  3. 💬 RFM69 Livolo 2 channels 1 way EU switch(VL-C700X-1_Ver_C2)
mysensorslivolo
47 Posts 9 Posters 18.5k Views 9 Watching
    shabba
    thanks @mtiutiu !!
    Quick one - Is there any difference in the bom?
    mtiutiuM 1 Reply Last reply
    • S shabba
      thanks @mtiutiu !!
      mtiutiuM
      mtiutiuM
      mtiutiu
      @shabba
      The bom is not fully updated yet. The main difference is the 2x7 connector with 2mm pitch.
      • tonnerre33T
        tonnerre33T
        tonnerre33
        Hi @mtiutiu, i need your help ;)
        The new board outline is perfect and the position of the connector too but my thickness board is too high (just an aesthetic point).
        So, the mecanic is good and when i power the pcb with 12v by a battery all is ok.
        But, there is a but :( when i power the node by the livolo, that's not working. The 12V goes to 3.15V.
        I tried to change the tantalum capacitor localised at the input of the MCP16301 by a ceramic capacitor but i have always the issue.
        Have you any idea ?
        Edit : one thing i didn't place it's the 470pF on the BYP MIC5205-3.3 because i haven't this value. I tried with 100pF and without capactitor but the issue still here
        Nca78N mtiutiuM 2 Replies Last reply
        • tonnerre33T tonnerre33
          Have you any idea ?
          Missing capacitor will not produce this effect, it will just not allow the low noise operation of the regulator. It might result in poor radio performance but nothing else.
          @tonnerre33 do you have a load on the main to allow enough current to pass through ? @mtiutiu uses a capacitor for that. If you don't the board can't draw enough power and that would be a good reason to have voltage droping.
            Have you any idea ?
            mtiutiuM
            mtiutiuM
            mtiutiu
            @tonnerre33 @Nca78 is right. First you need to have a capacitor in parallel with the light bulb (a 0.47uF/275Vac type X2 is enough). This is needed because the power supply from the original Livolo board doesn't provide enough current in standby mode and this is obviously a good reason because otherwise the light bulb will flicker or maybe light up a little bit and this is not wanted. Remember that we talk here about a series circuit and that we need to take power not in the standard way - usually a power supply is made for being wired with both live and neutral and not live wire only as in the current situation.
            If the capacitor across the light bulb still doesn't help then you need​ to follow the other steps I mentioned in the first project that I made for Livolo. One of the steps is to wire a bridge across that resistor marked with 104 - you can spot it easily as seen from those pictures that I made at that time. Then if it still doesn't work you need a second wire for the MOSFET biasing - this may be a little hard to see where it goes exactly as the Livolo manufacturer changed the board layout a little bit - not that much from the original one...but I need to figure out.
            • tonnerre33T
              tonnerre33T
              tonnerre33
              @mtiutiu I wired a bridge across the resistor marked 104 and my node was powered well.
              But after on or two command, the 12v doesn't work when the lamp is off. When the lamp is on (forcing command relay), the 12V appear and all run.
              Is the CMOS broken ? Which component produce this 12V when the lamp is off ?
              mtiutiuM TigroenotT 2 Replies Last reply
                mtiutiuM
                mtiutiuM
                mtiutiu
                @tonnerre33
                Maybe the mosfet bias hack needs to be done also. The truth is that power electronics is not my thing and this power supply is a little bit beyond my understanding...well not that much but some things are not clear for me either. Those hardware modifications were picked from other thread in this forum. Maybe @Nca78 knows better than me this part?
                @tonnerre33 did you wired the capacitor across the light bulb as well?
                Nca78N tonnerre33T 2 Replies Last reply
                • mtiutiuM mtiutiu
                  @tonnerre33
                  @mtiutiu said in 💬 Livolo 2 channels 1 way EU switch(VL-C700X-1_Ver_C2):
                  Haha, no way :D I did my board using NRF24 so I don't have to mess with the power/relay board ;)
                  • mtiutiuM mtiutiu
                    @tonnerre33
                    tonnerre33T
                    tonnerre33T
                    tonnerre33
                    Nope, the light bulb i use contains already a capacitor 1.1µF (thx Nca ;) ) and the bulb is lighted a little even if the button is off.
                    I duno why but the mofset is HS, i have checked him with my multimetor.
                    He can operate with 1.5A max, i don't understand why he burnt and why after a command... Before this command all was ok ... Why i pushed the button :laughing:
                    Which thread ?
                      Which thread ?
                      mtiutiuM
                      mtiutiuM
                      mtiutiu
                      @tonnerre33
                      Here: https://forum.mysensors.org/topic/2775/livolo-glass-panel-touch-light-wall-switch-arduino-433mhz/62. I think that @Tigroenot and @jirm know better than me actually. Sorry @Nca78 to involve you on this part. But @tonnerre33 if you wait until next week I'll inspect the new Livolo power board in a little bit more detail and see if I can come up with something.
                        TigroenotT
                        TigroenotT
                        Tigroenot
                        @tonnerre33 well, the reason for that is that livolo switch power circuit board contains two power circuits :)
                        One is a standby power which feeds the MC while all lamps are off and another one is the circuit that powers the whole system while at least one of the lamps is on (for two lamps switch).
