  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • alexsh1A alexsh1
    @tbowmo I do not have the oven to reflow the whole board, but can mount / unmount or re-work certain components 0805 or 0603. Below this it is a pain in the a***
    Another observation - The GW behaves like this with or without W5100 mounted.
    Seems like an SPI problem to me. How can I wire W5100 to MYSX please and what shall I can in the sketch please? Thank for your help - very much appreciate it
    AnticimexA
    AnticimexA
    Anticimex
    @alexsh1 The ATSHA is not connected to the SPI and is totally unrelated, so I am also inclined to suspect that perhaps one side of the SAMD is not entirely in contact with the pads. I had to hot-airgun mine to get USB working well but it was an early prototype like @tbowmo said.
    • alexsh1A
      alexsh1A
      alexsh1
      @tbowmo OK, I manage to find the answer here -
      MYSX
      D11 - MOSI
      D12 - MISO
      D13 - SCK
      D14 -CS
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN 13
      #define MY_SOFT_SPI_MISO_PIN 12
      #define MY_SOFT_SPI_MOSI_PIN 11
      MY_RF24_CS_PIN 14
      RF24_CE_PIN ???
      Am I correct?
      • alexsh1A
        alexsh1A
        alexsh1
        My current config for nrf24l01+ and w5100 is as follows:
        #define MY_GATEWAY_W5100
        #define MY_SOFTSPI
        #define MY_RF24_CE_PIN 5
        #define MY_RF24_CS_PIN 6
        Why CE / CS pins are 5 and 6?
        Should that be 27 and 3?
        • alexsh1A
          alexsh1A
          alexsh1
          #234
          @tbowmo I have just re-worked SAMD and all the connectors (nrf24l01+ and NET_SPI), but still have the same issue sadly.
          EDIT: If I change to rfm69, the same behavior is observed. It seems that Net_SPI is just not working.
          • tbowmoT
            tbowmoT
            tbowmo
            #235
            @alexsh1
            Configuration of the pins are handled by the hardware configuration file, https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h#L227
            If you look in the gatewayW5100 sketch, the settings for CE / CS pins are enclosed in ifdefs, so they are only used if they are not defined previously.
            If you want to connect the W5100 to the mysx connector, you can change line 174 in the hardware definition file, use SPI2 instead of SPI1 for SPI_ETH
            It could also be a defective W5100 shield? Can you verify that it works on other hardware?
            alexsh1A 1 Reply Last reply
            • tbowmoT tbowmo
              @alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              @tbowmo Swapping SPIs did not resolve the problem. I am now getting another W5100 to test further.
              • alexsh1A
                alexsh1A
                alexsh1
                Unfortunately, a new W5100 shield did not work - it seems like a production issue with this sensebender gatewsay as the SPI2 did not work either with W5100.
                Will get a new one ordered.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  Is it possible for you to check the spi wires with a scope? Just to make sure if mosi/miso/ce/Ss lines are toggling as expected?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    #239
                    Another thing, are you using static ip? If yes, can you ping it? If no, does your DHCP server hand out an ip address?
                    Have you tried the basic ethernet examples for the W5100?
                    • tbowmoT tbowmo
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @tbowmo I am using the static IP and I can ping it, but the "Gateway Ready" message never comes up. Also I can only see the neg24l01+ log (incoming messages only)
                      tbowmoT 1 Reply Last reply
                      • alexsh1A alexsh1
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @alexsh1
                        If you can ping it, then the W5100 is configured. Something else is wrong..
                        One thing that comes to mind, if you compile it as an ethernet GW, then it does not wait for serial console to be active, before initializing the radio. If you compile it as serial GW, then it waits with initialization, until serial is active.
                        This means that you probably is missing the GW ready message on the serial port, as it is "sent" before you have an active serial connection.
                        Look in MyHwSamd.cpp in the HwInit routine, remove the #ifdef around the while() loop, and try again.
