  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
  • DigdoggerD
    DigdoggerD
    Digdogger
    Thanx for your answers. @AWI, the BME280 looks great and not expansive i will replace the DHT by this one. Thank you.
    • DigdoggerD Digdogger
      I would like to use this example and reduce power consumtion by removing the regulator on the mini Pro and the power led.
      If we remove the regulator, we can power the board with 3V on Vcc. It will be OK for the mini pro and the NRF but the DHT22 needs 3.3V minimum. The solution will consist to use a step up boost module. What is the current consumtion of the step up boost?
      J
      J
      jwosnick
      @Digdogger
      Out of curiosity, do you expect there to be a big savings in power consumption by removing the regulator and power LED? I've never used the Mini Pro (the smallest I get to is the Nano) but I understand it already is very efficient with power usage.
      gohanG mfalkviddM 2 Replies Last reply
      • DigdoggerD
        DigdoggerD
        Digdogger
        @jwosnick: please take a look here: http://www.home-automation-community.com/arduino-low-power-how-to-run-atmega328p-for-a-year-on-coin-cell-battery/.
        You'll see that the current saving is significant (almost 40% saving)
        • J jwosnick
          @Digdogger
          @jwosnick
          Arduino is efficient for a live node, but for a battery powered sleeping node voltage regulators have a small drain on battery; led also consumes some power. The Nano has also the usb chip that is powered but not used that also increases battery drain. So, as rule of thumb, everything that is not really used/necessary will drain some battery over time.
          • J jwosnick
            @Digdogger
            @jwosnick with the led and regulator, battery life on 2xAA is about three weeks. Removing them will usually give you 2-5 years.
            J 1 Reply Last reply
              J
              J
              jwosnick
              @mfalkvidd
              Thank you. I didn't realize the differences were so stark.
              I have some Pro Mini 3.3V units on order and hope to convert my sensors to that platform, when they arrive.
              • H
                H
                hashem25
                hello I ran it but i didnt see anthing except the garbage in com monitor
                Nca78N 1 Reply Last reply
                • H hashem25
                  @hashem25 said in 💬 Air Humidity Sensor:
                  Hello, you need to change the baud rate at the bottom right of the Arduino serial monitor window until you see clear text.
                  • H
                    H
                    hashem25
                    thanks it works
                    • A
                      anno
                      How do i get 2 dht22's working in the code?
                        If you already have one, it is a matter of just repeating your code for the first sensor and just change the pin number where you connected the second one
                        • I
                          I
                          ianatkin
                          This example doesn't seem to be included in the latest library version - am I being blind or is this deliberate?
                          • I ianatkin
                            @ianatkin that is correct. Follow the instructions under the "Example" headline on the build page.
                            I 1 Reply Last reply
                              I
                              I
                              ianatkin
                              @mfalkvidd Thanks :)
                              • I ianatkin
                                @ianatkin you're welcome. Great to see a new forum member :)
                                • G
                                  G
                                  godwinguru
                                  Is it the same code that i will burn to the controller circuit. Can someone help me with a little explanation on the code for the controller circuit so as to be receiving the temperature values
                                    MrVince
                                    Hi ! Thank's for working :)
                                    I add the libraries in "MySensors external examples" to Arduino IDE but when I want to compile I have this one log error :
                                    DhtTemperatureAndHumiditySensor.ino:43:25: fatal error: MySensors.h: No such file or directory
                                    compilation terminated.
                                    In MySensors folder's libraries, I have a MySensor.h, without 's' . This is one? Do I forget something?
                                    • M MrVince
                                      @MrVince sounds like MySensors 1.x is installed. Remove the MySensors folder and install the latest version. Instructions: https://www.mysensors.org/about/arduino#installing-the-sensor-libraries
                                      • G
                                        G
                                        godwinguru
                                        Please can someone help me on how I can be able to access the temperature and humidity data sent by the sensor on the gateway. I am recently working on sending temperature and humidity data to a controller. I used the above .ino code( /mysensors/MySensorsArduinoExamples/examples/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino) as it is and ensured my data pin is pin3 and for my gateway am using this(/mysensors/MySensors/examples/GatewayW5100/GatewayW5100.ino). I did not make any changes on both codes as i am new and do not have knowledge of what to do. I was receiving the following on the sensor serial monitor
                                        3 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        11 TSM:INIT:TSP OK
                                        13 TSM:FPAR
                                        15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        2022 !TSM:FPAR:NO REPLY
                                        2024 TSM:FPAR
                                        2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        4034 !TSM:FPAR:NO REPLY
                                        4036 TSM:FPAR
                                        5636 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        7644 !TSM:FPAR:NO REPLY
                                        7646 TSM:FPAR
                                        7648 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        9656 !TSM:FPAR:FAIL
                                        9657 TSM:FAIL:CNT=1
                                        9659 TSM:FAIL:PDT
                                        19662 TSM:FAIL:RE-INIT
                                        19664 TSM:INIT
                                        19672 TSM:INIT:TSP OK
                                        19674 TSM:FPAR
                                        19676 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        21684 !TSM:FPAR:NO REPLY
                                        21686 TSM:FPAR
                                        21688 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        23696 !TSM:FPAR:NO REPLY
                                        23698 TSM:FPAR
                                        23700 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        25708 !TSM:FPAR:NO REPLY
                                        25710 TSM:FPAR
                                        27310 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        29318 !TSM:FPAR:FAIL
                                        29319 TSM:FAIL:CNT=2
                                        29321 TSM:FAIL:PDT
                                        39324 TSM:FAIL:RE-INIT
                                        39326 TSM:INIT
                                        39333 TSM:INIT:TSP OK
                                        39335 TSM:FPAR
                                        39337 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        41346 !TSM:FPAR:NO REPLY
                                        41348 TSM:FPAR
                                        41357 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        43365 !TSM:FPAR:NO REPLY
                                        43367 TSM:FPAR
