  3. Another simple (No SMT) relay actuator
42 Posts 8 Posters 16.0k Views 6 Watching
  • M MLs
    @dpressle
    I do not get Atmel to run with Mysbootloader 8MHz.
    Seems like it does not use the internal clock
    Also tried to put your text into the board.txt file without any difference.
    But if I use the bottloader ATmega328 on a breadboard (8 MHz internal clock it work.
    dpressleD
    dpressleD
    dpressle
    @MLs as i said, i can only try to help if you get me more information about your environment and pictures and then i can compare it to mine.
    • dpressleD dpressle
      MLs
      wrote on last edited by MLs
      #29
      @dpressle
      MYSBL13.name=ATmega328 with MYSBootloader
      MYSBL13.upload.tool=avrdude
      MYSBL13.upload.protocol=arduino
      MYSBL13.bootloader.tool=avrdude
      MYSBL13.bootloader.unlock_bits=0x3F
      MYSBL13.bootloader.lock_bits=0x0F
      MYSBL13.build.mcu=atmega328p
      MYSBL13.build.board=AVR_PRO
      MYSBL13.build.core=arduino
      MYSBL13.build.variant=standard
      ## Arduino with MYSBootloader 1.3pre
      MYSBL13.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8)
      MYSBL13.menu.cpu.16MHzatmega328.upload.maximum_size=30720
      MYSBL13.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048
      MYSBL13.menu.cpu.16MHzatmega328.upload.speed=115200
      MYSBL13.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
      MYSBL13.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
      MYSBL13.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
      MYSBL13.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_16Mhz.hex
      MYSBL13.menu.cpu.16MHzatmega328.build.mcu=atmega328p
      MYSBL13.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
      MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8)
      MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_size=30720
      MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
      MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
      MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
      MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
      MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
      MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_8Mhz.hex
      MYSBL13.menu.cpu.8MHzatmega328.build.mcu=atmega328p
      MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
      ############# DO NOT WORK INTERNAL CLOCK #####################
      MYSBL13.menu.cpu.8MHzinternalclockatmega328=ATmega328 8MHz internal clock (RC, BOD1V8)
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.upload.maximum_size=30720
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.upload.maximum_data_size=2048
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.upload.speed=38400
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.upload.tool=arduino:avrdude
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.upload.protocol=arduino
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.bootloader.low_fuses=0xE2
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.bootloader.high_fuses=0xDA
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.bootloader.extended_fuses=0xfe
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.bootloader.file=breadboard/MYSBL13pre_atmega328_8Mhz.hex
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.bootloader.unlock_bits=0x3F
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.bootloader.lock_bits=0x0F
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.bootloader.tool=arduino:avrdude
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.build.mcu=atmega328p
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.build.f_cpu=8000000L
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.build.core=arduino:arduino
      MYSBL13.menu.cpu.8MHzinternalclockatmega328.build.variant=arduino:standard
      MYSBL13.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8)
      MYSBL13.menu.cpu.1MHzatmega328.upload.maximum_size=30720
      MYSBL13.menu.cpu.1MHzatmega328.upload.maximum_data_size=2048
      MYSBL13.menu.cpu.1MHzatmega328.upload.speed=9600
      MYSBL13.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
      MYSBL13.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
      MYSBL13.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
      MYSBL13.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_1Mhz.hex
      MYSBL13.menu.cpu.1MHzatmega328.build.mcu=atmega328p
      MYSBL13.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
      dpressleD 1 Reply Last reply
      • M MLs
        @dpressle
        dpressleD
        dpressleD
        dpressle
        @MLs try to first upload the burning sketch to the nano (even if its already uploaded) and then burn the bootloader.
        What set up do you have, how the nano is connected to the atmega?
        What error do you get when bootloader burn fails?
          MLs
          #31
          @dpressle
          The problem is not to burn bootloader. The problem I think is that the Mysbootloader does not use internal clock.
          Therefore, I asked you how to know how a bootloader uses an external clock or internal clock.