                        • tbowmoT tbowmo
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          #242
                          @tbowmo Well, if I try the MEGA 2560 with W5100, I get the following:
                          0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.1.1
                          0;255;3;0;9;TSM:INIT
                          0;255;3;0;9;TSF:WUR:MS=0
                          0;255;3;0;9;TSM:INIT:TSP OK
                          0;255;3;0;9;TSM:INIT:GW MODE
                          IP: 10.1.1.120
                          0;255;3;0;9;MCO:BGN:STP
                          I never get this message with Sensebender GW. I only get
                          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:2019.12
                          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:6275.51
                          0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:18.77
                          or similar messages from nodes.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #243
                            @alexsh1
                            on atmega2560 you are resetting the device, when you connect a serial terminal to the usb device, so you get all the debug messages on the serial port..
                            On SAMD it uses a native USB port, and the chip is not reset when connecting a serial terminal. When using serialGw it will wait until a serial terminal is connected. before initializing radio transport (this is because it does not make sense to have a serial gateway that spits out data to a none existing port).
                            When using it as a ethernet gateway, we skip this, as we do not want to wait for a serial terminal, in case you are just using the USB as a power source. So in this mode, it skips the waiting, and just initializes radio gateway etc.
                            as stated in my previous message you could look at the MyHwSAMD.cpp file line 73. Remove the #ifdef recompile, upload, and check your serial terminal again.
                            Also the log shows that you actually are receiving data from your nodes, so the radio transport is clearly active.. And you can ping your gateways static IP, which means that the W5100 is initialized with the correct IP address.
                            • alexsh1A alexsh1
                              IP: 10.1.1.120
                              tbowmoT
                              tbowmoT
                              tbowmo
                              @alexsh1
                              Did you try my suggestion about hacking the core? Or did you give up on the beast? :)
                              I'm curious to hear if it is solved..
                              alexsh1A 2 Replies Last reply
                              • tbowmoT tbowmo
                                @alexsh1
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @tbowmo I will try it tomorrow. However, given the amount of time I spent already, I am about to give up...
                                  micropet
                                  Hello everybody.
                                  I got my Sensebender gateway yesterday. Have the W5100 Ethernet board mounted and loaded a sketch with the WizNET (W5100) Ethernet module and MQTT.
                                  The gateway immediately ran as desired.
                                  Unfortunately only for about 2 hours, then it freezes.
                                  After a restart it runs again 3 hours and freezes again.
                                  And so on.
                                  I wanted to replace an RPI Gatway, which has worked flawlessly for many weeks.
                                  If the Sensebender gateway works only a few hours it is quite useless.
                                  • M micropet
                                    Hello everybody.
                                    And so on.
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @micropet
                                    It must be a software issue. Are you using it with nrf24? Do you have a github account? If you have, would you mind filling an issue report on the mysensors library? As we need to dig further into this. Please also make a note of how many nodes you have running in your system.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @alexsh1
                                      I would really like to get it solved, so it can bring peace to my mind :) so please, if you can..
                                        micropet
                                        I also think that it is a software problem.
                                        I use only the RFM96HW.
                                        My "real" network has 20 nodes.
                                        The Sensebender gateway has only one DS18b20 node on a seperate frequency.
                                        (#define MY_RFM69_FREQUENCY (868200000ul))
                                        And yes, I have a github account and will make an issue report today.
                                        • tbowmoT tbowmo
                                          @alexsh1
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #250
                                          @tbowmo I think I am on the right track here. This is the log:
                                          0;255;3;0;9;TSF:LRT:OK
                                          IP: 0.0.0.0
                                          The GW Init is correct one, but IP is 0.0.0.0
                                          This is the sketch:
                                          #define MY_RF24_CHANNEL    76
                                          //#define MY_W5100_SPI_EN 4
                                          // radio on the same spi bus.
                                          #define MY_SOFTSPI
                                          #ifndef MY_RF24_CE_PIN
                                          #ifndef MY_RF24_CS_PIN
                                          // Enable to UDP
                                          //#define MY_USE_UDP
                                          #define MY_IP_ADDRESS 10,1,1,150   // If this is disabled, DHCP is used to retrieve address
                                          #define MY_PORT 5003
                                          // Enable inclusion mode
                                          // Set blinking period
                                          // Flash leds on rx/tx/err
                                          #if defined(MY_USE_UDP)
                                          #include <EthernetUdp.h>
                                          #include <Ethernet.h>
                                          I cannot connect to W5100. Tried a different shield with the same result.