                                        43397 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        45405 !TSM:FPAR:NO REPLY
                                        45407 TSM:FPAR
                                        45409 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        47417 !TSM:FPAR:FAIL
                                        47418 TSM:FAIL:CNT=3
                                        47420 TSM:FAIL:PDT
                                        57423 TSM:FAIL:RE-INIT
                                        57425 TSM:INIT
                                        57433 TSM:INIT:TSP OK
                                        57435 TSM:FPAR
                                        57437 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        59445 !TSM:FPAR:NO REPLY
                                        59447 TSM:FPAR
                                        59456 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        61464 !TSM:FPAR:NO REPLY
                                        61466 TSM:FPAR
                                        61475 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        63484 !TSM:FPAR:NO REPLY
                                        63486 TSM:FPAR
                                        63489 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        65497 !TSM:FPAR:FAIL
                                        65498 TSM:FAIL:CNT=4
                                        65500 TSM:FAIL:PDT
                                        75503 TSM:FAIL:RE-INIT
                                        75505 TSM:INIT
                                        75512 TSM:INIT:TSP OK
                                        75514 TSM:FPAR
                                        75516 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        77526 !TSM:FPAR:NO REPLY
                                        77528 TSM:FPAR
                                        77537 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        79545 !TSM:FPAR:NO REPLY
                                        79547 TSM:FPAR
                                        79556 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        81564 !TSM:FPAR:NO REPLY
                                        81566 TSM:FPAR
                                        81568 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        83576 !TSM:FPAR:FAIL
                                        83577 TSM:FAIL:CNT=5
                                        83579 TSM:FAIL:PDT
                                        93582 TSM:FAIL:RE-INIT
                                        93584 TSM:INIT
                                        93591 TSM:INIT:TSP OK
                                        93593 TSM:FPAR
                                        93595 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        95603 !TSM:FPAR:NO REPLY
                                        95605 TSM:FPAR
                                        95618 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        97625 !TSM:FPAR:NO REPLY
                                        97627 TSM:FPAR
                                        97637 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        99645 !TSM:FPAR:NO REPLY
                                        99647 TSM:FPAR
                                        99649 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        101657 !TSM:FPAR:FAIL
                                        101659 TSM:FAIL:CNT=6
                                        101661 TSM:FAIL:PDT
                                        111664 TSM:FAIL:RE-INIT
                                        111666 TSM:INIT
                                        111673 TSM:INIT:TSP OK
                                        111675 TSM:FPAR
                                        111678 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        113685 !TSM:FPAR:NO REPLY
                                        113687 TSM:FPAR
                                        113700 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        115709 !TSM:FPAR:NO REPLY
                                        115712 TSM:FPAR
                                        115720 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        117728 !TSM:FPAR:NO REPLY
                                        117730 TSM:FPAR
                                        and on the gateway monitor i received this:
                                        0;255;3;0;9;TSM:INIT
                                        0;255;3;0;9;TSF:WUR:MS=0
                                        0;255;3;0;9;TSM:FAIL:CNT=1
                                        0;255;3;0;9;TSM:FAIL:PDT
                                        0;255;3;0;9;TSM:FAIL:RE-INIT
                                        0;255;3;0;9;TSM:FAIL:CNT=2
                                        0;255;3;0;9;TSM:FAIL:CNT=3
                                        0;255;3;0;9;TSM:FAIL:CNT=4
                                        0;255;3;0;9;TSM:FAIL:CNT=5
                                        0;255;3;0;9;TSM:FAIL:CNT=6
                                        0;255;3;0;9;TSM:FAIL:CNT=7
                                        Please can someone tell me what to do and how I can access the sent temperature and humidity value at the gateway. If there is further code to add to the one I have referenced, please do let me know.
                                        • G godwinguru
                                          3 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          11 TSM:INIT:TSP OK
                                          13 TSM:FPAR
                                          2024 TSM:FPAR
                                          4036 TSM:FPAR
                                          7646 TSM:FPAR
                                          9656 !TSM:FPAR:FAIL
                                          9657 TSM:FAIL:CNT=1
                                          9659 TSM:FAIL:PDT
                                          19664 TSM:INIT
                                          19674 TSM:FPAR
                                          21686 TSM:FPAR
                                          23698 TSM:FPAR
                                          25710 TSM:FPAR
                                          29321 TSM:FAIL:PDT
                                          39326 TSM:INIT
                                          39335 TSM:FPAR
                                          41348 TSM:FPAR
                                          43367 TSM:FPAR
                                          45407 TSM:FPAR
                                          47420 TSM:FAIL:PDT
                                          57425 TSM:INIT
                                          57435 TSM:FPAR
                                          59447 TSM:FPAR
                                          61466 TSM:FPAR
                                          63486 TSM:FPAR
                                          65500 TSM:FAIL:PDT
                                          75505 TSM:INIT
                                          75514 TSM:FPAR
                                          77528 TSM:FPAR
                                          79547 TSM:FPAR
                                          81566 TSM:FPAR
                                          83579 TSM:FAIL:PDT
                                          93584 TSM:INIT
                                          93593 TSM:FPAR
                                          95605 TSM:FPAR
                                          97627 TSM:FPAR
                                          99647 TSM:FPAR
                                          101661 TSM:FAIL:PDT
                                          111666 TSM:INIT
                                          111675 TSM:FPAR
                                          113687 TSM:FPAR
                                          115712 TSM:FPAR
                                          117730 TSM:FPAR
                                          sundberg84S
                                          sundberg84S
                                          TSM:INIT:TSP FAIL
                                          @godwinguru - your radio on the gw isnt initialised.
                                          Check wiring and power.
