  3. [SOLVED] Yet another RFM69HCW / W5100 ethernet gateway thread :-)
22 Posts 6 Posters 7.8k Views 5 Watching
  • scalzS scalz
    @korttoma
    I remember i checked, in recent Mysensors lib, w5100+rfm69 on same hardware spi bus without any changes to the w5100 lib.. Isn't it working??
    tbowmoT
    tbowmoT
    tbowmo
    @scalz said in Yet another RFM69HCW / W5100 ethernet gateway thread :-):
    @korttoma
    Depends on your W5100 module :)
      tested it with this module https://www.itead.cc/w5100-ethernet-network-module.html and a 8Mhz/3.3v arduino mini if i remember (so no level shifting needed in my case)
      • korttomaK
        korttomaK
        korttoma
        My RFM69 EthGW is built on the 2.1.0 version of the MySensors library and back then the w5100 lib hack was required. I don't know what the case is with current available MySensors Lib versions. And I don't have additional hardware to test this on...
        • Tomas
          I am waiting for some new w5100 shields and rfm69hw that I'll test
          • stevebusS
            stevebusS
            stevebus
            Hi guys,
            Thanks for all the responses! I had not made any edits to the w5100.h file because a) I thought I had read they had become unnecessary, and b) I wasn't sure what exact values to use. Does the W5100 shield use pin 10 for CS? (pretty sure it uses 10 for the Ethernet module and 4 for the SD card, which I don't use, but hadn't had time to research for sure yet)... I'm using this shield, not a module, so I can't change the wiring. I've ordered the module-based W5100, but it'll be early June before I get it.
            With that said, I wonder it it's an issue between mysensors and specifically the Adafruit breakout of the RFM69HCW? Just to test a different way, I quickly last night built a raspberry pi Ethernet gateway (so the W5100 isn't' involved) and I had the same problem with the radio (failed to init). The radio initializes and works fine with the tests here, so I believe the radios are good. They just don't seem to respond to either an Arduino-based gateway or the raspberry pi one. I've ordered a couple of 'bare bones" RFM69HCW radios to test with.
            --Steve
            Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
            Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
            • stevebusS
              stevebusS
              stevebus
              Hey guys,
              quick update: got this working, at least on the gateway side -- haven't tried hooking up a node yet, that's next... Once I confirm that works, I'll add SOLVED to the title of this. :-)
              For the gateway, I went digging through the new driver code, looking for things to try and adding some debug writes, and found the code in RFM69_Initialise() where, if MY_RFM69_RST_PIN is defined, it will reset the radio. I already had the RST line on the RFM69HCW wired up, and had previously (with the old driver) manually added code to do it, but it didn't help...
              But with the new driver from the dev branch (used by #define MY_RFM69_NEW_DRIVER) I just added
              #define MY_RFM69_RST_PIN 6
              to my sketch and now I get...
              0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RPNGA---,VER=2.2.0-beta
              0;255;3;0;9;26 TSM:INIT
              0;255;3;0;9;28 TSF:WUR:MS=0
              0;255;3;0;9;36 TSM:INIT:TSP OK
              0;255;3;0;9;39 TSM:INIT:GW MODE
              0;255;3;0;9;43 TSM:READY:ID=0,PAR=0,DIS=0
              0;255;3;0;9;46 MCO:REG:NOT NEEDED
              IP: 192.168.0.215
              0;255;3;0;9;1350 MCO:BGN:STP
              0;255;3;0;9;1353 MCO:BGN:INIT OK,TSP=1
              I had read somewhere that the Adafruit breakout normally pulls RST high and supposedly resets itself at power-on, but I guess that wasn't enough... Explicitly resetting the radio seems to have done the trick and may be required for the Adafruit RFM69HCW breakout.
              Going to see if I can get the raspberry pi GW working now, since my curiosity is piqued :-)
              Thank you all for the help and input!
              --Steve
              • stevebusS
                stevebusS
                stevebus
                Hey guys,
                Another update... and an admission :-).
                After playing with it some more, it looks like I mis-read the details on how the Adafruit breakout treats the reset pin. I hard connected it to ground and it now works without setting the RST_PIN define. Apparently we just need to explicitly pull the RST pin low (which makes sense). Having the 'define' set was doing that in code earlier.
                You do have to have the new drivers, but don't have to fool with the reset pin. The GW works in both Arduino and raspberry pi now.
                thanks for thinking through this with me.
                • stevebusS
                  stevebusS
                  stevebus
                  Marking SOLVED - we are back in business. Thanks everyone!
                  • stevebusS
                    stevebusS
                    stevebus
                    Ok - apparently I don't know how to mark it as SOLVED :-)
                    • stevebusS stevebus
                      @stevebus click edit on your fist post in this topic. At the very top in the edit view you can update the topic subject.
                      • stevebusS
                        stevebusS
                        stevebus
                        done! Thanks @mfalkvidd
