  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    My current config for nrf24l01+ and w5100 is as follows:
    #define MY_GATEWAY_W5100
    #define MY_SOFTSPI
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    Why CE / CS pins are 5 and 6?
    Should that be 27 and 3?
    • alexsh1A
      alexsh1A
      alexsh1
      #234
      @tbowmo I have just re-worked SAMD and all the connectors (nrf24l01+ and NET_SPI), but still have the same issue sadly.
      EDIT: If I change to rfm69, the same behavior is observed. It seems that Net_SPI is just not working.
      • tbowmoT
        tbowmoT
        tbowmo
        #235
        @alexsh1
        Configuration of the pins are handled by the hardware configuration file, https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h#L227
        If you look in the gatewayW5100 sketch, the settings for CE / CS pins are enclosed in ifdefs, so they are only used if they are not defined previously.
        If you want to connect the W5100 to the mysx connector, you can change line 174 in the hardware definition file, use SPI2 instead of SPI1 for SPI_ETH
        It could also be a defective W5100 shield? Can you verify that it works on other hardware?
        alexsh1A 1 Reply Last reply
        • tbowmoT tbowmo
          @alexsh1
          alexsh1A
          alexsh1A
          alexsh1
          @tbowmo Swapping SPIs did not resolve the problem. I am now getting another W5100 to test further.
          • alexsh1A
            alexsh1A
            alexsh1
            Unfortunately, a new W5100 shield did not work - it seems like a production issue with this sensebender gatewsay as the SPI2 did not work either with W5100.
            Will get a new one ordered.
            • tbowmoT
              tbowmoT
              tbowmo
              Is it possible for you to check the spi wires with a scope? Just to make sure if mosi/miso/ce/Ss lines are toggling as expected?
              • tbowmoT
                tbowmoT
                tbowmo
                #239
                Another thing, are you using static ip? If yes, can you ping it? If no, does your DHCP server hand out an ip address?
                Have you tried the basic ethernet examples for the W5100?
                • tbowmoT tbowmo
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @tbowmo I am using the static IP and I can ping it, but the "Gateway Ready" message never comes up. Also I can only see the neg24l01+ log (incoming messages only)
                  tbowmoT 1 Reply Last reply
                  • alexsh1A alexsh1
                    tbowmoT
                    tbowmoT
                    tbowmo
                    @alexsh1
                    If you can ping it, then the W5100 is configured. Something else is wrong..
                    One thing that comes to mind, if you compile it as an ethernet GW, then it does not wait for serial console to be active, before initializing the radio. If you compile it as serial GW, then it waits with initialization, until serial is active.
                    This means that you probably is missing the GW ready message on the serial port, as it is "sent" before you have an active serial connection.
                    Look in MyHwSamd.cpp in the HwInit routine, remove the #ifdef around the while() loop, and try again.
                    • tbowmoT tbowmo
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #242
                      @tbowmo Well, if I try the MEGA 2560 with W5100, I get the following:
                      0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.1.1
                      0;255;3;0;9;TSM:INIT
                      0;255;3;0;9;TSF:WUR:MS=0
                      0;255;3;0;9;TSM:INIT:TSP OK
                      0;255;3;0;9;TSM:INIT:GW MODE
                      IP: 10.1.1.120
                      0;255;3;0;9;MCO:BGN:STP
                      I never get this message with Sensebender GW. I only get
                      0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:2019.12
                      0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:6275.51
                      0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:18.77
                      or similar messages from nodes.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #243
                        @alexsh1
                        on atmega2560 you are resetting the device, when you connect a serial terminal to the usb device, so you get all the debug messages on the serial port..
                        On SAMD it uses a native USB port, and the chip is not reset when connecting a serial terminal. When using serialGw it will wait until a serial terminal is connected. before initializing radio transport (this is because it does not make sense to have a serial gateway that spits out data to a none existing port).
                        When using it as a ethernet gateway, we skip this, as we do not want to wait for a serial terminal, in case you are just using the USB as a power source. So in this mode, it skips the waiting, and just initializes radio gateway etc.
                        as stated in my previous message you could look at the MyHwSAMD.cpp file line 73. Remove the #ifdef recompile, upload, and check your serial terminal again.
                        Also the log shows that you actually are receiving data from your nodes, so the radio transport is clearly active.. And you can ping your gateways static IP, which means that the W5100 is initialized with the correct IP address.
                        • alexsh1A alexsh1
                          IP: 10.1.1.120
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @alexsh1
                          Did you try my suggestion about hacking the core? Or did you give up on the beast? :)
                          I'm curious to hear if it is solved..