                        • TigroenotT Tigroenot
                          tonnerre33T
                          tonnerre33T
                          tonnerre33
                          @Tigroenot Thank you for your comment.
                          I understand there is 2 power circuits, but i don't understand why the mosfet burnt, after wire a bridge across the 100K resistor and after few commands (not immediatly).
                          I did many simulations with LTspice and i didn't find the reason...
                          I think he has burnt when i have the lamp 1 on and i have pushed on the other button without lamp 2 connected on the livolo.
                          If someone have any idea, that's will be helpfull for not burn another mofset. ^^
                          Now i'am waiting the deliveri of the mofset and i am hoping that is the HS component ;)
                          • mtiutiuM
                            mtiutiuM
                            mtiutiu
                            Good news everyone! I managed to set up a test board in order to verify the new Livolo relays/power board and with the required modifications IT WORKS!!! as the previous one did from my old project. This time only 2 modifications are required on the board instead of 3 because the 12-14V supply is already connected now to the 2x7 connector.
                            I expected this to work as the power/relays board didn't changed - they placed the same set of components but in some different places and I was able to recognize the base layout.
                            @tonnerre33 Maybe yo wired something wrong..but for me it worked from the start. I will post here images and test results so stay tuned.
                            There you have it in action(sorry for my phone camera and delays): MySensors Livolo in action
                            Power/relays board required modifications(red lines represent wires - you could desolder those components too and just put some solder/wire bridges)
                            Next as seen in the video I wired a cheap dc-dc step down converter bought from Aliexpress to the 12-14V pin from the connector and ground and used its 3.3V output to power up the arduino pro mini board. The RELAY 1 - S and 1- R pins mean: channel 1(or 2 - it doesn't matter as the channels are identical) Set and Reset(because we have bi-stable relays). Those were wired to some digital outputs on arduino pro mini as seen here:
                            • mtiutiuM mtiutiu
                              tonnerre33T
                              tonnerre33T
                              tonnerre33
                              @mtiutiu Did you try with only a brige on the 100K resistor ?
                              Which type of lamp and power did you use ?
                                mtiutiuM
                                mtiutiuM
                                mtiutiu
                                #21
                                @tonnerre33
                                CFL - 15W. No, I wired both bridges.
                                Here's a quick block diagram for the whole circuit. I hope that I didn't missed anything or wired wrong there.
                                Well in reality the internal relay contact is not wired like in my diagram but to some extra circuits in order to provide voltage when the switch is closed - this is just a quick and dirty overview of the system.
                                The test circuit is working now for more than an hour with no problems. Oh..and the old project that I made for Livolo is in production now for more than a month and it works flawlessly.
                                I tested both CFL and LED bulbs - 5W was the lowest that I tried and it worked perfectly in both cases. The important part here is the parallel capacitor across the light bulb which gives the extra current that the standby circuit needs from the Livolo board in order to power the whole thing. The most sensitive part is the standby circuit because in that case the light bulb is OFF and it cannot provide enough current in this state - this is obvious because the load which is in series is turned off so only a small amount of current is present in the series circuit.
                                This works for the original board because the touch sensing part draws very little current(under a 1mA I think) and the radio receiver (in the RC variant) which they use draws 5mA or so. This compared with MySensors RFM69W which draws 60mA peak and on average 20-30mA or so.
                                • mtiutiuM mtiutiu
                                  @tonnerre33
                                  tonnerre33T
                                  tonnerre33T
                                  tonnerre33
                                  #22
                                  @mtiutiu Thx for the answers ;)
                                  I think you have a mistake on your picture. The GND pin is the second pin of the bottom when you start by the left side ;)
                                  Did you test both relays in Set position (simulate 2 lamps power on even if one isn't connected) ?
                                    mtiutiuM
                                    mtiutiuM
                                    mtiutiu
                                    #23
                                    @tonnerre33
                                    Yes it seems that the gnd pin is shifted by one position to the right. I will fix that - thanks for noticing. I will do the test with the other channel too. It's sufficient to have one light bulb and capacitor to trigger the other channel too.
                                    • mtiutiuM
                                      mtiutiuM
                                      mtiutiu
                                      Fixed the diagram posted earlier and now the required solder bridges are visible(R3 and R13 needs to be replaced by a solder/wire bridge as seen in the picture).
                                      This is valable only for the VL-C700X-1 VER: C2 livolo power/relays board hw revision only!
                                      • mtiutiuM mtiutiu
                                        @tonnerre33
                                        tonnerre33T
                                        tonnerre33T
                                        tonnerre33
                                        @mtiutiu Yes if you can just test the two channels on with only one bulb and capacitor this would be great
                                          mtiutiuM
                                          mtiutiuM
                                          mtiutiu
                                          #26
                                          @tonnerre33
                                          Ok so this board is basically the same board and it has the same set of components as the previous one(the old one from the old project that I've made) so it should work with both channels or in whatever combination you want. They only changed some components location - that's all. For now I don't know when I'll have time to test - I think only when my boards will arrive from the manufacturer.
