppM Offline
        mppM Offline
        mpp
        @gohan thanks for the reply but that was just a typo. The sketch compiles and uploads properly. Yet I keep seeing connections to my Wifi when I upload the ping pong script for example, this doesn't seem to be normal.
        • mppM Offline
          mppM Offline
          mpp
          The problems seem to have been caused by a bad connection on D1.
          Still I find it strange that a Wifi login appears on the serial interface after programming the pingpong sketch.
          • mppM mpp
            mfalkviddM Online
            mfalkviddM Online
            @mpp the esp stores (in a special area of the eeprom) ssid and key for the accesspoint it last connected to, and automatically connects back next time unless wifi is turned off in the sketch.
            12.2k