                          alexsh1A 2 Replies Last reply
                          • tbowmoT tbowmo
                            @alexsh1
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @tbowmo I will try it tomorrow. However, given the amount of time I spent already, I am about to give up...
                              micropet
                              Hello everybody.
                              I got my Sensebender gateway yesterday. Have the W5100 Ethernet board mounted and loaded a sketch with the WizNET (W5100) Ethernet module and MQTT.
                              The gateway immediately ran as desired.
                              Unfortunately only for about 2 hours, then it freezes.
                              After a restart it runs again 3 hours and freezes again.
                              And so on.
                              I wanted to replace an RPI Gatway, which has worked flawlessly for many weeks.
                              If the Sensebender gateway works only a few hours it is quite useless.
                              • M micropet
                                Hello everybody.
                                And so on.
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @micropet
                                It must be a software issue. Are you using it with nrf24? Do you have a github account? If you have, would you mind filling an issue report on the mysensors library? As we need to dig further into this. Please also make a note of how many nodes you have running in your system.
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @alexsh1
                                  I would really like to get it solved, so it can bring peace to my mind :) so please, if you can..
                                    micropet
                                    I also think that it is a software problem.
                                    I use only the RFM96HW.
                                    My "real" network has 20 nodes.
                                    The Sensebender gateway has only one DS18b20 node on a seperate frequency.
                                    (#define MY_RFM69_FREQUENCY (868200000ul))
                                    And yes, I have a github account and will make an issue report today.
                                    • tbowmoT tbowmo
                                      @alexsh1
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #250
                                      @tbowmo I think I am on the right track here. This is the log:
                                      0;255;3;0;9;TSF:LRT:OK
                                      IP: 0.0.0.0
                                      The GW Init is correct one, but IP is 0.0.0.0
                                      This is the sketch:
                                      #define MY_RF24_CHANNEL    76
                                      //#define MY_W5100_SPI_EN 4
                                      // radio on the same spi bus.
                                      #define MY_SOFTSPI
                                      #ifndef MY_RF24_CE_PIN
                                      #ifndef MY_RF24_CS_PIN
                                      // Enable to UDP
                                      //#define MY_USE_UDP
                                      #define MY_IP_ADDRESS 10,1,1,150   // If this is disabled, DHCP is used to retrieve address
                                      #define MY_PORT 5003
                                      // Enable inclusion mode
                                      // Set blinking period
                                      // Flash leds on rx/tx/err
                                      #if defined(MY_USE_UDP)
                                      #include <EthernetUdp.h>
                                      #include <Ethernet.h>
                                      I cannot connect to W5100. Tried a different shield with the same result.
                                      • tbowmoT tbowmo
                                        @alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @tbowmo BTW, I cannot ping it (I suppose there was another network device with the same IP on a network).
                                        If I try to switch to DHCP I get:
                                        DHCP FAILURE...0;255;3;0;9;!MCO:BGN:TSP FAIL
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #252
                                          @tbowmo I have received the second GW and I have exactly the same problem. As you suggested, I modified MyHwSAMD.cpp and can see now the start-up message, but there is a problem between the W5100 and GW:
                                          0;255;3;0;9;660 MCO:BGN:INIT GW,CP=RNNGS---,VER=2.2.0-beta
                                          0;255;3;0;9;707 TSF:LRT:OK
                                          0;255;3;0;9;717 TSM:INIT
                                          0;255;3;0;9;727 TSF:WUR:MS=0
                                          0;255;3;0;9;742 TSM:INIT:TSP OK
                                          0;255;3;0;9;752 TSM:INIT:GW MODE
                                          0;255;3;0;9;762 TSM:READY:ID=0,PAR=0,DIS=0
                                          0;255;3;0;9;772 MCO:REG:NOT NEEDED
                                          IP: 0.0.0.0
                                          0;255;3;0;9;2082 MCO:BGN:STP
                                          0;255;3;0;9;2092 MCO:BGN:INIT OK,TSP=1
                                          0;255;3;0;9;17920 TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:1956.28
                                          0;255;3;0;9;17931 TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:6080.20
                                          0;255;3;0;9;17942 TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:20.71
                                          0;255;3;0;9;17953 TSF:MSG:READ,11-11-0,s=1,c=1,t=37,pt=7,l=5,sg=0:13282.11
                                          I tried different MySensors (stable and dev) and checked solding.
                                          Now sure what to do now
                                          EDIT: This is my sketch:
                                           * Version 1.0 - Henrik EKblad
                                           * LED purposes:
                                          //#define MY_SIGNING_ATSHA204
                                          #define MY_SOFTSPI
                                          // Enable to UDP