          And because you had a bootloader for OTA and internal clock, 8MHz I wanted you to send it to me.
          • M MLs
            @dpressle
            dpressleD
            dpressleD
            dpressle
            @MLs I am completely lost here, you said "I do not get Atmel to run with Mysbootloader 8MHz." and now you are asking "how to know how a bootloader uses an external clock or internal clock" how can you say its not working and then ask me how to know that its working?
            To conclude this, if you successfully burn the 8Mhz Mysbootloader and the board is working then it is working with 8Mhz it cannot be working on 16Mhz because there is no external osc, its not 1Mhz because of the fuses etc.
              MLs
              #33
              @dpressle
              @MLs said in Another simple (No SMT) relay actuator:
              @dpressle
              Feeling a bit confused how do you know that a bootloader uses the internal clock?
              Because I used another bootloader after installing your card, I did not get the Atmega circuit to run. But if I used this bootloader, I started the Atmega circuit and everything worked.
              Https://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5
              But what makes the internal clock in used?
              I use a UNO when I'm burning bootloader and do not know if you can change fuses and clock option.
              If you use a bootloader that uses an external clock, you will not get the Atmega circuit to run. If I understand everything right.
              No if I'm burning 8MHz Mysbootloader, the Atmega circuit does not start.
              But instead, I use this bootloader (ATmega328 on a 8 MHz internal clock) and I get the Atmega circuit to run, but without OTA.
              M dpressleD 2 Replies Last reply
              • M MLs
                @dpressle
                @dpressle
                MLs
                @dpressle
                @dpressle
                • M MLs
                  @dpressle
                  @dpressle
                  dpressleD
                  dpressleD
                  dpressle
                  @MLs You said before "The problem is not to burn bootloader."
                  and now you are saying "No if I'm burning 8MHz Mysbootloader, the Atmega circuit does not start."
                  I am asking again, are you able to successfully burn and run Mysbootloader 8Mhz or not?
                    MLs
                    @dpressle
                    I can burn Mysbootloader yes.
                    But the Atmega circuit does not start.
                    The problem I think is that Mysbootloader does not use the internal clock
                    And because you said you had a bootloader for OTA and internal clock, 8MHz I wanted you to send it to me.
                    Then there would have been no problem, I think.
                    • M MLs
                      @dpressle
                      dpressleD
                      dpressleD
                      dpressle
                      @MLs i use what you use, Mysbotloader 1.3pre, as i said in one of the first messages, you dont need me to send it to you you can (and did) download it from here.
                      This is why i think you are doing something wrong or have wrong settings.
                        MLs
                        @dpressle
                        And my settings are seen in previous posts.
                        But this does not lead to anything so I finish this now.
                          Shaun Storbakken
                          Is this setup to take a maximum 2 amp load? Plenty for a lighting circuit, just curious in case someone tries to use it on a switched outlet circuit etc.
                          J1 is power feed and J2 are the three switched outputs right with the wall switch connected using D5 - D6 - D7 right?
                          • S Shaun Storbakken
                            dpressleD
                            dpressleD
                            dpressle
                            @Shaun-Storbakken It was designed with the idea of controlling 3 different loads of up to 2 Amp each, lightning, switches etc.
                            The D-5,6,7 are for manual switching and they will (if you use my code) control the 3 relays respectively, J1 is power input 110-220V, please note that you should pay attention to the polarity and connect line wire to the right of J1 (otherwise you will end up switching natural to the load), J2 is AC output where each one is different relay, so you have 3 X 110-220V outputs of max 2 A each.
                            I hope it was helpful, please let me know if you need further help.
                            • dpressleD
                              dpressleD
                              dpressle
                              Small update, i connected touch switches to the board instead of mechanical switches.
                              where i live we are using gwiss switches and when the board is in the box there is not much room for mechanical switches as they are too deep, so i took some blanks that are used to cover unused switch hols and added touch switch to it, see the pictures below:
                              breimannB 1 Reply Last reply
                                breimannB
                                breimannB
                                breimann
                                @dpressle Nice job!
